Invoking NICE CXone Outbound Campaign APIs for Dial Initiation with Java
A Java service that validates agent capacity constraints, constructs outbound dial payloads with contact list matrices and priority directives, initiates campaigns via atomic POST operations, synchronizes dial events through webhooks, tracks connection metrics, and generates compliance audit logs. This implementation uses the NICE CXone REST API v2 with OkHttp for precise request control and Jackson for JSON serialization. The tutorial covers Java 17 with production-ready error handling and retry logic.
- OAuth 2.0 Client Credentials flow with scopes:
campaigns:read,campaigns:write,contacts:read,webhooks:write,analytics:read,routing:read,auditlogs:read - CXone API Base URL:
https://<region>.api.cxone.com - Java 17 or later
- Maven dependencies:
com.squareup.okhttp3:okhttp:4.12.0,com.fasterxml.jackson.core:jackson-databind:2.17.0,org.slf4j:slf4j-api:2.0.9 - A preexisting CXone campaign ID and contact list ID in your tenant
CXone uses standard OAuth 2.0 client credentials. The following manager handles token acquisition, caching, and automatic refresh on 401 responses.
import okhttp3.*;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
import java.io.IOException;
import java.time.Instant;
public class CxoneAuthManager {
private static final Logger log = LoggerFactory.getLogger(CxoneAuthManager.class);
private final String baseUrl;
private final String clientId;
private final String clientSecret;
private final OkHttpClient httpClient;
private final ConcurrentHashMap<String, TokenCache> tokenCache = new ConcurrentHashMap<>();
public CxoneAuthManager(String baseUrl, String clientId, String clientSecret) {
this.baseUrl = baseUrl.endsWith("/") ? baseUrl.substring(0, baseUrl.length() - 1) : baseUrl;
this.clientId = clientId;
this.httpClient = new OkHttpClient.Builder()
.connectTimeout(10, TimeUnit.SECONDS)
.readTimeout(10, TimeUnit.SECONDS)
.build();
public String getAccessToken() throws IOException {
String cacheKey = clientId + ":" + clientSecret;
TokenCache cache = tokenCache.get(cacheKey);
if (cache != null && cache.expiresAt > Instant.now().getEpochSecond() + 60) {
return cache.token;
RequestBody form = new FormBody.Builder()
.add("grant_type", "client_credentials")
.add("client_id", clientId)
.add("client_secret", clientSecret)
.build();
Request request = new Request.Builder()
.url(baseUrl + "/oauth/token")
.post(form)
.build();
try (Response response = httpClient.newCall(request).execute()) {
if (!response.isSuccessful()) {
throw new IOException("OAuth token request failed: " + response.code() + " " + response.body().string());
String json = response.body().string();
TokenCache newCache = parseTokenResponse(json);
tokenCache.put(cacheKey, newCache);
return newCache.token;
private TokenCache parseTokenResponse(String json) {
// Simplified parsing for tutorial clarity
String token = json.split("\"access_token\":\"")[1].split("\"")[0];
long expiresIn = Long.parseLong(json.split("\"expires_in\":")[1].split(",")[0]);
return new TokenCache(token, Instant.now().getEpochSecond() + expiresIn);
public String getBaseUrl() {
return baseUrl;
private static class TokenCache {
final String token;
final long expiresAt;
TokenCache(String token, long expiresAt) {
this.token = token;
this.expiresAt = expiresAt;
Step 1: Validate Agent Capacity and Concurrent Dial Limits
Before initiating a dial, the system must verify that the requested maxConcurrentCalls does not exceed available agent capacity. CXone routes calls based on skill matching and agent availability. The following method queries available agents, calculates capacity, and validates dial ratios.
OAuth Scope: routing:read
import okhttp3.*;
import java.util.List;
import java.util.stream.Collectors;
public class CxoneCapacityValidator {
private final ObjectMapper mapper = new ObjectMapper();
private final String accessToken;
public CxoneCapacityValidator(String baseUrl, String accessToken, OkHttpClient httpClient) {
this.baseUrl = baseUrl;
this.accessToken = accessToken;
this.httpClient = httpClient;
public void validateCapacity(int maxConcurrentCalls, double dialRatio, String skillGroupId) throws IOException {
.url(baseUrl + "/api/v2/routing/users?status=available&skillGroupId=" + skillGroupId)
.get()
.header("Authorization", "Bearer " + accessToken)
.header("Accept", "application/json")
.build();
if (response.code() == 429) {
throw new IOException("Rate limit exceeded (429). Implement exponential backoff.");
throw new IOException("Agent capacity query failed: " + response.code() + " " + response.body().string());
JsonNode root = mapper.readTree(response.body().string());
List<JsonNode> users = root.path("users").isArray() ? root.path("users") : List.of();
long availableAgents = users.stream().filter(u -> u.path("status").asText().equals("available")).count();
int maxAllowed = (int) Math.floor(availableAgents * dialRatio);
if (maxConcurrentCalls > maxAllowed) {
throw new IllegalArgumentException("Dial limit violation: requested " + maxConcurrentCalls +
" concurrent calls, but capacity supports " + maxAllowed + " based on dial ratio " + dialRatio);
Step 2: Construct Dial Payload and Execute Atomic Campaign Start
CXone campaigns are configured via PUT /api/v2/campaigns/{id} and initiated atomically via POST /api/v2/campaigns/{id}/start. The payload must reference the contact list matrix, set priority directives, and define dial settings. The following method constructs the configuration, validates the schema, and executes the atomic start operation.
OAuth Scopes: campaigns:write, contacts:read
import okhttp3.*;
import java.util.Map;
public class CxoneDialInitiator {
public CxoneDialInitiator(String baseUrl, String accessToken, OkHttpClient httpClient) {
public String initiateCampaign(String campaignId, String contactListId, int priority,
int maxConcurrentCalls, double dialRatio) throws IOException {
// Step 2a: Update campaign configuration
String configJson = mapper.writeValueAsString(Map.of(
"contactListIds", List.of(contactListId),
"priority", priority,
"dial", Map.of(
"maxConcurrentCalls", maxConcurrentCalls,
"dialRatio", dialRatio,
"dialType", "progressive"
"status", "configured"
RequestBody configBody = RequestBody.create(configJson, MediaType.parse("application/json"));
Request configRequest = new Request.Builder()
.url(baseUrl + "/api/v2/campaigns/" + campaignId)
.put(configBody)
.build();
try (Response configResponse = httpClient.newCall(configRequest).execute()) {
if (configResponse.code() == 429) {
throw new IOException("Rate limit exceeded during configuration update.");
if (!configResponse.isSuccessful()) {
throw new IOException("Campaign configuration failed: " + configResponse.code() + " " + configResponse.body().string());
// Step 2b: Atomic campaign start
Request startRequest = new Request.Builder()
.url(baseUrl + "/api/v2/campaigns/" + campaignId + "/start")
.post(RequestBody.create("", MediaType.parse("application/json")))
.build();
long startTime = System.currentTimeMillis();
try (Response startResponse = httpClient.newCall(startRequest).execute()) {
long latency = System.currentTimeMillis() - startTime;
if (startResponse.code() == 409) {
throw new IOException("Campaign state conflict: campaign is already running or paused.");
if (!startResponse.isSuccessful()) {
throw new IOException("Campaign initiation failed: " + startResponse.code() + " " + startResponse.body().string());
return "Campaign started successfully. Latency: " + latency + "ms";
Step 3: Register Webhook Callbacks for CRM Synchronization
Dial events must synchronize with external CRM platforms. The following method registers a webhook targeting campaign start and call connection events. CXone validates the endpoint via an HTTP challenge before routing events.
OAuth Scope: webhooks:write
import okhttp3.*;
public class CxoneWebhookManager {
public CxoneWebhookManager(String baseUrl, String accessToken, OkHttpClient httpClient) {
public String registerCampaignWebhook(String webhookUrl, String campaignId) throws IOException {
String payload = mapper.writeValueAsString(Map.of(
"name", "CRM_Dial_Sync_" + campaignId,
"url", webhookUrl,
"eventTypes", List.of("CampaignStarted", "CallConnected", "CallAbandoned"),
"scope", "campaigns",
"scopeIds", List.of(campaignId),
"enabled", true,
"secret", "your-webhook-signing-secret"
RequestBody body = RequestBody.create(payload, MediaType.parse("application/json"));
.url(baseUrl + "/api/v2/webhooks")
.post(body)
.build();
throw new IOException("Rate limit exceeded during webhook registration.");
throw new IOException("Webhook registration failed: " + response.code() + " " + response.body().string());
return response.body().string();
Step 4: Track Latency, Success Rates and Generate Audit Logs
Operational efficiency requires tracking initiation latency and connection success rates. The following method queries CXone analytics for campaign details, calculates success metrics, and generates a structured audit log for governance compliance. CXone supports pagination for analytics queries.
OAuth Scopes: analytics:read, auditlogs:read
import okhttp3.*;
import java.util.ArrayList;
public class CxoneAnalyticsAuditor {
public CxoneAnalyticsAuditor(String baseUrl, String accessToken, OkHttpClient httpClient) {
public Map<String, Object> trackAndAudit(String campaignId, long initiationLatencyMs) throws IOException {
// Analytics query with pagination support
String queryJson = mapper.writeValueAsString(Map.of(
"interval", "PT1H",
"dateFrom", "2024-01-01T00:00:00Z",
"dateTo", "2024-01-01T01:00:00Z",
"groupings", List.of(Map.of("type", "entityId", "entityId", campaignId)),
"metrics", List.of("calls.total", "calls.connected", "calls.abandoned")
RequestBody body = RequestBody.create(queryJson, MediaType.parse("application/json"));
.url(baseUrl + "/api/v2/analytics/campaigns/details/query")
.post(body)
.build();
int totalCalls = 0;
int connectedCalls = 0;
int pageToken = null;
do {
Request paginatedRequest = request.newBuilder()
.url(baseUrl + "/api/v2/analytics/campaigns/details/query" + (pageToken != null ? "?pageToken=" + pageToken : ""))
.build();
try (Response response = httpClient.newCall(paginatedRequest).execute()) {
Thread.sleep(2000); // Simple backoff for tutorial clarity
continue;
throw new IOException("Analytics query failed: " + response.code());
if (root.path("groups").isArray()) {
for (JsonNode group : root.path("groups")) {
for (JsonNode metric : group.path("metrics")) {
String name = metric.path("name").asText();
totalCalls += metric.path(name).path("value").asInt(0);
if (name.equals("calls.connected")) connectedCalls += metric.path("value").asInt(0);
pageToken = root.path("pageToken").isNull() ? null : root.path("pageToken").asText();
} while (pageToken != null);
double successRate = totalCalls > 0 ? (double) connectedCalls / totalCalls * 100 : 0.0;
// Generate audit log payload for compliance
String auditPayload = mapper.writeValueAsString(Map.of(
"eventType", "DIAL_INITIATION_AUDIT",
"campaignId", campaignId,
"initiationLatencyMs", initiationLatencyMs,
"totalCalls", totalCalls,
"connectedCalls", connectedCalls,
"successRatePercent", successRate,
"timestamp", java.time.Instant.now().toString(),
"complianceFlags", List.of("GDPR_ART_30", "TCPA_COMPLIANT")
// In production, push auditPayload to your SIEM or compliance sink
return Map.of(
"successRate", successRate,
"auditPayload", auditPayload
The following class orchestrates the full dial initiation workflow with production-grade retry logic, error handling, and structured logging.
import okhttp3.*;
public class CxonDialOrchestrator {
private static final Logger log = LoggerFactory.getLogger(CxonDialOrchestrator.class);
private final CxoneAuthManager auth;
public CxonDialOrchestrator(String baseUrl, String clientId, String clientSecret) {
this.auth = new CxoneAuthManager(baseUrl, clientId, clientSecret);
.connectTimeout(15, TimeUnit.SECONDS)
.readTimeout(30, TimeUnit.SECONDS)
.addInterceptor(chain -> {
Request original = chain.request();
Response response = chain.proceed(original);
long retryAfter = response.header("Retry-After") != null
? Long.parseLong(response.header("Retry-After"))
: 2;
log.warn("Rate limited. Retrying after {} seconds.", retryAfter);
Thread.sleep(retryAfter * 1000);
return chain.proceed(original);
return response;
.build();
public void runDialWorkflow(String campaignId, String contactListId, int priority,
int maxConcurrent, double dialRatio, String skillGroupId,
String webhookUrl) {
String token = auth.getAccessToken();
log.info("Authenticated successfully.");
// Step 1: Validate capacity
CxoneCapacityValidator validator = new CxoneCapacityValidator(auth.getBaseUrl(), token, httpClient);
validator.validateCapacity(maxConcurrent, dialRatio, skillGroupId);
log.info("Capacity validation passed.");
// Step 2: Register webhook
CxoneWebhookManager webhookMgr = new CxoneWebhookManager(auth.getBaseUrl(), token, httpClient);
webhookMgr.registerCampaignWebhook(webhookUrl, campaignId);
log.info("Webhook registered for CRM synchronization.");
// Step 3: Initiate campaign
CxoneDialInitiator initiator = new CxoneDialInitiator(auth.getBaseUrl(), token, httpClient);
String startResult = initiator.initiateCampaign(campaignId, contactListId, priority, maxConcurrent, dialRatio);
log.info(startResult);
// Step 4: Track and audit
CxoneAnalyticsAuditor auditor = new CxoneAnalyticsAuditor(auth.getBaseUrl(), token, httpClient);
var metrics = auditor.trackAndAudit(campaignId, latency);
log.info("Audit payload generated: {}", metrics.get("auditPayload"));
log.info("Connection success rate: {}%", metrics.get("successRate"));
} catch (IOException | InterruptedException e) {
log.error("Dial workflow failed: {}", e.getMessage(), e);
String baseUrl = "https://us-east-1.api.cxone.com";
String clientId = System.getenv("CXONE_CLIENT_ID");
String clientSecret = System.getenv("CXONE_CLIENT_SECRET");
CxonDialOrchestrator orchestrator = new CxonDialOrchestrator(baseUrl, clientId, clientSecret);
orchestrator.runDialWorkflow(
"a1b2c3d4-e5f6-7890-g1h2-i3j4k5l6m7n8",
"contact-list-matrix-id-001",
1, 9, 0.8, "skill-group-outbound", "https://your-crm.com/webhooks/cxone"
- Cause: OAuth token expired or invalid. The token cache did not refresh in time.
- Fix: Implement token refresh logic before every request. The
CxoneAuthManagercaches tokens with a 60-second safety buffer and fetches new tokens on expiration. - Code Fix: Ensure
getAccessToken()is called immediately before API invocations. Add a retry interceptor for 401 responses that triggers a fresh token fetch.
Error: 403 Forbidden
- Cause: Missing OAuth scopes or insufficient tenant permissions.
- Fix: Verify that your OAuth client includes
campaigns:write,contacts:read,webhooks:write,analytics:read, androuting:read. Check tenant role assignments for the API user. - Code Fix: Log the exact scope error from the response body and validate against your client configuration.
Error: 409 Conflict
- Cause: Campaign state mismatch. The campaign is already running, paused, or in a terminal state.
- Fix: Query
GET /api/v2/campaigns/{id}to check the currentstatusfield. Pause the campaign first if necessary, or handle the conflict gracefully. - Code Fix: Add a state check before
POST /start. If status isrunning, skip initiation and log a warning.
- Cause: CXone rate limits exceeded. Outbound dial APIs typically enforce 100-200 requests per minute per tenant.
- Fix: Implement exponential backoff with jitter. The
OkHttpClientinterceptor in the complete example handles automatic retry after 429 responses. - Code Fix: Parse the
Retry-Afterheader. If absent, use a base delay of 2 seconds with exponential growth up to 30 seconds.
Error: 400 Bad Request (Schema Validation)
- Cause: Invalid dial payload structure, missing required fields, or priority out of range (1-9).
- Fix: Validate JSON against CXone OpenAPI schema before sending. Ensure
contactListIdsis an array of strings anddialTypematches allowed values. - Code Fix: Add Jackson schema validation or use a JSON Schema library to verify payloads client-side before network transmission.
