I’m developing a brand-new IVR application with Genesys Studio. For that, I’m using Java (JSP).
My client has a legacy application written in ASP but, for cost reduction, they decided to turn it off, lefting only the new JSP application active.
Now, as I thought, they regretted doing that, so now they want me to include in the IVR the old funcionalities that were present in the old ASP application.
My question is: Can I use a JUMP block (or something like that) to direct a call from my JSP IVR to the old ASP IVR?
Remember, GVP consumes XML, no matter if build with PHP, ASP, JSP, CFUSION, whatever you want…whatever it does on ASP can be done on JSP and any other language.
It is like if you ask that if you can call a WS made on ASP from a JSP page, the answer is…yes, yes you can do it.
Well… I tried to use a jump block on my JSP application and then, in my ASP application, tried to get the query string parameters at the start block. I didn’t succeed.
Why can’t I get the values from the query string passed on the jump URL?
I’m basically using the following code at the Main_Start block: Session("Number) = Request.QueryString(“num”)
Session(“Service”) = Request.QueryString(“service”)
When I try to use the session values after in the code, they are empty
