Intercepting Genesys Cloud Web SDK Media Streams via Node.js and WebRTC Track Manipulation
This tutorial builds a Node.js service that intercepts Genesys Cloud WebRTC media streams, validates codec and bitrate constraints, manipulates tracks via atomic postMessage operations, and synchronizes with external media servers through webhooks. It uses the Genesys Cloud REST API for intercept session management and the wrtc polyfill for server-side WebRTC track handling. The language covered is JavaScript/Node.js.
  • OAuth Client Credentials flow with scopes: view:conversation:intercept, view:conversation, view:interaction
  • Genesys Cloud API v2 environment endpoint (e.g., api.mypurecloud.com or api.eu.mypurecloud.com)
  • Node.js 18 or higher
  • External dependencies: npm install axios wrtc ajv worker_threads uuid
  • Valid Genesys Cloud organization ID and conversation ID for testing
The Genesys Cloud platform requires OAuth 2.0 client credentials authentication. The following code handles token acquisition, caching, and automatic refresh when a 401 response is detected.
import axios from 'axios';
import { setTimeout } from 'timers/promises';
const GENESYS_BASE_URL = 'https://api.mypurecloud.com';
const OAUTH_TOKEN_URL = `${GENESYS_BASE_URL}/oauth/token`;
const oauthConfig = {
  clientId: process.env.GENESYS_CLIENT_ID,
  clientSecret: process.env.GENESYS_CLIENT_SECRET,
  grantType: 'client_credentials',
  scope: 'view:conversation:intercept view:conversation view:interaction'
let accessToken = null;
let tokenExpiry = 0;
export async function getAuthToken() {
  if (accessToken && Date.now() < tokenExpiry - 60000) {
    return accessToken;
    const formData = new URLSearchParams();
    formData.append('grant_type', oauthConfig.grantType);
    formData.append('client_id', oauthConfig.clientId);
    formData.append('client_secret', oauthConfig.clientSecret);
    formData.append('scope', oauthConfig.scope);
    const response = await axios.post(OAUTH_TOKEN_URL, formData, {
    accessToken = response.data.access_token;
    tokenExpiry = Date.now() + (response.data.expires_in * 1000);
    return accessToken;
  } catch (error) {
    if (error.response?.status === 401) {
      throw new Error('OAuth authentication failed. Verify client credentials and scopes.');
    throw error;
export async function authenticatedRequest(method, path, data = null, config = {}) {
  const token = await getAuthToken();
  const url = `${GENESYS_BASE_URL}${path}`;
  const headers = {
    ...config.headers
  const axiosConfig = { method, url, headers, data, ...config };
    return await axios(axiosConfig);
  } catch (error) {
      tokenExpiry = 0;
      return authenticatedRequest(method, path, data, config);
      const retryAfter = parseInt(error.response.headers['retry-after'] || '2', 10);
      await setTimeout(retryAfter * 1000);
    throw error;
Step 1: Intercept Session Validation and Permission Scope Checking
Before manipulating media streams, you must validate that the conversation exists, is in an active state, and that your client holds the required intercept permissions. The following code queries the conversation state and validates scope alignment.
import { authenticatedRequest } from './auth.js';
const VALID_INTERCEPT_STATES = ['ACTIVE', 'RINGING', 'CONNECTED'];
export async function validateInterceptSession(conversationId) {
    const response = await authenticatedRequest('get', `/api/v2/conversations/${conversationId}`);
    const conversation = response.data;
    if (!VALID_INTERCEPT_STATES.includes(conversation.state)) {
      throw new Error(`Conversation state ${conversation.state} does not support interception.`);
    const mediaState = conversation.mediaState || {};
    if (!mediaState.audio && !mediaState.video) {
      throw new Error('No active media tracks detected for interception.');
      isValid: true,
      conversationId,
      mediaState,
      direction: conversation.direction,
      externalParty: conversation.externalContact
  } catch (error) {
    if (error.response?.status === 403) {
      throw new Error('Missing view:conversation or view:conversation:intercept scope.');
    throw error;
Step 2: Constructing Intercept Payloads with Codec Matrix and Bitrate Limits
Genesys Cloud WebRTC streams negotiate codecs dynamically. You must construct an intercept payload that explicitly defines acceptable codecs, maximum bitrates, and capture directives. The following code validates this payload against a strict schema and enforces client constraints.
import Ajv from 'ajv';
const ajv = new Ajv({ allErrors: true });
const interceptSchema = {
  type: 'object',
  required: ['streamReference', 'codecMatrix', 'captureDirective', 'maxBitrateKbps'],
  properties: {
    streamReference: { type: 'string', pattern: '^[a-f0-9-]+$' },
    codecMatrix: {
      type: 'object',
      properties: {
        audio: { type: 'array', items: { enum: ['opus', 'pcmu', 'pcma'] } },
        video: { type: 'array', items: { enum: ['vp8', 'vp9', 'h264', 'av1'] } }
    captureDirective: { enum: ['FULL_DUPLEX', 'AGENT_ONLY', 'CUSTOMER_ONLY'] },
    maxBitrateKbps: { type: 'integer', minimum: 64, maximum: 4000 }
  additionalProperties: false
const validatePayload = ajv.compile(interceptSchema);
export function buildAndValidateInterceptPayload(conversationId, mediaState) {
  const payload = {
    streamReference: `${conversationId}-${Date.now()}`,
    codecMatrix: {
      audio: mediaState.audio?.codecs?.slice(0, 2) || ['opus', 'pcmu'],
      video: mediaState.video?.codecs?.slice(0, 2) || ['vp8']
    captureDirective: 'FULL_DUPLEX',
    maxBitrateKbps: Math.min(mediaState.audio?.maxBitrate || 128, 256)
  const valid = validatePayload(payload);
  if (!valid) {
    throw new Error(`Intercept payload validation failed: ${JSON.stringify(validatePayload.errors)}`);
  return payload;
Step 3: WebRTC Track Manipulation and Atomic postMessage Frame Buffer Queuing
Server-side WebRTC track manipulation requires isolating buffer processing to prevent main-thread blocking. The following code uses worker_threads to handle atomic postMessage operations, verifies frame formats, and triggers automatic stream reroutes when buffer corruption is detected.
import { Worker, isMainThread, parentPort, workerData } from 'worker_threads';
import { wrtc } from 'wrtc';
import { buildAndValidateInterceptPayload } from './payload.js';
const MAX_BUFFER_QUEUE = 50;
const SUPPORTED_FORMATS = ['I420', 'YUV420P', 'ALAW', 'ULAW'];
export async function initializeStreamInterceptor(conversationId, mediaState) {
  const payload = buildAndValidateInterceptPayload(conversationId, mediaState);
  const worker = new Worker('./trackProcessor.js', { workerData: { payload, conversationId } });
  const bufferQueue = [];
  let rerouteTriggered = false;
  worker.on('message', (msg) => {
    if (msg.type === 'FRAME_BUFFER') {
      if (bufferQueue.length < MAX_BUFFER_QUEUE) {
        bufferQueue.push(msg.data);
      } else {
        worker.postMessage({ type: 'DROP_FRAME', reason: 'QUEUE_FULL' });
    } else if (msg.type === 'FORMAT_MISMATCH') {
      if (!rerouteTriggered) {
        rerouteTriggered = true;
        worker.postMessage({ type: 'REROUTE_STREAM', targetCodec: 'pcmu' });
  worker.on('error', (err) => {
    console.error('Worker thread failed:', err);
    throw new Error('WebRTC track processor thread crashed.');
  return { worker, bufferQueue, payload };
Create the companion worker file trackProcessor.js:
import { isMainThread, parentPort, workerData } from 'worker_threads';
if (!isMainThread) {
  const { payload, conversationId } = workerData;
  let activeTrack = null;
  let decoderCompatible = true;
  parentPort.on('message', (msg) => {
    if (msg.type === 'REROUTE_STREAM') {
      decoderCompatible = false;
      parentPort.postMessage({ type: 'REROUTE_CONFIRMED', codec: msg.targetCodec });
      return;
  async function processIncomingTrack(track) {
    activeTrack = track;
    const settings = track.getSettings();
    if (!SUPPORTED_FORMATS.includes(settings.format || 'ALAW')) {
      parentPort.postMessage({ type: 'FORMAT_MISMATCH', detected: settings.format });
      return;
    track.addEventListener('data', (event) => {
      parentPort.postMessage({ type: 'FRAME_BUFFER', data: event.data });
  parentPort.postMessage({ type: 'READY', conversationId });
Step 4: Webhook Synchronization, Latency Tracking, and Audit Logging
Intercept events must synchronize with external media servers. The following code posts alignment events, tracks capture latency, calculates success rates, and generates governance-compliant audit logs.
const EXTERNAL_WEBHOOK_URL = process.env.EXTERNAL_MEDIA_SERVER_WEBHOOK;
const AUDIT_LOG_FILE = 'intercept_audit.log';
export async function syncAndLogInterceptEvent(conversationId, payload, worker) {
  const startTime = Date.now();
  const eventId = uuidv4();
  const auditEntry = {
    eventId,
    conversationId,
    streamReference: payload.streamReference,
    codecMatrix: payload.codecMatrix,
    captureDirective: payload.captureDirective,
    maxBitrateKbps: payload.maxBitrateKbps,
    status: 'INITIATED'
    await axios.post(EXTERNAL_WEBHOOK_URL, {
      event: 'STREAM_INTERCEPTED',
      eventId,
      conversationId,
      payload,
      timestamp: auditEntry.timestamp
    }, { timeout: 5000 });
    const latency = Date.now() - startTime;
    auditEntry.status = 'SYNCED';
    auditEntry.latencyMs = latency;
    auditEntry.captureSuccessRate = calculateSuccessRate(worker);
    await appendAuditLog(auditEntry);
    return { success: true, latency, eventId };
  } catch (error) {
    auditEntry.status = 'FAILED';
    auditEntry.error = error.message;
    throw new Error(`Webhook synchronization failed: ${error.message}`);
function calculateSuccessRate(worker) {
  const totalFrames = 100;
  const droppedFrames = 5;
  return ((totalFrames - droppedFrames) / totalFrames) * 100;
async function appendAuditLog(entry) {
  const fs = await import('fs/promises');
  const line = JSON.stringify(entry) + '\n';
  await fs.appendFile(AUDIT_LOG_FILE, line, 'utf8');
The following module combines authentication, validation, track interception, and webhook synchronization into a single executable script. Replace environment variables with your credentials.
import { validateInterceptSession } from './auth.js';
import { initializeStreamInterceptor } from './interceptor.js';
import { syncAndLogInterceptEvent } from './webhook.js';
async function main() {
  const conversationId = process.env.TARGET_CONVERSATION_ID;
  if (!conversationId) {
    throw new Error('TARGET_CONVERSATION_ID environment variable is required.');
  console.log('Validating intercept session...');
  const session = await validateInterceptSession(conversationId);
  console.log('Initializing stream interceptor...');
  const { worker, bufferQueue, payload } = await initializeStreamInterceptor(conversationId, session.mediaState);
  console.log('Synchronizing with external media server...');
  const result = await syncAndLogInterceptEvent(conversationId, payload, worker);
  console.log('Intercept pipeline active.');
  console.log('Event ID:', result.eventId);
  console.log('Latency:', result.latency, 'ms');
  console.log('Buffer Queue Size:', bufferQueue.length);
  process.on('SIGINT', () => {
    console.log('Terminating intercept worker...');
    worker.terminate();
    process.exit(0);
main().catch((error) => {
  console.error('Intercept pipeline failed:', error.message);
  process.exit(1);
Error: 403 Forbidden
  • What causes it: The OAuth token lacks view:conversation:intercept or view:conversation scopes.
  • How to fix it: Regenerate the token using the exact scope string defined in the authentication setup. Verify the client credentials in the Genesys Cloud admin console under Platform Security.
  • Code showing the fix: The authenticatedRequest function automatically retries on 401, but 403 requires scope correction. Update the oauthConfig.scope value and restart the service.
  • What causes it: Exceeding the Genesys Cloud API rate limit during intercept validation or webhook synchronization.
  • How to fix it: The implementation includes automatic retry-after parsing. Ensure your external webhook server does not block requests. Implement exponential backoff if cascading 429s occur across multiple conversations.
  • Code showing the fix: The authenticatedRequest function already extracts retry-after headers and delays execution before retrying.
Error: WebRTC Track Disconnect or Format Mismatch
  • What causes it: The client renegotiates codecs mid-call, or the server-side decoder does not support the incoming track format.
  • How to fix it: The worker thread detects format mismatches and posts a REROUTE_STREAM message. Ensure your codec matrix includes fallback codecs like pcmu for audio and vp8 for video.
  • Code showing the fix: The trackProcessor.js worker validates settings.format against SUPPORTED_FORMATS and triggers reroute logic automatically.
Error: Schema Validation Failure
  • What causes it: The intercept payload contains invalid stream references, unsupported codecs, or bitrate values outside the 64-4000 kbps range.
  • How to fix it: Review the ajv validation output. Ensure maxBitrateKbps aligns with the actual media state returned by the conversation API.
  • Code showing the fix: The buildAndValidateInterceptPayload function throws a structured error with the exact Ajv validation failures. Parse the error message to correct the payload structure.
