Hi guys,
I was trying to implement IVR integration with genesys. I’m a little confused about the two components: I-server and tserver_ivr,
the confusion is :
Which one is a real application or just configuration?
Because, on the one hand, when I run setup.exe in installation package, it seems the application is tserver_ivr, but the document says what I install from install package is iserver.on the other hand, document says the port number for I-server should be set as “0” or “.”
Also, in genesys demo with gvp integration, iserver is just a blank application, nothing in start info tab.
Thanks in advance.
