Is it possible to configure Genesys Cloud BYOC edge nodes to handle higher concurrent WebSocket connections without hitting 429 errors? Running JMeter scripts with 300 concurrent sessions against the media API triggers immediate throttling. The standard rate limits seem too aggressive for our stress testing phase. Current setup uses the default edge configuration.
make sure you adjust the jmeter thread group settings before worrying about the edge config. the 429 errors are often caused by the http client in jmeter sending too many connection requests in a short burst, which triggers the rate limiter on the gateway. it is not always about the websocket limit itself. try reducing the ramp-up time to spread the load. if you have 300 threads, set the ramp-up to at least 60 seconds. this prevents the “thread storm” effect where all threads try to connect at the exact same millisecond.
also, check your websocket keep-alive interval. if it is too low, the client sends pings too frequently, which counts against the rate limit. increase wsKeepAliveInterval to 30000ms in the sdk config. this reduces the overhead on the connection.
in jmeter, add a constant timer to simulate realistic user think time. even a 500ms delay between requests can help smooth out the spike. here is a sample jmeter config snippet:
the documentation suggests that the default edge configuration handles up to 1000 concurrent connections, but the rate limit for new connections is lower. by spreading the connections over time, you stay within the rate limit. if you still see 429s, check the maxConcurrentConnections setting in your byoc edge config. it might be set to a lower value for testing environments. increasing it to 2000 might help, but only if the jmeter side is optimized first. focus on the client-side pacing first.
Take a look at at the X-Genesys-Request-Id header for correlation, as BYOC edges enforce per-tenant burst limits that JMeter’s default HTTP sampler doesn’t respect. Adjusting the ramp-up helps, but you still need to implement client-side throttling.
The problem here is treating the WebSocket handshake like a standard HTTP request during load generation. While the thread ramp-up suggestion above is solid for general traffic, BYOC edges specifically monitor the initial connection burst against the tenant’s configured concurrency limits. If your JMeter script fires 300 connections instantly, the edge drops them before the WFM schedule sync or adherence data can even be validated against the active agent state.
To stabilize these tests without hitting the 429 wall, try these adjustments:
Implement Exponential Backoff: Instead of a linear ramp-up, use a custom JMeter BeanShell or JSR223 processor to add a random delay between connection attempts. This mimics real-world agent login patterns where users don’t all click “Start” at the exact same millisecond.
Check Schedule Adherence Limits: Ensure your test agents are marked as “Available” in the WFM system. If the schedule shows them as “Offline” or “In Training,” the edge might reject the WebSocket upgrade faster than usual. Align your JMeter test windows with published shifts.
Use Connection Pooling: Configure the JMeter HTTP Request Defaults to reuse connections where possible. Setting httpclient4.retry_count to 0 prevents JMeter from aggressively retrying failed handshakes, which only worsens the rate limiting.
Monitor via WFM API: Pull the real-time adherence data during the test using the WFM API. If the error rate spikes when adherence drops below 80%, it confirms the edge is correlating connection attempts with valid schedule entries.
We see this often during weekly schedule publishing when agents try to log in simultaneously. Spreading the load isn’t just about network capacity; it’s about respecting the WFM state machine’s processing limits.
Have you tried configuring the WebSocket upgrade handler in JMeter to respect the tenant’s burst limits instead of hammering the gateway? The 429s are usually caused by instant connection spikes rather than actual capacity issues.
Warning: Do not disable rate limiting in your test environment; it masks real-world performance bottlenecks.
