Intercepting Genesys Cloud Web Messaging Bot Handoff Signals with Python SDK
  • A Python service that monitors active web messaging conversations, detects bot handoff triggers, validates session constraints, checks agent availability, and executes a safe reroute to a routing queue.
  • This implementation uses the Genesys Cloud v2 REST API surface exposed through the official Python SDK.
  • The code is written in Python 3.9+ using the genesyscloud SDK, httpx, and pydantic for schema validation.
  • OAuth 2.0 Client Credentials Flow: Service account with conversation:read, routing:queue:read, routing:user:read, webhook:write, and analytics:report:read scopes.
  • SDK Version: genesyscloud>=160.0.0
  • Runtime: Python 3.9 or higher
  • Dependencies: pip install genesyscloud httpx pydantic uuid
  • Environment Variables: GENESYS_CLOUD_REGION, GENESYS_CLOUD_CLIENT_ID, GENESYS_CLOUD_CLIENT_SECRET, EXTERNAL_WEBHOOK_URL
The Genesys Cloud Python SDK handles token acquisition and automatic refresh. You initialize the client with your service account credentials and region. The SDK caches the token in memory and refreshes before expiration.
from genesyscloud.platform_client_v2 import PureCloudPlatformClientV2
from genesyscloud.conversations.api import ConversationsApi
from genesyscloud.routing.api import RoutingQueuesApi, RoutingUsersApi
from genesyscloud.platformwebhooks.api import WebhooksApi
import os
def initialize_genesys_client() -> PureCloudPlatformClientV2:
    """Initializes the Genesys Cloud platform client with OAuth2 credentials."""
    region = os.environ.get("GENESYS_CLOUD_REGION", "mypurecloud.com")
    client_id = os.environ.get("GENESYS_CLOUD_CLIENT_ID")
    client_secret = os.environ.get("GENESYS_CLOUD_CLIENT_SECRET")
        raise ValueError("GENESYS_CLOUD_CLIENT_ID and GENESYS_CLOUD_CLIENT_SECRET are required.")
    platform_client = PureCloudPlatformClientV2(
        host=f"https://{region}",
        client_id=client_id,
        client_secret=client_secret
    return platform_client
Step 1: Fetch Active Web Messaging Conversations via Atomic GET
You retrieve active conversations using the Conversations API. The endpoint supports pagination and filtering by conversation type. You must handle 429 rate limits and validate the response schema.
Required Scope: conversation:read
Endpoint: GET /api/v2/conversations
from genesyscloud.api_exception import ApiException
from typing import List
def fetch_active_webmessaging_conversations(conversations_api: ConversationsApi) -> List:
    """Polls active webmessaging conversations with pagination and 429 retry logic."""
    active_conversations = []
    page_size = 50
    page_number = 1
    max_retries = 3
    while True:
        retries = 0
        while retries < max_retries:
                # GET /api/v2/conversations?type=webmessaging&pageSize=50&pageNumber=1
                response = conversations_api.get_conversations(
                    type="webmessaging",
                    page_size=page_size,
                    page_number=page_number,
                    expand=["participants", "customAttributes"]
                break
            except ApiException as e:
                if e.status == 429:
                    wait_time = 2 ** retries
                    print(f"Rate limited on conversations fetch. Retrying in {wait_time}s...")
                    time.sleep(wait_time)
                    retries += 1
                else:
                    raise
        if not response.entities:
            break
        active_conversations.extend(response.entities)
        if len(response.entities) < page_size:
            break
        page_number += 1
    return active_conversations
Step 2: Validate Handoff Triggers and Session Constraints
You evaluate whether a conversation requires human escalation. You check custom attributes for bot handoff signals, verify channel compatibility, and enforce maximum session timeout limits to prevent stale intercept attempts.
Validation Schema: Pydantic model for payload structure
from pydantic import BaseModel, Field, validator
from datetime import datetime, timezone, timedelta
class HandoffTriggerPayload(BaseModel):
    conversation_id: str
    signal_reference: str
    handoff_matrix: dict = Field(default_factory=dict)
    reroute_directive: str
    sentiment_score: float = Field(ge=-1.0, le=1.0)
    created_at: str
    @validator("reroute_directive")
    def validate_reroute_directive(cls, v):
        allowed = ["queue_transfer", "priority_escalation", "skill_based_routing"]
        if v not in allowed:
            raise ValueError(f"Invalid directive. Must be one of {allowed}")
        return v
def evaluate_handoff_trigger(conversation: dict, max_session_minutes: int = 30) -> dict | None:
    """Validates conversation state against handoff constraints and returns payload if valid."""
    custom_attrs = conversation.get("customAttributes", {})
    bot_handoff_flag = custom_attrs.get("bot.handoff.triggered")
    sentiment = custom_attrs.get("bot.sentiment.score")
    if not bot_handoff_flag or bot_handoff_flag != "true":
        return None
        created_dt = datetime.fromisoformat(conversation["createdDate"].replace("Z", "+00:00"))
        age_minutes = (datetime.now(timezone.utc) - created_dt).total_seconds() / 60
        if age_minutes > max_session_minutes:
            print(f"Conversation {conversation['id']} exceeded max session timeout. Skipping.")
            return None
    except (KeyError, ValueError):
        return None
        "conversation_id": conversation["id"],
        "signal_reference": f"webmessaging.handoff.{conversation['id']}",
        "handoff_matrix": {
            "priority": custom_attrs.get("routing.priority", "standard"),
            "skill": custom_attrs.get("routing.skill", "general_support")
        "reroute_directive": "queue_transfer",
        "sentiment_score": float(sentiment) if sentiment else 0.0,
        "created_at": conversation["createdDate"]
Step 3: Poll Agent Availability and Queue Capacity
You verify that the target routing queue has capacity before initiating the handoff. You use atomic GET operations to fetch queue configuration and active participant counts. You also check channel compatibility to ensure the queue accepts web messaging.
Required Scope: routing:queue:read
Endpoint: GET /api/v2/routing/queues/{queueId}
def validate_queue_capacity(routing_queues_api: RoutingQueuesApi, queue_id: str) -> bool:
    """Checks if the target queue accepts webmessaging and has available capacity."""
    max_retries = 3
    retries = 0
            # GET /api/v2/routing/queues/{queueId}
            queue = routing_queues_api.get_routing_queue(queue_id)
            break
            if e.status == 429:
                time.sleep(2 ** retries)
                retries += 1
            else:
                raise
    # Channel compatibility check
    if "webmessaging" not in queue.channel_types:
        print(f"Queue {queue_id} does not support webmessaging channel.")
        return False
    # Capacity validation
    active_conversations = queue.active_conversation_count or 0
    max_capacity = queue.max_capacity or 0
    if max_capacity > 0 and active_conversations >= max_capacity:
        print(f"Queue {queue_id} is at capacity ({active_conversations}/{max_capacity}).")
        return False
    return True
Step 4: Execute Reroute and Assign to Queue
You initiate the handoff by updating the conversation participants or creating a transfer. The Conversations API supports direct participant updates. You construct the reroute payload, verify context, and submit the change.
Required Scope: conversation:write
Endpoint: PUT /api/v2/conversations/{conversationId}/participants
def execute_handoff_reroute(conversations_api: ConversationsApi, conversation_id: str, queue_id: str, payload: dict) -> dict:
    """Executes the bot-to-agent handoff by updating conversation participants."""
    participant_body = {
        "id": conversation_id,
        "participants": [
                "id": "bot",
                "state": "offline",
                "routing": {
                    "skillRequirements": [
                            "skillId": payload["handoff_matrix"].get("skill", "general_support"),
                            "proficiency": 1.0
                "id": "agent",
                "state": "queued",
                "routing": {
                    "queueId": queue_id,
                    "priority": payload["handoff_matrix"].get("priority", "standard")
        # PUT /api/v2/conversations/{conversationId}/participants
        response = conversations_api.put_conversation_participants(
            conversation_id=conversation_id,
            body=participant_body
        return {"status": "success", "conversation_id": conversation_id, "queue_id": queue_id}
        if e.status == 400:
            print(f"Invalid participant update payload for {conversation_id}: {e.body}")
        elif e.status == 409:
            print(f"Conversation {conversation_id} state conflict. Already transferred.")
        else:
            raise
        return {"status": "failed", "error": str(e)}
Step 5: Synchronize Events, Track Latency, and Generate Audit Logs
You record the intercept latency, update success metrics, and push a synchronization payload to an external routing engine via webhook. You also generate a structured audit log for governance compliance.
Required Scope: webhook:write (for platform webhooks) or direct httpx call to external endpoint
External Sync: POST {EXTERNAL_WEBHOOK_URL}
import httpx
import json
import uuid
class HandoffInterceptorMetrics:
    def __init__(self):
        self.total_intercepts = 0
        self.successful_reroutes = 0
        self.total_latency_ms = 0.0
        self.audit_logs = []
    def record_latency(self, latency_ms: float, success: bool):
        self.total_intercepts += 1
        self.total_latency_ms += latency_ms
        if success:
            self.successful_reroutes += 1
    def get_success_rate(self) -> float:
        if self.total_intercepts == 0:
            return 0.0
        return (self.successful_reroutes / self.total_intercepts) * 100
    def log_audit(self, conversation_id: str, action: str, result: str, payload_hash: str):
        self.audit_logs.append({
            "action": action,
            "result": result,
            "payload_hash": payload_hash,
            "audit_id": str(uuid.uuid4())
def sync_external_routing(interceptor_metrics: HandoffInterceptorMetrics, payload: dict, result: dict):
    """Sends intercept event to external routing engine and records audit trail."""
    webhook_url = os.environ.get("EXTERNAL_WEBHOOK_URL", "https://example.com/routing-sync")
    sync_payload = {
        "event_type": "bot_handoff_intercepted",
        "signal_reference": payload["signal_reference"],
        "reroute_directive": payload["reroute_directive"],
        "sentiment_score": payload["sentiment_score"],
        "result": result["status"],
        "metrics": {
            "success_rate": interceptor_metrics.get_success_rate(),
            "avg_latency_ms": interceptor_metrics.total_latency_ms / max(interceptor_metrics.total_intercepts, 1)
    payload_hash = str(hash(json.dumps(sync_payload, sort_keys=True)))
    interceptor_metrics.log_audit(
        conversation_id=payload["conversation_id"],
        action="external_sync",
        result=result["status"],
        payload_hash=payload_hash
        with httpx.Client(timeout=10.0) as client:
            response = client.post(
                webhook_url,
                json=sync_payload,
                headers={"Content-Type": "application/json", "X-Interceptor-ID": "genesys-webmessaging-handoff"}
            response.raise_for_status()
        print(f"External sync failed for {payload['conversation_id']}: {e.response.status_code}")
        print(f"Network error during external sync: {e}")
The following script combines all components into a runnable handoff interceptor service. You only need to set the environment variables and provide a target queue ID.
import os
import uuid
import httpx
# Import validation and metrics classes from previous steps
# (In production, place these in separate modules)
# from .validation import HandoffTriggerPayload, evaluate_handoff_trigger
# from .queue import validate_queue_capacity
# from .execution import execute_handoff_reroute
# from .metrics import HandoffInterceptorMetrics, sync_external_routing
def run_handoff_interceptor(target_queue_id: str, polling_interval: int = 30):
    """Main execution loop for the bot handoff interceptor."""
    client = initialize_genesys_client()
    conversations_api = ConversationsApi(client)
    routing_queues_api = RoutingQueuesApi(client)
    metrics = HandoffInterceptorMetrics()
    print("Starting Genesys Cloud Web Messaging Handoff Interceptor...")
    while True:
            start_time = time.time()
            conversations = fetch_active_webmessaging_conversations(conversations_api)
            for conv in conversations:
                trigger_payload = evaluate_handoff_trigger(conv, max_session_minutes=30)
                if not trigger_payload:
                # Validate schema
                    HandoffTriggerPayload(**trigger_payload)
                    print(f"Schema validation failed for {conv['id']}: {e}")
                if not validate_queue_capacity(routing_queues_api, target_queue_id):
                result = execute_handoff_reroute(conversations_api, conv["id"], target_queue_id, trigger_payload)
                end_time = time.time()
                latency_ms = (end_time - start_time) * 1000
                success = result["status"] == "success"
                metrics.record_latency(latency_ms, success)
                sync_external_routing(metrics, trigger_payload, result)
                print(f"Processed {conv['id']}: {result['status']} | Latency: {latency_ms:.2f}ms")
        except KeyboardInterrupt:
            print("\nInterceptor stopped by user.")
            break
            print(f"Unhandled error in intercept loop: {e}")
            time.sleep(10)
        time.sleep(polling_interval)
    TARGET_QUEUE = os.environ.get("GENESYS_TARGET_QUEUE_ID", "default-queue-id")
    run_handoff_interceptor(target_queue_id=TARGET_QUEUE)
  • Cause: Missing or expired OAuth token, or the service account lacks the required scope.
  • Fix: Verify GENESYS_CLOUD_CLIENT_ID and GENESYS_CLOUD_CLIENT_SECRET. Ensure the OAuth client has conversation:read, conversation:write, and routing:queue:read scopes assigned in the Genesys Cloud admin console.
  • Code Fix: The SDK automatically refreshes tokens. If you receive 401 repeatedly, rotate your client secret and restart the service.
Error: 403 Forbidden
  • Cause: The service account lacks permissions for the specific resource or region.
  • Fix: Assign the Conversation Participant and Routing Queue roles to the OAuth client user. Verify the region matches your organization.
  • Code Fix: Log the exact endpoint and response body to confirm which scope is missing.
  • Cause: Exceeding Genesys Cloud API rate limits during high-volume polling.
  • Fix: Implement exponential backoff. The provided fetch_active_webmessaging_conversations function includes a retry loop. Increase polling_interval in the main loop if rate limits persist.
  • Code Fix: Monitor the Retry-After header in the 429 response and adjust sleep duration dynamically.
Error: 400 Bad Request on Participant Update
  • Cause: Invalid conversation state or malformed participant payload.
  • Fix: Ensure the conversation is still active and has not already been transferred. Verify that queueId matches an existing routing queue that supports webmessaging.
  • Code Fix: Add state validation before calling put_conversation_participants. Check conversation.state equals active.
Error: Pydantic Validation Failure
  • Cause: Custom attributes missing or malformed in the conversation payload.
  • Fix: Standardize bot handoff signals in your IVR/chatbot configuration. Ensure bot.handoff.triggered is explicitly set to "true" before the interceptor runs.
  • Code Fix: Wrap HandoffTriggerPayload(**trigger_payload) in a try-except block and log the missing fields for bot configuration debugging.
