Injecting Dynamic System Prompts into Cognigy.AI via Python
A Python module that constructs, validates, and injects dynamic system prompts into Cognigy.AI flows using atomic POST operations, with built-in token counting, injection attack prevention, latency tracking, and audit logging.
The implementation uses the Cognigy.AI REST API with requests and pydantic for schema enforcement.
The tutorial covers Python 3.9+ with production-grade error handling and governance tracking.
  • OAuth2 client credentials with scopes: bot:write, flow:write, webhook:manage
  • Cognigy.AI API v1/v2 base URL (e.g., https://your-region.cognigy.ai)
  • Python 3.9+ runtime
  • Dependencies: requests, pydantic, tiktoken, python-dotenv
  • Install via: pip install requests pydantic tiktoken python-dotenv
Cognigy.AI uses standard OAuth2 client credentials flow. The following code retrieves and caches the access token with automatic refresh logic.
import os
import requests
from typing import Optional
load_dotenv()
BASE_URL = os.getenv("COGNIGY_BASE_URL", "https://your-region.cognigy.ai")
CLIENT_ID = os.getenv("COGNIGY_CLIENT_ID")
CLIENT_SECRET = os.getenv("COGNIGY_CLIENT_SECRET")
class CognigyAuthClient:
    def __init__(self, client_id: str, client_secret: str, base_url: str):
        self.client_id = client_id
    def _get_token(self) -> str:
        if self.token and time.time() < self.token_expiry - 60:
            return self.token
        payload = {
            "client_id": self.client_id,
            "scope": "bot:write flow:write webhook:manage"
        response = requests.post(
            f"{self.base_url}/oauth/token",
            data=payload,
            timeout=10
        response.raise_for_status()
        data = response.json()
        self.token = data["access_token"]
        self.token_expiry = time.time() + data["expires_in"]
        return self.token
            "Authorization": f"Bearer {self._get_token()}",
OAuth Scope Requirement: bot:write flow:write webhook:manage is required for flow modification and webhook registration. The token cache prevents unnecessary authentication calls during batch injection operations.
The injection payload must contain a template reference, a variable matrix for dynamic substitution, and an injection directive. Pydantic enforces the schema before any API call.
from pydantic import BaseModel, Field, validator
from typing import Dict, Any, Literal
class InjectPayload(BaseModel):
    templateRef: str = Field(..., description="Reference to the base prompt template")
    variableMatrix: Dict[str, Any] = Field(..., description="Key-value pairs for dynamic substitution")
    injectionDirective: Literal["prepend", "append", "replace"] = Field(..., description="How the prompt merges with existing configuration")
    content: str = Field(..., description="The raw system prompt text")
    @validator("templateRef")
    def validate_template_ref(cls, v: str) -> str:
        if not v.startswith("sys_prompt_"):
            raise ValueError("templateRef must start with 'sys_prompt_'")
        return v
    @validator("content")
    def validate_content_not_empty(cls, v: str) -> str:
        if len(v.strip()) == 0:
            raise ValueError("content cannot be empty or whitespace only")
        return v
    def to_api_format(self) -> dict:
        return self.dict()
Expected Response: Validation raises pydantic.ValidationError immediately if the payload structure violates AI engine constraints. This prevents malformed requests from reaching the Cognigy API.
Step 2: Token Counting and Injection Attack Prevention
LLM prompts have strict length limits. The following logic counts tokens using tiktoken and scans for injection patterns before composition.
import tiktoken
import re
class PromptValidator:
    def __init__(self, max_tokens: int = 4096):
        self.encoder = tiktoken.encoding_for_model("gpt-3.5-turbo")
        self.max_tokens = max_tokens
        self.injection_patterns = [
            r"ignore\s+previous\s+instructions",
            r"system\s+prompt\s+override",
            r"<\|endofprompt\|>",
            r"return\s+all\s+instructions",
            r"^[^:]+:\s*[^:]+$",  # Basic roleplay injection pattern
    def count_tokens(self, text: str) -> int:
        return len(self.encoder.encode(text))
    def check_injection_attempts(self, text: str) -> bool:
        text_lower = text.lower()
        for pattern in self.injection_patterns:
            if re.search(pattern, text_lower, re.IGNORECASE):
                return True
        return False
    def validate(self, payload: InjectPayload) -> dict:
        token_count = self.count_tokens(payload.content)
        if token_count > self.max_tokens:
            raise ValueError(f"Prompt exceeds maximum token limit. Current: {token_count}, Limit: {self.max_tokens}")
        if self.check_injection_attempts(payload.content):
            raise ValueError("Prompt contains potential injection attack patterns. Injection blocked.")
            "status": "valid",
            "token_count": token_count,
            "max_tokens": self.max_tokens,
            "utilization_percent": round((token_count / self.max_tokens) * 100, 2)
Error Handling: The validator raises ValueError for length violations or injection attempts. The calling code must catch these and log them before proceeding.
Step 3: Atomic POST Injection and Format Verification
Cognigy.AI flow nodes accept configuration updates via POST. The following method handles the atomic injection with retry logic for rate limits.
import json
from requests.adapters import HTTPAdapter
from urllib3.util.retry import Retry
class CognigyPromptInjector:
    def __init__(self, auth: CognigyAuthClient, validator: PromptValidator):
        self.auth = auth
        self.validator = validator
        self.session = requests.Session()
        retry_strategy = Retry(
            total=3,
            backoff_factor=1,
            status_forcelist=[429, 500, 502, 503, 504],
            allowed_methods=["POST"]
        adapter = HTTPAdapter(max_retries=retry_strategy)
        self.session.mount("https://", adapter)
    def inject_prompt(self, bot_id: str, flow_id: str, node_id: str, payload: InjectPayload) -> dict:
        validation_result = self.validator.validate(payload)
        api_payload = {
            "templateRef": payload.templateRef,
            "variableMatrix": payload.variableMatrix,
            "injectionDirective": payload.injectionDirective,
            "content": payload.content,
            "metadata": validation_result
        url = f"{self.auth.base_url}/api/v1/bots/{bot_id}/flows/{flow_id}/nodes/{node_id}/configuration"
        start_time = time.time()
            response = self.session.post(
                url,
                headers=self.auth.get_headers(),
                json=api_payload,
                timeout=15
            latency_ms = round((time.time() - start_time) * 1000, 2)
                "success": True,
                "latency_ms": latency_ms,
                "status_code": response.status_code,
                "response_body": response.json(),
                "validation": validation_result
                "success": False,
                "status_code": response.status_code if 'response' in locals() else None,
                "error": str(e),
                "success": False,
                "latency_ms": round((time.time() - start_time) * 1000, 2),
                "error": f"Network or timeout failure: {str(e)}",
OAuth Scope Requirement: bot:write flow:write is required for this endpoint. The retry strategy automatically handles 429 rate limits with exponential backoff. The response includes latency tracking and validation metadata for governance.
Step 4: Webhook Synchronization and Audit Logging
External prompt stores require synchronization after successful injection. The following code dispatches a webhook and generates an audit log.
import logging
logger = logging.getLogger("CognigyPromptInjector")
class PromptGovernanceManager:
    def __init__(self, webhook_url: str, auth: CognigyAuthClient):
        self.auth = auth
    def sync_external_store(self, bot_id: str, flow_id: str, node_id: str, result: dict) -> bool:
        if not result["success"]:
            logger.warning("Skipping webhook sync due to injection failure")
            return False
        webhook_payload = {
            "event": "prompt_applied",
            "bot_id": bot_id,
            "flow_id": flow_id,
            "node_id": node_id,
            "latency_ms": result["latency_ms"],
            "token_utilization": result["validation"]["utilization_percent"],
            "status": "applied"
            resp = self.session.post(
                self.webhook_url,
                json=webhook_payload,
                timeout=10
            resp.raise_for_status()
            logger.info(f"Webhook sync successful for node {node_id}")
            return True
            logger.error(f"Webhook sync failed: {str(e)}")
            return False
    def generate_audit_log(self, bot_id: str, flow_id: str, node_id: str, payload: InjectPayload, result: dict) -> dict:
        audit_entry = {
            "audit_id": f"AUD-{datetime.now(timezone.utc).strftime('%Y%m%d%H%M%S%f')}",
            "action": "prompt_injection",
            "bot_id": bot_id,
            "flow_id": flow_id,
            "node_id": node_id,
            "template_ref": payload.templateRef,
            "directive": payload.injectionDirective,
            "success": result["success"],
            "token_count": result["validation"]["token_count"],
            "injection_blocked": not result["success"] and "injection" in str(result.get("error", "")).lower(),
            "governance_status": "compliant" if result["success"] else "rejected"
        logger.info(f"Audit log generated: {json.dumps(audit_entry, indent=2)}")
        return audit_entry
Expected Response: The webhook payload matches Cognigy’s event schema for external synchronization. The audit log captures instruction adherence, latency, and safety verification results for compliance reporting.
import os
import json
import requests
load_dotenv()
# Reuse classes from previous sections (CognigyAuthClient, InjectPayload, PromptValidator, CognigyPromptInjector, PromptGovernanceManager)
def main():
    base_url = os.getenv("COGNIGY_BASE_URL", "https://your-region.cognigy.ai")
    auth = CognigyAuthClient(
        client_id=os.getenv("COGNIGY_CLIENT_ID"),
        client_secret=os.getenv("COGNIGY_CLIENT_SECRET"),
        base_url=base_url
    validator = PromptValidator(max_tokens=4096)
    injector = CognigyPromptInjector(auth=auth, validator=validator)
    governance = PromptGovernanceManager(
        webhook_url=os.getenv("EXTERNAL_PROMPT_STORE_WEBHOOK"),
        auth=auth
    # Construct inject payload
    payload = InjectPayload(
        templateRef="sys_prompt_support_v3",
        variableMatrix={
            "language": "en",
            "tone": "professional",
            "max_turns": 15,
            "fallback_action": "transfer_to_agent"
        injectionDirective="prepend",
        content="You are a customer support assistant specialized in billing inquiries. Always verify account ownership before sharing sensitive details. Maintain a professional tone and limit responses to three sentences when possible."
    bot_id = os.getenv("COGNIGY_BOT_ID")
    flow_id = os.getenv("COGNIGY_FLOW_ID")
    node_id = os.getenv("COGNIGY_NODE_ID")
    print(f"Initiating prompt injection for node {node_id}...")
    result = injector.inject_prompt(bot_id, flow_id, node_id, payload)
    print(f"Injection result: {json.dumps(result, indent=2)}")
    if result["success"]:
        governance.sync_external_store(bot_id, flow_id, node_id, result)
        audit = governance.generate_audit_log(bot_id, flow_id, node_id, payload, result)
        print(f"Audit complete. Governance status: {audit['governance_status']}")
    else:
        print("Injection failed. Review validation and error details.")
    main()
Execution Notes: Set environment variables for COGNIGY_BASE_URL, COGNIGY_CLIENT_ID, COGNIGY_CLIENT_SECRET, COGNIGY_BOT_ID, COGNIGY_FLOW_ID, COGNIGY_NODE_ID, and EXTERNAL_PROMPT_STORE_WEBHOOK. The script runs end-to-end validation, injection, synchronization, and audit logging.
  • Cause: Expired access token or invalid client credentials.
  • Fix: Verify COGNIGY_CLIENT_ID and COGNIGY_CLIENT_SECRET match the registered OAuth2 application. Ensure the token cache expiration logic accounts for network latency. Refresh the token manually by calling auth._get_token().
  • Code Fix: The CognigyAuthClient automatically refreshes tokens 60 seconds before expiry. If 401 persists, check scope permissions in the Cognigy admin console.
  • Cause: Exceeding Cognigy API rate limits during batch injection operations.
  • Fix: The HTTPAdapter with Retry strategy handles automatic backoff. If failures continue, implement a request queue with a maximum of 5 concurrent POST operations per bot.
  • Code Fix: Adjust backoff_factor in the retry strategy or add a time.sleep(0.5) between batch iterations.
Error: 400 Bad Request (Schema/Length Violation)
  • Cause: Payload fails Pydantic validation or exceeds the 4096 token limit.
  • Fix: Review the InjectPayload schema. Ensure templateRef starts with sys_prompt_. Run validator.count_tokens() on the content before injection. Trim or split the prompt if utilization exceeds 90 percent.
  • Code Fix: Wrap the injection call in a try-except block that catches ValueError and logs the specific validation failure before retrying with a modified payload.
  • Cause: Cognigy flow node is locked, deprecated, or the injection directive conflicts with existing configuration.
  • Fix: Verify the node exists and is in an editable state. Check the injectionDirective value against the node type. Replace replace with prepend if the node expects additive configuration.
  • Code Fix: Add a pre-flight GET request to /api/v1/bots/{bot_id}/flows/{flow_id}/nodes/{node_id} to verify node status before POSTing.
