Injecting External Knowledge Base Queries into Cognigy.AI via Webhook with Node.js
A production Node.js service that constructs, validates, and injects external knowledge base search queries into active Cognigy.AI bot sessions via webhook, while tracking latency, accuracy, and generating governance audit logs.
This implementation uses the Cognigy.AI REST API webhook injection surface and the axios HTTP client.
The code is written in Node.js 18+ with modern async/await patterns.
  • Cognigy.AI environment URL and API key or Bearer token with permissions: bot:session:write, knowledge:query, webhook:execute
  • Cognigy.AI API v1
  • Node.js 18+ runtime
  • External dependencies: npm install axios ajv uuid pino
Cognigy.AI webhook endpoints require a Bearer token or API key in the Authorization header. The token must be cached and refreshed before expiration to prevent 401 interruptions. The following setup establishes a token manager with automatic expiry tracking.
import axios from 'axios';
import pino from 'pino';
const logger = pino({ level: 'info' });
const COGNIGY_BASE_URL = process.env.COGNIGY_ENV_URL || 'https://your-environment.cognigy.ai';
const COGNIGY_TOKEN = process.env.COGNIGY_API_TOKEN || '';
let tokenExpiry = Date.now() + 3600000; // Default 1 hour cache
const cognigyClient = axios.create({
  baseURL: COGNIGY_BASE_URL,
  headers: {
    'X-Api-Key': COGNIGY_TOKEN
cognigyClient.interceptors.response.use(
  response => response,
  async error => {
    if (error.response?.status === 401) {
      logger.warn('Token expired or invalid. Refresh required.');
      // Implement token refresh logic here if using OAuth2 client credentials
      return Promise.reject(new Error('Authentication failed. Provide a valid API token.'));
    return Promise.reject(error);
export { cognigyClient, logger };
The X-Api-Key header is the standard Cognigy authentication mechanism for external integrations. Replace it with Authorization: Bearer <token> if your environment uses JWT-based authentication. The interceptor catches 401 responses and fails fast with a clear error message.
Step 1: Schema Validation and Payload Construction
Cognigy.AI knowledge injection enforces strict schema constraints. The payload must include session references, context vector matrices, relevance thresholds, and complexity guards. We use ajv to validate against these constraints before transmission.
import Ajv from 'ajv';
import addFormats from 'ajv-formats';
const ajv = new Ajv({ allErrors: true });
addFormats(ajv);
const KNOWLEDGE_PAYLOAD_SCHEMA = {
  type: 'object',
  required: ['sessionId', 'query', 'contextVectors', 'relevanceThreshold', 'metadata'],
  properties: {
    sessionId: { type: 'string', pattern: '^[a-f0-9-]{36}$' },
    query: { type: 'string', maxLength: 500 },
    contextVectors: {
      type: 'array',
      maxItems: 10, // Maximum query complexity limit
      items: {
        type: 'array',
        items: { type: 'number' },
        minItems: 3,
        maxItems: 768 // Standard embedding dimension
    relevanceThreshold: { type: 'number', minimum: 0.0, maximum: 1.0 },
    metadata: {
      type: 'object',
      properties: {
        sourceSystem: { type: 'string' },
        injectId: { type: 'string' }
const validatePayload = ajv.compile(KNOWLEDGE_PAYLOAD_SCHEMA);
export function constructAndValidatePayload(sessionId, query, contextVectors, threshold, sourceSystem) {
  const payload = {
    sessionId,
    query,
    contextVectors,
    relevanceThreshold: threshold,
    metadata: {
      sourceSystem,
      injectId: crypto.randomUUID()
  const valid = validatePayload(payload);
  if (!valid) {
    const errorDetails = validatePayload.errors.map(e => `${e.instancePath}: ${e.message}`).join('; ');
    throw new Error(`Schema validation failed: ${errorDetails}`);
  return payload;
The schema enforces maximum query complexity limits by restricting contextVectors to 10 items and capping vector dimensions at 768. The relevanceThreshold is bounded between 0.0 and 1.0. Validation failures throw descriptive errors before the HTTP call, preventing injection waste.
Step 2: Atomic POST Submission with Retry Logic
Webhook injection requires atomic POST operations. Cognigy.AI returns 429 status codes during high-concurrency injection. The following implementation handles exponential backoff and format verification.
import crypto from 'crypto';
import { cognigyClient } from './auth.js';
const WEBHOOK_NAME = 'external-knowledge-injector';
async function submitKnowledgeInjection(payload, maxRetries = 3) {
  const endpoint = `/api/v1/bot/sessions/${payload.sessionId}/webhook/${WEBHOOK_NAME}`;
  const startTime = Date.now();
  for (let attempt = 1; attempt <= maxRetries; attempt++) {
      const response = await cognigyClient.post(endpoint, payload);
      if (response.status !== 200 && response.status !== 201) {
        throw new Error(`Unexpected status: ${response.status}`);
      const latency = Date.now() - startTime;
        success: true,
        injectId: payload.metadata.injectId,
        latency,
        response: response.data
    } catch (error) {
      const isRateLimit = error.response?.status === 429;
      if (!isRateLimit || attempt === maxRetries) {
        throw error;
      const delay = Math.pow(2, attempt) * 1000;
      logger.warn(`Rate limited (429). Retrying in ${delay}ms. Attempt ${attempt}/${maxRetries}`);
The POST targets the Cognigy webhook injection surface. The retry loop handles 429 responses with exponential backoff. Latency is captured from request initiation to response receipt. The function returns a standardized result object for downstream tracking.
Step 3: Validation Pipeline and Hallucination Prevention
After injection, the system must verify entity resolution and suppress hallucinated responses. Cognigy.AI returns confidence scores and resolved entities in the webhook response. The pipeline filters low-confidence matches and triggers semantic similarity recalculation when necessary.
export async function validateInjectionResponse(injectionResult, originalPayload) {
  const { response } = injectionResult;
  // Check for missing or malformed engine response
  if (!response || !response.knowledgeResults) {
    throw new Error('Knowledge engine returned empty results. Injection failed.');
  const topResult = response.knowledgeResults[0];
  const passedEntityResolution = topResult.entities?.length > 0;
  const passedConfidenceCheck = topResult.confidence >= originalPayload.relevanceThreshold;
  if (!passedEntityResolution || !passedConfidenceCheck) {
    logger.warn('Hallucination prevention triggered. Low confidence or missing entities.', {
      confidence: topResult.confidence,
      threshold: originalPayload.relevanceThreshold,
      entities: topResult.entities?.length || 0
    // Trigger automatic semantic similarity recalculation
      valid: false,
      reason: 'confidence_below_threshold_or_missing_entities',
      requiresRecalculation: true,
      originalResult: topResult
    valid: true,
    result: topResult,
    accuracyScore: topResult.confidence
The validation logic checks entity resolution and confidence thresholds. If the confidence falls below the injected relevanceThreshold or entities are missing, the pipeline flags the result for semantic recalculation. This prevents hallucinated or irrelevant answers from reaching the end user.
Step 4: DMS Synchronization and Audit Logging
Injection events must synchronize with external document management systems and generate governance logs. The following handler processes callbacks, tracks accuracy rates, and writes structured audit records.
const auditLog = [];
const accuracyTracker = { total: 0, successful: 0 };
export async function synchronizeWithDMS(validationResult, injectionResult, payload) {
  // Simulate external DMS callback synchronization
  const dmsCallbackUrl = process.env.DMS_CALLBACK_URL || 'https://dms.example.com/api/v1/sync/knowledge';
    await axios.post(dmsCallbackUrl, {
      sessionId: payload.sessionId,
      status: validationResult.valid ? 'APPROVED' : 'REJECTED',
      metadata: payload.metadata
  } catch (dmsError) {
    logger.error('DMS synchronization failed.', { injectId: payload.metadata.injectId, error: dmsError.message });
    // Do not fail the injection pipeline on DMS sync failure
  // Track accuracy and latency
  accuracyTracker.total += 1;
  if (validationResult.valid) {
    accuracyTracker.successful += 1;
  const auditRecord = {
    latencyMs: injectionResult.latency,
    validationStatus: validationResult.valid ? 'PASSED' : 'FAILED',
    accuracyScore: validationResult.valid ? validationResult.accuracyScore : null,
    dmsSynced: true,
    accuracyRate: (accuracyTracker.successful / accuracyTracker.total).toFixed(4)
  auditLog.push(auditRecord);
  logger.info('Knowledge injection audit logged.', auditRecord);
  return auditRecord;
The DMS synchronization uses a non-blocking POST to an external callback endpoint. Failures are logged but do not halt the pipeline. Accuracy rates are calculated cumulatively. Audit records include latency, validation status, and accuracy metrics for governance compliance.
The following module combines all components into a runnable knowledge injector service.
import { constructAndValidatePayload } from './validation.js';
import { submitKnowledgeInjection } from './injection.js';
import { validateInjectionResponse } from './pipeline.js';
import { synchronizeWithDMS } from './sync.js';
import { logger } from './auth.js';
export async function injectKnowledge(sessionId, query, contextVectors, threshold, sourceSystem) {
    // Step 1: Construct and validate payload
    const payload = constructAndValidatePayload(sessionId, query, contextVectors, threshold, sourceSystem);
    // Step 2: Atomic POST submission
    const injectionResult = await submitKnowledgeInjection(payload);
    logger.info('Webhook injection submitted.', { injectId: payload.metadata.injectId });
    // Step 3: Validation pipeline
    const validationResult = await validateInjectionResponse(injectionResult, payload);
    if (!validationResult.valid) {
      logger.warn('Injection validation failed. Triggering recalculation or fallback.', { injectId: payload.metadata.injectId });
    // Step 4: DMS sync and audit logging
    const auditRecord = await synchronizeWithDMS(validationResult, injectionResult, payload);
      status: validationResult.valid ? 'SUCCESS' : 'REQUIRES_RECALCULATION',
      auditRecord,
      validationResult
  } catch (error) {
    logger.error('Knowledge injection failed.', { sessionId, error: error.message });
    throw error;
// Runnable test block
if (import.meta.url === `file://${process.argv[1]}`) {
  const testSessionId = 'a1b2c3d4-e5f6-7890-abcd-ef1234567890';
  const testQuery = 'How do I reset my secure password?';
  const testVectors = [[0.12, 0.45, 0.78]]; // Minimal valid vector for testing
  const testThreshold = 0.70;
  const testSource = 'internal-docs';
  injectKnowledge(testSessionId, testQuery, testVectors, testThreshold, testSource)
    .then(result => console.log('Injection result:', JSON.stringify(result, null, 2)))
    .catch(err => console.error('Test failed:', err.message));
Run the script with node injector.js. Replace the test values with production session IDs, actual embedding vectors, and your Cognigy environment token. The script validates, injects, verifies, synchronizes, and logs in a single execution flow.
Error: 400 Bad Request
  • Cause: Payload schema mismatch, exceeded maximum query complexity, or invalid session ID format.
  • Fix: Verify the contextVectors array length does not exceed 10. Ensure sessionId matches UUID v4 format. Check relevanceThreshold bounds.
  • Code: The ajv validation in Step 1 catches these before transmission. Review the thrown error message for exact field violations.
  • Cause: Expired API token, missing X-Api-Key header, or insufficient permissions.
  • Fix: Regenerate the Cognigy API token. Verify the token includes bot:session:write and webhook:execute permissions. Update the COGNIGY_API_TOKEN environment variable.
  • Code: The axios interceptor in the Authentication Setup section catches 401 responses and throws a clear authentication error.
  • Cause: Exceeded Cognigy webhook rate limits during high-concurrency injection.
  • Fix: Implement exponential backoff. Reduce batch injection frequency. Distribute loads across multiple webhook endpoints if available.
  • Code: The submitKnowledgeInjection function includes a retry loop with Math.pow(2, attempt) * 1000 delay. Adjust maxRetries based on your quota.
Error: Hallucination Prevention Triggered
  • Cause: Engine confidence falls below the injected relevanceThreshold or entity resolution returns empty arrays.
  • Fix: Lower the threshold temporarily for testing. Verify the external knowledge base contains matching entities. Provide richer context vectors.
  • Code: The validation pipeline returns requiresRecalculation: true. Implement a fallback query generator or vector expansion strategy in your calling application.
