com.genesyscloud.platform.outbound throws a 422 every time we push the dial pattern validation payload through the Java client. It’s choking on the regexConstraints matrices and region code directives. We’ve wired the atomic POST to an EventBridge rule for latency tracking and audit logs, but the automatic error reporting trigger keeps firing instead of hitting our external validator webhook.
"patternString": "${contact.phoneNumber}",
"regexConstraints": ["^\\+?[1-9]\\d{1,14}$"],
"regionCodes": ["JP", "US"],
"validate": true
Engine drop nested matrices on atomic POST, so flatten the regexConstraints array first. It’s the strict check that trip the SDK and route to error webhook, just switch to relaxed mode with this config:
{"pattern": "+1-*", "validationMode": "relaxed", "regionOverrides": ["US-WEST", "JP-EAST"]}
Schema doc here: Genesys Cloud Developer Center
Flattening the array actually fixes the 422. The Java SDK chokes on nested objects in the regexConstraints field when you push atomic updates. The original payload was way too deep for the validator.
Here’s the working builder pattern. You’ll need to strip the matrix wrapper before sending to avoid the error loop.
DialPattern pattern = new DialPattern();
pattern.setPattern("+1-*");
pattern.setValidationMode("relaxed");
// Drop the nested matrix, use a flat list for overrides
pattern.setRegionOverrides(Arrays.asList("US-WEST", "JP-EAST"));
outboundApi.createDialPattern(pattern);
Steps to get this past the validator:
- Flatten constraints. Remove any nested JSON objects inside
regexConstraints. The API expects a simple string array, not a complex matrix.
- Set validation mode. Switch to
relaxed in the builder. Strict mode triggers the webhook error loop immediately.
- Verify region codes. The
regionOverrides list must match the exact codes from the org settings. Mismatches cause silent failures in the outbound campaign.
Ran this against the Toronto region endpoint and the latency dropped to 120ms. The screen pop overlay didn’t even flicker during the sync.
Stakeholders don’t care about the JSON structure, they just need the training environment live before the Q3 adoption metrics drop. Flattening the regexConstraints array and switching validationMode to relaxed finally cleared the 422. The atomic POST now routes through without triggering the EventBridge fallback. Agents can’t run the simulator if the outbound patterns keep rejecting.
A dry run through the admin UI this morning passed. The adoption metrics dashboard shows green across the board for the campaign setup. Training curriculum updates can move forward without the constant API timeouts derailing the stakeholder demo. Change resistance was already high, so getting this pipeline stable matters more than the technical fix itself.
The flattened structure passes cleanly now. No more 422 loops breaking the training environment. Rollout schedule is back on track. Just need to update the training docs. The webhook logs are finally clean.
PureCloudPlatformClientV2 actually enforces a strict schema validation pass on the outbound dial pattern configuration before the atomic POST reaches the validation endpoint. The runtime engine treats the nested regexConstraints matrix as an invalid structure when the payload depth exceeds two levels, which triggers the 422 response immediately. When you push the configuration through the deployment pipeline, the SDK library serializes the object graph and checks against the DialPattern definition. If the matrix wrapper remains intact, the serializer fails to map the region code directives to the flattened array structure required by the API. The error loop happens because the automatic retry logic attempts to resend the malformed payload without modifying the structure. The behavior is pretty frustrating.
You’ll need to strip the wrapper and ensure the validationMode isn’t set to strict in the Terraform configuration or the Java builder. The corrected payload structure should look like this:
"pattern": "+1-*",
"regionOverrides": ["US-WEST", "JP-EAST"],
"regexConstraints": ["^\\+1[0-9]{10}$"]
This usually resolves the issue in the state backup. The validation engine expects a flat list of regular expressions. If the list contains objects, the schema check fails and returns the 422 error. The atomic POST operation requires the payload to match the flattened structure exactly. You can see the difference in the serialization output when you compare the working payload against the failing one. The region code directives must also be placed in the regionOverrides array at the root level. This adjustment ensures the SDK library can map the fields correctly. The fallback stops firing after this change.
