IWS - Create a simple module - Error to load application
Hi everyone,
I’m new in Genesys development, and I trying to create a simple module (just a new tab).
When I use the examples made by Genesys, they work right.
But, if I try to open Visual Studio (2013) and create a new “WPF User Control Library” (or any kind of projects), and just copy and paste the example to my project, it doesn’t work.
I try to use the “Genesyslab.Desktop.Modules.ExtensionSample” example
After to configure all the project, when a click to “start” on Visual Studio the IWS throw an exception.
“System.TypeInitializationException was unhandled
Message: An unhandled exception of type ‘System.TypeInitializationException’ occurred in Unknown Module.
Additional information: O inicializador de tipo de ‘Genesyslab.Desktop.App’ acionou uma exceção.”
in theory the problem is because the “.module-config” is wrong, but as I said, I copied and pasted like the example.
Are there some pattern default to create a new module ?
[ol]- In case, when using the examples, just overwrite the example and use it as-is
  • In case, when using the new project/solution, just do not copy and paste the code (there are other namespaces, assemblies, etc.)[/ol]
I am using the WPF application with little change with output type, which should be confgiured with “Class Library”.
Thanks alot for your answer, and I’ll follow it.
What I copied, were some general things, like module-config and some features of classes.
;D This is my developer…help us :smiley:
We are stuck at this…
Can’t see an error on what he is doing
Maybe you want to take a look on my notes I created when was learning WDE customisation: http://files.fm/u/vyldzdd
Janis
:o :o :o :o
Just amazing! You rock! Can we grab this with your permission as a base and make a video showing it? We will share later after samples are run.
Thanks again!
Yes, sure. Nice to know that my doc helps to somebody.
Thanks a loooot man.
It’s a great file.
I’ve just opened my doc and seems I did not finish last chapter about web browser. I copied some parts from first example but did not replace with valid content. Sorry, it is not done for purpose. I just had not time enough.
Janis
I want to thank you again.
I test here, and works.
About WebBrowser, I created a new view. And it’s not hard to create and manipulate web browser.
I recommend use Awesomium (http://www.awesomium.com/), it’s more powerful, and it uses webkit as the engine
