Injecting SIP Routing Headers via Genesys Cloud Telephony API with Go
A Go module that programmatically configures SIP header injection rules on a Genesys Cloud Telephony Provider, validates payloads against SIP protocol constraints, triggers test call legs, and synchronizes state with external PSTN gateways via webhooks. The implementation uses the Genesys Cloud Telephony API and direct HTTP calls with production-grade error handling, atomic updates, and audit logging.
  • OAuth2 Client Credentials registered in Genesys Cloud Admin Console
  • Required scopes: telephony:provider:write, telephony:provider:read, telephony:call:write, webhook:write
  • Go 1.21 or higher
  • Standard library dependencies: net/http, encoding/json, crypto/sha256, sync/atomic, time, fmt, os, log, net/url
  • Environment variables: GENESYS_ORGANIZATION_ID, GENESYS_CLIENT_ID, GENESYS_CLIENT_SECRET
Genesys Cloud uses OAuth2 Client Credentials flow. The following function handles token acquisition, caching, and automatic retry on 429 rate limits.
package main
import (
	"bytes"
	"context"
	"crypto/sha256"
	"encoding/json"
	"fmt"
	"io"
	"net/http"
	"os"
	"time"
const (
	oauthEndpoint = "https://login.mypurecloud.com/oauth/token"
	baseURL       = "https://api.mypurecloud.com"
	maxRetryDelay = 5 * time.Second
type OAuthTokenResponse struct {
	TokenType   string `json:"token_type"`
	ExpiresIn   int    `json:"expires_in"`
type APIRequest struct {
	Method    string
	Path      string
	Headers   map[string]string
	Body      []byte
	ETag      string
func acquireToken(ctx context.Context) (string, error) {
	payload := map[string]string{
		"grant_type":    "client_credentials",
		"client_id":     os.Getenv("GENESYS_CLIENT_ID"),
		"client_secret": os.Getenv("GENESYS_CLIENT_SECRET"),
	jsonBody, err := json.Marshal(payload)
	if err != nil {
		return "", fmt.Errorf("failed to marshal oauth payload: %w", err)
	var token string
	var resp *http.Response
	for attempt := 0; attempt < 3; attempt++ {
		req, err := http.NewRequestWithContext(ctx, http.MethodPost, oauthEndpoint, bytes.NewBuffer(jsonBody))
		if err != nil {
			return "", fmt.Errorf("failed to create oauth request: %w", err)
		resp, err = client.Do(req)
		if err != nil {
			return "", fmt.Errorf("oauth request failed: %w", err)
		defer resp.Body.Close()
			retryAfter := 2 * time.Duration(attempt+1) * time.Second
			if retryAfter > maxRetryDelay {
				retryAfter = maxRetryDelay
			time.Sleep(retryAfter)
			return "", fmt.Errorf("oauth failed with status %d: %s", resp.StatusCode, string(body))
		var tokenResp OAuthTokenResponse
			return "", fmt.Errorf("failed to decode oauth response: %w", err)
		token = tokenResp.AccessToken
		break
	if token == "" {
		return "", fmt.Errorf("failed to acquire token after retries")
	return token, nil
Step 1: Payload Construction and SIP Constraint Validation
SIP headers must comply with RFC 3261 constraints. Maximum header size must not exceed 4096 bytes to prevent SIP message fragmentation. URI normalization ensures consistent routing. Loop prevention checks Route and Record-Route headers.
type HeaderManipulation struct {
	Name  string `json:"name"`
	Value string `json:"value"`
	Action string `json:"action"` // prepend, append, replace, delete
	Match string `json:"match,omitempty"` // exact, contains, regex
type SipInjectionPayload struct {
	Headers []HeaderManipulation `json:"headers"`
	RouteMatrix string           `json:"routeMatrix,omitempty"`
	PrependDirective string      `json:"prependDirective,omitempty"`
func ValidateSipPayload(ctx context.Context, payload SipInjectionPayload) error {
	totalSize := 0
	for _, h := range payload.Headers {
		headerBytes := len(h.Name) + len(h.Value) + 2 // name + value + ": "
		totalSize += headerBytes
		if headerBytes > 2048 {
			return fmt.Errorf("individual header exceeds 2KB limit: %s", h.Name)
	if totalSize > 4096 {
		return fmt.Errorf("aggregate header size %d exceeds 4KB SIP constraint", totalSize)
	// URI normalization validation
	if payload.RouteMatrix != "" {
		uri, err := normalizeURI(payload.RouteMatrix)
		if err != nil {
			return fmt.Errorf("invalid route matrix URI: %w", err)
		payload.RouteMatrix = uri
	// Loop prevention: check for recursive routing directives
		if h.Name == "Route" || h.Name == "Record-Route" {
			if containsLoopDirective(h.Value) {
				return fmt.Errorf("loop prevention check failed: recursive route detected in %s", h.Name)
	return nil
func normalizeURI(uri string) (string, error) {
	parsed, err := net/url.Parse(uri)
	if err != nil {
		return "", err
	parsed.Host = parsed.Host
	if parsed.RawQuery != "" {
		// Normalize query parameters
		q := parsed.Query()
		parsed.RawQuery = q.Encode()
	return parsed.String(), nil
func containsLoopDirective(value string) bool {
	// Simplified loop detection: check for self-referencing route patterns
	return len(value) > 0 && (value[0] == 'X' || value[0] == 'x') && value[1:] == value[:len(value)-1]
Step 2: Atomic PUT Operations with ETag and Format Verification
Genesys Cloud Telephony Provider updates require If-Match with the current ETag to prevent race conditions. The following function fetches the current provider state, applies the injection payload, and performs an atomic update.
func updateTelephonyProvider(ctx context.Context, token, providerID string, payload SipInjectionPayload) error {
	if err := ValidateSipPayload(ctx, payload); err != nil {
		return fmt.Errorf("validation failed: %w", err)
	// Fetch current provider to get ETag
	currentProvider, etag, err := fetchProvider(ctx, token, providerID)
	if err != nil {
		return fmt.Errorf("failed to fetch provider: %w", err)
	// Merge headers into provider configuration
	updatedProvider := map[string]interface{}{
		"id":             providerID,
		"name":           currentProvider["name"],
		"enabled":        true,
		"headerManipulations": payload.Headers,
		"routePattern":   payload.RouteMatrix,
		"prependDirective": payload.PrependDirective,
	jsonBody, err := json.Marshal(updatedProvider)
	if err != nil {
		return fmt.Errorf("failed to marshal provider update: %w", err)
	url := fmt.Sprintf("%s/api/v2/telephony/providers/%s", baseURL, providerID)
		req, err := http.NewRequestWithContext(ctx, http.MethodPut, url, bytes.NewBuffer(jsonBody))
		if err != nil {
			return fmt.Errorf("failed to create update request: %w", err)
		req.Header.Set("If-Match", etag)
		req.Header.Set("X-Genesys-Client-Id", "custom-injector-go")
		resp, err := client.Do(req)
		if err != nil {
			return fmt.Errorf("update request failed: %w", err)
		if resp.StatusCode == http.StatusConflict {
			// ETag mismatch: refresh and retry
			_, etag, err = fetchProvider(ctx, token, providerID)
			if err != nil {
				return fmt.Errorf("etag refresh failed: %w", err)
			time.Sleep(2 * time.Duration(attempt+1) * time.Second)
		if resp.StatusCode != http.StatusOK && resp.StatusCode != http.StatusNoContent {
			return fmt.Errorf("provider update failed %d: %s", resp.StatusCode, string(body))
		// Format verification: read back the updated provider
		updated, _, err := fetchProvider(ctx, token, providerID)
		if err != nil {
			return fmt.Errorf("format verification failed: %w", err)
		if updated["headerManipulations"] == nil {
			return fmt.Errorf("format verification failed: headers not persisted")
		return nil
	return fmt.Errorf("failed to update provider after retries")
func fetchProvider(ctx context.Context, token, providerID string) (map[string]interface{}, string, error) {
	req, err := http.NewRequestWithContext(ctx, http.MethodGet, fmt.Sprintf("%s/api/v2/telephony/providers/%s", baseURL, providerID), nil)
	if err != nil {
		return nil, "", err
	if err != nil {
		return nil, "", err
		return nil, "", fmt.Errorf("fetch failed %d: %s", resp.StatusCode, string(body))
	var provider map[string]interface{}
	if err := json.NewDecoder(resp.Body).Decode(&provider); err != nil {
		return nil, "", err
	return provider, resp.Header.Get("ETag"), nil
Step 3: Automatic Call Leg Triggers and Webhook Synchronization
After header injection, trigger a test call leg to validate routing. Synchronize state with external PSTN gateways via webhook configuration.
func triggerTestCallLeg(ctx context.Context, token, toNumber, fromNumber string) error {
	payload := map[string]interface{}{
		"to":     toNumber,
		"from":   fromNumber,
		"type":   "pstn",
		"status": "initiated",
	if err != nil {
		return fmt.Errorf("failed to marshal call payload: %w", err)
	client := &http.Client{Timeout: 20 * time.Second}
	req, err := http.NewRequestWithContext(ctx, http.MethodPost, fmt.Sprintf("%s/api/v2/telephony/calls", baseURL), bytes.NewBuffer(jsonBody))
	if err != nil {
		return fmt.Errorf("failed to create call request: %w", err)
	if err != nil {
		return fmt.Errorf("call trigger failed: %w", err)
	if resp.StatusCode != http.StatusCreated {
		return fmt.Errorf("call trigger failed %d: %s", resp.StatusCode, string(body))
	return nil
func syncPSTNGatewayWebhook(ctx context.Context, token, webhookURL string) error {
		"name":        "PSTN-Header-Sync",
		"enabled":     true,
		"targetUrl":   webhookURL,
		"eventFilters": []string{"telephony.call.initiated", "telephony.header.injected"},
		"headers":     map[string]string{"X-Sync-Source": "genesys-injector"},
	if err != nil {
		return fmt.Errorf("failed to marshal webhook payload: %w", err)
	req, err := http.NewRequestWithContext(ctx, http.MethodPost, fmt.Sprintf("%s/api/v2/platform/webhooks", baseURL), bytes.NewBuffer(jsonBody))
	if err != nil {
		return fmt.Errorf("failed to create webhook request: %w", err)
	if err != nil {
		return fmt.Errorf("webhook sync failed: %w", err)
	if resp.StatusCode != http.StatusCreated && resp.StatusCode != http.StatusOK {
		return fmt.Errorf("webhook sync failed %d: %s", resp.StatusCode, string(body))
	return nil
The following module combines authentication, validation, atomic updates, call leg triggering, webhook synchronization, latency tracking, and audit logging into a single executable package.
package main
import (
	"context"
	"encoding/json"
	"fmt"
	"log"
	"net/url"
	"os"
	"sync/atomic"
	"time"
// Metrics and Audit Tracking
type InjectorMetrics struct {
	TotalAttempts    int64
	SuccessfulInjects int64
	FailedValidations int64
	AvgLatencyMs     float64
var metrics InjectorMetrics
func logAudit(event string, payload interface{}, latency time.Duration) {
	record := map[string]interface{}{
		"timestamp": time.Now().UTC().Format(time.RFC3339),
		"event":     event,
		"payload":   payload,
		"latencyMs": latency.Milliseconds(),
		"orgId":     os.Getenv("GENESYS_ORGANIZATION_ID"),
	auditJSON, _ := json.Marshal(record)
	log.Printf("AUDIT: %s", string(auditJSON))
func main() {
	ctx := context.Background()
	token, err := acquireToken(ctx)
	if err != nil {
		log.Fatalf("Authentication failed: %v", err)
	providerID := os.Getenv("GENESYS_PROVIDER_ID")
	if providerID == "" {
		log.Fatal("GENESYS_PROVIDER_ID environment variable is required")
	payload := SipInjectionPayload{
		Headers: []HeaderManipulation{
			{Name: "X-Route-Matrix", Value: "A-Primary", Action: "prepend", Match: "exact"},
			{Name: "X-Custom-Header", Value: "gateway-sync-enabled", Action: "append"},
		RouteMatrix: "sip:trunk01.pstn.gateway.com:5060;transport=udp",
		PrependDirective: "priority-route-A",
	start := time.Now()
	atomic.AddInt64(&metrics.TotalAttempts, 1)
	err = updateTelephonyProvider(ctx, token, providerID, payload)
	if err != nil {
		atomic.AddInt64(&metrics.FailedValidations, 1)
		log.Fatalf("Provider update failed: %v", err)
	injectLatency := time.Since(start)
	atomic.AddInt64(&metrics.SuccessfulInjects, 1)
	metrics.AvgLatencyMs = float64(injectLatency.Milliseconds())
	logAudit("sip.header.injected", payload, injectLatency)
	// Trigger test call leg
	testStart := time.Now()
	err = triggerTestCallLeg(ctx, token, "+12025551234", "+12025559876")
	if err != nil {
		log.Printf("Call leg trigger warning: %v", err)
	} else {
		callLatency := time.Since(testStart)
		logAudit("call.leg.triggered", map[string]string{"to": "+12025551234"}, callLatency)
	// Sync with external PSTN gateway
	webhookStart := time.Now()
	err = syncPSTNGatewayWebhook(ctx, token, os.Getenv("EXTERNAL_WEBHOOK_URL"))
	if err != nil {
		log.Printf("Webhook sync warning: %v", err)
	} else {
		webhookLatency := time.Since(webhookStart)
		logAudit("webhook.pstn.synced", map[string]string{"url": os.Getenv("EXTERNAL_WEBHOOK_URL")}, webhookLatency)
	// Output final metrics
	finalMetrics := map[string]interface{}{
		"total_attempts":      metrics.TotalAttempts,
		"successful_injects":  metrics.SuccessfulInjects,
		"failed_validations":  metrics.FailedValidations,
		"avg_latency_ms":      metrics.AvgLatencyMs,
		"prepend_success_rate": float64(metrics.SuccessfulInjects) / float64(metrics.TotalAttempts) * 100,
	metricsJSON, _ := json.Marshal(finalMetrics)
	log.Printf("FINAL_METRICS: %s", string(metricsJSON))
Error: 409 Conflict (ETag Mismatch)
  • What causes it: Concurrent updates to the Telephony Provider resource modify the server state before your If-Match header matches the current version.
  • How to fix it: Implement exponential backoff and refetch the resource to obtain the fresh ETag before retrying the PUT request. The provided updateTelephonyProvider function handles this automatically.
  • Code showing the fix:
    if err != nil {
    continue // Retry with new ETag
Error: 400 Bad Request (SIP Header Size Exceeded)
  • What causes it: The aggregate size of injected headers exceeds the 4096-byte SIP constraint, or individual headers exceed 2048 bytes. Genesys Cloud rejects oversized payloads to prevent SIP stack fragmentation.
  • How to fix it: Validate header sizes before transmission. Trim redundant headers or compress values. Use the ValidateSipPayload function to enforce limits.
Error: 401 Unauthorized / 403 Forbidden
  • What causes it: Missing or expired OAuth token, or insufficient scopes (telephony:provider:write, telephony:call:write).
  • How to fix it: Verify the OAuth client credentials have the correct scopes assigned in the Genesys Cloud Admin Console. Ensure the token is refreshed before expiration.
if resp.StatusCode == http.StatusUnauthorized || resp.StatusCode == http.StatusForbidden {
    return fmt.Errorf("scope or token invalid: check telephony:provider:write and telephony:call:write permissions")
Error: SIP Loop Detection Failure
  • What causes it: Injected Route or Record-Route headers contain recursive directives that cause the SIP proxy to reject the message to prevent infinite routing loops.
  • How to fix it: Validate header values against known loop patterns. Ensure route matrices reference distinct downstream gateways.
