Integrate NICE Cognigy.AI Booking Intents with Legacy Mainframe Systems Using Java Webhooks and COBOL Marshalling
- A production-ready Java webhook service that captures flight booking intents from NICE Cognigy.AI, converts them to COBOL copybook structures, transmits them over a TCP/IP socket to a mainframe, parses the binary response, and returns structured JSON to Cognigy.
- This tutorial uses the Cognigy.AI Webhook API, Jackson for JSON processing, Apache Commons Pool2 for socket management, and a COBOL copybook marshalling library for binary packing.
- The implementation is written in Java 17 with Spring Boot 3.x and includes explicit timeout handling, exponential backoff retry logic, and transaction code mapping.
- Cognigy.AI project with a configured Bot and Webhook integration endpoint
- OAuth2 Client Credentials flow configured in Cognigy.AI with
webhook:writeandbot:readscopes - Java 17 runtime and Maven 3.8+
- Dependencies:
spring-boot-starter-web,com.fasterxml.jackson.core:jackson-databind,org.apache.commons:commons-pool2,com.github.cobol-parser:cobol-parser - Mainframe endpoint details (host, port, transaction codes, copybook definition file)
- EBCDIC character set conversion capability for mainframe text fields
Cognigy.AI verifies webhook payloads using a shared secret. When your Java service needs to call Cognigy.AI APIs programmatically (for logging or state updates), you must use the OAuth2 Client Credentials flow. The following code demonstrates secure token acquisition and caching. The required scope for webhook verification and bot state updates is webhook:write.
import java.net.URI;
import java.time.Duration;
public class CognigyAuthService {
private static final String TOKEN_URL = "https://api.cognigy.ai/v1/auth/token";
private final String clientId;
private final String clientSecret;
private final ConcurrentHashMap<String, String> tokenCache = new ConcurrentHashMap<>();
private final HttpClient httpClient;
public CognigyAuthService(String clientId, String clientSecret) {
this.clientId = clientId;
this.httpClient = HttpClient.newBuilder()
.connectTimeout(Duration.ofSeconds(5))
.build();
public String getAccessToken() throws Exception {
String cached = tokenCache.get("access_token");
if (cached != null) {
return cached;
.uri(URI.create(TOKEN_URL))
.header("Content-Type", "application/x-www-form-urlencoded")
.POST(HttpRequest.BodyPublishers.ofString(
"grant_type=client_credentials&scope=webhook:write+bot:read"))
.build();
throw new RuntimeException("OAuth token request failed with status " + response.statusCode());
// Parse token from JSON response using Jackson or simple string extraction
String token = extractToken(response.body());
tokenCache.put("access_token", token);
return token;
private String extractToken(String json) {
// Simplified extraction for demonstration. Use Jackson in production.
int start = json.indexOf("\"access_token\":\"") + 16;
int end = json.indexOf("\"", start);
return json.substring(start, end);
HTTP Request Cycle for OAuth Token
POST /v1/auth/token HTTP/1.1
Host: api.cognigy.ai
Authorization: Basic <base64(clientId:clientSecret)>
Expected Response
"token_type": "Bearer",
"expires_in": 3600
Step 1: Configure Webhook Endpoint and Intent Extraction
Cognigy.AI sends a POST request to your webhook URL when a dialog node triggers an external action. You must parse the incoming JSON, extract the booking intent, and map it to a mainframe transaction code. The required OAuth scope for receiving webhooks is webhook:read (configured in the Cognigy console, not sent in the request).
import org.springframework.http.ResponseEntity;
import org.springframework.web.bind.annotation.PostMapping;
import org.springframework.web.bind.annotation.RequestBody;
import org.springframework.web.bind.annotation.RestController;
import java.util.Map;
@RestController
public class CognigyWebhookController {
private final ObjectMapper objectMapper = new ObjectMapper();
private final MainframeBookingService bookingService;
public CognigyWebhookController(MainframeBookingService bookingService) {
this.bookingService = bookingService;
@PostMapping("/webhook/cognigy/booking")
public ResponseEntity<String> handleBookingIntent(@RequestBody String payload) throws Exception {
JsonNode root = objectMapper.readTree(payload);
String intent = root.path("intent").asText();
String passengerName = root.path("entities").path("passenger_name").asText("");
String flightDate = root.path("entities").path("travel_date").asText("");
String transactionCode = mapIntentToTransactionCode(intent);
// Delegate to mainframe service
Map<String, Object> mainframeResponse = bookingService.processBooking(
transactionCode, passengerName, flightDate);
// Map mainframe response back to Cognigy dialog node variables
JsonNode responsePayload = objectMapper.createObjectNode()
.put("dialog_node", mainframeResponse.get("dialog_node"))
.put("variables", objectMapper.valueToTree(mainframeResponse.get("variables")));
return ResponseEntity.ok(objectMapper.writeValueAsString(responsePayload));
private String mapIntentToTransactionCode(String intent) {
return switch (intent) {
case "book_flight" -> "TF01";
case "modify_reservation" -> "TF02";
case "cancel_ticket" -> "TF03";
default -> "TF99";
HTTP Request Cycle for Webhook Payload
POST /webhook/cognigy/booking HTTP/1.1
Host: your-service.example.com
X-Cognigy-Webhook-Secret: <configured_secret>
"intent": "book_flight",
"entities": {
"passenger_name": "GARCIA, MARIO",
"travel_date": "20241115"
"dialog_node": "external_booking_handler"
Step 2: Construct COBOL Copybook Structures and Send via TCP Socket
The mainframe expects a packed binary structure matching a COBOL copybook. You will use a marshalling library to convert a Java DTO into the correct byte sequence, apply EBCDIC encoding for alphanumeric fields, and transmit it over a TCP/IP socket.
import com.github.cobol.parser.Copybook;
import com.github.cobol.parser.CopybookParser;
import com.github.cobol.parser.Record;
import com.ibm.jcckit.conversion.EbcdicConverter;
import org.apache.commons.codec.binary.Hex;
import java.io.*;
import java.net.Socket;
import java.nio.charset.StandardCharsets;
public class MainframeSocketClient {
private static final String COPYBOOK_PATH = "/resources/BOOKING_COPYBOOK.cob";
private final String host;
private final int port;
private final Copybook copybook;
public MainframeSocketClient(String host, int port) throws Exception {
this.host = host;
this.port = port;
try (InputStream is = getClass().getClassLoader().getResourceAsStream(COPYBOOK_PATH)) {
this.copybook = CopybookParser.parse(is);
public byte[] marshalBookingRequest(String transactionCode, String passengerName, String travelDate) throws Exception {
Record record = copybook.createRecord();
// Transaction code: 4-byte alphanumeric
record.put("TRANSACTION_ID", transactionCode);
// Passenger name: 30-byte alphanumeric (padded)
String paddedName = String.format("-30s", passengerName.toUpperCase());
record.put("PASSENGER_NAME", paddedName);
// Travel date: 8-byte numeric (YYYYMMDD)
record.put("TRAVEL_DATE", travelDate);
byte[] asciiBytes = record.getBytes();
// Convert alphanumeric fields to EBCDIC as required by mainframe
return EbcdicConverter.asciiToEbcdic(asciiBytes);
public byte[] sendAndReceive(byte[] requestBytes, Socket socket) throws IOException {
OutputStream out = socket.getOutputStream();
InputStream in = socket.getInputStream();
out.write(requestBytes);
out.flush();
// Read response until mainframe closes stream or sends terminator
ByteArrayOutputStream responseBuffer = new ByteArrayOutputStream();
byte[] buffer = new byte[1024];
int bytesRead;
while ((bytesRead = in.read(buffer)) != -1) {
responseBuffer.write(buffer, 0, bytesRead);
if (responseBuffer.size() >= 512) { // Adjust based on copybook record length
break;
return responseBuffer.toByteArray();
Step 3: Parse Binary Response and Map to Cognigy Dialog Nodes
The mainframe returns a binary response matching the same or a different copybook. You must unmarshal the bytes, convert EBCDIC back to ASCII, extract status codes, and map them to Cognigy dialog node routing variables.
import org.springframework.stereotype.Service;
import java.util.HashMap;
import java.util.concurrent.TimeoutException;
@Service
public class MainframeBookingService {
private final MainframeSocketClient socketClient;
private final int SOCKET_TIMEOUT_MS = 5000;
public MainframeBookingService(MainframeSocketClient socketClient) {
this.socketClient = socketClient;
public Map<String, Object> processBooking(String transactionCode, String passengerName, String travelDate) throws Exception {
byte[] requestBytes = socketClient.marshalBookingRequest(transactionCode, passengerName, travelDate);
// Simulate socket acquisition from pool (implemented in Step 4)
java.net.Socket socket = acquireSocketFromPool();
socket.setSoTimeout(SOCKET_TIMEOUT_MS);
byte[] responseBytes = socketClient.sendAndReceive(requestBytes, socket);
return parseMainframeResponse(responseBytes);
} catch (SocketTimeoutException e) {
handleTimeoutAndRetry(socket, requestBytes, transactionCode);
return Map.of("dialog_node", "error_retry_triggered", "variables", Map.of("status", "RETRY"));
} finally {
returnToPool(socket);
private Map<String, Object> parseMainframeResponse(byte[] responseBytes) throws Exception {
byte[] asciiBytes = EbcdicConverter.ebcdicToAscii(responseBytes);
Record record = copybook.parseRecord(asciiBytes);
String status = record.get("RESPONSE_STATUS").toString().trim();
String bookingRef = record.get("BOOKING_REF").toString().trim();
String errorMessage = record.get("ERROR_MSG").toString().trim();
Map<String, Object> variables = new HashMap<>();
variables.put("mainframe_status", status);
variables.put("booking_reference", bookingRef);
variables.put("error_message", errorMessage);
String dialogNode = switch (status) {
case "000" -> "booking_confirmed";
case "101" -> "payment_required";
case "202" -> "seat_unavailable";
default -> "booking_failed";
Map<String, Object> result = new HashMap<>();
result.put("dialog_node", dialogNode);
result.put("variables", variables);
return result;
Step 4: Implement Connection Pooling and Timeout Retry Logic
Mainframe TCP sessions are expensive and stateful. You must implement a connection pool to reuse sockets and handle session timeouts by re-establishing connections and retrying the transaction with exponential backoff.
import org.apache.commons.pool2.PooledObject;
import org.apache.commons.pool2.PooledObjectFactory;
import org.apache.commons.pool2.impl.DefaultPooledObject;
import org.apache.commons.pool2.impl.GenericObjectPool;
import org.apache.commons.pool2.impl.GenericObjectPoolConfig;
import java.io.IOException;
import java.net.SocketTimeoutException;
public class MainframeConnectionPool implements PooledObjectFactory<Socket> {
private GenericObjectPool<Socket> pool;
public MainframeConnectionPool(String host, int port) {
this.host = host;
this.port = port;
GenericObjectPoolConfig<Socket> config = new GenericObjectPoolConfig<>();
config.setMaxTotal(20);
config.setMinIdle(5);
config.setMaxWaitMillis(10000);
config.setTestOnBorrow(true);
this.pool = new GenericObjectPool<>(this, config);
@Override
public PooledObject<Socket> makeObject() throws Exception {
Socket socket = new Socket();
socket.setSoTimeout(5000);
socket.connect(new java.net.InetSocketAddress(host, port), 3000);
return new DefaultPooledObject<>(socket);
@Override
public void destroyObject(PooledObject<Socket> socketPooledObject) throws Exception {
socketPooledObject.getObject().close();
} catch (IOException ignored) {}
@Override
public boolean validateObject(PooledObject<Socket> socketPooledObject) {
return socketPooledObject.getObject().isConnected() && !socketPooledObject.getObject().isClosed();
@Override
public void activateObject(PooledObject<Socket> socketPooledObject) {}
@Override
public void passivateObject(PooledObject<Socket> socketPooledObject) {}
public Socket borrowObject() throws Exception {
return pool.borrowObject();
public void returnObject(Socket socket) {
pool.returnObject(socket);
} catch (Exception e) {
pool.invalidateObject(socket);
public void retryWithBackoff(Socket failedSocket, byte[] requestBytes, String transactionCode) throws Exception {
int maxRetries = 3;
long delayMs = 1000;
for (int attempt = 1; attempt <= maxRetries; attempt++) {
System.out.println("Retry attempt " + attempt + " for transaction " + transactionCode);
TimeUnit.MILLISECONDS.sleep(delayMs);
Socket freshSocket = borrowObject();
socketClient.sendAndReceive(requestBytes, freshSocket);
System.out.println("Retry successful.");
return;
} finally {
returnObject(freshSocket);
if (attempt == maxRetries) throw e;
delayMs *= 2; // Exponential backoff
} catch (IOException e) {
returnObject(failedSocket); // Mark invalid
The following Spring Boot application integrates all components. Replace placeholder credentials and endpoints with your environment values.
import org.springframework.boot.SpringApplication;
import org.springframework.boot.autoconfigure.SpringBootApplication;
import org.springframework.context.annotation.Bean;
@SpringBootApplication
public class CognigyMainframeIntegrationApp {
SpringApplication.run(CognigyMainframeIntegrationApp.class, args);
@Bean
public MainframeConnectionPool mainframePool() {
return new MainframeConnectionPool("mainframe.yourcompany.com", 2001);
@Bean
public MainframeSocketClient socketClient(MainframeConnectionPool pool) {
// Wrapper that delegates pool operations
return new MainframeSocketClient(pool.getHost(), pool.getPort());
@Bean
public CognigyAuthService cognigyAuth() {
return new CognigyAuthService(
System.getenv("COGNIGY_CLIENT_ID"),
System.getenv("COGNIGY_CLIENT_SECRET")
Maven Dependencies (pom.xml)
<dependencies>
<dependency>
<groupId>org.springframework.boot</groupId>
<artifactId>spring-boot-starter-web</artifactId>
</dependency>
<dependency>
<groupId>com.fasterxml.jackson.core</groupId>
<artifactId>jackson-databind</artifactId>
</dependency>
<dependency>
<groupId>org.apache.commons</groupId>
<artifactId>commons-pool2</artifactId>
<version>2.11.1</version>
</dependency>
<dependency>
<groupId>com.github.cobol-parser</groupId>
<artifactId>cobol-parser</artifactId>
<version>1.0.0</version>
</dependency>
</dependencies>
Error: 401 Unauthorized (Cognigy API)
- Cause: Missing or expired OAuth token, incorrect client credentials, or missing
webhook:writescope in the token request. - Fix: Verify the
grant_type=client_credentialspayload includes the correct scope. Ensure the token cache evicts expired tokens. - Code Fix: Add token expiration tracking and force re-authentication when
response.statusCode() == 401.
Error: SocketTimeoutException (Mainframe Session Timeout)
- Cause: The mainframe idle timeout exceeded the socket read timeout, or the network dropped the TCP keep-alive.
- Fix: Implement the retry logic shown in Step 4. Increase
setSoTimeoutif the transaction legitimately requires longer processing. Configure TCP keep-alive at the OS level. - Code Fix: Catch
SocketTimeoutException, invalidate the pooled socket, borrow a fresh one, and retry with exponential backoff.
Error: COBOL UnmarshallingException (Packed Decimal Misalignment)
- Cause: The response byte length does not match the copybook record definition, or EBCDIC/ASCII conversion was skipped.
- Fix: Verify the copybook matches the mainframe program layout exactly. Use hex dumps to compare expected vs actual byte sequences. Ensure
EbcdicConverteris applied consistently. - Code Fix: Add defensive length checking before parsing:
if (responseBytes.length != expectedRecordLength) throw new IllegalArgumentException("Record length mismatch");
Error: 429 Too Many Requests (Cognigy Webhook Rate Limit)
- Cause: Exceeding Cognigy.AI webhook throughput limits during high concurrency.
- Fix: Implement request throttling in your Spring Boot controller using a rate-limiting filter. Queue excess requests and process them asynchronously.
- Code Fix: Return
ResponseEntity.status(429).body("{\"error\": \"rate_limited\"}")and configure Cognigy to retry with backoff.
