The Reporting API keeps dropping my Java calls at the five-minute mark. I’m wiring up a metric extractor for historical performance data, but the query execution latency spikes when I add dimension filters.
Specs:
- Java 17 with OkHttp
- CXone
/api/v2/reporting/reports
- Cursor pagination
Steps I tried:
- Shrunk date range to 24 hours.
- Swapped to a streaming parser for the large dataset extraction.
It still bombs with a 504 Gateway Timeout. The timezone conversion pipeline works fine locally. The data warehouse partitioning rules just reject the aggregation functions. Here’s the payload:
{"reportDefinition":{"metric":"agent.handleTime","aggregation":"AVG","dimensions":["agent.id"]}}
I don’t see the bulk export APIs fire. Memory stays flat.
Are you forcing aggregate_by_agent on a dataset that massive? Saw the same timeout in that eastern window sync thread when the pacing slider bricks. Drop the include_totals flag and cap max_records at 200.
java.net.SocketTimeoutException: Read timed out.
The suggestion above regarding max_records is the main fix. Pretty sure the reporting engine chokes on wide aggregates and kills the stream before the cursor initializes. You’ll definitely hit that 5-minute wall if the payload stays heavy.
There’s a client-side config trap too. OkHttp defaults to a 10-second read timeout, which is way too short for historical metric extraction. It’s also worth checking if the OAuth token expires while the request is pending. The SDK might retry silently and just extend the hang time.
Bump the timeout window.
OkHttpClient httpClient = new OkHttpClient.Builder()
.readTimeout(15, TimeUnit.MINUTES)
.connectTimeout(10, TimeUnit.SECONDS)
.build();
PureCloudPlatformClientV2 platformClient = PlatformClient.create("myApp", "1.0", "myClientId", "myClientSecret", httpClient);
Make sure reporting:read is in the scope list. Missing scope returns a 403 that some wrappers mask as a timeout.
