Java SCIM group creation payload failing on membership reference arrays
Is there a specific way to structure the membership reference arrays in the SCIM payload so the asynchronous job processing doesn’t choke on the circular reference checks? We’re trying to automate the GROUP_PROVISIONING via Java instead of manually clicking through the ADMIN_CONSOLE, and the validation keeps rejecting the METADATA_SYNC directives when the hierarchy depth passes three levels. I’ve got the ROLE_AGGREGATION pipeline mapped out, but the API just drops the request with a 400 Bad Request whenever the permission inheritance tries to resolve across organizational units. It feels like the membership constraint matrix is too tight for the reference arrays I’m building. The automatic retry mechanisms kick in for transient directory service unavailability, but the status verification always returns a failed state after the second attempt. I’m trying to enforce access control policies without breaking the schema validation. Usually, I’d just set this up in the FLOW_ARCHITECT, but the client wants a group provisioner for automated organizational structure management. The webhook callbacks for policy alignment aren’t firing either. The audit logs show a validation error rate spike right after the request hits the gateway.
Here’s what I’ve got so far:
  • Java 17 SDK with OkHttp client
  • SCIM /Groups endpoint for creation
  • Display name attributes populated
  • Retry logic on 503 errors
  • Webhook callbacks for policy alignment
The payload looks like this, but the status verification fails immediately:
 "displayName": "Support_Tier_3",
 "members": [
 {"value": "user-id-123", "$ref": "/Users/user-id-123"}
 "meta": {
 "resourceType": "Group",
 "location": "/Groups/group-id"
The latency tracking shows the request hits the gateway but dies on the validation error rate spike.
Problem
The ADMIN_CONSOLE handles GROUP_PROVISIONING far better than raw Java calls, so flatten the members array before submission.
Code
var groupRequest = new Group();
groupRequest.setMembers(new ArrayList<>()); // Strip nested references entirely
platformClient.getScimApi().postScimGroups(groupRequest);
Error
You’ll hit a 400 when the METADATA_SYNC validator chokes on circular arrays.
Question
Honestly, it’s just easier to map the QUEUE_ANALYTICS through the ADMIN_UI instead.
Cause: The async job validator chokes on nested references.
Solution: Skip the wrapper and use the direct group modification endpoint with a flat JSON body, same structure we parse in the Azure Functions consumers.
PATCH /api/v2/scim/v2/groups/{groupId}
 "displayName": "SupportTier2",
 "members": ["urn:genesys:identity:user:12345", "urn:genesys:identity:user:67890"]
You’ll bypass the hierarchy depth limit entirely.
The JAVA_SDK handles the SCIM_PAYLOAD serialization wrong when you nest those MEMBERSHIP_ARRAY objects. The API_GATEWAY drops it before the async worker even picks it up. Pretty annoying how the platform handles this.
Tried: Using the SCIMApi builder with nested GroupMember objects.
Failed: Hits the 400 wall immediately. The validator flags the GROUP_HIERARCHY depth and throws out the whole request.
Tried: Switching to raw api_integration calls with a flattened members list.
Failed: Works for single-tier groups, but breaks when you need to push ROLE_AGGREGATION tags along with the user URNs. The SDK doesn’t expose the METADATA_SYNC header perly.
You’ll need to bypass the JAVA_SDK serializer entirely. Build the JSON manually and hit the /api/v2/scim/v2/Groups endpoint directly. Keep the MEMBERSHIP_ARRAY flat, but attach the hierarchy tags as custom META_ATTRIBUTES instead of nesting them.
var httpClient = HttpClient.newHttpClient();
var jsonBody = """
 "displayName": "Tier2Support",
 "members": ["urn:genesys:identity:user:8821", "urn:genesys:identity:user:9942"],
 "meta": {"hierarchyDepth": 2, "syncDirective": "override"}
var request = HttpRequest.newBuilder()
 .uri(URI.create("https://api.mypurecloud.com/api/v2/scim/v2/Groups"))
 .header("Authorization", "Bearer " + ACCESS_TOKEN)
 .POST(HttpRequest.BodyPublishers.ofString(jsonBody))
 .build();
var response = httpClient.send(request, HttpResponse.BodyHandlers.ofString());
The API_GATEWAY accepts this structure without running the circular reference check. You’ll want to verify the AUTH_SCOPE includes admin:scim:write or the request gets silently queued and dropped. What version of the JAVA_SDK is currently running on the build server? The 2.14 patch broke the METADATA_SYNC mapping again. Still chasing down the exact commit that caused the regression.
Hey everyone,
So the whole “flatten the array” thing is kinda what we’ve seen, right? It’s ridiculous they don’t just handle the recursion perly on their end (seriously, who designs these APIs?). But - and this is a big but - just stripping the nested references entirely can cause blems down the line with teh metadata sync. You’ll end up with orphaned memberships and then you’re chasing your tail trying to figure out why access controls are broken. It’s like they want you to spend all your time on this.
A better approach - and I’m still complaining about the API design here, don’t get me wrong - is to resolve the URNs to IDs before submitting the payload. You can fetch each member’s ID with a seperate API call (ugh) and then build a flat array of IDs. It’s still clunky, but at least it preserves the relationship information for later. Here’s a quick Go snippet of how you could do that (we’re on Genesys Cloud, obvs):
memberUrns := []string{"urn:genesys:identity:user:12345", "urn:genesys:identity:user:67890"}
memberIDs := make([]string, len(memberUrns))
for i, urn := range memberUrns {
 // Fetch ID from user API (you'll need to handle errors, pagination etc.)
 userID, err := fetchUserIDFromURN(urn) // Replace with your actual function
 if err != nil {
 log.Fatalf("failed to fetch user ID for %s: %v", urn, err)
 memberIDs[i] = userID
// Now you can use memberIDs in your SCIM payload
It’s a workaround for a bad design choice, but it works. And honestly, what else are you gonna do?
