Intercepting and Modifying Genesys Cloud Webchat Network Payloads with Python
A Python-based async HTTP interceptor that captures, validates, modifies, and logs network payloads destined for the Genesys Cloud Webchat API, enforcing schema constraints, mutation limits, integrity verification, and automatic retry logic. This service uses httpx and fastapi to act as a transparent middleware proxy between your frontend Webchat implementation and the Genesys Cloud platform. The language covered is Python 3.10+.
- Genesys Cloud OAuth client credentials (confidential client type)
- Required OAuth scopes:
openid,webchat:read,webchat:write,analytics:read,offline_access - Python 3.10 or newer
- Dependencies:
fastapi,uvicorn,httpx,pydantic,jsonschema,hashlib,uuid,logging,time - A local or cloud environment capable of hosting an async HTTP service
Genesys Cloud uses OAuth 2.0 client credentials flow for server-to-server communication. The interceptor requires a valid access token to validate payloads against platform constraints and to push audit logs to Genesys Cloud endpoints. The following manager handles token acquisition, caching, and automatic refresh before expiration.
import httpx
import logging
from typing import Optional
logger = logging.getLogger("genesys.interceptor")
class GenesysAuthManager:
def __init__(self, client_id: str, client_secret: str, base_url: str = "https://login.mypurecloud.com"):
self.client_id = client_id
self.token_url = f"{base_url}/oauth/token"
self.expires_at: float = 0.0
self._http = httpx.AsyncClient(timeout=10.0)
if self.access_token and time.time() < self.expires_at - 30:
return self.access_token
payload = {
"client_id": self.client_id,
"scope": "openid webchat:read webchat:write analytics:read offline_access"
response = await self._http.post(self.token_url, data=payload)
response.raise_for_status()
data = response.json()
self.access_token = data["access_token"]
self.expires_at = time.time() + data["expires_in"]
logger.info("OAuth token refreshed successfully")
logger.error(f"OAuth token fetch failed: {e.response.status_code} - {e.response.text}")
raise
logger.error(f"Unexpected OAuth error: {e}")
raise
Required Scope: openid webchat:read webchat:write analytics:read offline_access
Endpoint: POST https://login.mypurecloud.com/oauth/token
Error Handling: Catches 401 (invalid credentials), 403 (insufficient scopes), and 5xx (platform outage). Raises httpx.HTTPStatusError for upstream middleware to catch.
Step 1: Core Interceptor with Request ID, Header Matrix, and Modify Directive
The interceptor attaches to every outbound request. It generates a deterministic X-Request-ID, captures the full header matrix, and evaluates a modify directive against the payload. The directive defines which JSON paths are allowed to mutate.
import uuid
import json
from typing import Dict, Any, List, Optional
@dataclass
class InterceptContext:
request_id: str = field(default_factory=lambda: str(uuid.uuid4()))
original_headers: Dict[str, str] = field(default_factory=dict)
modified_payload: Optional[str] = None
mutation_count: int = 0
max_mutations: int = 5
cors_origin: Optional[str] = None
integrity_hash_before: Optional[str] = None
integrity_hash_after: Optional[str] = None
latency_ms: float = 0.0
success: bool = False
class WebchatInterceptor:
def __init__(self, allowed_paths: List[str] = None):
self.allowed_paths = allowed_paths or ["/api/v2/webchat/instances", "/api/v2/webchat/messages"]
self.context_store: Dict[str, InterceptContext] = {}
def prepare_context(self, headers: Dict[str, str], payload: Optional[str]) -> InterceptContext:
ctx = InterceptContext()
ctx.original_headers = dict(headers)
ctx.cors_origin = headers.get("Origin", headers.get("origin"))
ctx.integrity_hash_before = self._compute_hash(payload or "{}")
self.context_store[ctx.request_id] = ctx
return ctx
def apply_modify_directive(self, ctx: InterceptContext, payload: str, directive: Dict[str, Any]) -> str:
if ctx.mutation_count >= ctx.max_mutations:
logger.warning(f"Mutation limit reached for request {ctx.request_id}")
return payload
data = json.loads(payload)
for path, value in directive.items():
keys = path.split(".")
current = data
for key in keys[:-1]:
if isinstance(current, dict):
current = current[key]
else:
raise KeyError(f"Invalid path segment: {key}")
current[keys[-1]] = value
ctx.mutation_count += 1
modified = json.dumps(data)
ctx.modified_payload = modified
ctx.integrity_hash_after = self._compute_hash(modified)
return modified
except json.JSONDecodeError as e:
logger.error(f"Payload JSON parse failed: {e}")
return payload
except KeyError as e:
logger.error(f"Modify directive path error: {e}")
return payload
@staticmethod
def _compute_hash(data: str) -> str:
import hashlib
return hashlib.sha256(data.encode("utf-8")).hexdigest()
Required Scope: None (client-side preparation)
Endpoint: N/A (local processing)
Error Handling: Catches JSONDecodeError and path traversal errors. Returns original payload to prevent request failure. Tracks mutation count against max_mutations.
Step 2: Schema Validation and Proxy Engine Constraints
Genesys Cloud Webchat payloads must conform to platform schemas. The interceptor validates against a JSON schema before forwarding. It enforces payload size limits and structural rules to prevent proxy engine rejection.
import jsonschema
WEBCHAT_INSTANCE_SCHEMA = {
"type": "object",
"required": ["name", "type"],
"properties": {
"name": {"type": "string", "maxLength": 100},
"type": {"type": "string", "enum": ["standard", "custom"]},
"settings": {"type": "object"}
"additionalProperties": False
class SchemaValidator:
def __init__(self, max_payload_bytes: int = 65536):
self.max_payload_bytes = max_payload_bytes
def validate(self, payload: str, schema: Dict[str, Any]) -> bool:
if len(payload.encode("utf-8")) > self.max_payload_bytes:
logger.error("Payload exceeds maximum size constraint")
return False
jsonschema.validate(instance=json.loads(payload), schema=schema)
return True
except jsonschema.ValidationError as e:
logger.error(f"Schema validation failed: {e.message}")
return False
logger.error(f"Validation pipeline error: {e}")
return False
Required Scope: None (local processing)
Endpoint: N/A
Error Handling: Returns False on validation failure. Logs exact schema violation. Prevents malformed payloads from reaching Genesys Cloud.
Step 3: Atomic Dispatch, Retry Logic, and CORS Verification
The dispatch layer forwards requests to Genesys Cloud. It performs atomic CORS policy checks, computes integrity hashes, and implements exponential backoff for 429 rate-limit responses. The dispatch operation is atomic: either the full request completes, or the interceptor rolls back to the original payload.
import asyncio
class AtomicDispatcher:
def __init__(self, auth: GenesysAuthManager, base_url: str = "https://api.mypurecloud.com"):
self.auth = auth
self.base_url = base_url
self._http = httpx.AsyncClient(timeout=30.0, follow_redirects=True)
async def dispatch(
self,
method: str,
path: str,
payload: str,
max_retries: int = 3
) -> httpx.Response:
url = f"{self.base_url}{path}"
token = await self.auth.get_token()
headers["Authorization"] = f"Bearer {token}"
headers["Content-Type"] = "application/json"
if not self._verify_cors(ctx.cors_origin):
raise ValueError(f"CORS policy violation. Origin: {ctx.cors_origin}")
attempt = 0
while attempt < max_retries:
response = await self._http.request(
method=method,
url=url,
headers=headers,
content=payload
ctx.latency_ms = (time.perf_counter() - start_time) * 1000
retry_after = float(response.headers.get("Retry-After", 2 ** attempt))
logger.warning(f"Rate limited. Retrying in {retry_after}s (attempt {attempt + 1})")
attempt += 1
ctx.success = True
return response
if e.response.status_code in (401, 403):
ctx.success = False
raise
attempt += 1
if attempt == max_retries:
ctx.success = False
raise
await asyncio.sleep(2 ** attempt)
ctx.success = False
raise
ctx.success = False
raise RuntimeError("Max retries exceeded during atomic dispatch")
@staticmethod
def _verify_cors(origin: Optional[str]) -> bool:
allowed_origins = ["https://webchat.example.com", "http://localhost:3000"]
return origin in allowed_origins if origin else True
Required Scope: webchat:write
Endpoint: POST/PUT/PATCH https://api.mypurecloud.com/api/v2/webchat/...
Error Handling: Handles 429 with exponential backoff. Validates CORS against allowlist. Raises on 401/403 or network failures. Tracks latency and success state.
Step 4: Webhook Sync, Latency Tracking, and Audit Logging
After dispatch, the interceptor synchronizes events to external observability tools via webhooks, tracks success rates, and generates structured audit logs for network governance.
import json
import logging
logger_audit = logging.getLogger("genesys.audit")
logger_audit.setLevel(logging.INFO)
handler = logging.StreamHandler()
handler.setFormatter(logging.Formatter("%(message)s"))
logger_audit.addHandler(handler)
class ObservabilitySync:
def __init__(self, webhook_url: str):
self._http = httpx.AsyncClient(timeout=5.0)
self.success_count = 0
self.total_count = 0
async def sync_event(self, ctx: InterceptContext, method: str, path: str) -> None:
self.total_count += 1
if ctx.success:
self.success_count += 1
audit_entry = {
"request_id": ctx.request_id,
"method": method,
"path": path,
"latency_ms": round(ctx.latency_ms, 2),
"mutations": ctx.mutation_count,
"integrity_before": ctx.integrity_hash_before,
"integrity_after": ctx.integrity_hash_after,
"success": ctx.success,
"success_rate": round(self.success_count / self.total_count * 100, 2) if self.total_count > 0 else 0.0
logger_audit.info(json.dumps(audit_entry))
await self._http.post(self.webhook_url, json=audit_entry, headers={"Content-Type": "application/json"})
logger_audit.error(f"Webhook sync failed: {e}")
Required Scope: analytics:read (for external correlation)
Endpoint: Custom webhook URL
Error Handling: Catches webhook delivery failures. Logs structured JSON audit entries. Tracks rolling success rate.
The following FastAPI application mounts the interceptor as middleware. It processes all requests destined for Genesys Cloud Webchat endpoints, applies validation, modification, dispatch, and observability pipelines.
import uvicorn
from fastapi import FastAPI, Request, Response
from fastapi.responses import JSONResponse
import logging
app = FastAPI(title="Genesys Webchat Interceptor Proxy")
# Initialize components
auth_manager = GenesysAuthManager(client_id="YOUR_CLIENT_ID", client_secret="YOUR_CLIENT_SECRET")
interceptor = WebchatInterceptor()
validator = SchemaValidator()
dispatcher = AtomicDispatcher(auth=auth_manager)
sync_service = ObservabilitySync(webhook_url="https://observability.example.com/webhooks/genesys-intercept")
@app.middleware("http")
async def intercept_webchat_traffic(request: Request, call_next):
target_path = request.url.path
if not any(target_path.startswith(prefix) for prefix in interceptor.allowed_paths):
return await call_next(request)
method = request.method
headers = dict(request.headers)
body = await request.body()
payload = body.decode("utf-8") if body else "{}"
ctx = interceptor.prepare_context(headers, payload)
if not validator.validate(payload, WEBCHAT_INSTANCE_SCHEMA):
return JSONResponse(status_code=400, content={"error": "Payload failed schema validation"})
modify_directive = {
"settings.routingStrategy": "longest-available-agent",
"settings.enableTranscript": True
modified_payload = interceptor.apply_modify_directive(ctx, payload, modify_directive)
response = await dispatcher.dispatch(ctx, method, target_path, headers, modified_payload)
await sync_service.sync_event(ctx, method, target_path)
return Response(
content=response.content,
status_code=response.status_code,
headers=dict(response.headers)
return JSONResponse(status_code=502, content={"error": str(e)})
uvicorn.run(app, host="0.0.0.0", port=8000)
Required Scope: webchat:write analytics:read
Endpoint: Proxies to https://api.mypurecloud.com/api/v2/webchat/...
Error Handling: Returns 400 on validation failure, 502 on dispatch failure. Logs all events. Ready to run with credentials populated.
- Cause: Expired OAuth token or invalid client credentials.
- Fix: Verify
client_idandclient_secretmatch a confidential client in Genesys Cloud. Ensure the token manager refreshes beforeexpires_inreaches zero. - Code Fix: The
GenesysAuthManageralready implements a 30-second safety buffer before expiration. If tokens still fail, rotate credentials in the Genesys Cloud Admin console under Security > OAuth Clients.
Error: 403 Forbidden
- Cause: Missing OAuth scopes or insufficient permissions for the target Webchat instance.
- Fix: Add
webchat:writeandanalytics:readto the client scope list. Assign the OAuth client to a role with Webchat Admin or Developer permissions. - Code Fix: Update the
scopeparameter inget_token()to include all required scopes. Restart the service to fetch a fresh token.
- Cause: Genesys Cloud rate limits exceeded for Webchat API calls.
- Fix: The
AtomicDispatcherimplements exponential backoff. Increasemax_retriesif traffic spikes are expected. Implement client-side request coalescing. - Code Fix: Adjust
max_retries=3indispatch()tomax_retries=5. MonitorRetry-Afterheaders returned by Genesys Cloud.
Error: Schema Validation Failed
- Cause: Payload contains invalid fields, exceeds size limits, or violates structural rules.
- Fix: Align frontend Webchat SDK payloads with Genesys Cloud schema requirements. Remove unsupported properties.
- Code Fix: Update
WEBCHAT_INSTANCE_SCHEMAto match the exact Genesys Cloud Webchat instance structure. Usejsonschema.validate()output to identify the exact violating path.
Error: Integrity Hash Mismatch
- Cause: Payload was modified between interception and dispatch, or hashing pipeline failed.
- Fix: Ensure
integrity_hash_beforeandintegrity_hash_afterare computed on the exact byte strings passed through the pipeline. Disable concurrent modifications. - Code Fix: The
WebchatInterceptorcomputes hashes synchronously before and after mutation. Log both values in the audit entry to trace divergence.
Error: CORS Policy Violation
- Cause: Request
Originheader does not match allowed domains. - Fix: Add the frontend domain to the
allowed_originslist inAtomicDispatcher._verify_cors(). - Code Fix: Update the allowlist to include production and staging Webchat hostnames. Do not use wildcard origins in production.
