Intercepting Web Messaging Events for Custom Chatbot Pre-Routing
Configure the Genesys Cloud Web Messaging widget to intercept outbound customer messages before platform routing, route them through a custom chatbot engine for intent classification and data collection, and conditionally resume native Genesys routing based on bot outcomes. The end result is a production-grade pre-routing layer that deflects routine inquiries, enriches conversation attributes with bot-derived metadata, and triggers queue routing only when human intervention is required.
  • Licensing Tier: CX 1 or higher (Web Messaging is included in all CX tiers). Architect access requires CX 2 or higher for advanced routing logic.
  • Permission Strings:
    • Web Messaging > Widget > Edit
    • Architect > Flow > Edit
    • Integration > External Service > Create
    • Conversation > Messaging > Update
  • OAuth Scopes: webmessaging:widget:update, architect:flow:view, conversations:messaging:update, integration:externalservice:create
  • External Dependencies: HTTPS-accessible chatbot inference endpoint, CORS-enabled domain for widget hosting, IP allowlisting for outbound Genesys REST API calls, TLS 1.2+ certificate on the custom bot endpoint.
1. Configuring the Web Messaging Widget Interceptor
The interception layer operates at the browser level before the message payload reaches the Genesys Cloud messaging engine. You implement this by modifying the widget initialization configuration to inject an asynchronous intercept callback. This callback receives the raw message object, allows your custom logic to execute, and returns a resolved promise to either forward, modify, or suppress the message.
Initialize the widget with the interception hook enabled. The configuration object must explicitly define the intercept property as an async function that accepts the message parameter and returns a Promise<Message>.
import { initWebMessaging } from '@genesys/web-messaging-widget';
const widgetConfig = {
  region: 'us-east-1',
  deploymentId: 'YOUR_DEPLOYMENT_ID',
  intercept: async (message) => {
    // Preserve original metadata for platform correlation
    const originalMessage = { ...message };
    // Route to custom chatbot engine
    const botResponse = await fetch('https://your-bot-endpoint.example.com/classify', {
      method: 'POST',
      headers: {
        'Authorization': 'Bearer YOUR_BOT_API_KEY'
      body: JSON.stringify({
        text: message.text,
        conversationId: message.conversationId,
        userId: message.userId,
        timestamp: message.timestamp
    const botPayload = await botResponse.json();
    // Decision matrix based on bot classification
    if (botPayload.deflect === true) {
      // Bot handles response entirely. Return null to suppress platform routing.
      return null;
    if (botPayload.handoffRequired === true) {
      // Enrich message with routing metadata before forwarding
      message.customAttributes = {
        ...message.customAttributes,
        bot_intent: botPayload.intent,
        bot_confidence: botPayload.confidence,
        bot_handoff_required: true,
        bot_pre_collected_data: botPayload.enrichedData
      return message;
    // Default: Forward unchanged to Genesys routing
    return message;
initWebMessaging(widgetConfig);
The Trap: Failing to return a resolved promise causes the widget UI to freeze indefinitely. The Genesys Cloud widget relies on the promise resolution to clear the input field, update the message history, and advance the conversation state. If your bot endpoint throws an unhandled exception or returns a non-JSON payload, the promise rejects silently in the browser console, and the customer sees a spinning indicator that never resolves. You must wrap the entire interception block in a try/catch that defaults to returning the original message on failure. This ensures platform continuity even when the bot engine experiences downtime.
Architectural Reasoning: Client-side interception shifts compute away from the Genesys Cloud messaging engine, which is optimized for high-throughput routing rather than synchronous AI inference. By resolving bot logic in the browser context, you achieve sub-100ms response times for deflections and prevent the platform from allocating queue resources to conversations that will never reach an agent. The null return value explicitly tells the widget to drop the message from the platform pipeline, which is critical for cost optimization in metered CCaaS environments.
2. Architecting the Pre-Routing Flow in Genesys Cloud
Messages that pass the interceptor with bot_handoff_required: true enter the Genesys Cloud messaging engine. You must configure an Architect flow to evaluate the custom attributes and route to the appropriate queue based on bot classification. The flow operates on the onMessage trigger and must handle attribute evaluation, queue selection, and fallback routing.
Create a new Architect flow with the Messaging trigger. Configure the trigger to fire on New Message events. Add a Data node to extract custom attributes from the conversation payload. Use the following expression to safely reference bot-derived metadata:
${conversation.custom_attributes.bot_intent}
Route through a Decision node that evaluates the bot_intent value. Configure branches for high-confidence intents that map to specialized queues. Add a default branch for low-confidence or unrecognized intents that route to a general support queue.
The Trap: Evaluating custom attributes synchronously without accounting for race conditions between the interceptor and the platform routing engine. The Genesys Cloud messaging engine processes messages asynchronously. If the interceptor updates custom attributes via the REST API after the message is already queued, the Architect flow evaluates against stale data. This causes misrouting and forces unnecessary supervisor reassignments. You must ensure attribute enrichment happens within the interceptor callback before the message is returned, or use the PATCH /api/v2/conversations/messaging/{conversation-id} endpoint with the custom_attributes merge strategy before the flow evaluates.
Architectural Reasoning: Architect flows evaluate custom attributes at the moment the message enters the routing pipeline. By embedding routing metadata directly into the message payload during interception, you eliminate network latency between bot classification and queue assignment. The flow should include a Set Custom Attributes node that stamps bot_processed_at and bot_version for auditability. This enables WEM supervisors to filter conversations by bot decision path and ensures compliance reporting captures the exact inference version used for each handoff.
Configure the flow to update the conversation queue dynamically. Use the Set Queue node with a dynamic expression that maps intents to queue IDs:
${map[conversation.custom_attributes.bot_intent] ?? "default_support_queue_id"}
Deploy the flow to a dedicated Web Messaging routing profile. Assign the profile to the widget deployment configuration to ensure all intercepted messages route through the bot-aware flow.
3. Implementing the Custom Chatbot Logic & State Handoff
The custom chatbot engine must maintain conversation state across multiple intercepted messages. You implement this by storing session context in a distributed cache keyed by conversationId. Each interception call retrieves the existing context, updates it with the new message, runs inference, and persists the updated state before returning the response.
Structure the bot endpoint to accept the message payload and return a standardized response object. The response must include deflection status, intent classification, confidence score, and any pre-collected data required for agent context.
  "deflect": false,
  "handoffRequired": true,
  "intent": "billing_inquiry",
  "confidence": 0.94,
  "enrichedData": {
    "accountStatus": "active",
    "lastPaymentDate": "2024-03-15",
    "outstandingBalance": 142.50
When the bot determines human intervention is required, you must push the enriched data into the Genesys Cloud conversation object before routing occurs. Use the Genesys REST API to update custom attributes atomically.
HTTP Method: PATCH
Endpoint: /api/v2/conversations/messaging/{conversation-id}
JSON Body:
  "custom_attributes": {
    "bot_intent": "billing_inquiry",
    "bot_confidence": 0.94,
    "bot_handoff_required": true,
    "bot_pre_collected_data": {
The Trap: Overwriting native Genesys conversation metadata during attribute updates. The PATCH endpoint performs a shallow merge by default. If your bot payload includes top-level conversation fields like state, queueId, or participants, the platform may reset critical routing state. You must restrict updates to the custom_attributes namespace only. Additionally, failing to implement idempotency keys on the bot endpoint causes duplicate attribute updates when the widget retries failed interceptions, leading to inflated API call counts and potential rate limiting.
Architectural Reasoning: Immutable attribute updates preserve the audit trail required for quality assurance and compliance. By scoping bot metadata to custom_attributes, you ensure that WFM forecasting, Speech Analytics, and WEM dashboards ingest the data without interfering with native platform routing logic. The bot engine must implement exponential backoff and circuit breaker patterns to handle Genesys API rate limits. When the platform returns 429 Too Many Requests, the bot must queue the attribute update and retry with jitter, rather than failing the interception and dropping the message.
Configure the bot to handle multi-turn conversations before handoff. Store the conversation history in a Redis instance or similar distributed cache with a TTL matching the platform’s conversation retention policy. Each interception call retrieves the history, appends the new message, runs the inference model, and updates the cache. This prevents state loss when customers switch devices or refresh the browser, as the conversationId remains constant across sessions.
Edge Case 1: WebSocket Reconnection During Bot Processing
The failure condition: The customer loses network connectivity while the interceptor is awaiting a response from the custom bot endpoint. The Genesys Cloud widget attempts to reconnect via WebSocket, but the interception promise remains pending in the original browser context. When connectivity restores, the widget drops the pending message and creates a new conversation thread.
The root cause: The Web Messaging widget maintains a single WebSocket connection per deployment ID. Network interruptions trigger a full reconnection sequence that invalidates pending asynchronous operations. The interceptor promise does not survive the reconnection cycle, causing message loss and duplicate conversation creation.
The solution: Implement client-side message queuing with retry logic. Before invoking the bot endpoint, store the message in localStorage or an IndexedDB queue with a pending status. If the bot response succeeds, mark the message as sent and forward it through the interceptor. If the network drops, the widget’s native retry mechanism will trigger a onReconnect event. Bind to this event to flush the pending queue and resume interception. Add a timeout to the bot fetch call (maximum 3 seconds) to prevent indefinite promise suspension.
Edge Case 2: Rate Limiting on Custom Bot Endpoint
The failure condition: High traffic volume triggers rate limiting on the custom bot inference API. The interceptor receives 429 responses, causing the promise to reject or timeout. The widget suppresses the message, and customers see no response. Concurrent interceptions queue up, creating a cascading failure that blocks all new conversations.
The root cause: The interceptor executes synchronously per message without backpressure management. Genesys Cloud Web Messaging can process thousands of concurrent sessions. Without rate limiting on the interceptor side, the bot endpoint becomes the bottleneck. The platform continues to fire interception callbacks faster than the bot can process them, exhausting connection pools.
The solution: Implement a token bucket rate limiter in the interceptor callback. Restrict bot calls to a sustainable throughput (e.g., 50 requests per second per widget instance). Messages that exceed the limit bypass the bot and route directly to the platform with a bot_throttled: true attribute. Configure the Architect flow to route throttled messages to a fallback queue with lower SLA targets. Add monitoring on the bot endpoint to trigger auto-scaling when queue depth exceeds threshold. Use HTTP/2 multiplexing to reduce connection overhead during high-volume periods.
Edge Case 3: Custom Attribute Schema Drift
The failure condition: The bot model version updates, introducing new keys or changing value types in the enrichedData payload. The Architect flow evaluates against outdated attribute paths, causing routing rules to fail silently. Conversations route to the default queue regardless of intent classification.
The root cause: Genesys Cloud custom attributes are dynamically typed. The platform does not enforce schema validation on custom_attributes. When the bot payload structure changes, existing Architect expressions reference undefined keys, resulting in null evaluations. The flow defaults to the fallback branch without logging the schema mismatch.
The solution: Implement a versioned attribute namespace (bot_v2_intent, bot_v2_enriched_data). Update the Architect flow to evaluate the latest version while maintaining backward compatibility with previous versions. Add a Set Custom Attributes node that validates the payload structure before routing. Use the Genesys Cloud API to audit attribute usage and deprecate old versions after a 30-day grace period. Integrate schema validation into the CI/CD pipeline that deploys bot model updates.
