Intercepting NICE CXone Voice API SIP INVITE Headers with Go
- A Go service that authenticates to NICE CXone, validates SIP INVITE header payloads against security and length constraints, constructs filter directives for header interception, applies them via atomic HTTP PUT operations, and exposes a webhook endpoint for external SBC synchronization and audit logging.
- This tutorial uses the NICE CXone Voice API REST endpoints and standard Go HTTP libraries.
- The programming language covered is Go 1.21+.
- OAuth2 Client Credentials flow configured in NICE CXone with the following scopes:
voice:sip:read,voice:sip:write,webhooks:write - CXone API version:
v2 - Go runtime:
1.21or higher - External dependencies:
github.com/go-resty/resty/v2for HTTP client management,golang.org/x/oauth2for token handling - A CXone organization with Voice routing enabled and SIP trunk configuration access
NICE CXone uses standard OAuth2 client credentials flow. The token endpoint requires your client ID and client secret. The response contains an access token valid for one hour. Production code must cache the token and refresh it before expiration.
package auth
import (
"context"
"fmt"
"sync"
"time"
"github.com/go-resty/resty/v2"
"golang.org/x/oauth2/clientcredentials"
type TokenManager struct {
clientID string
clientSecret string
tokenURL string
mu sync.Mutex
token *oauth2.Token
nextRefresh time.Time
func NewTokenManager(clientID, clientSecret, orgURL string) *TokenManager {
return &TokenManager{
clientID: clientID,
clientSecret: clientSecret,
tokenURL: fmt.Sprintf("%s/api/v2/oauth2/token", orgURL),
func (tm *TokenManager) GetToken(ctx context.Context) (*oauth2.Token, error) {
tm.mu.Lock()
defer tm.mu.Unlock()
if tm.token != nil && time.Now().Before(tm.nextRefresh) {
return tm.token, nil
conf := &clientcredentials.Config{
ClientID: tm.clientID,
ClientSecret: tm.clientSecret,
TokenURL: tm.tokenURL,
token, err := conf.Token(ctx)
if err != nil {
return nil, fmt.Errorf("oauth2 token fetch failed: %w", err)
tm.token = token
tm.nextRefresh = time.Now().Add(time.Duration(token.Expiry.Sub(time.Now())) - 5*time.Minute)
return token, nil
The TokenManager caches the token and subtracts five minutes from the expiry window to prevent boundary failures during high-throughput filter updates. The required scope for subsequent SIP operations is voice:sip:read and voice:sip:write.
Step 1: Initialize CXone Client & Fetch Existing Filter Matrix
The Voice API exposes SIP filters under /api/v2/voice/sip/filters. The response contains a pagination wrapper and an array of filter objects. Each filter contains a sip-ref (route identifier), voice-matrix (routing configuration), and filter directive (header manipulation rules).
package cxone
import (
"context"
"encoding/json"
"fmt"
"net/http"
"time"
type SIPFilter struct {
ID string `json:"id"`
SipRef string `json:"sipRef"`
VoiceMatrix json.RawMessage `json:"voiceMatrix"`
FilterDirective FilterDirective `json:"filterDirective"`
Priority int `json:"priority"`
Enabled bool `json:"enabled"`
MaximumHeaderLength int `json:"maximumHeaderLength"`
type FilterDirective struct {
HeaderName string `json:"headerName"`
HeaderValue string `json:"headerValue"`
Action string `json:"action"` // ADD, MODIFY, REMOVE
Condition string `json:"condition"`
type FilterListResponse struct {
PageSize int `json:"pageSize"`
PageCount int `json:"pageCount"`
TotalCount int `json:"totalCount"`
Entities []SIPFilter `json:"entities"`
func FetchFilterMatrix(ctx context.Context, client *resty.Client, orgURL string, token string) ([]SIPFilter, error) {
var allFilters []SIPFilter
page := 1
for {
resp, err := client.R().
SetContext(ctx).
SetAuthToken(token).
SetHeader("Accept", "application/json").
SetQueryParams(map[string]string{
"pageSize": "50",
"page": fmt.Sprintf("%d", page),
Get(fmt.Sprintf("%s/api/v2/voice/sip/filters", orgURL))
if err != nil {
return nil, fmt.Errorf("HTTP request failed: %w", err)
if resp.StatusCode() == http.StatusTooManyRequests {
retryAfter := 2
if delay, ok := resp.Header()["Retry-After"]; ok {
fmt.Sscanf(delay[0], "%d", &retryAfter)
time.Sleep(time.Duration(retryAfter) * time.Second)
if resp.StatusCode() < 200 || resp.StatusCode() >= 300 {
return nil, fmt.Errorf("CXone API error: %s %s", resp.Status(), string(resp.Body()))
var pageResp FilterListResponse
if err := json.Unmarshal(resp.Body(), &pageResp); err != nil {
return nil, fmt.Errorf("JSON parse error: %w", err)
allFilters = append(allFilters, pageResp.Entities...)
if page >= pageResp.PageCount {
break
page++
return allFilters, nil
The pagination loop respects the Retry-After header for 429 responses. The FilterDirective structure maps directly to CXone SIP header manipulation payloads. The maximumHeaderLength field enforces RFC 3261 compliance and CXone platform limits.
Step 2: Validate SIP Headers Against Voice Constraints & Security Policies
Before applying any filter, the payload must pass malformed-SIP checking and security-policy verification. SIP injection attacks often exploit oversized headers or malformed header-value pairs. The validation pipeline checks header length, rejects control characters, and verifies routing priority evaluation logic.
package validator
import (
"fmt"
"regexp"
"strings"
const MaxSIPHeaderLength = 768
var invalidHeaderChars = regexp.MustCompile(`[^\x20-\x7E]`)
func ValidateSIPHeader(headerName, headerValue string, priority int) error {
if headerName == "" {
return fmt.Errorf("header name cannot be empty")
if len(headerValue) > MaxSIPHeaderLength {
return fmt.Errorf("header value exceeds maximum-header-length limit of %d bytes", MaxSIPHeaderLength)
if invalidHeaderChars.MatchString(headerValue) {
return fmt.Errorf("header value contains invalid control characters")
if strings.Contains(headerValue, "..") || strings.Contains(headerValue, "%") {
return fmt.Errorf("header value contains potential SIP injection sequences")
if priority < 1 || priority > 100 {
return fmt.Errorf("routing priority must be between 1 and 100")
return nil
The validator rejects headers exceeding 768 bytes, blocks non-printable ASCII characters, and strips sequences commonly used in SIP injection payloads. The routing priority evaluation ensures the filter inserts correctly into the CXone processing pipeline without breaking existing voice-matrix ordering.
Step 3: Construct Filter Directive & Apply Atomic PUT
CXone requires atomic updates for SIP filters. The HTTP PUT operation replaces the entire filter object. The code constructs the intercepting payload, validates it, and applies it with format verification. Automatic modify triggers activate when the action field changes from ADD to MODIFY.
package cxone
import (
"context"
"encoding/json"
"fmt"
"net/http"
"time"
"yourmodule/validator"
func UpdateSIPFilter(ctx context.Context, client *resty.Client, orgURL, token, filterID string, directive FilterDirective, priority int) error {
if err := validator.ValidateSIPHeader(directive.HeaderName, directive.HeaderValue, priority); err != nil {
return fmt.Errorf("filter validation failed: %w", err)
payload := map[string]interface{}{
"id": filterID,
"sipRef": "route-primary-01",
"voiceMatrix": json.RawMessage(`{"type": "sip_route", "trunkGroup": "primary-tg"}`),
"filterDirective": directive,
"priority": priority,
"enabled": true,
"maximumHeaderLength": 768,
payloadBytes, err := json.Marshal(payload)
if err != nil {
return fmt.Errorf("JSON marshaling failed: %w", err)
startTime := time.Now()
SetContext(ctx).
SetHeader("Content-Type", "application/json").
SetBody(payloadBytes).
Put(fmt.Sprintf("%s/api/v2/voice/sip/filters/%s", orgURL, filterID))
duration := time.Since(startTime)
if err != nil {
return fmt.Errorf("HTTP request failed: %w", err)
retryAfter := 2
return UpdateSIPFilter(ctx, client, orgURL, token, filterID, directive, priority)
if resp.StatusCode() != http.StatusOK && resp.StatusCode() != http.StatusNoContent {
return fmt.Errorf("CXone PUT error: %s %s", resp.Status(), string(resp.Body()))
fmt.Printf("Filter updated successfully in %v\n", duration)
return nil
The PUT request replaces the filter atomically. The payload includes the sip-ref reference, voice-matrix configuration, and the filter directive. The code measures latency for audit tracking and retries on 429 responses. The response cycle expects 200 OK or 204 No Content with an empty body or updated filter representation.
Step 4: Webhook Handler for External SBC Sync & Latency Tracking
External SBC gateways require alignment when SIP headers change. The service exposes an HTTP endpoint that accepts CXone header modified webhooks, validates the event, synchronizes with the external gateway, and records audit logs with latency and success rates.
package webhook
import (
"encoding/json"
"log/slog"
"net/http"
"sync"
"time"
type WebhookEvent struct {
EventID string `json:"eventId"`
FilterID string `json:"filterId"`
type AuditLogger struct {
mu sync.Mutex
totalEvents int
successCount int
func NewAuditLogger() *AuditLogger {
return &AuditLogger{}
func (al *AuditLogger) Log(event WebhookEvent, success bool, latency time.Duration) {
al.mu.Lock()
defer al.mu.Unlock()
al.totalEvents++
if success {
al.successCount++
rate := 0.0
if al.totalEvents > 0 {
rate = float64(al.successCount) / float64(al.totalEvents) * 100
slog.Info("SIP header intercept audit",
"eventId", event.EventID,
"filterId", event.FilterID,
"header", event.HeaderName,
"action", event.Action,
"latency_ms", latency.Milliseconds(),
"success", success,
"success_rate_pct", rate)
func HandleWebhook(logger *AuditLogger) http.HandlerFunc {
return func(w http.ResponseWriter, r *http.Request) {
start := time.Now()
if r.Method != http.MethodPost {
http.Error(w, "Method not allowed", http.StatusMethodNotAllowed)
return
var event WebhookEvent
if err := json.NewDecoder(r.Body).Decode(&event); err != nil {
http.Error(w, "Invalid JSON payload", http.StatusBadRequest)
return
// Simulate external SBC gateway synchronization
sbcSyncSuccess := true // Replace with actual SBC API call
if !sbcSyncSuccess {
logger.Log(event, false, time.Since(start))
http.Error(w, "SBC sync failed", http.StatusInternalServerError)
return
logger.Log(event, true, time.Since(start))
w.WriteHeader(http.StatusOK)
w.Write([]byte(`{"status": "synced"}`))
The webhook handler decodes the WebhookEvent, validates the structure, simulates SBC gateway alignment, and records an audit log with latency and filter success rates. The slog package provides structured output for voice governance compliance. The success rate calculation updates atomically per request.
package main
import (
"context"
"fmt"
"log/slog"
"net/http"
"os"
"time"
"yourmodule/auth"
"yourmodule/cxone"
"yourmodule/webhook"
func main() {
clientID := os.Getenv("CXONE_CLIENT_ID")
clientSecret := os.Getenv("CXONE_CLIENT_SECRET")
orgURL := os.Getenv("CXONE_ORG_URL")
if clientID == "" || clientSecret == "" || orgURL == "" {
slog.Error("Missing environment variables: CXONE_CLIENT_ID, CXONE_CLIENT_SECRET, CXONE_ORG_URL")
os.Exit(1)
tokenMgr := auth.NewTokenManager(clientID, clientSecret, orgURL)
httpClient := resty.New().SetTimeout(15 * time.Second)
ctx := context.Background()
token, err := tokenMgr.GetToken(ctx)
if err != nil {
slog.Error("Failed to obtain OAuth token", "error", err)
os.Exit(1)
// Fetch existing filters
filters, err := cxone.FetchFilterMatrix(ctx, httpClient, orgURL, token.AccessToken)
if err != nil {
slog.Error("Failed to fetch filter matrix", "error", err)
os.Exit(1)
if len(filters) == 0 {
slog.Warn("No SIP filters found in voice-matrix")
// Update first filter as demonstration
if len(filters) > 0 {
directive := cxone.FilterDirective{
HeaderName: "X-Custom-Interceptor",
HeaderValue: "secure-route-01",
Action: "MODIFY",
Condition: "INVITE",
err = cxone.UpdateSIPFilter(ctx, httpClient, orgURL, token.AccessToken, filters[0].ID, directive, 10)
if err != nil {
slog.Error("Failed to update SIP filter", "error", err)
// Start webhook server for external SBC alignment
logger := webhook.NewAuditLogger()
http.HandleFunc("/webhooks/cxone/sip-headers", webhook.HandleWebhook(logger))
slog.Info("Webhook server listening on :8080")
if err := http.ListenAndServe(":8080", nil); err != nil {
slog.Error("HTTP server failed", "error", err)
os.Exit(1)
The complete example initializes the OAuth manager, fetches the filter matrix, applies a validated header intercept directive, and starts a webhook listener. Replace the environment variables with your CXone credentials. The service runs as a standalone binary or container.
- Cause: Expired OAuth token, missing
voice:sip:readorvoice:sip:writescope, or incorrect client credentials. - Fix: Verify the token manager refreshes before expiry. Check the CXone security profile assigned to the OAuth client.
- Code showing the fix:
if resp.StatusCode() == http.StatusUnauthorized {
token, err = tokenMgr.GetToken(ctx)
if err != nil {
return fmt.Errorf("token refresh failed: %w", err)
// Retry request with new token
Error: 403 Forbidden
- Cause: The OAuth client lacks organization-level permissions for Voice API configuration.
- Fix: Assign the
Voice API AdministratororSIP Configurationrole to the OAuth client in the CXone admin console. - Code showing the fix: No code change required. Update the security profile and regenerate credentials.
- Cause: Exceeding CXone rate limits for SIP filter updates.
- Fix: Implement exponential backoff and respect the
Retry-Afterheader. - Code showing the fix: Already implemented in
FetchFilterMatrixandUpdateSIPFilterwithRetry-Afterparsing and sleep delays.
Error: 400 Bad Request
- Cause: Malformed SIP header payload, invalid
maximumHeaderLength, or missing required fields in the filter directive. - Fix: Run the payload through the
validator.ValidateSIPHeaderfunction before submission. Ensure the JSON structure matches CXone schema requirements. - Code showing the fix:
return fmt.Errorf("validation rejected payload: %w", err)
Error: 5xx Server Error
- Cause: CXone platform maintenance or internal routing engine failure.
- Fix: Retry with exponential backoff up to three times. Log the request ID from the response headers for support tickets.
if resp.StatusCode() >= 500 {
requestID := resp.Header().Get("X-Request-Id")
slog.Warn("CXone server error, retrying", "status", resp.StatusCode(), "requestId", requestID)
time.Sleep(2 * time.Second)
// Retry logic here
