From time to time in EventRouteUsed we have G3Cause 612. These calls are routed default. Is these only wait time setting in PBX or there is something else that should be checked in CTI.
The force will be with you…always
According to my knowledge G3Cause =612 is related only to Timer in the switch.
regards
jbobinsk
10x jbobinsk. It is as I feared. :-\ I will appreciate any other ideas…if there is. ???
In URS you can configure where do you want to go a call when it is default routed.
It`s done ![]()
