IWS-Development-related Question
Dear all,
The requirement from our customer is as follows:
When the agent is to place a call manually GAS screen and its side button are displayed on InteractionWorksheetRegion and CaseViewSideButtonRegion, respectively.
And when the agent is to handle a preview call GAS screen and its side button MUST be removed/invisible.
To do this, I use the following code:
                ViewActivator view_ = null;
                bool GASFound = false;
                foreach (ViewActivator view in Globals.MyViewManager.ViewsByRegionName["CaseViewSideButtonRegion"])
                    if (view.ViewName.Contains("GAS"))
                        view.ActivateView = false;
                        view.ViewType = null;
                        view_ = view;
                        GASFound = true;
                        break;
		 Globals.MyViewManager.ViewsByRegionName["CaseViewSideButtonRegion"].Remove(Globals.GASView);
Which successfully removes the GAS. However, I couldn’t add it back to the Interaction Window. Could you please tell us how to add and remove GAS screen and its side button efficiently?
Thank you in advance.
Have you tried to add a custom command before or after any action??
https://docs.genesys.com/Documentation/IW/8.5.1/Developer/UseCustomizableCommands
If not, maybe overwriting the entire view and add your own then add a condition or something like that?
