Java SDK 409 Conflict when activating routing strategy with dynamic priority weights
We’re pushing updated routing strategies through the Java Platform SDK and hitting a wall on the activation step. The request to update the routing strategy completes without errors, but the activation endpoint returns a 409 Conflict. The response body points to a validation mismatch against the agent skill matrix. This happens even though the JSON payload matches the schema exactly.
Here is the payload structure we are sending:
 "name": "dynamic-priority-v2",
 "algorithm": "skills_and_longest_idle",
 "priority_weights": [
 {"skill_id": "abc-123", "weight": 0.8},
 {"skill_id": "def-456", "weight": 0.2}
 "queue_capacity_limits": {
 "max_concurrent": 50,
 "overflow_action": "queue"
The Java client code looks like this:
RoutingApi routingApi = new RoutingApi();
routingApi.createStrategy(payload);
String activationId = routingApi.activateStrategy(strategyId);
// Polling loop with jitter
while (!isActivated(activationId)) {
 long baseDelay = 2000L;
 long jitter = ThreadLocalRandom.current().nextLong(0, 500);
 Thread.sleep(baseDelay + jitter);
We’ve verified the skill IDs exist in the org. Queue capacity constraints are also within licensed limits. The 409 response doesn’t give a specific field error. Just a generic validation failure. Weird how the API swallows the actual constraint violation. We thought maybe the async activation process needs a hard delay before the skill matrix validation runs. Adding a fixed sleep didn’t fix it. The polling loop with jitter is standard practice anyway.
Environment details:
  • Java 17 with Genesys Cloud Platform SDK v2.28.0
  • OkHttp 4.11.0 for underlying transport
  • Target org region: us-east-1
  • Tested with both service account and OAuth2 client credentials grant
  • Payload validated against the OpenAPI spec locally
The whole setup is meant to optimize routing strategies dynamically. We’re feeding priority weights from an ML model trained on historical routing performance data. Interaction wait times and efficiency metrics are being tracked for performance tuning. The strategy simulator is completely blocked until we get past this activation error. Compliance reporting needs the audit logs generated by the API calls, and we can’t sync the settings with our external WFM system via event-driven integrations until the base config is live. Waiting on the activation token.
PureCloudPlatformClientV2 strictly validates the version field on routing strategy updates, and a missing version usually masks the skill matrix error as a 409 Conflict. You’re probably sending the payload without the current version number from the server, which makes the API reject the state transition before it even parses the skill references. The Java SDK might not be auto-fetching that version like the Node client does, so the server sees a stale update attempt. Also, the skill matrix mismatch happens when the skill objects in the priority array have truncated IDs or missing name fields, so the lookup against /api/v2/routing/skills fails internally. The weight field also needs to be an integer, not a float, or the schema validation throws the 409 back as a conflict. The skill object requires the version property too, otherwise the reference check fails. Sometimes the Java SDK serializes the priority array with zero-based indices that don’t align with the strategy’s expected order, causing the activation logic to reject the matrix. You’ll need to ensure the priority structure matches the strict schema exactly. Run a GET first to grab the version from the response body, then include it in the PUT. Check the platformClient logs to see if the request body is being altered before send. The routingApi method expects the full strategy object, not just the delta. If you’re patching, use the PATCH endpoint instead of PUT, but activation usually requires the full state.
const routingApi = new platformClient.RoutingApi();
const response = await routingApi.getRoutingStrategy(strategyId);
const payload = response.body;
// payload.version must be present and match the server to avoid 409
payload.priorities = [
 skill: { id: "valid-skill-id", name: "Support-L1", version: 1 },
 weight: 10
await routingApi.putRoutingStrategy(strategyId, payload);
The previous suggestion about the VERSION field is correct. My deployment scripts don’t pass the VERSION integer to the STRATEGY_ID update and we hit that same 409 error. The API won’t process the SKILL_MATRIX changes if the VERSION is missing from the request body. You’ll need to fetch the active configuration first and inject the VERSION into your payload.
This step pulls the current state so you can grab the VERSION value for the subsequent update step. It’s the standard way to handle the optimistic locking in the routing API.
The version integer enforces optimistic locking when updating the routing strategy. You’ll hit a hard 409 if concurrent updates overwrite the state.
