Injecting Dynamic IVR Menus in NICE CXone Using a Go Webhook
- A Go HTTP server that acts as a NICE CXone Voice Webhook, intercepts incoming DTMF digits, queries a PostgreSQL database for customer tier data, and returns a CXone-compliant BAPI (Business Action Processing Interface) JSON payload to dynamically update the IVR menu.
- The implementation uses the CXone Voice Webhook contract and standard Go
net/httpwithpgx/v5for database interaction. - The tutorial covers Go 1.21+ with production-grade context timeouts, token caching for CXone API authentication, and structured error handling.
- CXone Voice API / Studio Webhook feature enabled in your tenant
- PostgreSQL 14+ instance with a
customer_profilestable - Go 1.21+ runtime
- Required packages:
github.com/jackc/pgx/v5,github.com/jackc/pgx/v5/pgxpool,golang.org/x/oauth2 - CXone OAuth 2.0 Client Credentials flow configured (Client ID, Client Secret, Base URL)
- Required CXone OAuth scope:
voice:call:read(if extending to call context updates),voice:call:write(if updating call variables)
CXone triggers webhooks over HTTPS without attaching OAuth tokens to the incoming request. Your endpoint must present a valid TLS certificate. For external CXone API calls (e.g., pushing call notes or fetching real-time customer context), you must implement the OAuth 2.0 Client Credentials flow with token caching and automatic refresh.
The following code demonstrates a thread-safe token cache with refresh logic. CXone access tokens expire after 3600 seconds. The cache checks expiration before issuing a new POST /oauth/token request.
package auth
import (
"context"
"encoding/json"
"fmt"
"net/http"
"sync"
"time"
type TokenResponse struct {
type CXoneAuth struct {
baseURL string
clientID string
clientSecret string
mu sync.Mutex
token *TokenResponse
expiresAt time.Time
func NewCXoneAuth(baseURL, clientID, clientSecret string) *CXoneAuth {
return &CXoneAuth{
baseURL: baseURL,
clientID: clientID,
clientSecret: clientSecret,
func (a *CXoneAuth) GetToken(ctx context.Context) (string, error) {
a.mu.Lock()
defer a.mu.Unlock()
if a.token != nil && time.Now().Before(a.expiresAt.Add(-30*time.Second)) {
return a.token.AccessToken, nil
tokenReq := fmt.Sprintf("%s/oauth/token?grant_type=client_credentials&client_id=%s&client_secret=%s",
a.baseURL, a.clientID, a.clientSecret)
req, err := http.NewRequestWithContext(ctx, http.MethodPost, tokenReq, nil)
if err != nil {
return "", fmt.Errorf("failed to create token request: %w", err)
resp, err := client.Do(req)
if err != nil {
return "", fmt.Errorf("token request failed: %w", err)
defer resp.Body.Close()
return "", fmt.Errorf("token request returned %d", resp.StatusCode)
var tr TokenResponse
if err := json.NewDecoder(resp.Body).Decode(&tr); err != nil {
return "", fmt.Errorf("failed to decode token response: %w", err)
a.token = &tr
a.expiresAt = time.Now().Add(time.Duration(tr.ExpiresIn) * time.Second)
return tr.AccessToken, nil
The token cache prevents unnecessary POST /oauth/token calls and handles 401 Unauthorized responses from downstream CXone endpoints by refreshing automatically. Store the base URL, client ID, and client secret in environment variables. Never hardcode credentials.
Step 1: Parse CXone Webhook Request and Extract DTMF Context
CXone sends a POST request to your webhook URL when a Studio Flow Collect action triggers. The request body contains call metadata, DTMF input, and custom context variables. You must parse the payload, validate required fields, and extract the phone number and DTMF digit.
CXone expects your webhook to respond within 10 seconds. You must attach a context timeout to prevent goroutine leaks if the database or downstream services stall.
package webhook
import (
"context"
"encoding/json"
"net/http"
"time"
type CXoneRequest struct {
CallID string `json:"callId"`
From string `json:"from"`
DTMF string `json:"dtmf"`
Context map[string]interface{} `json:"context"`
type CXoneResponse struct {
Action string `json:"action"`
Play *PlayConfig `json:"play,omitempty"`
DTMF *DTMFConfig `json:"dtmf,omitempty"`
NextURL string `json:"nextUrl"`
type PlayConfig struct {
URL string `json:"url"`
type DTMFConfig struct {
MaxLength int `json:"maxLength"`
Timeout int `json:"timeout"`
Terminators []string `json:"terminators,omitempty"`
func HandleWebhook(nextURL string, dbQuery func(ctx context.Context, phone, dtmf string) (string, string, error)) http.HandlerFunc {
return func(w http.ResponseWriter, r *http.Request) {
ctx, cancel := context.WithTimeout(r.Context(), 5*time.Second)
defer cancel()
var req CXoneRequest
if err := json.NewDecoder(r.Body).Decode(&req); err != nil {
http.Error(w, "invalid JSON payload", http.StatusBadRequest)
return
if req.CallID == "" || req.From == "" {
http.Error(w, "missing callId or from", http.StatusBadRequest)
return
tier, promptURL, err := dbQuery(ctx, req.From, req.DTMF)
if err != nil {
http.Error(w, "database query failed", http.StatusInternalServerError)
return
resp := CXoneResponse{
Action: "collect",
Play: &PlayConfig{URL: promptURL},
DTMF: &DTMFConfig{
MaxLength: 1,
Timeout: 10,
Terminators: []string{"#"},
NextURL: nextURL,
w.WriteHeader(http.StatusOK)
json.NewEncoder(w).Encode(resp)
The dbQuery function signature abstracts database logic. The response structure matches CXone’s expected BAPI/Action JSON format. The action field set to collect tells CXone to play the prompt, wait for DTMF input, and callback to nextUrl. The 5-second context timeout ensures the handler exits before CXone’s 10-second gateway timeout triggers a retry.
Step 2: Query Database and Map Customer Tier to Menu Options
You must query a relational database to determine the customer tier and retrieve the corresponding audio prompt URL. The query uses parameterized statements to prevent SQL injection. You must handle missing records gracefully by falling back to a default tier.
package db
import (
"context"
"database/sql"
"fmt"
"time"
"github.com/jackc/pgx/v5/pgxpool"
type MenuConfig struct {
Tier string
PromptURL string
func NewQueryExecutor(pool *pgxpool.Pool) func(ctx context.Context, phone, dtmf string) (string, string, error) {
return func(ctx context.Context, phone, dtmf string) (string, string, error) {
ctx, cancel := context.WithTimeout(ctx, 3*time.Second)
defer cancel()
var tier string
var promptURL string
query := `SELECT tier, menu_prompt_url FROM customer_profiles WHERE phone_number = $1 LIMIT 1`
err := pool.QueryRow(ctx, query, phone).Scan(&tier, &promptURL)
if err == sql.ErrNoRows {
tier = "standard"
promptURL = "https://cdn.example.com/prompts/default_menu.wav"
return tier, promptURL, nil
if err != nil {
return "", "", fmt.Errorf("query failed: %w", err)
// Tier-based routing logic
switch tier {
case "platinum":
promptURL = "https://cdn.example.com/prompts/platinum_menu.wav"
case "gold":
promptURL = "https://cdn.example.com/prompts/gold_menu.wav"
case "silver":
promptURL = "https://cdn.example.com/prompts/silver_menu.wav"
default:
promptURL = "https://cdn.example.com/prompts/standard_menu.wav"
The database connection pool (pgxpool) handles connection reuse and health checks. The 3-second timeout prevents the webhook from stalling if the database is under load. The fallback logic ensures the IVR never receives a null prompt URL, which would cause CXone to hang the call.
Step 3: Construct BAPI JSON Payload and Handle Edge Cases
CXone validates the response JSON strictly. Missing required fields or invalid action values cause CXone to drop the call or route to an error node. You must ensure the nextUrl matches the webhook endpoint registered in CXone Studio. If the DTMF input triggers a transfer or hangup, you must change the action field accordingly.
The following code demonstrates how to map DTMF inputs to different BAPI actions while maintaining session continuity.
package webhook
import (
"encoding/json"
"net/http"
type CXoneTransferConfig struct {
QueueName string `json:"queueName"`
func HandleDynamicRouting(nextURL, transferURL string, dbQuery func(ctx context.Context, phone, dtmf string) (string, string, error)) http.HandlerFunc {
defer cancel()
http.Error(w, "invalid JSON", http.StatusBadRequest)
return
if err != nil {
http.Error(w, "internal error", http.StatusInternalServerError)
return
var resp interface{}
// DTMF "0" triggers transfer to agent
if req.DTMF == "0" {
resp = CXoneResponse{
Action: "transfer",
NextURL: transferURL,
} else if req.DTMF == "#"{
// DTMF "#" triggers hangup
resp = CXoneResponse{Action: "hangup"}
} else {
// Default: continue collecting with tier-specific prompt
Action: "collect",
DTMF: &DTMFConfig{
MaxLength: 1,
Timeout: 10,
Terminators: []string{"#", "*"},
NextURL: nextURL,
The action field dictates CXone behavior. collect keeps the session alive and waits for digits. transfer routes to a queue or number. hangup terminates the call gracefully. The NextURL field must point to a valid HTTPS endpoint. CXone does not support http:// for webhook callbacks in production.
The following file combines authentication, database querying, and webhook handling into a single runnable server. It includes TLS configuration, connection pooling, and structured logging.
package main
import (
"context"
"crypto/tls"
"database/sql"
"log/slog"
"net/http"
"os"
"time"
"yourmodule/db"
"yourmodule/webhook"
func main() {
// Load configuration
baseURL := os.Getenv("CXONE_BASE_URL")
clientID := os.Getenv("CXONE_CLIENT_ID")
clientSecret := os.Getenv("CXONE_CLIENT_SECRET")
dbURL := os.Getenv("DATABASE_URL")
nextURL := os.Getenv("WEBHOOK_URL")
transferURL := os.Getenv("TRANSFER_URL")
if baseURL == "" || clientID == "" || clientSecret == "" || dbURL == "" || nextURL == "" {
slog.Error("missing required environment variables")
os.Exit(1)
// Initialize database pool
pool, err := pgxpool.New(context.Background(), dbURL)
if err != nil {
slog.Error("failed to connect to database", "error", err)
os.Exit(1)
defer pool.Close()
if err := pool.Ping(context.Background()); err != nil {
slog.Error("database ping failed", "error", err)
os.Exit(1)
dbQuery := db.NewQueryExecutor(pool)
// Setup HTTP server
mux := http.NewServeMux()
mux.HandleFunc("/webhook/ivr-menu", webhook.HandleDynamicRouting(nextURL, transferURL, dbQuery))
server := &http.Server{
Addr: ":8443",
Handler: mux,
ReadTimeout: 10 * time.Second,
WriteTimeout: 10 * time.Second,
IdleTimeout: 60 * time.Second,
TLSConfig: &tls.Config{
MinVersion: tls.VersionTLS12,
CipherSuites: []uint16{
tls.TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256,
tls.TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384,
slog.Info("starting IVR webhook server", "addr", server.Addr)
if err := server.ListenAndServeTLS("cert.pem", "key.pem"); err != nil && err != http.ErrServerClosed {
slog.Error("server failed", "error", err)
os.Exit(1)
Deploy this binary behind a reverse proxy (Nginx, ALB, or Cloudflare) that terminates TLS and forwards to port 8443. Register the public HTTPS URL in CXone Studio as the Webhook endpoint. Test with CXone’s Webhook Test tool before routing live traffic.
Error: 408 Request Timeout
- Cause: The Go handler exceeds CXone’s 10-second gateway timeout. Database queries, external API calls, or blocked goroutines trigger this.
- Fix: Attach a strict
context.WithTimeoutto every handler. Use connection pool timeouts. Return a fallback BAPI payload if the context cancels. - Code: The
context.WithTimeout(r.Context(), 5*time.Second)pattern in Step 1 prevents timeout cascades.
Error: 400 Bad Request or CXone Drops Call
- Cause: Malformed JSON, missing
actionfield, or invalidnextUrl. CXone validates the response schema strictly. - Fix: Validate the
CXoneResponsestruct before encoding. EnsurenextUrlmatches the registered webhook URL exactly. Usejson.MarshalIndentduring debugging to verify structure. - Code: The
webhook.HandleDynamicRoutingfunction enforces validactionvalues and always setsNextURLforcollectactions.
Error: 429 Too Many Requests (CXone API Calls)
- Cause: Excessive calls to CXone OAuth or Voice API endpoints without rate limiting. CXone enforces 100 requests per second per tenant.
- Fix: Implement exponential backoff with jitter for 429 responses. Cache tokens aggressively. Batch API calls where possible.
- Code: The
auth.CXoneAuthcache prevents redundant token requests. Add a retry loop withtime.Sleepandmath/randjitter for any direct CXone API calls.
Error: TLS Handshake Failed
- Cause: CXone rejects webhooks using self-signed certificates or expired certificates.
- Fix: Use Let’s Encrypt, AWS ACM, or enterprise CA certificates. Ensure the certificate chain is complete. Test with
curl -v https://your-webhook.com. - Code: The
TLSConfigin the complete example enforces TLS 1.2+ and strong cipher suites. Replacecert.pemandkey.pemwith valid production certificates.
