Invoking NICE Cognigy.AI NLU Prediction Endpoints with Node.js
A production-ready Node.js module that constructs, validates, and executes NLU prediction requests against the Cognigy.AI REST API. The module enforces schema constraints, verifies model availability, enforces token limits, measures request latency, generates audit logs, and synchronizes results with external logging services via callback handlers.
- Node.js 18.0 or higher with ES module support
axios(v1.6+) for HTTP client operationszod(v3.22+) for runtime schema validation- Cognigy.AI tenant URL, client ID, and client secret
- OAuth scope:
nlu:predict api:access - Environment variables configured for credentials and base URL
Cognigy.AI uses OAuth 2.0 for programmatic access. The client credentials flow provides a short-lived bearer token that grants access to the NLU prediction surface. Token caching is mandatory to avoid unnecessary authentication overhead and rate limit exhaustion.
import axios from 'axios';
const COGNIFY_BASE_URL = process.env.COGNIFY_BASE_URL || 'https://api.cognigy.ai';
const COGNIFY_CLIENT_ID = process.env.COGNIFY_CLIENT_ID;
const COGNIFY_CLIENT_SECRET = process.env.COGNIFY_CLIENT_SECRET;
const COGNIFY_SCOPE = 'nlu:predict api:access';
let cachedToken = null;
let tokenExpiry = 0;
export async function getCognigyToken() {
const now = Date.now();
if (cachedToken && now < tokenExpiry) {
return cachedToken;
const response = await axios.post(`${COGNIFY_BASE_URL}/api/v1/oauth/token`, {
client_id: COGNIFY_CLIENT_ID,
client_secret: COGNIFY_CLIENT_SECRET,
scope: COGNIFY_SCOPE
cachedToken = response.data.access_token;
tokenExpiry = now + (response.data.expires_in * 1000) - 5000;
return cachedToken;
} catch (error) {
if (error.response) {
throw new Error(`Cognigy OAuth failed with ${error.response.status}: ${error.response.data.message || error.response.statusText}`);
throw new Error('Cognigy OAuth request failed: network or timeout error');
The token endpoint returns a JSON payload containing access_token and expires_in. The cache subtracts five seconds from the expiration window to prevent boundary race conditions. The required scope nlu:predict grants access to the prediction endpoint, while api:access ensures baseline tenant authentication.
Step 1: Schema Validation and Payload Construction
The Cognigy NLU engine rejects malformed payloads immediately. Runtime validation prevents serialization failures and reduces unnecessary network calls. The payload must contain the input text, target language, model version, optional context directives, and a configurable token ceiling.
import { z } from 'zod';
export const MODEL_VERSION_MATRIX = {
en: ['v2.1', 'v2.2', 'v3.0'],
de: ['v2.1', 'v2.3'],
es: ['v2.2', 'v2.4']
export const NluInvokeSchema = z.object({
text: z.string().min(1).max(4000),
language: z.string().refine(
(lang) => lang in MODEL_VERSION_MATRIX,
{ message: 'Language is not supported in the model version matrix' }
modelVersion: z.string().refine(
(val, ctx) => {
const lang = ctx.data.parent?.language;
const allowed = lang ? MODEL_VERSION_MATRIX[lang] : [];
return allowed.includes(val);
{ message: 'Model version is not available for the specified language' }
context: z.array(z.object({
intent: z.string(),
entities: z.array(z.object({
value: z.string()
})).optional().default([]),
maxTokens: z.number().int().positive().lte(1024).optional().default(512)
The zod schema enforces strict typing and cross-field validation. The modelVersion refinement references the parent language field to ensure the requested version exists in the deployment matrix. Context directives follow Cognigy’s expected structure, allowing upstream intents and entities to influence disambiguation. The maxTokens field defaults to 512, which aligns with standard Cognigy NLU engine limits.
Step 2: Model Availability and Token Limit Verification
Before network transmission, the payload must pass encoding and token boundary checks. UTF-8 validation prevents surrogate pair corruption, and token estimation prevents engine-side truncation errors. Cognigy counts tokens using a subword tokenizer, so a heuristic approximation is used here with a safety margin.
function validateEncoding(text) {
const encoder = new TextEncoder();
const decoder = new TextDecoder('utf-8', { fatal: true });
decoder.decode(encoder.encode(text));
return true;
} catch {
return false;
function estimateTokenCount(text) {
const normalized = text.normalize('NFC');
const words = normalized.split(/[\s\n\r\t]+/).filter(Boolean);
return words.length;
export function validateInvocationPayload(payload) {
const parsed = NluInvokeSchema.parse(payload);
if (!validateEncoding(parsed.text)) {
throw new Error('Text input contains invalid UTF-8 sequences or unpaired surrogates');
const estimatedTokens = estimateTokenCount(parsed.text);
if (estimatedTokens > parsed.maxTokens) {
throw new Error(`Text exceeds maximum token limit. Estimated: ${estimatedTokens}, Limit: ${parsed.maxTokens}`);
return parsed;
The validateEncoding function uses the native TextDecoder with the fatal flag to catch malformed byte sequences. The estimateTokenCount function splits on whitespace and control characters. Production systems should replace this heuristic with the exact tokenizer used by the Cognigy model (for example, a BPE or SentencePiece implementation) to guarantee precise boundary enforcement.
Step 3: Atomic POST Invocation with Latency Tracking
The prediction request executes as a single HTTP POST operation. Latency measurement wraps the entire request lifecycle. The implementation includes automatic retry logic for 429 rate limit responses with exponential backoff and jitter.
const MAX_RETRIES = 3;
const BASE_DELAY = 1000;
async function retryWithBackoff(fn, attempt = 1) {
return await fn();
} catch (error) {
if (error.response?.status === 429 && attempt < MAX_RETRIES) {
const jitter = Math.random() * 0.5;
const delay = BASE_DELAY * Math.pow(2, attempt - 1) * (1 + jitter);
console.log(`Rate limited. Retrying in ${Math.round(delay)}ms (attempt ${attempt})`);
return retryWithBackoff(fn, attempt + 1);
throw error;
export async function invokeNluPrediction(validatedPayload, token) {
const endpoint = `${COGNIFY_BASE_URL}/api/v1/nlu/predict`;
const headers = {
'Accept': 'application/json'
const requestBody = {
text: validatedPayload.text,
language: validatedPayload.language,
modelVersion: validatedPayload.modelVersion,
context: validatedPayload.context,
maxTokens: validatedPayload.maxTokens
const startTime = performance.now();
const response = await retryWithBackoff(async () => {
return axios.post(endpoint, requestBody, { headers, timeout: 8000 });
const latencyMs = performance.now() - startTime;
if (!response.data || typeof response.data.predictions === 'undefined') {
throw new Error('Invalid NLU prediction response format received from Cognigy engine');
predictions: response.data.predictions,
latencyMs: Math.round(latencyMs * 100) / 100,
requestId: response.headers['x-request-id'] || 'unknown'
The retryWithBackoff function catches 429 responses and applies exponential backoff with randomized jitter to prevent thundering herd scenarios. The invokeNluPrediction function measures wall-clock latency using performance.now(). It verifies the response structure before returning, ensuring downstream consumers receive a predictable shape. The x-request-id header is extracted for trace correlation.
Step 4: Audit Logging and Callback Synchronization
Governance requirements demand immutable audit trails and external service synchronization. The invoker class generates structured audit logs containing input hashes, model metadata, latency, confidence scores, and execution status. Callback handlers receive the complete invocation context for downstream logging or conversation state management.
import crypto from 'crypto';
export class CognigyNluInvoker {
constructor(options = {}) {
this.onInvocationComplete = options.onInvocationComplete || (() => {});
this.auditLogSink = options.auditLogSink || console.log;
generateAuditLog(inputText, payload, result, status) {
const inputHash = crypto.createHash('sha256').update(inputText).digest('hex').substring(0, 16);
const topPrediction = result.predictions?.[0] || {};
return JSON.stringify({
status: status,
inputHash: inputHash,
language: payload.language,
modelVersion: payload.modelVersion,
maxTokens: payload.maxTokens,
latencyMs: result.latencyMs,
topIntent: topPrediction.intent || 'none',
topConfidence: topPrediction.confidence || 0,
requestId: result.requestId
async invoke(rawPayload) {
let validatedPayload;
validatedPayload = validateInvocationPayload(rawPayload);
} catch (validationError) {
const auditEntry = this.generateAuditLog(
rawPayload.text,
{ language: rawPayload.language, modelVersion: rawPayload.modelVersion, maxTokens: rawPayload.maxTokens },
{ latencyMs: 0, requestId: 'validation-failed' },
'VALIDATION_ERROR'
this.auditLogSink(auditEntry);
throw validationError;
const token = await getCognigyToken();
const result = await invokeNluPrediction(validatedPayload, token);
validatedPayload,
result,
'SUCCESS'
this.onInvocationComplete({
status: 'success',
payload: validatedPayload,
result: result,
auditEntry: auditEntry
return result;
} catch (executionError) {
validatedPayload,
{ latencyMs: 0, requestId: 'execution-failed' },
'EXECUTION_ERROR'
status: 'error',
error: executionError.message,
throw executionError;
The generateAuditLog method creates a deterministic input hash to avoid storing raw PII while preserving traceability. Confidence rates are extracted from the top prediction for efficiency monitoring. The onInvocationComplete callback receives the full context, enabling integration with external conversation logging services, metric aggregators, or state machines.
// index.js
import { CognigyNluInvoker } from './nlu-invoker.js';
const invoker = new CognigyNluInvoker({
onInvocationComplete: (event) => {
console.log('[Callback] Invocation synchronized:', event.status);
if (event.status === 'success') {
console.log('[Callback] Top intent:', event.result.predictions[0].intent);
console.log('[Callback] Confidence:', event.result.predictions[0].confidence);
auditLogSink: (logLine) => {
console.log('[Audit]', logLine);
async function runPrediction() {
const inputPayload = {
text: 'I want to cancel my subscription effective next month',
language: 'en',
modelVersion: 'v3.0',
context: [
intent: 'billing.inquiry',
entities: [{ name: 'account_type', value: 'premium' }]
maxTokens: 512
const result = await invoker.invoke(inputPayload);
console.log('[Result] Latency:', result.latencyMs, 'ms');
console.log('[Result] Predictions:', JSON.stringify(result.predictions, null, 2));
} catch (error) {
console.error('[Fatal] Invocation failed:', error.message);
process.exit(1);
runPrediction();
Execute the script with node index.js. The module validates the payload, authenticates with Cognigy, submits the prediction request, measures latency, writes the audit trail, triggers the callback, and returns the structured response. Replace environment variables with valid tenant credentials before execution.
Common Errors and Debugging
Error: 400 Bad Request (Schema or Token Limit Violation)
The Cognigy engine returns 400 when the payload structure deviates from the expected schema or when the text exceeds the model token ceiling. The validation pipeline catches most schema violations before network transmission. If the engine still rejects the request, verify that the context array matches the exact entity name format expected by the deployed model. Increase maxTokens only if the model documentation explicitly supports larger windows.
// Fix: Adjust maxTokens or truncate text before invocation
if (estimateTokenCount(payload.text) > payload.maxTokens) {
payload.text = payload.text.substring(0, payload.text.lastIndexOf(' ', payload.maxTokens * 4));
Authentication failures occur when the client credentials are invalid, the token has expired, or the OAuth scope lacks nlu:predict. The token caching logic automatically refreshes expired tokens. If 403 persists after a successful 200 from the OAuth endpoint, verify that the client ID has been granted NLU prediction permissions in the Cognigy tenant console.
// Debug: Log token endpoint response for scope verification
console.log('Granted scopes:', response.data.scope?.split(' '));
if (!response.data.scope?.includes('nlu:predict')) {
throw new Error('Missing required nlu:predict scope in token response');
Cognigy enforces tenant-level rate limits on the NLU prediction endpoint. The retry logic handles transient 429 responses with exponential backoff. If retries exhaust, implement request queuing or circuit breaker patterns upstream. Monitor the Retry-After header if Cognigy returns it for precise wait times.
// Enhancement: Read Retry-After header when available
if (error.response?.headers['retry-after']) {
const retrySeconds = parseInt(error.response.headers['retry-after'], 10);
console.log(`Server requested ${retrySeconds}s wait time`);
Error: 504 Gateway Timeout or 5xx Server Error
Timeout errors indicate engine overload or network degradation. The 8-second timeout balances responsiveness with model inference duration. If 504 errors increase during scaling events, reduce batch sizes, implement client-side request throttling, or contact Cognigy support to verify model replica availability. The audit log records latency spikes, enabling correlation with infrastructure scaling events.
