Running a Java service that wraps the GC Media API for voice recording. The gateway’s batching these requests through DataLoader. The recording initiation keeps failing. Hitting a 400 Bad Request when attempting to initiate a recording. The payload shape looks valid against the OpenAPI spec. The media engine rejects it during the atomic POST.
Here’s the request body we’re sending:
"conversationId": "a1b2c3d4-e5f6-7890-abcd-ef1234567890",
"mediaType": "voice",
"maxDurationSeconds": 14400,
"codecMatrix": ["PCMU", "PCMA", "G729"],
"storagePathDirective": "s3://prod-archive/voice/2024/10",
"autoCaptureStream": true
The validation pipeline runs carrier capability checking and storage quota verification pipelines before firing. Quota’s fine. Carrier supports the codecs. Still getting the 400. The error response just says Invalid recording configuration. Media scaling trips this up when the gateway batches multiple concurrent calls.
Tried a few things already:
- Dropped the maxDurationSeconds to 3600. Same error.
- Swapped the codec array to a single string
PCMU. Gateway still rejects it. - Removed the storagePathDirective entirely. Recording starts, but dumps to the default bucket. We don’t want that.
Need the recorder to sync with an external archiving gateway via webhook callbacks. Tracking record latency and audio integrity scores is also part of the flow. Audit logs have to capture every initiation attempt for governance. Exposing a call recorder for automated Media management is the end goal. It’s blowing up on the format verification.
DataLoader batches these fine for analytics endpoints. Schema stitching handles the resolver caching. The media engine validation is just strict. Anyone else hit this codec matrix constraint when wrapping the Java client? What’s the exact payload shape that passes the atomic format verification? Left the debug logs running. The automatic stream capture triggers aren’t even firing.
