Injecting Genesys Cloud LLM Gateway System Prompts via Python SDK
A production-ready Python module that constructs, validates, and injects system prompts into the Genesys Cloud AI Gateway, implements versioned A/B traffic splitting, exports telemetry to external observability platforms, and maintains compliance audit logs. This tutorial uses the Genesys Cloud AI Gateway API (/api/v2/ai/llm/gateway/...) and the official genesyscloud Python SDK. The implementation targets Python 3.10+.
- OAuth 2.0 Client Credentials grant configured in Genesys Cloud
- Required scopes:
ai:prompt:write,ai:prompt:read,ai:telemetry:read,ai:gateway:write - SDK:
genesyscloud>=2.40.0 - Runtime: Python 3.10+
- Dependencies:
requests>=2.31.0,pydantic>=2.5.0 - External observability endpoint accepting JSON telemetry payloads
The Genesys Cloud platform requires a valid bearer token for every API call. The following class handles client credentials authentication, caches the token, and enforces a sixty-second safety margin before refresh.
import requests
from typing import Optional
from genesyscloud.rest import Configuration
class GenesysAuthManager:
def __init__(self, client_id: str, client_secret: str, org_domain: str):
self.client_id = client_id
self.org_domain = org_domain.rstrip("/")
self.base_url = f"https://{self.org_domain}"
self.config = Configuration()
self.config.host = self.base_url
def get_token(self) -> str:
if self.token and time.time() < self.token_expiry - 60:
return self.token
url = f"{self.base_url}/oauth/token"
payload = {"grant_type": "client_credentials"}
auth = (self.client_id, self.client_secret)
response = requests.post(url, data=payload, auth=auth)
response.raise_for_status()
data = response.json()
self.token = data["access_token"]
self.token_expiry = time.time() + data["expires_in"]
return self.token
The Configuration object from genesyscloud.rest establishes the base host and prepares the SDK environment. The token retrieval follows the standard OAuth 2.0 client credentials flow. The response body contains access_token and expires_in. Caching prevents unnecessary network calls and reduces rate limit exposure.
Step 1: Construct Prompt Configuration Payloads with Token Budget Validation
The AI Gateway requires structured prompt configurations that reference a model endpoint, define temperature parameters, and enforce safety guardrails. The payload must also respect token budget constraints to prevent inference failures.
import json
class PromptBuilder:
def __init__(self, auth: GenesysAuthManager):
self.auth = auth
self.base_url = auth.base_url
def _make_request(self, method: str, path: str, payload: Any = None) -> Dict[str, Any]:
headers = {
"Authorization": f"Bearer {self.auth.get_token()}",
url = f"{self.base_url}{path}"
response = requests.request(method, url, headers=headers, json=payload)
retry_after = int(response.headers.get("Retry-After", 5))
time.sleep(retry_after)
return self._make_request(method, path, payload)
return response.json()
def _validate_token_budget(self, text: str, max_tokens: int) -> bool:
estimated_tokens = len(text) // 4.0
if estimated_tokens > max_tokens:
raise ValueError(f"Token budget exceeded. Estimated: {estimated_tokens:.1f}, Limit: {max_tokens}")
return True
def build_and_create_prompt(self, name: str, model_ref: str, system_prompt: str,
temperature: float, safety_filters: List[str], max_tokens: int, version: str) -> Dict[str, Any]:
self._validate_token_budget(system_prompt, max_tokens)
payload = {
"name": name,
"modelEndpointRef": model_ref,
"systemPrompt": system_prompt,
"temperature": temperature,
"safetyGuardrails": {
"contentFiltering": safety_filters,
"maxTokens": max_tokens,
"blockedCategories": ["violence", "hate_speech", "self_harm"]
"version": version,
"trafficDistribution": {"defaultVersion": version}
# POST /api/v2/ai/llm/gateway/prompts
# Required scope: ai:prompt:write
# HTTP Request:
# POST /api/v2/ai/llm/gateway/prompts HTTP/1.1
# Host: {org}.mygen.com
# Authorization: Bearer {token}
# Content-Type: application/json
# Body: {payload}
# HTTP Response: 201 Created
# Body: {"id": "a1b2c3d4-e5f6-7890-abcd-ef1234567890", "version": "1.0.0", "status": "ACTIVE"}
return self._make_request("POST", "/api/v2/ai/llm/gateway/prompts", payload)
The _validate_token_budget method uses a character-to-token ratio heuristic. Production systems should integrate tiktoken for exact model-specific counting. The trafficDistribution field reserves space for A/B testing weights. The API returns a unique prompt identifier and confirms activation status.
Step 2: Versioned State Management with A/B Testing Hooks
Traffic splitting requires updating the prompt configuration with version weights. The API supports fractional distribution across multiple versions.
def configure_traffic_split(self, prompt_id: str, version_weights: Dict[str, float]) -> Dict[str, Any]:
total_weight = sum(version_weights.values())
if abs(total_weight - 1.0) > 0.01:
raise ValueError("Traffic distribution weights must sum to 1.0")
versions_payload = [{"version": k, "weight": v} for k, v in version_weights.items()]
payload = {
"versions": versions_payload,
"splitStrategy": "random"
# PUT /api/v2/ai/llm/gateway/prompts/{id}
# HTTP Request:
# PUT /api/v2/ai/llm/gateway/prompts/{prompt_id} HTTP/1.1
# Body: {payload}
# HTTP Response: 200 OK
# Body: {"id": "{prompt_id}", "trafficDistribution": {"versions": [...]}}
return self._make_request("PUT", f"/api/v2/ai/llm/gateway/prompts/{prompt_id}", payload)
The validation ensures weights sum to exactly one. The splitStrategy parameter controls how the gateway routes inference requests. Random splitting provides statistical parity for model tuning experiments.
Step 3: Prompt Optimization Logic with Few-Shot Generation and Context Window Resizing
Generative accuracy improves when few-shot examples are dynamically injected and the context window is constrained to prevent token overflow.
def optimize_prompt_context(self, base_prompt: str, examples: List[Dict[str, str]],
context_window_limit: int) -> str:
few_shot_block = "\n".join([f"User: {ex['input']}\nAssistant: {ex['output']}" for ex in examples])
combined = f"{base_prompt}\n\nExamples:\n{few_shot_block}"
while len(combined) // 4.0 > context_window_limit and examples:
examples.pop(0)
return combined
def update_prompt_with_optimization(self, prompt_id: str, optimized_prompt: str, version: str) -> Dict[str, Any]:
payload = {
"systemPrompt": optimized_prompt,
"version": version
The resizing loop removes the oldest few-shot examples until the token budget constraint is satisfied. This prevents context window overflow during high-volume inference sessions.
Step 4: Telemetry Exports and Performance Tracking
The AI Gateway exposes telemetry endpoints that return latency, token utilization, and error rates. The following method paginates through results and exports metrics to an external observability platform.
def fetch_and_export_telemetry(self, prompt_id: str, start_time: str, end_time: str,
observability_url: str) -> List[Dict[str, Any]]:
all_metrics = []
cursor = None
while True:
params = {
"promptId": prompt_id,
"startTime": start_time,
"endTime": end_time,
"pageSize": 50
if cursor:
params["cursor"] = cursor
# GET /api/v2/ai/llm/gateway/telemetry
# Required scope: ai:telemetry:read
response = self._make_request("GET", "/api/v2/ai/llm/gateway/telemetry", params)
entities = response.get("entities", [])
all_metrics.extend(entities)
cursor = response.get("nextPageCursor")
if not cursor:
break
time.sleep(0.5)
headers = {"Content-Type": "application/json", "X-Source": "genesys-ai-gateway"}
export_payload = {
"metrics": all_metrics,
"exportTimestamp": time.strftime("%Y-%m-%dT%H:%M:%SZ", time.gmtime())
export_resp = requests.post(observability_url, json=export_payload, headers=headers)
export_resp.raise_for_status()
return all_metrics
The pagination loop respects the nextPageCursor field. The export payload structures latency and token utilization rates for downstream dashboarding. The time.sleep(0.5) prevents cascading 429 responses during high-frequency polling.
Step 5: Audit Logs and Controlled Prompt Injector
Compliance requires immutable audit trails for prompt modifications. The injector endpoint provides controlled orchestration for runtime inference.
def generate_audit_log(self, prompt_id: str, action: str, details: Dict[str, Any]) -> Dict[str, Any]:
log_entry = {
"action": action,
"timestamp": time.strftime("%Y-%m-%dT%H:%M:%SZ", time.gmtime()),
"details": details,
"complianceStatus": "VALIDATED",
"metadata": {"sourceSystem": "prompt-manager", "sdkVersion": "2.40.0"}
# POST /api/v2/ai/llm/gateway/audit-logs
# Required scope: ai:gateway:write
return self._make_request("POST", "/api/v2/ai/llm/gateway/audit-logs", log_entry)
def inject_prompt(self, prompt_id: str, user_input: str, session_id: str) -> Dict[str, Any]:
payload = {
"userInput": user_input,
"sessionId": session_id,
"options": {
"stream": False,
"returnTokenUsage": True
# POST /api/v2/ai/llm/gateway/invocations
# HTTP Request:
# POST /api/v2/ai/llm/gateway/invocations HTTP/1.1
# Body: {payload}
# Body: {"responseId": "inv-123", "output": "Generated text...", "tokenUsage": {"prompt": 120, "completion": 45}}
return self._make_request("POST", "/api/v2/ai/llm/gateway/invocations", payload)
The audit log captures the exact action, timestamp, and compliance status. The injector returns token usage metrics directly in the response body, enabling real-time cost tracking.
import requests
from typing import Dict, Any, List, Optional
return self.token
response = requests.post(url, data={"grant_type": "client_credentials"}, auth=(self.client_id, self.client_secret))
return self.token
class GenesysPromptManager:
self.auth = auth
headers = {"Authorization": f"Bearer {self.auth.get_token()}", "Content-Type": "application/json"}
return True
def create_prompt(self, name: str, model_ref: str, system_prompt: str,
payload = {
"name": name, "modelEndpointRef": model_ref, "systemPrompt": system_prompt,
"temperature": temperature, "safetyGuardrails": {"contentFiltering": safety_filters, "maxTokens": max_tokens},
"version": version, "trafficDistribution": {"defaultVersion": version}
if abs(sum(version_weights.values()) - 1.0) > 0.01:
payload = {"trafficDistribution": {"versions": [{"version": k, "weight": v} for k, v in version_weights.items()], "splitStrategy": "random"}}
def optimize_prompt_context(self, base_prompt: str, examples: List[Dict[str, str]], context_window_limit: int) -> str:
examples.pop(0)
return combined
def fetch_and_export_telemetry(self, prompt_id: str, start_time: str, end_time: str, observability_url: str) -> List[Dict[str, Any]]:
all_metrics, cursor = [], None
while True:
params = {"promptId": prompt_id, "startTime": start_time, "endTime": end_time, "pageSize": 50}
if cursor: params["cursor"] = cursor
all_metrics.extend(response.get("entities", []))
if not cursor: break
time.sleep(0.5)
requests.post(observability_url, json={"metrics": all_metrics, "exportTimestamp": time.strftime("%Y-%m-%dT%H:%M:%SZ", time.gmtime())})
return all_metrics
return self._make_request("POST", "/api/v2/ai/llm/gateway/audit-logs", {
"promptId": prompt_id, "action": action, "timestamp": time.strftime("%Y-%m-%dT%H:%M:%SZ", time.gmtime()),
"details": details, "complianceStatus": "VALIDATED"
return self._make_request("POST", "/api/v2/ai/llm/gateway/invocations", {
"promptId": prompt_id, "userInput": user_input, "sessionId": session_id,
"options": {"stream": False, "returnTokenUsage": True}
auth = GenesysAuthManager(client_id="YOUR_CLIENT_ID", client_secret="YOUR_CLIENT_SECRET", org_domain="YOUR_ORG.mygen.com")
manager = GenesysPromptManager(auth)
prompt_resp = manager.create_prompt(
name="support_agent", model_ref="anthropic/claude-3-sonnet",
system_prompt="You are a helpful customer support agent.", temperature=0.2,
safety_filters=["pii", "profanity"], max_tokens=1500, version="1.0.0"
prompt_id = prompt_resp["id"]
manager.generate_audit_log(prompt_id, "CREATE", {"version": "1.0.0"})
print(f"Prompt created: {prompt_id}")
- Cause: Expired or invalid OAuth token, or incorrect client credentials.
- Fix: Verify the
client_idandclient_secretmatch a registered OAuth client in Genesys Cloud. Ensure the token refresh logic runs before expiry. Theget_tokenmethod enforces a sixty-second buffer to prevent mid-request expiration. - Code Fix: The authentication class automatically retries token acquisition. Log the
response.textfrom/oauth/tokento verify credential acceptance.
Error: 403 Forbidden
- Cause: Missing required OAuth scope on the client application.
- Fix: Navigate to the Genesys Cloud admin console, locate the OAuth client, and append
ai:prompt:write,ai:telemetry:read, orai:gateway:writedepending on the failing endpoint. Regenerate the client secret if scope changes require reauthorization. - Code Fix: Catch
requests.exceptions.HTTPErrorand inspectresponse.status_code == 403. Print the required scope from the error payload.
- Cause: Exceeding the AI Gateway rate limits for prompt creation or telemetry polling.
- Fix: Implement exponential backoff. The
_make_requestmethod reads theRetry-Afterheader and sleeps accordingly. For telemetry loops, maintain a minimum interval of five hundred milliseconds between requests. - Code Fix: The retry logic is embedded in
_make_request. Add a maximum retry counter to prevent infinite loops in degraded network conditions.
Error: 400 Bad Request (Token Budget Violation)
- Cause: System prompt character count exceeds the
max_tokensthreshold defined insafetyGuardrails. - Fix: Adjust the
max_tokensvalue to match the actual prompt length, or truncate the system prompt. The_validate_token_budgetmethod raises aValueErrorbefore the API call, allowing graceful fallback to a compressed prompt variant. - Code Fix: Wrap
create_promptin a try-except block that catchesValueErrorand logs the token estimation discrepancy.
