Issue creating virtual queue using SDK
I am trying to create virtual queue using Genesys SDK.
The code I’m trying something like below; I don’t have the exact code.
(Please ignore syntax errors as this is written in notepad)
public void createVQ(string number)
//server parameters
confService.open();
CfgSwitchQuery cfgSwitch = new CfgSwitchQuery();
cfgSwitch.Name=“my_vq_switch”;
CfgSwitch switchName = confService.RetrieveObject(cfgSwitch);
                CfgDN vq=new CfgDN(Number=number, Switch=switchName);
				vq.Type=CfgDNType.CFGVirtACDQueue;
                vq.Save();
I am getting parameter missing error from line vq.Save();
Could anyone tell me what are the issue with the above code and what all are the mandatory parameters I need to pass while creating create a virtual queue.
Sudipta
What is the new Vq name?
The vq name I am passing as ‘number’ variable.
I want to create a new vq with name say ‘test_vq_dev’;
Thanks for your reply,
Try to do a try{catch()}
You will see which mandatory parameters you are missing.
I think VQ must have an Alias (the property name in SDK is Name if I remember thar well)
Let him learn it by himself so next time he has the idea on how to fix it on his own :wink:
When I tested your code I got the error message “Mandatory property ‘routeType’ not set.”.
I tested with this code and it worked for me:
                CfgDN vq = new CfgDN(confService);
                vq.Number = "MyQueue";
                vq.Switch = switchName;
                vq.Type = CfgDNType.CFGVirtACDQueue;
                vq.RouteType = CfgRouteType.CFGDefault;
                vq.Save();
