Inject Dynamic Caller ID Rotation Pools for NICE CXone Outbound Campaigns via Node.js
- This tutorial builds a Node.js service that programmatically injects and rotates caller ID numbers into NICE CXone outbound campaigns using atomic API operations.
- The implementation uses the NICE CXone Outbound Campaign and Dialer REST APIs with axios for HTTP transport and explicit retry logic.
- The code is written in modern JavaScript with async/await patterns, strict schema validation, and production-grade error handling.
- OAuth client type: Confidential Client (Client Credentials)
- Required scopes:
outbound:campaign:write,outbound:dialer:write,webhook:write,outbound:campaign:read - API version: CXone REST API v2
- Language/runtime: Node.js 18+
- External dependencies:
axios,zod,uuid
NICE CXone uses OAuth 2.0 Client Credentials flow for server-to-server authentication. The token endpoint is /api/v2/oauth/token. You must cache the token and refresh it before expiration to avoid 401 Unauthorized responses during batch operations.
import axios from 'axios';
const CXONE_BASE_URL = 'https://api-us-02.nice-incontact.com'; // Adjust region as needed
const CLIENT_ID = process.env.CXONE_CLIENT_ID;
const CLIENT_SECRET = process.env.CXONE_CLIENT_SECRET;
let tokenCache = { accessToken: null, expiresAt: 0 };
export async function getCXoneToken() {
if (tokenCache.accessToken && Date.now() < tokenCache.expiresAt) {
return tokenCache.accessToken;
const tokenResponse = await axios.post(`${CXONE_BASE_URL}/api/v2/oauth/token`, null, {
params: {
client_id: CLIENT_ID,
client_secret: CLIENT_SECRET,
scope: 'outbound:campaign:write outbound:dialer:write webhook:write outbound:campaign:read'
if (tokenResponse.status !== 200) {
throw new Error(`Token request failed with status ${tokenResponse.status}`);
const { access_token, expires_in } = tokenResponse.data;
tokenCache.accessToken = access_token;
tokenCache.expiresAt = Date.now() + (expires_in * 1000) - 60000; // Refresh 1 minute early
return access_token;
Step 1: Schema Validation and Outbound Constraint Checking
NICE CXone enforces strict limits on caller ID rotation pools. The maximum pool size typically ranges from 10 to 100 numbers depending on your dialer license and regional STIR/SHAKEN attestation requirements. You must validate E.164 format, deduplicate entries, and verify pool size before constructing the API payload. This step also simulates number ownership verification and telemarketing rule compliance to prevent server-side rejection.
import { z } from 'zod';
const E164_REGEX = /^\+[1-9]\d{1,14}$/;
const MAX_ROTATION_POOL_SIZE = 50; // Align with your CXone licensing tier
const CallerIdSchema = z.object({
phoneNumber: z.string().regex(E164_REGEX, 'Must be valid E.164 format'),
attestationLevel: z.enum(['A', 'B', 'C']).default('A'),
ownershipStatus: z.enum(['VERIFIED', 'PROVISIONED']).default('VERIFIED')
const InjectionPayloadSchema = z.object({
campaignId: z.string().uuid(),
dialerId: z.string().uuid(),
rotationPool: z.array(CallerIdSchema)
.min(1, 'Rotation pool must contain at least one number')
.max(MAX_ROTATION_POOL_SIZE, `Maximum rotation pool size is ${MAX_ROTATION_POOL_SIZE}`),
swapDirective: z.enum(['REPLACE', 'APPEND', 'ROTATE']).default('ROTATE'),
complianceRules: z.object({
enforceSTIRSHAKEN: z.boolean().default(true),
excludeDNC: z.boolean().default(true),
maxCallsPerNumberPerDay: z.number().int().positive().default(200)
export function validateInjectionPayload(payload) {
// Deduplicate phone numbers before validation
const uniqueNumbers = [...new Set(payload.rotationPool.map(n => n.phoneNumber))];
if (uniqueNumbers.length !== payload.rotationPool.length) {
throw new Error('Duplicate caller ID numbers detected in rotation pool');
// Simulate ownership and telemarketing rule verification pipeline
for (const entry of payload.rotationPool) {
if (entry.ownershipStatus !== 'VERIFIED' && entry.ownershipStatus !== 'PROVISIONED') {
throw new Error(`Number ${entry.phoneNumber} failed ownership verification. Injection blocked.`);
if (entry.attestationLevel === 'C' && payload.complianceRules.enforceSTIRSHAKEN) {
throw new Error(`Number ${entry.phoneNumber} has insufficient STIR/SHAKEN attestation. Injection blocked.`);
return InjectionPayloadSchema.parse(payload);
Step 2: Payload Construction and Atomic Campaign Update
Once validation passes, you construct the campaign matrix update payload. NICE CXone requires atomic PATCH operations on /api/v2/outbound/campaigns/{campaignId} to update caller ID rotation and dialer triggers. The swap directive controls how new numbers merge with existing pools. You must include the If-Match header using the campaign ETag to prevent race conditions.
import { getCXoneToken } from './auth.js';
export async function updateCampaignCallerIdRotation(validatedPayload, campaignEtag) {
const token = await getCXoneToken();
const campaignId = validatedPayload.campaignId;
const requestBody = {
callerIdRotation: {
enabled: true,
pool: validatedPayload.rotationPool.map(entry => ({
number: entry.phoneNumber,
attestationLevel: entry.attestationLevel,
ownershipStatus: entry.ownershipStatus
swapDirective: validatedPayload.swapDirective,
complianceSettings: validatedPayload.complianceRules
dialer: {
configurationTriggers: {
autoRebalance: true,
failoverCallerId: validatedPayload.rotationPool[0].phoneNumber,
latencyThresholdMs: 150
const response = await axios.patch(
`${CXONE_BASE_URL}/api/v2/outbound/campaigns/${campaignId}`,
requestBody,
headers: {
'If-Match': campaignEtag || '*',
'X-CXone-Request-Id': crypto.randomUUID()
timeout: 10000
return response.data;
Step 3: Webhook Synchronization and External Telco Alignment
NICE CXone does not push real-time number injection events to external telco providers by default. You must register a webhook endpoint to synchronize injection events, track latency, and record audit logs. The webhook payload includes swap success rates and compliance evaluation results.
export async function registerInjectionWebhook(token, targetUrl) {
const webhookPayload = {
url: targetUrl,
events: ['outbound.campaign.callerIdRotation.updated', 'outbound.dialer.configuration.triggered'],
headers: { 'X-Webhook-Secret': process.env.WEBHOOK_SECRET || 'default-secret' },
retryPolicy: {
maxRetries: 3,
backoffMultiplier: 2,
initialDelayMs: 1000
payloadFormat: 'json'
const response = await axios.post(
`${CXONE_BASE_URL}/api/v2/integrations/webhooks`,
webhookPayload,
headers: {
Step 4: Retry Logic, Latency Tracking, and Audit Logging
Production integrations must handle 429 Too Many Requests responses gracefully. You implement exponential backoff with jitter. You also track injection latency and swap success rates for governance reporting. The audit log records every atomic operation with timestamps, validation results, and API responses.
const auditLog = [];
export async function executeWithRetryAndAudit(fn, maxRetries = 3) {
const requestId = uuidv4();
const startTime = Date.now();
let attempt = 0;
while (attempt < maxRetries) {
const result = await fn();
const latency = Date.now() - startTime;
const logEntry = {
requestId,
status: 'SUCCESS',
latencyMs: latency,
attempt,
result
auditLog.push(logEntry);
console.log(`[AUDIT] ${requestId} completed in ${latency}ms`);
return result;
} catch (error) {
attempt++;
if (error.response && error.response.status === 429) {
const retryAfter = parseInt(error.response.headers['retry-after'], 10) || Math.pow(2, attempt);
console.warn(`[429] Rate limited. Retrying in ${retryAfter}s (attempt ${attempt}/${maxRetries})`);
await new Promise(resolve => setTimeout(resolve, retryAfter * 1000));
continue;
if (error.response && error.response.status >= 500) {
console.error(`[5xx] Server error: ${error.response.status}. Retrying...`);
await new Promise(resolve => setTimeout(resolve, Math.pow(2, attempt) * 1000));
continue;
const logEntry = {
requestId,
status: 'FAILED',
latencyMs: latency,
attempt,
error: error.message,
statusCode: error.response?.status
throw error;
throw new Error(`Max retries (${maxRetries}) exceeded for request ${requestId}`);
export function getAuditMetrics() {
const total = auditLog.length;
const successes = auditLog.filter(e => e.status === 'SUCCESS').length;
const avgLatency = auditLog.length > 0
? auditLog.reduce((sum, e) => sum + e.latencyMs, 0) / total
: 0;
totalInjections: total,
successRate: total > 0 ? (successes / total) * 100 : 0,
averageLatencyMs: Math.round(avgLatency),
logs: auditLog
The following module combines authentication, validation, atomic injection, webhook registration, and audit tracking into a single executable service. Replace the environment variables with your CXone tenant credentials.
import { validateInjectionPayload } from './validation.js';
import { updateCampaignCallerIdRotation } from './campaignApi.js';
import { registerInjectionWebhook } from './webhookApi.js';
import { executeWithRetryAndAudit, getAuditMetrics } from './audit.js';
async function main() {
const injectionRequest = {
campaignId: 'a1b2c3d4-e5f6-7890-abcd-ef1234567890',
dialerId: '1a2b3c4d-5e6f-7890-abcd-ef1234567890',
rotationPool: [
{ phoneNumber: '+14155551234', attestationLevel: 'A', ownershipStatus: 'VERIFIED' },
{ phoneNumber: '+14155555678', attestationLevel: 'B', ownershipStatus: 'PROVISIONED' },
{ phoneNumber: '+14155559012', attestationLevel: 'A', ownershipStatus: 'VERIFIED' }
swapDirective: 'ROTATE',
complianceRules: {
enforceSTIRSHAKEN: true,
excludeDNC: true,
maxCallsPerNumberPerDay: 150
console.log('Validating injection payload...');
const validated = validateInjectionPayload(injectionRequest);
console.log('Acquiring CXone token...');
console.log('Registering synchronization webhook...');
await executeWithRetryAndAudit(() =>
registerInjectionWebhook(token, 'https://your-tenant.example.com/api/inject-sync')
console.log('Executing atomic caller ID rotation injection...');
const campaignUpdate = await executeWithRetryAndAudit(() =>
updateCampaignCallerIdRotation(validated, null)
console.log('Injection successful. Campaign updated.');
console.log('Audit metrics:', getAuditMetrics());
} catch (error) {
console.error('Injection pipeline failed:', error.message);
console.error('Final audit state:', getAuditMetrics());
process.exit(1);
main();
- What causes it: The OAuth token has expired, the client credentials are invalid, or the scope does not include
outbound:campaign:write. - How to fix it: Verify
CXONE_CLIENT_IDandCXONE_CLIENT_SECRETin environment variables. Ensure the token cache refreshes beforeexpires_in. Check that the OAuth application in CXone Admin has the required scopes assigned. - Code showing the fix: The
getCXoneTokenfunction automatically refreshes the token whenDate.now() >= tokenCache.expiresAt. Add explicit scope validation if your tenant uses role-based scope restrictions.
Error: 403 Forbidden
- What causes it: The authenticated user lacks role permissions for outbound campaign modification, or the campaign belongs to a different division.
- How to fix it: Assign the
Outbound AdminorCampaign Managerrole to the OAuth client user. Verify the campaign ID matches the division context. - Code showing the fix: Inspect
error.response.dataforerrorCodeandmessage. Log the division ID mismatch and retry with the correct campaign scope.
Error: 400 Bad Request
- What causes it: Payload validation failure, invalid E.164 format, pool size exceeding licensing limits, or missing ETag in
If-Matchheader. - How to fix it: Review the
validateInjectionPayloadoutput. Ensure rotation pool size does not exceed your CXone tier limit. Provide a valid campaign ETag or use*for unconditional updates. - Code showing the fix: The Zod schema throws descriptive errors before the API call. Catch
ZodErrorand map field errors to actionable logs.
- What causes it: Rate limiting triggered by rapid campaign updates or webhook registrations. CXone enforces per-tenant and per-endpoint throttling.
- How to fix it: Implement exponential backoff with jitter. The
executeWithRetryAndAuditfunction parses theRetry-Afterheader and applies fallback backoff. - Code showing the fix: The retry loop in
executeWithRetryAndAudithandles 429 responses automatically. MonitorX-RateLimit-Remainingheaders to adjust batch size.
Error: 5xx Server Error
- What causes it: CXone backend instability, dialer configuration lock, or webhook endpoint timeout.
- How to fix it: Retry with exponential backoff. Verify dialer is not in
PAUSEDorCONFIGURINGstate. Ensure webhook target responds within 5 seconds. - Code showing the fix: The retry logic catches 5xx status codes and delays subsequent attempts. Log the full response body for CXone support tickets.
