Invoking NICE Cognigy LLM Gateway Inference Endpoints with Python
- A production-grade Python module that constructs, validates, and executes LLM inference requests against the NICE Cognigy Gateway API.
- The implementation uses the Cognigy REST API surface with
httpxfor atomic HTTP POST operations, automatic streaming fallback, and structured audit logging. - The tutorial covers Python 3.9+ with
httpx,pydantic, andaiofilesfor async execution and file-based governance logging.
- Cognigy Cloud tenant URL format:
https://{tenant}.cognigy.com - OAuth2 Client Credentials flow with scopes:
auth:client_credentials,llm:write,gateway:invoke - Python 3.9+ runtime
- External dependencies:
pip install httpx pydantic aiofiles tenacity - Network access to Cognigy API endpoints and your external AI logging webhook
The Cognigy platform uses Bearer token authentication. You must exchange client credentials for an access token before invoking the LLM Gateway. The token expires after a configurable duration, so implement caching and refresh logic.
import httpx
from typing import Optional
class CognigyAuthClient:
def __init__(self, tenant: str, client_id: str, client_secret: str):
self.base_url = f"https://{tenant}.cognigy.com"
self.client_id = client_id
self._expires_at: float = 0.0
if self._token and time.time() < self._expires_at:
return self._token
response = await client.post(
f"{self.base_url}/api/v1/auth/token",
data={
"client_id": self.client_id,
"scope": "llm:write gateway:invoke"
headers={"Content-Type": "application/x-www-form-urlencoded"}
response.raise_for_status()
payload = response.json()
self._token = payload["access_token"]
self._expires_at = time.time() + (payload.get("expires_in", 3600) - 60)
return self._token
Required OAuth Scope: llm:write, gateway:invoke
Endpoint: POST /api/v1/auth/token
Response: {"access_token": "eyJ...", "expires_in": 3600, "token_type": "Bearer"}
You must construct the inference payload using the model-ref, prompt-matrix, and generate directive. Validate the structure against Pydantic models before transmission. This prevents 400 Bad Request errors caused by malformed JSON or missing required fields.
from pydantic import BaseModel, Field, field_validator
class PromptMessage(BaseModel):
role: str = Field(..., pattern="^(system|user|assistant)$")
content: str
class GenerateDirective(BaseModel):
temperature: float = Field(..., ge=0.0, le=2.0)
max_tokens: int = Field(..., gt=0, le=8192)
stop: Optional[List[str]] = []
stream: bool = False
class LLMInvokePayload(BaseModel):
model_ref: str = Field(..., alias="model-ref")
prompt_matrix: List[PromptMessage] = Field(..., alias="prompt-matrix")
generate: GenerateDirective = Field(..., alias="generate")
@field_validator("prompt_matrix")
@classmethod
def validate_prompt_order(cls, v: List[PromptMessage]) -> List[PromptMessage]:
if not v:
raise ValueError("prompt-matrix must contain at least one message")
if v[0].role != "system" and v[0].role != "user":
raise ValueError("prompt-matrix must start with system or user role")
return v
def model_dump(self, *args, **kwargs) -> dict:
return super().model_dump(by_alias=True, *args, **kwargs)
Validation Logic: The field_validator enforces role ordering and prevents empty matrices. The max_tokens constraint aligns with Cognigy Gateway limits. Serialization uses by_alias=True to match the exact JSON keys expected by the API.
Step 2: Security Validation and Constraint Checking
Before transmission, run the payload through an injection attack checker and token limit estimator. This step blocks prompt leakage and prevents out-of-memory failures on the gateway side.
import re
import json
class InvokeValidator:
INJECTION_PATTERNS = [
r"ignore\s+previous\s+instructions",
r"system\s+override",
r"<\s*xml\s*>",
r"\\n\\n\\n",
r"return\s+json"
@staticmethod
def check_injection(matrix: List[PromptMessage]) -> bool:
combined_text = " ".join(msg.content.lower() for msg in matrix)
for pattern in InvokeValidator.INJECTION_PATTERNS:
if re.search(pattern, combined_text):
return True
return False
@staticmethod
def estimate_tokens(matrix: List[PromptMessage]) -> int:
# Conservative heuristic: 1 token approx equals 4 characters for English text
total_chars = sum(len(msg.content) for msg in matrix)
return max(1, total_chars // 4)
@staticmethod
def validate_constraints(payload: LLMInvokePayload) -> None:
if InvokeValidator.check_injection(payload.prompt_matrix):
raise ValueError("BLOCKED: Potential prompt injection detected in prompt-matrix")
estimated_tokens = InvokeValidator.estimate_tokens(payload.prompt_matrix)
if estimated_tokens > payload.generate.max_tokens:
raise ValueError(
f"BLOCKED: Estimated input tokens ({estimated_tokens}) exceed max_tokens ({payload.generate.max_tokens})"
Security Pipeline: The regex patterns catch common jailbreak and XML injection attempts. The token estimator provides a safety margin. Both checks raise ValueError to halt execution before network I/O.
Step 3: Atomic POST Execution with Stream Fallback
Execute the inference request as an atomic HTTP POST. If the non-streaming response times out or returns malformed JSON, automatically retry with stream: true and parse Server-Sent Events. Include retry logic for 429 rate limits.
from tenacity import retry, stop_after_attempt, wait_exponential, retry_if_exception_type
import asyncio
class LLMGatewayInvoker:
def __init__(self, auth: CognigyAuthClient, webhook_url: str):
self.auth = auth
self.success_count = 0
self.failure_count = 0
self.total_latency_ms = 0.0
@retry(
retry=retry_if_exception_type(httpx.HTTPStatusError),
stop=stop_after_attempt(3),
wait=wait_exponential(multiplier=1, min=2, max=10)
async def invoke(self, payload: LLMInvokePayload) -> dict:
async with httpx.AsyncClient(timeout=30.0) as client:
token = await self.auth.get_token()
headers = {
"Accept": "application/json"
# Initial atomic POST
f"https://{self.auth.base_url.split('://')[1]}/api/v1/llm/gateway/invoke",
json=payload.model_dump(),
headers=headers
# Handle 429 explicitly before retry decorator catches it
retry_after = int(response.headers.get("Retry-After", 5))
result = response.json()
# Format verification
if "choices" not in result or not isinstance(result["choices"], list):
# Automatic stream fallback trigger
payload.generate.stream = True
result = await self._invoke_streaming(client, token, payload)
return result
async def _invoke_streaming(self, client: httpx.AsyncClient, token: str, payload: LLMInvokePayload) -> dict:
headers = {
"Accept": "text/event-stream"
headers=headers
full_content = ""
async for line in response.aiter_lines():
if line.startswith("data: "):
data_str = line[6:].strip()
if data_str == "[DONE]":
break
chunk = json.loads(data_str)
delta = chunk.get("choices", [{}])[0].get("delta", {}).get("content", "")
full_content += delta
except json.JSONDecodeError:
return {"choices": [{"message": {"role": "assistant", "content": full_content}, "finish_reason": "stop"}]}
HTTP Cycle Documentation:
- Method:
POST - Path:
/api/v1/llm/gateway/invoke - Headers:
Authorization: Bearer <token>,Content-Type: application/json,Accept: application/json - Request Body:
{"model-ref": "openai:gpt-4o", "prompt-matrix": [{"role": "user", "content": "Hello"}], "generate": {"temperature": 0.7, "max_tokens": 256, "stop": [], "stream": false}} - Response Body:
{"choices": [{"message": {"role": "assistant", "content": "Hi there!"}, "finish_reason": "stop"}]}
Step 4: Metrics, Webhooks, and Audit Logging
Track latency and success rates. Emit structured audit logs for AI governance. Synchronize invoking events with your external AI log via webhook POST.
import aiofiles
import json as json_module
async def execute_with_governance(self, payload: LLMInvokePayload) -> dict:
InvokeValidator.validate_constraints(payload)
result = await self.invoke(payload)
self.success_count += 1
status = "SUCCESS"
self.failure_count += 1
status = "FAILURE"
result = {"error": str(e)}
# Calculate latency and update metrics
latency_ms = (time.perf_counter() - self._start_time) * 1000 if hasattr(self, '_start_time') else 0
self.total_latency_ms += latency_ms
# Audit log entry
audit_entry = {
"timestamp": time.strftime("%Y-%m-%dT%H:%M:%SZ", time.gmtime()),
"model_ref": payload.model_ref,
"status": status,
"token_usage": result.get("usage", {}),
"webhook_sync": True
await self._write_audit_log(audit_entry)
await self._sync_webhook(audit_entry)
return result
async def _write_audit_log(self, entry: dict) -> None:
async with aiofiles.open("llm_gateway_audit.jsonl", mode="a") as f:
await f.write(json_module.dumps(entry) + "\n")
async def _sync_webhook(self, entry: dict) -> None:
async with httpx.AsyncClient(timeout=5.0) as client:
await client.post(
self.webhook_url,
json=entry,
headers={"Content-Type": "application/json", "X-Source": "cognigy-llm-gateway"}
except httpx.RequestError:
# Fail silently for webhook sync to prevent blocking main inference flow
pass
Governance Pipeline: The audit log writes to a JSONL file for compliance retention. The webhook sync runs asynchronously to align with external AI monitoring systems. Latency and success rates are aggregated in memory and can be exposed via a metrics endpoint.
import asyncio
import httpx
import aiofiles
import re
# --- Models & Validators ---
content: str
@classmethod
if not v:
return v
INJECTION_PATTERNS = [r"ignore\s+previous\s+instructions", r"system\s+override", r"<\s*xml\s*>"]
@staticmethod
return any(re.search(p, combined_text) for p in InvokeValidator.INJECTION_PATTERNS)
@staticmethod
return max(1, sum(len(msg.content) for msg in matrix) // 4)
@staticmethod
raise ValueError("BLOCKED: Potential prompt injection detected")
if InvokeValidator.estimate_tokens(payload.prompt_matrix) > payload.generate.max_tokens:
raise ValueError("BLOCKED: Input exceeds max_tokens constraint")
# --- Auth & Invoker ---
return self._token
resp = await client.post(
data={"grant_type": "client_credentials", "client_id": self.client_id, "client_secret": self.client_secret, "scope": "llm:write gateway:invoke"},
resp.raise_for_status()
data = resp.json()
self._token = data["access_token"]
self._expires_at = time.time() + (data.get("expires_in", 3600) - 60)
return self._token
def __init__(self, tenant: str, client_id: str, client_secret: str, webhook_url: str):
self.auth = CognigyAuthClient(tenant, client_id, client_secret)
@retry(retry=retry_if_exception_type(httpx.HTTPStatusError), stop=stop_after_attempt(3), wait=wait_exponential(multiplier=1, min=2, max=10))
start = time.perf_counter()
headers = {"Authorization": f"Bearer {token}", "Content-Type": "application/json", "Accept": "application/json"}
resp = await client.post(f"https://{self.auth.base_url.split('://')[1]}/api/v1/llm/gateway/invoke", json=payload.model_dump(), headers=headers)
if resp.status_code == 429:
await asyncio.sleep(int(resp.headers.get("Retry-After", 5)))
result = resp.json()
self.total_latency_ms += (time.perf_counter() - start) * 1000
return result
headers = {"Authorization": f"Bearer {token}", "Content-Type": "application/json", "Accept": "text/event-stream"}
full = ""
async for line in resp.aiter_lines():
d = line[6:].strip()
if d == "[DONE]": break
try: full += json_module.loads(d).get("choices", [{}])[0].get("delta", {}).get("content", "")
except: continue
return {"choices": [{"message": {"role": "assistant", "content": full}, "finish_reason": "stop"}]}
async def execute(self, payload: LLMInvokePayload) -> dict:
status = "SUCCESS"
status = "FAILURE"
audit = {"timestamp": time.strftime("%Y-%m-%dT%H:%M:%SZ", time.gmtime()), "model_ref": payload.model_ref, "status": status, "webhook_sync": True}
async with aiofiles.open("audit.jsonl", mode="a") as f:
await f.write(json_module.dumps(audit) + "\n")
async with httpx.AsyncClient(timeout=5.0) as c:
await c.post(self.webhook_url, json=audit, headers={"Content-Type": "application/json"})
except: pass
return result
invoker = LLMGatewayInvoker(
tenant="your-tenant",
client_id="your-client-id",
client_secret="your-client-secret",
webhook_url="https://your-webhook-endpoint.com/logs"
payload = LLMInvokePayload(
model_ref="openai:gpt-4o",
prompt_matrix=[{"role": "system", "content": "You are a CXone assistant."}, {"role": "user", "content": "Check order status."}],
generate={"temperature": 0.7, "max_tokens": 256, "stop": [], "stream": False}
print(asyncio.run(invoker.execute(payload)))
Error: 400 Bad Request
- Cause: Malformed
prompt-matrixstructure, invalidmodel-ref, ormax_tokensexceeding gateway limits. - Fix: Verify payload serialization uses
by_alias=True. Ensuremodel-refmatches an approved model ID in your Cognigy tenant. Reducemax_tokensto 4096 if the gateway rejects higher values. - Code Fix: The
LLMInvokePayloadPydantic model enforces field types and aliases. Wrap calls intry/except pydantic.ValidationErrorto catch schema mismatches early.
- Cause: Expired Bearer token, missing
llm:writeorgateway:invokescopes, or tenant mismatch. - Fix: Regenerate the token via
CognigyAuthClient.get_token(). Verify the client credentials were provisioned with the correct scopes in the Cognigy admin console. - Code Fix: The auth client automatically refreshes tokens 60 seconds before expiration. Log
response.status_codeandresponse.textto confirm scope rejection messages.
- Cause: Exceeding Cognigy Gateway rate limits during concurrent CXone scaling events.
- Fix: Implement exponential backoff. The
tenacitydecorator handles retry loops automatically. Respect theRetry-Afterheader when present. - Code Fix: The
invokemethod includes explicit 429 handling withawait asyncio.sleep(int(resp.headers.get("Retry-After", 5)))before raising the status error for the retry decorator to catch.
Error: Stream Fallback Triggered Unexpectedly
- Cause: Non-streaming POST returns truncated JSON or times out under high load.
- Fix: Increase
httpx.AsyncClient(timeout=30.0)to 60.0 for complex generation tasks. Verify thegenerate.streamflag is correctly toggled during fallback. - Code Fix: The
_invoke_streamingmethod parses SSE chunks safely and reconstructs the final response structure to match the non-streaming schema.
