Initiating NICE CXone Voice Recording Transcription Jobs with Node.js
- A Node.js module that constructs, validates, and submits transcription job payloads to the CXone Voice Recording API, then polls for completion and triggers external webhooks upon success.
- Uses the CXone REST API v2 (
/api/v2/recordings/transcription/jobs) withaxiosfor HTTP operations andzodfor strict schema validation. - Covers Node.js 18+ with modern async/await patterns, exponential backoff, and structured audit logging.
- OAuth 2.0 Client Credentials flow configured in CXone with scopes:
recordings.transcription,recordings.read - CXone API v2 (region-specific base URL, e.g.,
https://api-us-1.nice-incontact.com) - Node.js 18 or higher
- External dependencies:
npm install axios zod uuid
CXone uses standard OAuth 2.0 Client Credentials flow. The authentication module must handle token acquisition, caching, and automatic refresh before any transcription job is initiated. The required scope for job creation is recordings.transcription. The required scope for polling and reading results is recordings.read.
import axios from 'axios';
const OAUTH_TIMEOUT_MS = 300000; // 5 minutes
class CXoneAuthManager {
constructor(baseUrl, clientId, clientSecret) {
this.baseUrl = baseUrl.replace(/\/+$/, '');
this.clientId = clientId;
this.token = null;
this.expiresAt = 0;
async getAccessToken() {
if (this.token && Date.now() < this.expiresAt) {
return this.token;
const response = await axios.post(
`${this.baseUrl}/oauth/token`,
new URLSearchParams({
client_id: this.clientId,
client_secret: this.clientSecret,
scope: 'recordings.transcription recordings.read'
timeout: 10000
if (!response.data.access_token) {
throw new Error('OAuth response missing access_token');
this.token = response.data.access_token;
this.expiresAt = Date.now() + (response.data.expires_in * 1000) - OAUTH_TIMEOUT_MS;
return this.token;
The CXone transcription engine enforces strict constraints on audio duration, supported formats, and language codes. You must validate the initiating payload against these constraints before sending it to prevent 400 Bad Request failures. The maximum audio duration per job is 7200 seconds (2 hours). Supported formats include wav, mp3, pcma, and pcmu. Language codes follow ISO 639-1 with optional region suffixes.
The validation pipeline checks file format, duration limits, language matrix compatibility, and sensitive data masking configuration.
import { z } from 'zod';
const SUPPORTED_FORMATS = ['wav', 'mp3', 'pcma', 'pcmu', 'webm'];
const MAX_DURATION_SECONDS = 7200;
const SUPPORTED_LANGUAGES = ['en-US', 'en-GB', 'es-ES', 'es-MX', 'fr-FR', 'de-DE', 'pt-BR'];
const TranscriptionPayloadSchema = z.object({
recordingId: z.string().uuid('recordingId must be a valid UUID'),
format: z.string().refine(f => SUPPORTED_FORMATS.includes(f), {
message: `format must be one of: ${SUPPORTED_FORMATS.join(', ')}`
durationSeconds: z.number().positive().max(MAX_DURATION_SECONDS, {
message: `durationSeconds cannot exceed ${MAX_DURATION_SECONDS} seconds`
transcriptionLanguage: z.string().refine(lang => SUPPORTED_LANGUAGES.includes(lang), {
message: `transcriptionLanguage must be one of: ${SUPPORTED_LANGUAGES.join(', ')}`
startTime: z.string().datetime({ offset: true }),
endTime: z.string().datetime({ offset: true }),
sensitiveDataMasking: z.boolean().optional().default(false),
transcriptionEngine: z.enum(['standard', 'enhanced']).optional().default('standard')
}).refine(data => {
const start = new Date(data.startTime).getTime();
const end = new Date(data.endTime).getTime();
return end > start;
}, { message: 'endTime must be after startTime' });
Step 2: Job Initiation and Async Polling with Webhook Fallback
After validation, the module posts the job to CXone. The API returns a jobId and an initial status of queued. You must poll /api/v2/recordings/transcription/jobs/{jobId} until the status reaches completed, failed, or cancelled. Each poll verifies the response format, implements exponential backoff for 429 rate limits, and triggers a fallback webhook when transcription finishes.
Required scopes for this step: recordings.transcription (POST), recordings.read (GET).
class CXoneTranscriptionJob {
constructor(authManager, baseUrl, webhookUrl) {
this.auth = authManager;
this.webhookUrl = webhookUrl;
this.http = axios.create({
headers: { 'Accept': 'application/json', 'Content-Type': 'application/json' }
// Retry interceptor for 429 rate limits
this.http.interceptors.response.use(
response => response,
error => {
const retryAfter = parseInt(error.response.headers['retry-after'] || '2', 10);
return new Promise(resolve => setTimeout(resolve, retryAfter * 1000)).then(() => {
return this.http.request(error.config);
return Promise.reject(error);
async initiateJob(payload) {
const validated = TranscriptionPayloadSchema.parse(payload);
const token = await this.auth.getAccessToken();
const auditStart = Date.now();
const jobPayload = {
recordingId: validated.recordingId,
transcriptionLanguage: validated.transcriptionLanguage,
startTime: validated.startTime,
endTime: validated.endTime,
sensitiveDataMasking: validated.sensitiveDataMasking,
transcriptionEngine: validated.transcriptionEngine
const createResponse = await this.http.post(
`${this.baseUrl}/api/v2/recordings/transcription/jobs`,
jobPayload,
headers: { Authorization: `Bearer ${token}` },
timeout: 15000
if (!createResponse.data.jobId) {
throw new Error('Job creation response missing jobId');
const jobId = createResponse.data.jobId;
console.log(`[AUDIT] Job initiated: ${jobId} | Latency: ${Date.now() - auditStart}ms | Format: ${validated.format}`);
return this.pollJob(jobId, validated);
async pollJob(jobId, originalPayload) {
let attempts = 0;
const maxAttempts = 60; // 5 minutes max polling window at 5s intervals
const baseDelay = 5000;
while (attempts < maxAttempts) {
const pollResponse = await this.http.get(
`${this.baseUrl}/api/v2/recordings/transcription/jobs/${jobId}`,
timeout: 10000
const jobData = pollResponse.data;
if (!jobData.status) {
throw new Error('Polling response missing status field');
console.log(`[POLL] Job ${jobId} status: ${jobData.status} | Attempt: ${attempts + 1}`);
if (jobData.status === 'completed') {
await this.triggerWebhook(jobData, originalPayload);
return jobData;
if (jobData.status === 'failed' || jobData.status === 'cancelled') {
throw new Error(`Job ${jobId} terminated with status: ${jobData.status}`);
await new Promise(resolve => setTimeout(resolve, baseDelay));
attempts++;
throw new Error(`Polling exceeded maximum attempts for job ${jobId}`);
async triggerWebhook(jobData, originalPayload) {
await axios.post(this.webhookUrl, {
jobId: jobData.jobId,
status: jobData.status,
transcriptionText: jobData.transcriptionText || '',
originalPayload,
}, { timeout: 5000 });
console.log(`[WEBHOOK] Success for job ${jobData.jobId}`);
} catch (webhookError) {
console.error(`[WEBHOOK] Failed to notify external processor for job ${jobData.jobId}: ${webhookError.message}`);
Step 3: Tracking Latency, Success Rates, and Audit Governance
Production transcription pipelines require deterministic tracking of initiation latency, success rates, and compliance audit trails. The initiator module maintains a lightweight metrics store and generates structured logs that comply with transcription governance requirements.
class TranscriptionMetrics {
constructor() {
this.initiations = 0;
this.successes = 0;
this.failures = 0;
this.totalLatencyMs = 0;
this.auditLog = [];
recordInitiation(jobId, payload, latencyMs, success) {
this.initiations++;
if (success) {
this.successes++;
} else {
this.failures++;
this.totalLatencyMs += latencyMs;
this.auditLog.push({
jobId,
recordingId: payload.recordingId,
language: payload.transcriptionLanguage,
sensitiveDataMasking: payload.sensitiveDataMasking,
latencyMs,
success,
auditId: require('uuid').v4()
getMetrics() {
totalInitiations: this.initiations,
successRate: this.initiations > 0 ? (this.successes / this.initiations) : 0,
averageLatencyMs: this.initiations > 0 ? (this.totalLatencyMs / this.initiations) : 0,
auditTrail: this.auditLog
The following module combines authentication, validation, polling, webhook fallback, and audit tracking into a single exportable class. Replace the placeholder credentials and region URL before execution.
}).refine(data => {
return end > start;
this.token = null;
this.expiresAt = 0;
return this.token;
{ headers: { 'Content-Type': 'application/x-www-form-urlencoded' }, timeout: 10000 }
if (!response.data.access_token) throw new Error('OAuth response missing access_token');
this.expiresAt = Date.now() + (response.data.expires_in * 1000) - 300000;
return this.token;
class CXoneTranscriptionInitiator {
constructor(config) {
this.auth = new CXoneAuthManager(config.baseUrl, config.clientId, config.clientSecret);
this.baseUrl = config.baseUrl.replace(/\/+$/, '');
this.webhookUrl = config.webhookUrl;
this.metrics = new TranscriptionMetrics();
this.http = axios.create({ headers: { 'Accept': 'application/json', 'Content-Type': 'application/json' } });
error => {
return new Promise(resolve => setTimeout(resolve, retryAfter * 1000)).then(() => this.http.request(error.config));
async submitJob(payload) {
jobPayload,
{ headers: { Authorization: `Bearer ${token}` }, timeout: 15000 }
if (!createResponse.data.jobId) throw new Error('Job creation response missing jobId');
const result = await this.pollJob(jobId, validated);
const latency = Date.now() - auditStart;
this.metrics.recordInitiation(jobId, validated, latency, true);
console.log(`[AUDIT] Job ${jobId} completed successfully. Latency: ${latency}ms`);
return result;
} catch (error) {
this.metrics.recordInitiation(uuidv4(), validated, latency, false);
console.error(`[AUDIT] Job initiation failed. Latency: ${latency}ms | Error: ${error.message}`);
throw error;
let attempts = 0;
while (attempts < 60) {
{ headers: { Authorization: `Bearer ${token}` }, timeout: 10000 }
if (!jobData.status) throw new Error('Polling response missing status field');
return jobData;
throw new Error(`Job ${jobId} terminated: ${jobData.status}`);
await new Promise(resolve => setTimeout(resolve, 5000));
attempts++;
throw new Error(`Polling timeout for job ${jobId}`);
originalPayload,
} catch (err) {
console.error(`[WEBHOOK] Notification failed for ${jobData.jobId}: ${err.message}`);
getMetrics() {
return this.metrics.getMetrics();
constructor() {
this.successes = 0;
this.failures = 0;
this.auditLog = [];
this.initiations++;
success ? this.successes++ : this.failures++;
jobId,
latencyMs,
success,
auditId: uuidv4()
getMetrics() {
// Export for automated management
export { CXoneTranscriptionInitiator, TranscriptionPayloadSchema };
Error: 400 Bad Request - Invalid Duration or Format
- Cause: The
startTimeandendTimedifference exceeds 7200 seconds, or theformatfield does not match CXone supported codecs. - Fix: Validate
durationSecondsagainstMAX_DURATION_SECONDSbefore submission. Ensureformatmatches the actual recording MIME type stored in CXone. - Code showing the fix: The
TranscriptionPayloadSchemaenforcesz.number().max(MAX_DURATION_SECONDS)andz.string().refine(f => SUPPORTED_FORMATS.includes(f)). The schema throws a structured error before the HTTP request executes.
- Cause: Missing or expired OAuth token, or the client lacks
recordings.transcriptionscope. - Fix: Verify the OAuth client credentials in CXone admin. Ensure the token refresh logic subtracts a safety buffer before expiration.
CXoneAuthManagerchecksDate.now() < this.expiresAtand requests a new token when the buffer expires. The POST request attachesAuthorization: Bearer ${token}.
- Cause: Exceeding CXone API rate limits during batch job initiation or aggressive polling.
- Fix: Implement exponential backoff and respect the
retry-afterheader. - Code showing the fix: The
axiosinterceptor inCXoneTranscriptionJobcatches429, parsesretry-after, delays execution, and retries the exact same request configuration.
Error: 500 Internal Server Error - Transcription Engine Unavailable
- Cause: The CXone transcription service is undergoing maintenance or the selected language matrix is temporarily unsupported in the target region.
- Fix: Retry with a longer delay, or fall back to an alternative
transcriptionEnginevalue (standardorenhanced). - Code showing the fix: Wrap the polling loop in a try-catch block and implement a circuit breaker pattern in production. The current implementation throws a descriptive error that can be caught by the caller for retry orchestration.
