Injecting Genesys Cloud Quality Evaluation Comments via Python SDK
  • A Python module that constructs, validates, and atomically injects structured comment blocks into Genesys Cloud Quality evaluations using JSON Patch.
  • The implementation uses the official Genesys Cloud Python SDK for authentication and httpx for precise HTTP control over the PATCH /api/v2/quality/evaluations/{evaluationId} endpoint.
  • The tutorial covers Python 3.9+ with type hints, production retry logic, audit logging, and external webhook synchronization.
  • OAuth2 Client Credentials configured in Genesys Cloud with the quality:evaluation:write scope.
  • Genesys Cloud Python SDK: genesys-cloud-purecloud-platform-client>=2.0.0
  • HTTP client: httpx>=0.24.0
  • Validation/Serialization: pydantic>=2.0.0
  • Python 3.9 or higher.
  • External webhook endpoint URL for collaboration tool synchronization.
Genesys Cloud uses standard OAuth2 client credentials flow. The token endpoint is https://{environment}.mygen.com/oauth/token. You must cache the access token and handle expiration gracefully. The SDK provides token management, but explicit control is required for audit trails and retry boundaries.
import httpx
from dataclasses import dataclass
from typing import Optional
@dataclass
class GenesysAuthConfig:
    client_id: str
    client_secret: str
    environment: str = "mypurecloud.com"
    scope: str = "quality:evaluation:write"
class TokenManager:
    def __init__(self, config: GenesysAuthConfig):
        self.config = config
        self.expires_at: float = 0.0
        self.base_url = f"https://{config.environment}"
    def get_token(self) -> str:
        if self.token and time.time() < self.expires_at - 30:
            return self.token
        url = f"{self.base_url}/oauth/token"
        payload = {
            "client_id": self.config.client_id,
            "client_secret": self.config.client_secret,
            "scope": self.config.scope
        with httpx.Client(timeout=10.0) as client:
            response = client.post(url, data=payload)
            response.raise_for_status()
        token_data = response.json()
        self.token = token_data["access_token"]
        self.expires_at = time.time() + token_data["expires_in"]
        return self.token
The TokenManager caches the token and refreshes it thirty seconds before expiration. The quality:evaluation:write scope is mandatory for modifying evaluation comments.
Step 1: SDK Initialization & API Configuration
The Genesys Cloud Python SDK requires a PlatformClient configuration object. You initialize it with the environment and authentication provider. The SDK handles header injection, but you will use httpx directly for the PATCH operation to guarantee exact JSON Patch formatting and content-type enforcement.
from genesyscloud.platform.client import PlatformClient
from genesyscloud.quality.api.evaluations_api import EvaluationsApi
import logging
logger = logging.getLogger("quality_comment_injector")
class QualityInjectorConfig:
    def __init__(self, auth: TokenManager):
        self.auth = auth
        self.platform_client = PlatformClient(
            environment=auth.config.environment,
            client_id=auth.config.client_id,
            client_secret=auth.config.client_secret
        self.evaluations_api = EvaluationsApi(self.platform_client)
        self.api_base = f"https://{auth.config.environment}/api/v2"
The EvaluationsApi instance remains available for metadata lookups, but the comment injection uses direct HTTP to avoid SDK model serialization overhead for JSON Patch arrays.
Step 2: Payload Construction & Schema Validation
Genesys Cloud Quality evaluations enforce strict constraints on comment injection. The text field has a maximum length of 2000 characters. The timestamp must follow ISO 8601. The authorId must belong to an active user. The type field accepts GENERAL, SECTION, or SCORE. You must validate the comment matrix before constructing the JSON Patch payload.
import re
import json
from pydantic import BaseModel, field_validator
from typing import List
SENSITIVE_PATTERNS = [
    r"\b(?:ssn|social security|credit card|cvv)\b",
    r"\b\d{3}[-\s]?\d{2}[-\s]?\d{4}\b",
    r"\b(?:password|passwd|pwd)\s*[:=]\s*\S+"
class EvaluationComment(BaseModel):
    author_id: str
    author_name: str
    text: str
    comment_type: str = "GENERAL"
    timestamp: datetime
    @field_validator("text")
    @classmethod
    def validate_text_constraints(cls, v: str) -> str:
        if len(v) > 2000:
            raise ValueError("Comment text exceeds Genesys Cloud maximum length of 2000 characters.")
        if not v.strip():
            raise ValueError("Comment text cannot be empty or whitespace.")
        return v.strip()
    @field_validator("comment_type")
    @classmethod
    def validate_type(cls, v: str) -> str:
        valid_types = {"GENERAL", "SECTION", "SCORE"}
        if v not in valid_types:
            raise ValueError(f"Invalid comment type. Must be one of {valid_types}.")
        return v
    @field_validator("author_id")
    @classmethod
    def validate_user_attribution(cls, v: str) -> str:
        if not re.match(r"^[a-f0-9-]{36}$", v, re.IGNORECASE):
            raise ValueError("author_id must be a valid UUID format.")
        return v
def sanitize_comment(comment: EvaluationComment) -> EvaluationComment:
    for pattern in SENSITIVE_PATTERNS:
        if re.search(pattern, comment.text, re.IGNORECASE):
            raise ValueError("Comment contains sensitive or restricted content.")
    return comment
def build_json_patch_payload(comments: List[EvaluationComment]) -> str:
    patch_operations = []
    for c in comments:
        op = {
            "op": "add",
            "path": "/comments/-",
            "value": {
                "authorId": c.author_id,
                "authorName": c.author_name,
                "timestamp": c.timestamp.isoformat(),
                "text": c.text,
                "type": c.comment_type
        patch_operations.append(op)
    return json.dumps(patch_operations)
The validation pipeline enforces length limits, UUID format for attribution, ISO 8601 timestamps, and sensitive content filtering. The build_json_patch_payload function generates a compliant JSON Patch document that appends multiple comments atomically.
Step 3: Atomic PATCH Execution, Retry Logic, & Audit Tracking
The injection step performs an atomic PATCH request. You must handle HTTP 429 rate limits with exponential backoff, track latency, log audit trails, and trigger external webhooks on success.
from typing import Dict, Any
import statistics
@dataclass
class InjectionMetrics:
    latencies: list = field(default_factory=list)
    successes: int = 0
    failures: int = 0
    success_rate: float = 0.0
    def record_success(self, latency_ms: float):
        self.latencies.append(latency_ms)
        self.successes += 1
        self.success_rate = self.successes / (self.successes + self.failures)
    def record_failure(self):
        self.failures += 1
def inject_comments(
    auth: TokenManager,
    evaluation_id: str,
    comments: List[EvaluationComment],
    webhook_url: str,
    metrics: InjectionMetrics,
    max_retries: int = 3
) -> Dict[str, Any]:
    token = auth.get_token()
    url = f"{auth.base_url}/api/v2/quality/evaluations/{evaluation_id}"
    headers = {
        "Content-Type": "application/json-patch+json",
        "Accept": "application/json"
    payload = build_json_patch_payload(comments)
    start_time = time.time()
    last_exception = None
    for attempt in range(max_retries + 1):
            with httpx.Client(timeout=15.0) as client:
                response = client.patch(url, headers=headers, content=payload)
                retry_after = float(response.headers.get("Retry-After", 2 ** attempt))
                logger.warning(f"Rate limited. Retrying in {retry_after}s (attempt {attempt + 1})")
                time.sleep(retry_after)
            metrics.record_success(latency_ms)
            audit_log = {
                "event": "quality_comment_injected",
                "evaluation_id": evaluation_id,
                "comments_count": len(comments),
                "latency_ms": latency_ms,
                "status": "success",
                "timestamp": datetime.now(timezone.utc).isoformat()
            logger.info(json.dumps(audit_log))
            # Synchronize with external collaboration tool
            if webhook_url:
                _trigger_webhook(webhook_url, audit_log)
                "injected_count": len(comments),
                "metrics": metrics
            last_exception = e
            metrics.record_failure()
            if e.response.status_code in (401, 403):
                logger.error(f"Authentication/Authorization failed: {e.response.status_code}")
                raise
            logger.warning(f"PATCH failed with {e.response.status_code}. Attempt {attempt + 1}/{max_retries + 1}")
            if attempt < max_retries:
                time.sleep(2 ** attempt)
            else:
                raise
    raise last_exception or RuntimeError("Unexpected injection failure")
def _trigger_webhook(webhook_url: str, payload: Dict[str, Any]):
        with httpx.Client(timeout=5.0) as client:
            client.post(
                webhook_url,
                json=payload,
                headers={"Content-Type": "application/json"}
        logger.error(f"Webhook synchronization failed: {e}")
The injection loop implements exponential backoff for 429 responses. It calculates latency, updates success metrics, generates structured audit logs, and posts to an external webhook. The application/json-patch+json content type ensures the Quality engine processes the payload as an atomic update.
The following script combines authentication, validation, injection, metrics tracking, and audit logging into a single executable module. Replace the placeholder credentials and webhook URL before execution.
import logging
import sys
# Configure logging
logging.basicConfig(
    level=logging.INFO,
    format="%(asctime)s [%(levelname)s] %(name)s: %(message)s"
def main():
    # 1. Authentication Setup
    auth_config = GenesysAuthConfig(
        client_id="YOUR_CLIENT_ID",
        client_secret="YOUR_CLIENT_SECRET",
        environment="YOUR_ENVIRONMENT.mypurecloud.com"
    token_manager = TokenManager(auth_config)
    # 2. Comment Matrix Construction
    evaluation_id = "a1b2c3d4-e5f6-7890-abcd-ef1234567890"
    author_id = "98765432-abcd-ef01-2345-6789abcdef01"
    comment_batch = [
        EvaluationComment(
            author_id=author_id,
            author_name="Quality Automation Engine",
            text="Automated compliance check passed. Call adhered to required greeting and disclosure standards.",
            comment_type="GENERAL",
            timestamp=datetime.now(timezone.utc)
        EvaluationComment(
            text="Active listening metrics indicate strong rapport building during the troubleshooting phase.",
    # 3. Validation Pipeline
        validated_comments = [sanitize_comment(c) for c in comment_batch]
    except ValueError as ve:
        logger.error(f"Validation failed: {ve}")
        sys.exit(1)
    # 4. Metrics & Injection
    metrics = InjectionMetrics()
    webhook_url = "https://hooks.example.com/quality-sync"
        result = inject_comments(
            auth=token_manager,
            evaluation_id=evaluation_id,
            comments=validated_comments,
            webhook_url=webhook_url,
            metrics=metrics
        logger.info(f"Injection complete: {result}")
        logger.error(f"Injection failed: {e}")
        sys.exit(1)
    main()
The script validates the comment matrix, tracks latency and success rates, logs structured audit events, and synchronizes with an external endpoint. It requires only credential substitution and a valid evaluation ID to run.
Error: 400 Bad Request (Invalid JSON Patch or Schema Violation)
  • Cause: The Content-Type header is missing application/json-patch+json, or the patch array contains invalid op, path, or value structures. Genesys Cloud also returns 400 when comment text exceeds 2000 characters or when authorId does not match an active user.
  • Fix: Verify the header matches exactly application/json-patch+json. Ensure the path uses /comments/- for appending. Validate text length and author UUID format before sending.
  • Code Fix: The build_json_patch_payload function enforces correct structure. The EvaluationComment Pydantic model enforces length and UUID constraints.
Error: 403 Forbidden (Missing OAuth Scope)
  • Cause: The OAuth token lacks the quality:evaluation:write scope. Read-only scopes like quality:evaluation:read reject mutation requests.
  • Fix: Regenerate the OAuth token with the correct scope. Verify the client credentials in the Genesys Cloud admin console under Integrations.
  • Code Fix: The TokenManager explicitly requests quality:evaluation:write in the scope parameter.
Error: 409 Conflict (Optimistic Concurrency Violation)
  • Cause: Genesys Cloud uses version tracking for evaluations. If another process modifies the evaluation between your read and PATCH operation, the server rejects the update.
  • Fix: Fetch the current evaluation version via GET /api/v2/quality/evaluations/{evaluationId}, extract the version field, and include it in a conditional header if required. For comment-only appends, the Quality engine often bypasses version conflicts, but explicit version matching ensures safety.
  • Code Fix: Add If-Match: {version} header to the PATCH request when strict concurrency is required.
Error: 429 Too Many Requests (Rate Limit Cascade)
  • Cause: Exceeding the Genesys Cloud Quality API rate limits (typically 100 requests per minute per client). Bulk injection without backoff triggers cascading failures.
  • Fix: Implement exponential backoff with jitter. Respect the Retry-After header.
  • Code Fix: The inject_comments function parses Retry-After and applies 2 ** attempt delay before retrying.
