Injecting Genesys Cloud Agent Assist Knowledge Suggestions via Java
A Java service that constructs and injects Agent Assist knowledge suggestions using the Genesys Cloud Knowledge API and a custom WebSocket push channel, validates payloads against relevance constraints and maximum count limits, calculates semantic match scores, tracks latency and success metrics, and generates structured audit logs for governance.
This tutorial uses the Genesys Cloud Java SDK (genesyscloud) and standard Jakarta WebSocket APIs to interface with /api/v2/knowledge/suggestions and real-time push endpoints.
The programming language covered is Java 17+.
- OAuth 2.0 Client Credentials flow with scopes:
knowledge:suggestion,knowledge:document,agentassist:config,conversation:read - Genesys Cloud Java SDK version 15.x or newer
- Java Development Kit 17+
- Maven or Gradle build system
- Dependencies:
com.genesyscloud:genesyscloud:15.x.x,com.fasterxml.jackson.core:jackson-databind:2.15.x,jakarta.websocket:jakarta.websocket-api:2.1.0,org.apache.httpcomponents.client5:httpclient5:5.2.x
The Genesys Cloud Java SDK manages OAuth token acquisition and caching automatically when initialized with client credentials. You must configure the environment variables GENESYS_CLOUD_CLIENT_ID, GENESYS_CLOUD_CLIENT_SECRET, and GENESYS_CLOUD_REGION before execution.
import com.genesyscloud.platform.client.v2.PureCloudPlatformClientV2;
import com.genesyscloud.platform.client.v2.auth.AuthMethod;
import com.genesyscloud.platform.client.v2.auth.OAuthClientCredentials;
public class GenesysAuthSetup {
public static PureCloudPlatformClientV2 initializeClient(String clientId, String clientSecret, String region) {
PureCloudPlatformClientV2 client = PureCloudPlatformClientV2.create();
OAuthClientCredentials credentials = new OAuthClientCredentials(clientId, clientSecret);
client.setAuthMethods(Arrays.asList(new AuthMethod(credentials)));
client.setRegion(region);
return client;
The SDK caches the access token and handles refresh automatically. If you require explicit token lifecycle control, you may intercept the OAuthClientCredentials refresh callback. For this integration, the default caching behavior provides sufficient reliability for high-throughput injection workflows.
Step 1: SDK Initialization and Knowledge API Binding
Bind the initialized client to the KnowledgeApi facade. This facade exposes the /api/v2/knowledge/suggestions endpoint and handles serialization, pagination, and retry policies.
import com.genesyscloud.platform.client.v2.api.KnowledgeApi;
public class SuggestionApiClient {
private final KnowledgeApi knowledgeApi;
public SuggestionApiClient(PureCloudPlatformClientV2 client) {
this.knowledgeApi = new KnowledgeApi(client);
public KnowledgeApi getKnowledgeApi() {
return knowledgeApi;
The KnowledgeApi instance inherits the client’s authentication context. All subsequent calls to createSuggestion or getDocument will automatically attach the bearer token and handle 429 rate-limit backoffs according to the SDK’s default exponential decay policy.
Step 2: Payload Construction and Schema Validation
Construct the injection payload using suggestion-ref, context-matrix, and push directive structures. Validate the payload against relevance constraints and maximum suggestion count limits before transmission.
import com.genesyscloud.platform.client.v2.model.SuggestionBody;
import com.genesyscloud.platform.client.v2.model.SuggestionReference;
import com.genesyscloud.platform.client.v2.api.client.ApiException;
import java.util.List;
import java.util.Map;
public class InjectionPayloadValidator {
private static final int MAX_SUGGESTION_COUNT = 15;
private static final double MIN_RELEVANCE_THRESHOLD = 0.72;
private final ObjectMapper mapper = new ObjectMapper();
private final ConcurrentHashMap<String, Boolean> seenSuggestions = new ConcurrentHashMap<>();
public void validateAndConstruct(List<Map<String, Object>> rawSuggestions, String conversationId) throws ApiException {
if (rawSuggestions.size() > MAX_SUGGESTION_COUNT) {
throw new ApiException(400, "Exceeds maximum-suggestion-count limit of " + MAX_SUGGESTION_COUNT);
List<SuggestionBody> validatedBodies = new java.util.ArrayList<>();
for (Map<String, Object> raw : rawSuggestions) {
double relevance = (double) raw.getOrDefault("relevanceScore", 0.0);
String contentHash = hashContent(raw.get("title").toString(), raw.get("snippet").toString());
if (relevance < MIN_RELEVANCE_THRESHOLD) {
continue;
if (seenSuggestions.putIfAbsent(contentHash, true) != null) {
continue;
SuggestionReference ref = new SuggestionReference();
ref.setKnowledgeBaseId((String) raw.get("knowledgeBaseId"));
ref.setDocumentId((String) raw.get("documentId"));
SuggestionBody body = new SuggestionBody();
body.setReference(ref);
body.setConversationId(conversationId);
body.setRelevance(relevance);
validatedBodies.add(body);
if (validatedBodies.isEmpty()) {
throw new ApiException(400, "No suggestions passed relevance-constraints validation");
private String hashContent(String title, String snippet) {
return java.util.Objects.hash(title.toLowerCase(), snippet.toLowerCase()) + "";
The validator enforces schema constraints before any network call occurs. The relevance-constraints check filters low-confidence matches. The maximum-suggestion-count limit prevents UI saturation. The seenSuggestions map provides duplicate-content checking at the application level.
Step 3: Semantic Match Calculation and Priority Weight Evaluation
Calculate semantic match scores and assign priority weights before push. This logic runs synchronously to ensure deterministic ordering.
import java.util.Comparator;
public class SemanticPriorityEvaluator {
public static List<Map<String, Object>> evaluateAndSort(List<Map<String, Object>> candidates) {
return candidates.stream()
.map(candidate -> {
double semanticScore = calculateCosineSimilarity(
(String) candidate.get("queryVector"),
(String) candidate.get("docVector")
double urgency = (double) candidate.getOrDefault("urgencyWeight", 1.0);
candidate.put("semanticMatch", semanticScore);
candidate.put("priorityWeight", semanticScore * urgency);
return candidate;
.sorted(Comparator.comparingDouble((Map<String, Object> c) -> (double) c.get("priorityWeight")).reversed())
.toList();
private static double calculateCosineSimilarity(String vec1Str, String vec2Str) {
double[] v1 = parseVector(vec1Str);
double[] v2 = parseVector(vec2Str);
double dotProduct = 0;
double norm1 = 0;
double norm2 = 0;
for (int i = 0; i < v1.length; i++) {
dotProduct += v1[i] * v2[i];
norm1 += v1[i] * v1[i];
norm2 += v2[i] * v2[i];
return (norm1 == 0 || norm2 == 0) ? 0.0 : dotProduct / (Math.sqrt(norm1) * Math.sqrt(norm2));
private static double[] parseVector(String csv) {
return java.util.Arrays.stream(csv.split(",")).mapToDouble(String::trim).toArray();
The semantic match calculation uses cosine similarity over normalized vectors. The priority weight multiplies the semantic score by an urgency multiplier. Sorting ensures high-value suggestions reach the agent first.
Step 4: Atomic WebSocket SEND and Push Validation Pipeline
Transmit the validated payload via an atomic WebSocket SEND operation. Implement agent-focus verification and format verification before dispatch.
import jakarta.websocket.ClientEndpointConfig;
import jakarta.websocket.ContainerProvider;
import jakarta.websocket.WebSocketContainer;
import jakarta.websocket.Session;
import java.net.URI;
import java.util.concurrent.locks.ReentrantLock;
public class WebSocketPushEngine {
private final Session session;
private final ReentrantLock sendLock = new ReentrantLock();
public WebSocketPushEngine(String wsUrl) throws Exception {
WebSocketContainer container = ContainerProvider.getWebSocketContainer();
this.session = container.connectToServer(
new Object(),
ClientEndpointConfig.Builder.create().build(),
new URI(wsUrl)
public void pushSuggestion(Map<String, Object> directive, String agentId, boolean isAgentFocused) throws Exception {
if (!isAgentFocused) {
throw new IllegalStateException("Agent-focus verification failed: agent is not in an active conversation");
sendLock.lock();
String payloadJson = mapper.writeValueAsString(directive);
session.getBasicRemote().sendText(payloadJson);
triggerAutoDisplay(directive);
} finally {
sendLock.unlock();
private void triggerAutoDisplay(Map<String, Object> directive) {
directive.put("displayTrigger", true);
directive.put("triggerTimestamp", System.currentTimeMillis());
The ReentrantLock guarantees atomic SEND operations across concurrent injection threads. Format verification occurs during JSON serialization. The isAgentFocused flag prevents information overload when the agent is idle or navigating away from the workspace. The triggerAutoDisplay method appends automatic display triggers to the payload.
Step 5: Metrics Tracking, Webhook Sync, and Audit Logging
Track injection latency, push success rates, and synchronize with external knowledge management systems via suggestion displayed webhooks. Generate structured audit logs for governance.
import java.time.Instant;
import java.util.concurrent.atomic.AtomicLong;
import java.util.concurrent.atomic.AtomicInteger;
import org.apache.hc.client5.http.classic.methods.HttpPost;
import org.apache.hc.client5.http.impl.classic.CloseableHttpClient;
import org.apache.hc.client5.http.impl.classic.HttpClients;
import org.apache.hc.core5.http.io.entity.StringEntity;
public class InjectionMetricsAndAudit {
private final AtomicLong totalLatencyNanos = new AtomicLong(0);
private final AtomicInteger successCount = new AtomicInteger(0);
private final AtomicInteger failureCount = new AtomicInteger(0);
private final CloseableHttpClient httpClient = HttpClients.createDefault();
public void recordAttempt(boolean success, long latencyNanos, Map<String, Object> auditPayload) throws Exception {
if (success) {
successCount.incrementAndGet();
} else {
failureCount.incrementAndGet();
totalLatencyNanos.addAndGet(latencyNanos);
publishAuditLog(auditPayload);
syncExternalKm(auditPayload);
public double getAverageLatencyMs() {
long totalAttempts = successCount.get() + failureCount.get();
return totalAttempts == 0 ? 0.0 : (totalLatencyNanos.get() / (1_000_000.0)) / totalAttempts;
public double getPushSuccessRate() {
long total = successCount.get() + failureCount.get();
return total == 0 ? 0.0 : successCount.get() / (double) total;
private void publishAuditLog(Map<String, Object> payload) {
payload.put("auditTimestamp", Instant.now().toString());
payload.put("auditEventType", "suggestion_injection_attempt");
System.out.println("AUDIT_LOG: " + safeToJson(payload));
private void syncExternalKm(Map<String, Object> payload) throws Exception {
String webhookUrl = "https://external-km.example.com/webhooks/suggestion-displayed";
HttpPost post = new HttpPost(webhookUrl);
post.setHeader("Content-Type", "application/json");
post.setEntity(new StringEntity(safeToJson(payload)));
httpClient.execute(post, response -> {
int status = response.getCode();
if (status < 200 || status >= 300) {
throw new RuntimeException("Webhook sync failed with status " + status);
return null;
private String safeToJson(Object obj) {
return mapper.writeValueAsString(obj);
} catch (Exception e) {
return "{}";
The metrics tracker aggregates latency and success rates using thread-safe atomic counters. The audit log publisher emits structured events for governance compliance. The external KM sync fires a POST to the suggestion displayed webhook to maintain alignment between the Genesys Cloud session and downstream knowledge repositories.
import java.util.*;
public class AgentAssistSuggestionInjector {
private final WebSocketPushEngine pushEngine;
private final InjectionMetricsAndAudit metrics;
private final ReentrantLock pipelineLock = new ReentrantLock();
public AgentAssistSuggestionInjector(PureCloudPlatformClientV2 client, String wsUrl) throws Exception {
this.pushEngine = new WebSocketPushEngine(wsUrl);
this.metrics = new InjectionMetricsAndAudit();
public void injectSuggestions(String conversationId, String agentId, boolean isAgentFocused, List<Map<String, Object>> rawCandidates) {
long startNanos = System.nanoTime();
boolean success = false;
Map<String, Object> auditPayload = new LinkedHashMap<>();
auditPayload.put("conversationId", conversationId);
auditPayload.put("agentId", agentId);
List<Map<String, Object>> ranked = SemanticPriorityEvaluator.evaluateAndSort(rawCandidates);
List<SuggestionBody> validatedBodies = new ArrayList<>();
for (Map<String, Object> candidate : ranked) {
if (validatedBodies.size() >= MAX_SUGGESTION_COUNT) break;
double relevance = (double) candidate.getOrDefault("semanticMatch", 0.0);
if (relevance < MIN_RELEVANCE_THRESHOLD) continue;
(String) candidate.get("title"),
(String) candidate.get("snippet")
if (seenSuggestions.putIfAbsent(contentHash, true) != null) continue;
ref.setKnowledgeBaseId((String) candidate.get("knowledgeBaseId"));
ref.setDocumentId((String) candidate.get("documentId"));
knowledgeApi.postKnowledgeSuggestion(conversationId, validatedBodies);
Map<String, Object> pushDirective = new LinkedHashMap<>();
pushDirective.put("suggestion-ref", validatedBodies.stream()
.map(b -> b.getReference().getDocumentId()).toList());
pushDirective.put("context-matrix", Map.of(
"conversationId", conversationId,
"agentId", agentId,
"timestamp", System.currentTimeMillis()
pushDirective.put("push directive", "display_immediate");
pushEngine.pushSuggestion(pushDirective, agentId, isAgentFocused);
success = true;
auditPayload.put("error", e.getClass().getSimpleName() + ": " + e.getMessage());
} finally {
long latency = System.nanoTime() - startNanos;
auditPayload.put("latencyNanos", latency);
auditPayload.put("success", success);
metrics.recordAttempt(success, latency, auditPayload);
} catch (Exception ex) {
System.err.println("Audit recording failed: " + ex.getMessage());
return String.valueOf(Objects.hash(title.toLowerCase(), snippet.toLowerCase()));
public static void main(String[] args) throws Exception {
String clientId = System.getenv("GENESYS_CLOUD_CLIENT_ID");
String clientSecret = System.getenv("GENESYS_CLOUD_CLIENT_SECRET");
String region = System.getenv("GENESYS_CLOUD_REGION");
client.setAuthMethods(Arrays.asList(new com.genesyscloud.platform.client.v2.auth.AuthMethod(
new com.genesyscloud.platform.client.v2.auth.OAuthClientCredentials(clientId, clientSecret))));
AgentAssistSuggestionInjector injector = new AgentAssistSuggestionInjector(client, "wss://your-ws-endpoint.example.com/agent-assist-push");
List<Map<String, Object>> candidates = Arrays.asList(
Map.of(
"title", "Password Reset Procedure",
"snippet", "Navigate to security settings and select reset.",
"knowledgeBaseId", "kb-123",
"documentId", "doc-456",
"queryVector", "0.2,0.5,0.1",
"docVector", "0.21,0.49,0.12",
"urgencyWeight", 1.5
injector.injectSuggestions("conv-abc", "agent-xyz", true, candidates);
System.out.println("Injection complete. Success rate: " + injector.metrics.getPushSuccessRate());
- What causes it: Expired OAuth token, invalid client credentials, or missing
knowledge:suggestionscope. - How to fix it: Verify environment variables. Ensure the OAuth application has the
knowledge:suggestionandknowledge:documentscopes assigned. The SDK will retry token refresh automatically, but stale credentials require manual rotation. - Code showing the fix: Replace the client credentials object and call
client.setAuthMethods()before reinitializing theKnowledgeApi.
Error: 403 Forbidden
- What causes it: The OAuth application lacks permissions to write to the target knowledge base, or the conversation ID does not belong to the authenticated user context.
- How to fix it: Grant the
knowledge:suggestion:writepermission to the OAuth application in the Genesys Cloud admin console. Verify theconversationIdmatches an active session owned by the service user. - Code showing the fix: Validate conversation ownership via
GET /api/v2/conversations/{id}before injection.
- What causes it: Exceeding the Genesys Cloud rate limit for suggestion creation or WebSocket message throughput.
- How to fix it: Implement exponential backoff. The SDK handles REST retries automatically. For WebSocket pushes, throttle messages using a
ScheduledExecutorServicewith a 100ms minimum interval between SEND operations. - Code showing the fix: Wrap
session.getBasicRemote().sendText()in a rate-limited queue that processes messages sequentially withThread.sleep(100).
Error: 400 Bad Request (Validation Failure)
- What causes it: Payload exceeds
maximum-suggestion-count, relevance score falls below threshold, or duplicate content hash collision occurs. - How to fix it: Adjust the
MAX_SUGGESTION_COUNTconstant or increase theMIN_RELEVANCE_THRESHOLD. Clear theseenSuggestionscache if stale data blocks valid injections. - Code showing the fix: Log the rejected candidate hashes and adjust the semantic vector generation pipeline to produce higher-differentiation scores.
Error: WebSocket Connection Refused or Stale Session
- What causes it: Network timeout, server-side session eviction, or invalid WebSocket URL.
- How to fix it: Implement session health checks. Reconnect the
WebSocketPushEnginewhensession.isOpen()returns false. - Code showing the fix: Add a
@OnClosecallback that triggerscontainer.connectToServer()with exponential backoff.
