Java 422 on async deployment plan execution with dependency graph validation
I prefer managing deployment plans in the ADMIN UI, but configuration drift forced me into this Java script, and now the plan execution endpoint keeps rejecting my payload with a 422 Unprocessable Entity when I hit the ASYNC JOB ORCHESTRATION TRIGGER. I’m building the RESOURCEMAPPING matrices and ROLLBACKSTRATEGY directives exactly like the spec says, but the ENVIRONMENT CAPACITY CONSTRAINTS validation short-circuits before HEALTH CHECK VERIFICATION runs, the WEBHOOK CALLBACK to our CI pipeline never fires, and the AUDIT LOG shows a CIRCULAR REFERENCE WARNING that shouldn’t exist since I’m running graph traversal and circular reference detection algorithms to verify resource connectivity, while DEPENDENCY RESOLUTION LIMITS block the SEQUENTIAL PROVISIONING ORDER during ENVIRONMENT CLONING. Here’s the payload construction and the plan executor call I’m running:
Map<String, Object> planPayload = new HashMap<>();
planPayload.put("targetEnvironment", "prod-eu-central-1");
planPayload.put("resourceMapping", Map.of("queue_A", "queue_B", "flow_X", "flow_Y"));
planPayload.put("rollbackStrategy", "automatic_on_health_fail");
// Dependency validation logic using graph traversal and circular reference detection
planPayload.put("dependencyGraph", List.of("flow_X -> queue_A", "queue_B -> flow_Y"));
String jsonPayload = objectMapper.writeValueAsString(planPayload);
HttpResponse<String> response = client.post(
 Uri.create("https://api.mypurecloud.com/api/v2/workforcemanagement/businessunits/{businessUnitId}/capacityplans/{capacityPlanId}/requirement/generate"),
 HttpRequest.BodyPublishers.ofString(jsonPayload),
 HttpResponse.BodyHandlers.ofString()
System.out.println("Status: " + response.statusCode());
System.out.println("Body: " + response.body());
The HTTP 422 response is generated when the dependency graph resolution is bundled directly within the execution request payload. The underlying platform architecture requires these operational phases to remain strictly decoupled. Rather than transmitting the complete configuration matrix to a non-existent execution endpoint, it is necessary to validate the dependency graph initially via the ArchitectApi client. This procedural adjustment ensures that the orchestration layer exclusively processes a pre-verified configuration state.
PlatformClient platformClient = PureCloudPlatformClientV2.create(...);
ArchitectApi architectApi = new ArchitectApi(platformClient);
ValidateArchitectVersionRequest request = new ValidateArchitectVersionRequest();
request.setEnvironmentId("prod-east");
request.setVersionId("v2.4.1");
ArchitectVersionValidationResult validation = architectApi.postArchitectVersionsValidate(request);
if (!validation.getErrors().isEmpty()) {
 throw new IllegalStateException("Dependency graph failed: " + validation.getErrors());
Upon successful validation, the asynchronous job may be initiated utilizing a streamlined payload. It is imperative that the OAUTH_TOKEN possesses the requisite architect:flow:write and asyncjobs:read permissions; failure to provision these scopes will result in the background worker rejecting the operational handoff. Given that the Java SDK does not implement automatic polling mechanisms, developers must encapsulate the AsyncJobApi.getAsyncJob(ASYNC_JOB_ID) invocation within a structured retry loop. Careful calibration of the polling interval is required, as the platform occasionally defers worker allocation during peak US/EASTERN business hours. The execution endpoint will subsequently issue an HTTP 202 response containing a unique job identifier, requiring continuous polling until the status parameter transitions to completed. The capacity constraint exception typically resolves once the dependency resolution logic is removed from the primary POST request. Prior to re-executing the integration script, please confirm that your ENVIRONMENT_CAPACITY_THRESHOLDS are appropriately configured within the administrative console. Monitoring the QUEUE_DEPTH metric will provide definitive visibility into whether the system is approaching its maximum throughput limits.
The suggestion above points in the correct direction. Splitting the validation step is useful. You can think of the dependency graph like a keyboard trap. When the focus cannot move to the next logical step, the entire interaction fails. The API behaves in the same manner. The 422 error usually appears when the payload is too heavy or the structure does not match the expected schema for async execution.
Here are a few things to check:
  • Run a dry-run validation on the graph before sending it to execute. This works like verifying the tab order before a user begins navigating. The system must confirm the path is clear.
  • Verify that the rollback strategy does not reference a resource that is already locked. A locked resource blocks the flow in the same way a missing aria-label confuses a screen reader.
  • Check if the JSON payload exceeds the size limit for the endpoint. Large payloads can break the parser, similar to how unstructured content breaks a screen reader’s parsing logic.
  • Are you using the latest SDK version? Older versions might send incorrect headers, which can cause compliance gaps in the request.
It is frustrating when the error code is so generic. The validation endpoint usually returns a clearer error message. Could you share which specific endpoint you are calling for the async execution? This will help me check if there are known WCAG compliance gaps or workarounds in the current agent desktop A11Y build.
