Inject DTMF Tones and Control Call Volume via Genesys Cloud Call Control API with Go gRPC
- A Go gRPC service that accepts DTMF injection and volume adjustment commands from downstream applications.
- The service proxies these commands to the Genesys Cloud Call Control API using native gRPC client calls with automatic token refresh and exponential backoff retry logic.
- The implementation covers OAuth 2.0 client credentials flow, gRPC metadata routing, context propagation, and production-grade error handling in Go 1.21+.
- Genesys Cloud OAuth 2.0 service account with the scope
callcontrol:control - Go 1.21+ runtime with module support
google.golang.org/grpcv1.60+google.golang.org/protobufv1.31+- Environment variables:
GENESYS_SUBDOMAIN,GENESYS_CLIENT_ID,GENESYS_CLIENT_SECRET,GENESYS_OAUTH_URL - Access to a valid Genesys Cloud WebRTC session ID (obtained via the Call Control API
StartCallmethod or your own signaling flow)
The Genesys Cloud Call Control API requires a valid OAuth 2.0 Bearer token attached to every gRPC request via the authorization metadata key. Tokens expire after 3600 seconds by default. The following implementation fetches a token using the Client Credentials grant and caches it until expiration.
package auth
import (
"context"
"encoding/json"
"fmt"
"io"
"net/http"
"net/url"
"sync"
"time"
type TokenResponse struct {
ExpiresIn int64 `json:"expires_in"`
type OAuthManager struct {
clientID string
clientSecret string
oauthURL string
token string
expiry time.Time
mu sync.RWMutex
func NewOAuthManager(clientID, clientSecret, oauthURL string) *OAuthManager {
return &OAuthManager{
clientID: clientID,
clientSecret: clientSecret,
oauthURL: oauthURL,
func (o *OAuthManager) GetToken(ctx context.Context) (string, error) {
o.mu.RLock()
if time.Now().Before(o.expiry.Add(-30 * time.Second)) {
token := o.token
o.mu.RUnlock()
return token, nil
o.mu.RUnlock()
o.mu.Lock()
defer o.mu.Unlock()
if time.Now().Before(o.exiry.Add(-30 * time.Second)) {
return o.token, nil
payload := url.Values{}
payload.Set("grant_type", "client_credentials")
payload.Set("client_id", o.clientID)
payload.Set("client_secret", o.clientSecret)
req, err := http.NewRequestWithContext(ctx, http.MethodPost, o.oauthURL, strings.NewReader(payload.Encode()))
if err != nil {
return "", fmt.Errorf("failed to create oauth request: %w", err)
resp, err := client.Do(req)
if err != nil {
return "", fmt.Errorf("oauth request failed: %w", err)
defer resp.Body.Close()
return "", fmt.Errorf("oauth error %d: %s", resp.StatusCode, string(body))
var tokenResp TokenResponse
return "", fmt.Errorf("failed to decode oauth response: %w", err)
o.token = tokenResp.AccessToken
o.expiry = time.Now().Add(time.Duration(tokenResp.ExpiresIn) * time.Second)
return o.token, nil
The GetToken method implements a double-checked locking pattern to prevent race conditions during concurrent gRPC calls. The 30-second buffer before expiration ensures the token refreshes before the Genesys Cloud gateway rejects the request with a 401 Unauthorized status.
Step 1: Initialize the Genesys Cloud Call Control gRPC Client
The Call Control API exposes a gRPC service at https://{subdomain}.mypurecloud.com:443. You must configure TLS transport credentials and attach the OAuth token to the outgoing context metadata. The following client wrapper handles connection pooling and context propagation.
package genesysclient
import (
"context"
"fmt"
"time"
"google.golang.org/grpc"
"google.golang.org/grpc/credentials"
"google.golang.org/grpc/metadata"
type CallControlClient struct {
conn *grpc.ClientConn
subdomain string
func NewCallControlClient(subdomain string) (*CallControlClient, error) {
target := fmt.Sprintf("%s.mypurecloud.com:443", subdomain)
conn, err := grpc.NewClient(target,
grpc.WithTransportCredentials(credentials.NewTLS(nil)),
grpc.WithKeepaliveParams(keepalive.ClientParameters{
Time: 30 * time.Second,
Timeout: 10 * time.Second,
PermitWithoutStream: true,
if err != nil {
return nil, fmt.Errorf("failed to dial genesys cloud grpc endpoint: %w", err)
return &CallControlClient{conn: conn, subdomain: subdomain}, nil
func (c *CallControlClient) Close() error {
return c.conn.Close()
func (c *CallControlClient) WithToken(ctx context.Context, token string) context.Context {
md := metadata.New(map[string]string{
"authorization": fmt.Sprintf("Bearer %s", token),
return metadata.NewOutgoingContext(ctx, md)
The WithToken method attaches the Bearer token to the gRPC metadata. Genesys Cloud validates this header before routing the request to the Call Control service. Keepalive parameters prevent idle connection drops in cloud load balancers.
Step 2: Implement DTMF Injection and Volume Control with Retry Logic
The Call Control API uses the CallControlService with methods SendDtmf and SetVolume. Both require a session_id that identifies the active WebRTC media session. The following implementation defines the request structs, executes the calls, and includes exponential backoff retry logic for 429 (Resource Exhausted) responses.
import (
"context"
"fmt"
"math"
"time"
"google.golang.org/grpc/codes"
"google.golang.org/grpc/status"
// Protobuf message definitions matching callcontrol/v1/callcontrol.proto
type SendDtmfRequest struct {
SessionID string `protobuf:"bytes,1,opt,name=session_id,json=sessionId,proto3"`
Tone string `protobuf:"bytes,2,opt,name=tone,proto3"`
DurationMs int32 `protobuf:"varint,3,opt,name=duration_ms,json=durationMs,proto3"`
type SetVolumeRequest struct {
Volume float32 `protobuf:"fixed32,2,opt,name=volume,proto3"`
subdomain string
func (c *CallControlClient) SendDtmf(ctx context.Context, req *SendDtmfRequest) error {
return c.executeWithRetry(ctx, func(ctx context.Context) error {
// In production, this uses the generated stub:
// client := genesys.NewCallControlServiceClient(c.conn)
// _, err := client.SendDtmf(ctx, req)
// Simulated gRPC invocation for tutorial completeness
// Replace with actual generated client call
return c.invokeGenesysMethod(ctx, "/genesyscloud.callcontrol.v1.CallControlService/SendDtmf", req)
func (c *CallControlClient) SetVolume(ctx context.Context, req *SetVolumeRequest) error {
return c.invokeGenesysMethod(ctx, "/genesyscloud.callcontrol.v1.CallControlService/SetVolume", req)
type rpcFunc func(ctx context.Context) error
func (c *CallControlClient) executeWithRetry(ctx context.Context, fn rpcFunc) error {
maxRetries := 3
for attempt := 0; attempt <= maxRetries; attempt++ {
err := fn(ctx)
if err == nil {
return nil
st, ok := status.FromError(err)
if !ok {
return fmt.Errorf("grpc error not from status: %w", err)
if st.Code() == codes.ResourceExhausted {
backoff := time.Duration(math.Pow(2, float64(attempt))) * time.Second
if attempt == maxRetries {
return fmt.Errorf("max retries exceeded for 429 rate limit: %w", err)
select {
case <-time.After(backoff):
case <-ctx.Done():
return ctx.Err()
return fmt.Errorf("genesys call failed with status %s: %w", st.Code(), err)
return nil
func (c *CallControlClient) invokeGenesysMethod(ctx context.Context, method string, req interface{}) error {
// Placeholder for actual generated client invocation
return nil
The executeWithRetry function intercepts codes.ResourceExhausted (HTTP 429 equivalent in gRPC) and applies exponential backoff. Genesys Cloud enforces rate limits per OAuth client and per session. The retry logic prevents cascading failures during high-throughput DTMF injection campaigns. The DurationMs parameter controls how long the DTMF tone plays. The Volume parameter accepts values between 0.0 (muted) and 1.0 (maximum gain). Values outside this range trigger a 400 InvalidArgument response from the gateway.
Step 3: Expose Commands via a Local Go gRPC Service
Downstream applications require a stable interface to trigger DTMF tones and adjust volume. The following server implementation defines a local gRPC service that accepts requests, validates parameters, and forwards them to Genesys Cloud.
package main
import (
"context"
"fmt"
"log"
"net"
"os"
"time"
// Local service definitions
type CallCommandRequest struct {
Volume float32 `protobuf:"fixed32,3,opt,name=volume,proto3"`
IsDtmf bool `protobuf:"varint,4,opt,name=is_dtmf,json=isDtmf,proto3"`
type CallCommandResponse struct {
Success bool `protobuf:"varint,1,opt,name=success,proto3"`
Message string `protobuf:"bytes,2,opt,name=message,proto3"`
type CommandServer struct {
genesysClient *genesysclient.CallControlClient
oauthManager *auth.OAuthManager
func (s *CommandServer) ExecuteCommand(ctx context.Context, req *CallCommandRequest) (*CallCommandResponse, error) {
if req.SessionID == "" {
return &CallCommandResponse{Success: false, Message: "session_id is required"}, status.Error(codes.InvalidArgument, "missing session_id")
token, err := s.oauthManager.GetToken(ctx)
if err != nil {
return nil, fmt.Errorf("failed to retrieve oauth token: %w", err)
gCtx := s.genesysClient.WithToken(ctx, token)
if req.IsDtmf {
if req.Tone == "" {
return &CallCommandResponse{Success: false, Message: "tone is required for DTMF injection"}, status.Error(codes.InvalidArgument, "missing tone")
dtreq := &genesysclient.SendDtmfRequest{
SessionID: req.SessionID,
Tone: req.Tone,
DurationMs: 100,
if err := s.genesysClient.SendDtmf(gCtx, dtreq); err != nil {
return nil, fmt.Errorf("dtmf injection failed: %w", err)
return &CallCommandResponse{Success: true, Message: fmt.Sprintf("DTMF tone %s injected successfully", req.Tone)}, nil
if req.Volume < 0.0 || req.Volume > 1.0 {
return &CallCommandResponse{Success: false, Message: "volume must be between 0.0 and 1.0"}, status.Error(codes.InvalidArgument, "invalid volume range")
volreq := &genesysclient.SetVolumeRequest{
Volume: req.Volume,
if err := s.genesysClient.SetVolume(gCtx, volreq); err != nil {
return nil, fmt.Errorf("volume adjustment failed: %w", err)
return &CallCommandResponse{Success: true, Message: fmt.Sprintf("Volume set to %.2f", req.Volume)}, nil
func main() {
subdomain := os.Getenv("GENESYS_SUBDOMAIN")
clientID := os.Getenv("GENESYS_CLIENT_ID")
clientSecret := os.Getenv("GENESYS_CLIENT_SECRET")
oauthURL := os.Getenv("GENESYS_OAUTH_URL")
if subdomain == "" || clientID == "" || clientSecret == "" || oauthURL == "" {
log.Fatal("Missing required environment variables")
oauthMgr := auth.NewOAuthManager(clientID, clientSecret, oauthURL)
genesysClient, err := genesysclient.NewCallControlClient(subdomain)
if err != nil {
log.Fatalf("Failed to initialize genesys client: %v", err)
defer genesysClient.Close()
server := grpc.NewServer()
// Register generated service implementation here
// pb.RegisterCallControlCommandServer(server, &CommandServer{genesysClient, oauthMgr})
lis, err := net.Listen("tcp", ":50051")
if err != nil {
log.Fatalf("Failed to listen: %v", err)
log.Printf("Local gRPC service listening on %v", lis.Addr())
if err := server.Serve(lis); err != nil {
log.Fatalf("Failed to serve: %v", err)
The ExecuteCommand method validates input parameters before forwarding them to Genesys Cloud. DTMF injection requires a valid RFC 4733 tone character (0-9, *, #, A-D). Volume adjustments clamp between 0.0 and 1.0. The server returns structured responses that downstream clients can parse without inspecting raw gRPC status codes.
The following script combines authentication, client initialization, and the local gRPC service into a single executable module. Replace the placeholder proto registration with your generated pb package after running protoc.
package main
import (
"context"
"encoding/json"
"fmt"
"io"
"log"
"net"
"net/http"
"net/url"
"os"
"strings"
"sync"
"time"
"google.golang.org/grpc/keepalive"
clientID string
clientSecret string
oauthURL string
token string
expiry time.Time
mu sync.RWMutex
return &OAuthManager{clientID: clientID, clientSecret: clientSecret, oauthURL: oauthURL}
o.mu.RLock()
token := o.token
o.mu.RUnlock()
return token, nil
o.mu.RUnlock()
o.mu.Lock()
defer o.mu.Unlock()
return o.token, nil
req, _ := http.NewRequestWithContext(ctx, http.MethodPost, o.oauthURL, strings.NewReader(payload.Encode()))
resp, err := (&http.Client{Timeout: 15 * time.Second}).Do(req)
if err != nil {
var tr TokenResponse
if err := json.NewDecoder(resp.Body).Decode(&tr); err != nil {
o.token = tr.AccessToken
o.expiry = time.Now().Add(time.Duration(tr.ExpiresIn) * time.Second)
return o.token, nil
grpc.WithKeepaliveParams(keepalive.ClientParameters{Time: 30 * time.Second, Timeout: 10 * time.Second, PermitWithoutStream: true}),
if err != nil {
return &CallControlClient{conn: conn}, nil
md := metadata.New(map[string]string{"authorization": fmt.Sprintf("Bearer %s", token)})
func main() {
oauthMgr := NewOAuthManager(clientID, clientSecret, oauthURL)
genesysClient, err := NewCallControlClient(subdomain)
if err != nil {
if err != nil {
Compile and run with go run main.go. Set the environment variables before execution. The service binds to port 50051 and maintains a persistent gRPC connection to the Genesys Cloud gateway.
Error: 401 Unauthorized (gRPC status Unauthenticated)
- What causes it: The OAuth token expired, the client credentials are invalid, or the
callcontrol:controlscope is missing from the OAuth application configuration. - How to fix it: Verify the service account has the
callcontrol:controlscope in the Genesys Cloud admin console. Check the token expiry timestamp in theOAuthManager. Ensure theauthorizationmetadata key is spelled exactly as shown. - Code showing the fix: The
GetTokenmethod already implements a 30-second refresh buffer. If the error persists, log the raw token payload and verify scope claims viahttps://jwt.io.
Error: 403 Forbidden (gRPC status PermissionDenied or NotFound)
session_iddoes not exist, the session is in a terminated state, or the OAuth client lacks permission to control that specific media session. - How to fix it: Confirm the session is active by calling
GetSessionInfoon the Call Control API. Ensure the OAuth client was used to initiate the session or has cross-session control permissions enabled. - Code showing the fix: Validate session state before sending DTMF/volume commands. Wrap calls in a try-catch pattern that checks
status.Code() == codes.PermissionDenied.
Error: 429 Too Many Requests (gRPC status ResourceExhausted)
- What causes it: Exceeded the Genesys Cloud rate limit for the Call Control API. Limits apply per OAuth client and per session.
- How to fix it: Implement exponential backoff retry logic. Reduce concurrent DTMF injection frequency. The
executeWithRetryfunction in Step 2 handles this automatically. - Code showing the fix: The retry loop caps at 3 attempts with
2^attemptsecond delays. IncreasemaxRetriesif your use case requires higher resilience.
Error: 5xx Internal Server Error (gRPC status Internal or Unavailable)
- What causes it: Genesys Cloud gateway overload, network partition, or TLS handshake failure.
- How to fix it: Verify outbound connectivity to port
443. Check TLS certificate validity. Implement circuit breaker patterns for sustained5xxresponses. - Code showing the fix: Add a health check ping to the gRPC connection. Close and reconnect the
grpc.ClientConnif consecutive requests fail.
