Intercepting NICE CXone Outbound Dial Attempts with Python
A Python module that queries active outbound attempts, constructs intercept payloads with attempt ID references and hold directives, validates them against dialing engine constraints, and executes atomic PATCH operations to override call control. It synchronizes intercept events with external CDR processors via webhooks, tracks latency and success rates, and generates audit logs for campaign governance.
  • NICE CXone API key pair (client ID and client secret)
  • OAuth scopes: outbound:read, outbound:write, campaign:read, attempt:write
  • Python 3.9 or higher
  • External dependencies: httpx, pydantic, structlog
  • Install dependencies: pip install httpx pydantic structlog
NICE CXone uses OAuth 2.0 client credentials flow. The authentication module fetches an access token, caches it in memory, and refreshes it before expiration. The token endpoint requires basic authentication with the client ID and secret.
import httpx
from typing import Optional
class CXoneAuth:
    def __init__(self, client_id: str, client_secret: str, base_url: str):
        self.client_id = client_id
        self.expiry: float = 0.0
        self.client = httpx.Client()
    def _get_token(self) -> str:
        url = f"{self.base_url}/api/v2/oauth/token"
        data = {
            "client_id": self.client_id,
            "scope": "outbound:read outbound:write campaign:read attempt:write"
        response = self.client.post(url, headers=headers, data=data)
        response.raise_for_status()
        payload = response.json()
        self.token = payload["access_token"]
        self.expiry = time.time() + payload["expires_in"]
        return self.token
        if not self.token or time.time() >= self.expiry - 60:
            self._get_token()
            "Authorization": f"Bearer {self.token}",
            "Accept": "application/json"
The _get_token method handles token acquisition. The get_headers method checks expiration and refreshes the token automatically. This prevents 401 Unauthorized errors during long-running intercept loops.
Step 1: Query Active Attempts and Validate Interception Window
The outbound campaign API returns attempts via paginated GET requests. Each attempt contains a dialingEngineStatus and interceptWindowLimit. You must filter attempts that fall within the valid interception window before constructing payloads.
import httpx
import logging
logger = logging.getLogger("cxone_interceptor")
def fetch_active_attempts(client: httpx.Client, headers: dict, campaign_id: str) -> List[Dict[str, Any]]:
    attempts = []
    page = 1
    page_size = 25
    while True:
        url = f"{client.base_url}/api/v2/outbound/campaigns/{campaign_id}/attempts"
        params = {
            "page": page,
            "pageSize": page_size,
            "status": "RINGING,ANSWERED,IN_PROGRESS",
            "sort": "createdTime DESC"
        response = client.get(url, headers=headers, params=params)
        data = response.json()
        if not data.get("entities"):
            break
        for entity in data["entities"]:
            created = entity.get("createdTime", "")
            window_limit = entity.get("interceptWindowLimit", 30)
            # Validate interception window constraint
            if _is_within_window(created, window_limit):
                attempts.append(entity)
        if page >= data.get("pageCount", 1):
            break
        page += 1
    return attempts
def _is_within_window(created_time: str, window_seconds: int) -> bool:
    created = datetime.fromisoformat(created_time.replace("Z", "+00:00"))
    now = datetime.now(timezone.utc)
    elapsed = (now - created).total_seconds()
    return elapsed <= window_seconds
The pagination loop respects pageCount and filters by status. The _is_within_window function prevents intercepting attempts that have already passed the dialing engine constraint. The API returns a realistic response structure with entities, pageCount, and pageSize.
Step 2: Construct and Validate Intercept Payload Against Dialing Engine Constraints
Intercept payloads require explicit attempt ID references, a status matrix, and a hold directive. You must validate the schema before submission to avoid 400 Bad Request errors from the dialing engine.
from pydantic import BaseModel, Field, field_validator
from typing import Literal
class InterceptPayload(BaseModel):
    attemptId: str
    intercept: dict = Field(
        description="Dialing engine override configuration"
    status: Literal["INTERCEPTED", "HOLD", "RINGBACK"]
    hold: bool = False
    ringbackTrigger: bool = False
    @field_validator("intercept")
    @classmethod
    def validate_intercept_schema(cls, v: dict) -> dict:
        required_keys = {"enabled", "priority", "overrideReason"}
        if not required_keys.issubset(v.keys()):
            raise ValueError("Intercept object must contain enabled, priority, and overrideReason")
        if not isinstance(v.get("enabled"), bool):
            raise ValueError("Intercept.enabled must be a boolean")
        return v
def build_intercept_payload(attempt: Dict[str, Any], hold_directive: bool = False) -> InterceptPayload:
    return InterceptPayload(
        attemptId=attempt["id"],
        intercept={
            "enabled": True,
            "priority": 1,
            "overrideReason": "AUTOMATED_SCALE_INTERCEPT"
        status="HOLD" if hold_directive else "INTERCEPTED",
        hold=hold_directive,
        ringbackTrigger=not hold_directive
The InterceptPayload model enforces schema validation. The field_validator checks for required dialing engine keys. The build_intercept_payload function maps attempt data to the validated structure. This prevents malformed payloads from reaching the PATCH endpoint.
Step 3: Execute Atomic PATCH Override with Ringback Generation Triggers
The intercept override uses an atomic PATCH request. You must verify the response format and trigger automatic ringback generation if the intercept succeeds. The PATCH operation updates the attempt state in the dialing engine.
def execute_intercept_override(
    headers: dict,
    campaign_id: str,
    attempt_id: str,
    payload: InterceptPayload
) -> Dict[str, Any]:
    url = f"{client.base_url}/api/v2/outbound/campaigns/{campaign_id}/attempts/{attempt_id}"
    response = client.patch(url, headers=headers, json=payload.model_dump())
    result = response.json()
    # Verify format and trigger ringback if configured
    if payload.ringbackTrigger and result.get("status") == "INTERCEPTED":
        trigger_ringback(client, headers, campaign_id, attempt_id)
    logger.info(
        "Intercept override executed",
        attempt_id=attempt_id,
        latency_ms=latency_ms,
        status=result.get("status")
    return result
def trigger_ringback(client: httpx.Client, headers: dict, campaign_id: str, attempt_id: str):
    ringback_url = f"{client.base_url}/api/v2/outbound/campaigns/{campaign_id}/attempts/{attempt_id}/ringback"
    ringback_payload = {"generate": True, "reason": "INTERCEPT_OVERRIDE"}
    client.post(ringback_url, headers=headers, json=ringback_payload)
The execute_intercept_override function measures latency and validates the response. The trigger_ringback function sends a POST to the ringback sub-resource. The PATCH operation is atomic, meaning partial failures roll back automatically.
Step 4: Synchronize Intercept Events with External CDR Processors via Webhooks
External CDR processors require aligned intercept events. You must push attempt intercepted webhooks to your CDR endpoint after successful overrides. The webhook payload includes SIP response codes and carrier rejection flags.
def sync_cdr_webhook(
    cdr_endpoint: str,
    intercept_result: Dict[str, Any],
    latency_ms: float
) -> bool:
    webhook_payload = {
        "event": "ATTEMPT_INTERCEPTED",
        "attemptId": attempt["id"],
        "campaignId": attempt.get("campaignId"),
        "sipResponseCode": attempt.get("sipResponseCode", 0),
        "carrierRejection": attempt.get("carrierRejection", False),
        "interceptStatus": intercept_result.get("status"),
        "latencyMs": latency_ms,
        "timestamp": time.strftime("%Y-%m-%dT%H:%M:%SZ", time.gmtime())
        response = client.post(cdr_endpoint, json=webhook_payload)
        logger.info("CDR webhook synchronized", attempt_id=attempt["id"])
        return True
        logger.error("CDR webhook failed", status_code=e.response.status_code, attempt_id=attempt["id"])
        return False
The sync_cdr_webhook function constructs a standardized event payload. It includes sipResponseCode and carrierRejection fields for pipeline verification. The function returns a boolean status for audit tracking.
Step 5: Track Latency, Override Success Rates, and Generate Audit Logs
Campaign governance requires intercept efficiency metrics. You must aggregate latency, success rates, and override outcomes into structured audit logs. The logging module formats outputs as JSON for downstream analytics.
import json
import structlog
class InterceptAuditor:
    def __init__(self):
        self.success_count = 0
        self.failure_count = 0
        self.latencies = []
        self.audit_log = []
    def record(self, attempt_id: str, success: bool, latency_ms: float, reason: str):
        self.latencies.append(latency_ms)
        if success:
            self.success_count += 1
        else:
            self.failure_count += 1
        entry = {
            "attemptId": attempt_id,
            "success": success,
            "reason": reason,
        self.audit_log.append(entry)
    def get_metrics(self) -> dict:
        avg_latency = sum(self.latencies) / len(self.latencies) if self.latencies else 0
            "totalIntercepts": total,
            "successRate": self.success_count / total if total > 0 else 0,
            "averageLatencyMs": round(avg_latency, 2),
            "auditEntries": len(self.audit_log)
    def export_audit(self) -> list:
        return self.audit_log
The InterceptAuditor class tracks metrics and maintains an audit trail. The get_metrics method calculates success rates and average latency. The export_audit method returns the full log for governance compliance.
import httpx
import logging
import structlog
# Configure logging
logging.basicConfig(level=logging.INFO, format="%(message)s")
structlog.configure(
    processors=[
        structlog.processors.add_log_level,
        structlog.processors.JSONRenderer()
    logger_factory=structlog.PrintLoggerFactory()
def run_interceptor(client_id: str, client_secret: str, base_url: str, campaign_id: str, cdr_endpoint: str):
    auth = CXoneAuth(client_id, client_secret, base_url)
    headers = auth.get_headers()
    client = httpx.Client(base_url=base_url)
    auditor = InterceptAuditor()
    attempts = fetch_active_attempts(client, headers, campaign_id)
    logger.info("Fetched active attempts", count=len(attempts))
    for attempt in attempts:
            payload = build_intercept_payload(attempt, hold_directive=True)
            start = time.perf_counter()
            result = execute_intercept_override(client, headers, campaign_id, attempt["id"], payload)
            latency = (time.perf_counter() - start) * 1000
            success = result.get("status") in ["INTERCEPTED", "HOLD"]
            auditor.record(attempt["id"], success, latency, "HOLD_DIRECTIVE")
            if success:
                sync_cdr_webhook(client, cdr_endpoint, attempt, result, latency)
            logger.error("Intercept failed", status_code=e.response.status_code, attempt_id=attempt["id"])
            auditor.record(attempt["id"], False, 0, f"HTTP_{e.response.status_code}")
            logger.error("Unexpected error", error=str(e), attempt_id=attempt["id"])
            auditor.record(attempt["id"], False, 0, "UNEXPECTED_ERROR")
    metrics = auditor.get_metrics()
    logger.info("Interceptor run complete", metrics=metrics)
    return auditor.export_audit()
    # Replace with actual credentials
    run_interceptor(
        client_id="YOUR_CLIENT_ID",
        client_secret="YOUR_CLIENT_SECRET",
        base_url="https://api-us-east-1.oc.nice-in接触.com",
        campaign_id="YOUR_CAMPAIGN_ID",
        cdr_endpoint="https://your-cdr-processor.example.com/webhooks/cxone-intercept"
The complete example initializes authentication, fetches attempts, validates payloads, executes overrides, synchronizes webhooks, and exports audit logs. Replace placeholder credentials with your CXone environment values. The script runs synchronously for simplicity but can be wrapped in asyncio for high-throughput campaigns.
Error: 409 Conflict
The dialing engine rejects the intercept because the attempt window has expired or the attempt is already in a terminal state. Verify interceptWindowLimit against createdTime. Ensure your validation logic filters out attempts that exceed the window.
if elapsed > window_limit:
    logger.warning("Attempt outside intercept window", attempt_id=attempt["id"], elapsed=elapsed)
The outbound API enforces rate limits per tenant. Implement exponential backoff with jitter for retry logic. The CXone API returns Retry-After headers.
import random
def retry_on_429(func, *args, max_retries=3, **kwargs):
            return func(*args, **kwargs)
            if e.response.status_code == 429:
                retry_after = float(e.response.headers.get("Retry-After", 2 ** attempt))
                jitter = random.uniform(0, 0.5)
                time.sleep(retry_after + jitter)
            else:
                raise
    raise Exception("Max retries exceeded for 429")
Error: 400 Bad Request
The intercept payload fails schema validation. The dialing engine requires exact field names and types. Use Pydantic validation before sending. Check that intercept.enabled is a boolean and overrideReason matches allowed values.
Error: SIP 486 Busy Here or 488 Not Acceptable Here
Carrier rejection pipelines return SIP response codes in the attempt payload. Your intercept logic should skip attempts with sipResponseCode in 486, 488, 408. This prevents wasted trunks during scaling.
if attempt.get("sipResponseCode") in [486, 488, 408]:
    logger.info("Skipping carrier rejected attempt", attempt_id=attempt["id"])
