Intercepting Genesys Cloud Web Messaging Guest API Incoming Messages with Node.js
A Node.js message interceptor that captures incoming guest web messages via WebSocket, validates payloads against constraints, applies rate limiting and profanity detection, blocks malicious content, synchronizes with an external UI via webhooks, tracks latency and success metrics, and generates audit logs. This uses the Genesys Cloud Web Messaging Guest API and WebSocket endpoints. This covers Node.js.
  • OAuth 2.0 client credentials flow with scopes: webchat:read webchat:write webchat:guest
  • Genesys Cloud Node SDK genesys-cloud-node-sdk v4.x
  • Node.js 18 LTS or higher
  • External dependencies: npm install genesys-cloud-node-sdk ws axios ajv uuid pino
The interceptor requires a valid OAuth 2.0 access token before establishing WebSocket connections or making REST calls. The following code implements the client credentials flow with token caching and automatic refresh logic.
const { v4: uuidv4 } = require('uuid');
class OAuthManager {
  constructor(clientId, clientSecret, orgUrl) {
    this.clientId = clientId;
    this.tokenUrl = `${orgUrl}/api/v2/oauth/token`;
    this.token = null;
    this.expiresAt = 0;
  async getAccessToken() {
    if (this.token && Date.now() < this.expiresAt - 60000) {
      return this.token;
    const payload = new URLSearchParams({
      client_id: this.clientId,
      client_secret: this.clientSecret,
      scope: 'webchat:read webchat:write webchat:guest'
      const response = await axios.post(this.tokenUrl, payload, {
      this.token = response.data.access_token;
      this.expiresAt = Date.now() + (response.data.expires_in * 1000);
      return this.token;
    } catch (error) {
      if (error.response && error.response.status === 401) {
        throw new Error('OAuth authentication failed. Verify client credentials.');
      throw new Error(`Token acquisition failed: ${error.message}`);
// HTTP Request/Response Cycle Example:
// POST /api/v2/oauth/token
// Headers: Content-Type: application/x-www-form-urlencoded
// Body: grant_type=client_credentials&client_id=YOUR_ID&client_secret=YOUR_SECRET&scope=webchat:read%20webchat:write%20webchat:guest
// Response 200:
//   "access_token": "eyJhbGciOiJIUzI1NiIs...",
//   "token_type": "bearer",
//   "expires_in": 28800,
//   "scope": "webchat:read webchat:write webchat:guest"
Step 1: Atomic WebSocket OPEN and Message Capture
Genesys Cloud Web Messaging uses a secure WebSocket endpoint for real-time guest message delivery. The connection must be opened atomically with format verification to prevent handshake failures. The following code establishes the connection, handles authentication headers, and captures incoming messages.
const WebSocket = require('ws');
class MessageCapture {
  constructor(oauthManager, orgUrl, messagingMatrix) {
    this.oauthManager = oauthManager;
    this.wsUrl = `wss://webmessaging.${orgUrl.replace(/^https?:\/\//, '')}/api/v2/webchat/ws`;
    this.messagingMatrix = messagingMatrix;
    this.ws = null;
    this.reconnectAttempts = 0;
    this.maxReconnectAttempts = 5;
  async openConnection() {
    const token = await this.oauthManager.getAccessToken();
    this.ws = new WebSocket(this.wsUrl, {
      headers: {
        'X-Genesys-Request-Id': uuidv4()
    this.ws.on('open', () => {
      console.log('WebSocket OPEN: Atomic connection established');
    this.ws.on('message', async (data) => {
        const payload = JSON.parse(data.toString());
        await this.handleIncomingMessage(payload);
      } catch (error) {
        console.error('Message parsing failed:', error.message);
    this.ws.on('error', (error) => {
      console.error('WebSocket error:', error.message);
      this.handleReconnect();
    this.ws.on('close', (code, reason) => {
      console.log(`WebSocket closed: ${code} - ${reason}`);
  handleReconnect() {
    if (this.reconnectAttempts < this.maxReconnectAttempts) {
      const delay = Math.min(1000 * Math.pow(2, this.reconnectAttempts), 30000);
      this.reconnectAttempts++;
      console.log(`Reconnecting in ${delay}ms (attempt ${this.reconnectAttempts})`);
      setTimeout(() => this.openConnection(), delay);
    } else {
      console.error('Max reconnect attempts reached. Stopping interceptor.');
Step 2: Payload Validation and Rate Limiting Evaluation
Incoming messages must pass through a validation pipeline that checks against messaging constraints and evaluates rate limits. This step prevents intercepting failure by rejecting malformed payloads before content inspection.
const Ajv = require('ajv');
const ajv = new Ajv({ allErrors: true });
const MESSAGE_SCHEMA = {
  type: 'object',
  required: ['messageRef', 'text', 'timestamp', 'guestId'],
  properties: {
    messageRef: { type: 'string', pattern: '^msg-[a-zA-Z0-9-]+$' },
    text: { type: 'string', maxLength: 2000 },
    timestamp: { type: 'number' },
    guestId: { type: 'string' },
    conversationId: { type: 'string' }
const MESSAGE_SCHEMA_VALIDATOR = ajv.compile(MESSAGE_SCHEMA);
class RateLimiter {
  constructor(maxRequests, windowMs) {
    this.maxRequests = maxRequests;
    this.windowMs = windowMs;
    this.requests = [];
  check() {
    const now = Date.now();
    this.requests = this.requests.filter(t => now - t < this.windowMs);
    if (this.requests.length >= this.maxRequests) {
      return false;
    this.requests.push(now);
    return true;
class ValidationPipeline {
  constructor(messagingConstraints, maxInterceptLatency) {
    this.constraints = messagingConstraints;
    this.maxLatency = maxInterceptLatency;
    this.rateLimiter = new RateLimiter(messagingConstraints.maxMessagesPerSecond, 1000);
  validate(payload, startTime) {
    const latency = Date.now() - startTime;
    if (latency > this.maxLatency) {
      throw new Error(`Maximum intercept latency exceeded: ${latency}ms > ${this.maxLatency}ms`);
    if (!this.rateLimiter.check()) {
      throw new Error('Rate limit exceeded. Message dropped to prevent 429 cascade.');
    const valid = MESSAGE_SCHEMA_VALIDATOR(payload);
    if (!valid) {
      throw new Error(`Schema validation failed: ${MESSAGE_SCHEMA_VALIDATOR.errors.map(e => e.message).join(', ')}`);
    if (payload.text.length > this.constraints.maxLength) {
      throw new Error('Message exceeds maximum length constraint.');
    return true;
Step 3: Content Inspection and Automatic Block Triggers
The capture directive requires content inspection calculation and profanity detection verification pipelines. This step implements safe chat environment enforcement by scanning message text and triggering automatic blocks when malicious input is detected.
class ContentInspector {
  constructor(profanityDictionary, customPatterns) {
    this.profanityDictionary = new Set(profanityDictionary);
    this.customPatterns = customPatterns.map(p => new RegExp(p, 'i'));
  inspect(text) {
    const normalizedText = text.toLowerCase().trim();
    const words = normalizedText.split(/\s+/);
    const profanityMatches = words.filter(w => this.profanityDictionary.has(w));
    const patternMatches = this.customPatterns.filter(p => p.test(text));
    const isBlocked = profanityMatches.length > 0 || patternMatches.length > 0;
      isBlocked,
      blockedReasons: [
        ...profanityMatches.map(w => `Profanity detected: "${w}"`),
        ...patternMatches.map(p => `Pattern match: ${p.source}`)
async function processMessageInterception(payload, validationPipeline, contentInspector, startTime) {
  validationPipeline.validate(payload, startTime);
  const inspectionResult = contentInspector.inspect(payload.text);
  if (inspectionResult.isBlocked) {
    console.log(`BLOCK TRIGGER: ${payload.messageRef} - ${inspectionResult.blockedReasons.join('; ')}`);
      action: 'BLOCKED',
      messageRef: payload.messageRef,
      reasons: inspectionResult.blockedReasons,
      timestamp: Date.now()
    action: 'ALLOWED',
Step 4: Webhook Synchronization, Latency Tracking, and Audit Logging
Intercepting events must synchronize with an external chat UI via message blocked webhooks. Latency tracking and capture success rates are recorded for intercept efficiency monitoring. Audit logs are generated for messaging governance compliance.
const pino = require('pino');
const logger = pino({ level: 'info', timestamp: () => `,"time":"${new Date().toISOString()}"` });
class InterceptorMetrics {
  constructor() {
    this.totalCaptured = 0;
    this.totalBlocked = 0;
    this.totalAllowed = 0;
    this.latencySum = 0;
    this.auditLogs = [];
  record(interceptResult, latencyMs) {
    this.totalCaptured++;
    this.latencySum += latencyMs;
    if (interceptResult.action === 'BLOCKED') {
      this.totalBlocked++;
    } else {
      this.totalAllowed++;
    const auditEntry = {
      messageId: interceptResult.messageRef,
      action: interceptResult.action,
      latencyMs,
      successRate: this.totalCaptured > 0 ? ((this.totalAllowed / this.totalCaptured) * 100).toFixed(2) + '%' : '0%'
    this.auditLogs.push(auditEntry);
    logger.info({ audit: auditEntry }, 'Intercept audit log generated');
  getMetrics() {
      totalCaptured: this.totalCaptured,
      totalBlocked: this.totalBlocked,
      totalAllowed: this.totalAllowed,
      averageLatencyMs: this.totalCaptured > 0 ? (this.latencySum / this.totalCaptured).toFixed(2) : 0,
      captureSuccessRate: this.totalCaptured > 0 ? ((this.totalAllowed / this.totalCaptured) * 100).toFixed(2) + '%' : '0%'
async function syncWebhook(interceptResult, webhookUrl) {
  if (!webhookUrl) return;
  const payload = {
    event: 'message:blocked',
    data: interceptResult,
    syncTimestamp: Date.now()
    await axios.post(webhookUrl, payload, {
      timeout: 5000
    logger.info({ messageId: interceptResult.messageRef }, 'Webhook synchronized successfully');
  } catch (error) {
      logger.warn('Webhook rate limited. Retrying with backoff.');
      setTimeout(() => syncWebhook(interceptResult, webhookUrl), 2000);
    } else {
      logger.error({ error: error.message }, 'Webhook synchronization failed');
The following module combines all components into a single, copy-pasteable interceptor service. Run this script after setting the required environment variables.
require('dotenv').config();
const { OAuthManager } = require('./oauth-manager');
const { MessageCapture } = require('./message-capture');
const { ValidationPipeline, ContentInspector, InterceptorMetrics } = require('./interceptor-core');
class GenesysMessageInterceptor {
  constructor() {
    this.oauthManager = new OAuthManager(
      process.env.GENESYS_CLIENT_ID,
      process.env.GENESYS_CLIENT_SECRET,
      process.env.GENESYS_ORG_URL
    this.messagingMatrix = {
      captureDirective: 'STRICT',
      maxInterceptLatency: 500,
      webhookUrl: process.env.EXTERNAL_CHAT_WEBHOOK_URL
    this.validationPipeline = new ValidationPipeline(
      { maxMessagesPerSecond: 10, maxLength: 1000 },
      this.messagingMatrix.maxInterceptLatency
    this.contentInspector = new ContentInspector(
      ['badword1', 'badword2', 'malicious'],
      ['\\d{4}[- ]\\d{4}[- ]\\d{4}']
    this.metrics = new InterceptorMetrics();
    this.captureService = new MessageCapture(this.oauthManager, process.env.GENESYS_ORG_URL, this.messagingMatrix);
  async handleIncomingMessage(payload) {
    const startTime = Date.now();
      const interceptResult = await processMessageInterception(
        payload,
        this.validationPipeline,
        this.contentInspector,
        startTime
      this.metrics.record(interceptResult, latency);
      if (interceptResult.action === 'BLOCKED' && this.messagingMatrix.webhookUrl) {
        await syncWebhook(interceptResult, this.messagingMatrix.webhookUrl);
      return interceptResult;
    } catch (error) {
      logger.error({ error: error.message, messageRef: payload.messageRef }, 'Interception pipeline failed');
      throw error;
  start() {
    console.log('Starting Genesys Cloud Web Messaging Interceptor...');
    this.captureService.openConnection();
    // Expose metrics endpoint for automated management
    const express = require('express');
    const app = express();
    app.get('/metrics', (req, res) => {
      res.json(this.metrics.getMetrics());
    app.listen(3000, () => {
      console.log('Interceptor management API listening on port 3000');
const interceptor = new GenesysMessageInterceptor();
interceptor.start();
  • Cause: OAuth token is expired, invalid, or missing required scopes.
  • Fix: Verify client_id and client_secret match the Genesys Cloud OAuth client configuration. Ensure the scope string includes webchat:read webchat:write webchat:guest. The OAuthManager automatically refreshes tokens before expiration.
  • Code showing the fix: The getAccessToken() method checks this.expiresAt - 60000 to proactively refresh before expiry. If the token is revoked, the method throws a clear error for credential rotation.
Error: 403 Forbidden
  • Cause: The OAuth client lacks permissions for the Web Messaging Guest API endpoints, or the WebSocket handshake rejects the Bearer token.
  • Fix: Navigate to the Genesys Cloud admin console and verify the OAuth client has the webchat API access enabled. Ensure the organization URL matches the token issuer domain.
  • Code showing the fix: The WebSocket constructor passes the token via the Authorization header. If rejected, the ws.on('error') handler triggers exponential backoff reconnection.
  • Cause: Rate limiting evaluation logic detected excessive message capture attempts or webhook synchronization calls.
  • Fix: Adjust maxMessagesPerSecond in the ValidationPipeline constructor. Implement exponential backoff for REST calls. The RateLimiter class enforces a sliding window to prevent cascade failures.
  • Code showing the fix: The RateLimiter.check() method filters requests older than the window and blocks new requests when the threshold is reached. The syncWebhook function catches 429 responses and retries after 2 seconds.
Error: WebSocket Connection Rejected or Format Verification Failure
  • Cause: Malformed WebSocket URL, missing X-Genesys-Request-Id header, or unsupported protocol version.
  • Fix: Construct the WebSocket URL using the exact pattern wss://webmessaging.{org}.mypurecloud.com/api/v2/webchat/ws. Ensure the request ID header is a valid UUID v4.
  • Code showing the fix: The MessageCapture class formats the URL dynamically and injects a UUID header during the atomic OPEN operation. Schema validation rejects payloads that do not match the MESSAGE_SCHEMA definition.
