Infomart tables not populating
Hi
I am busy setting up custom data for infomart in a lab environment. I can see the data being captured on the ICON in the G_USERDATA_HISTORY table. The data is then moved to the Infomart DB and I can see the data in the GIDB_G_USERDATA_HISTORY_V table. The problem is the data is not being updated to the IRF_USER_DATA_CUST_1 table and INTERACTION_DESSCRIPTOR table
When checking the CTL_TRANSFORM_HISTORY table I can see the table is being transformed.
I have also changed the following two options on the infomart in the gim-etl section to true
link-msf-userdata-mm
link-msf-userdata-voice
There are no errors in the log file for the transform job
The question is now what am I missing. How do I get these table to populate
Have you configured the content of ctl_ud_to_ude_mapping and ctl_ude_keys_to_dim_mapping tables on the infomart database?
Yes I have and I can see mapped custom data in the CTL_UD_TO_UDE_MAPPING the CTL_UDE_KEYS_TO_DIM_MAPPING also contains the mapping for the custom keys as wel as the DIM_1 and DIM_2 table
Is it a BEP version of Genesys? If yes, Infomart Will not transform custom attach data
This is not a BEP version
Would you post how it is configured on ctl_ud_to_ude_mapping? Also, check if the UpperCase and LowerCase match the AttachData, since it is case-sensitive.
Hi
The information is being populated to both ICON table for userdata and Infomart GIDB table just not being populated to the other tables.
DIM_TABLE_NAME DIM_TABLE_PK_NAME UDE_KEY_NAME
INTERACTION_DESCRIPTOR INTERACTION_DESCRIPTOR_KEY INTERACTION_DESCRIPTOR_KEY
USER_DATA_CUST_DIM_1 ID CUSTOM_KEY_1
USER_DATA_CUST_DIM_2 ID CUSTOM_KEY_2
ID UD_KEY_NAME UDE_TABLE_NAME UDE_COLUMN_NAME PROPAGATION_RULE DEFAULT_VALUE ACTIVE_FLAG CONVERT_EXPRESSION
1 CustomerSegment INTERACTION_DESCRIPTOR CUSTOMER_SEGMENT CALL DEFAULT_CUSTOMER_SEGMENT 1 NULL
2 ServiceType INTERACTION_DESCRIPTOR SERVICE_TYPE CALL DEFAULT_SERVICE_TYPE 1 NULL
3 ServiceSubType INTERACTION_DESCRIPTOR SERVICE_SUBTYPE CALL DEFAULT_SERVICE_SUBTYPE 1 NULL
4 Business Result INTERACTION_DESCRIPTOR BUSINESS_RESULT CALL DEFAULT_BUSINESS_RESULT 1 NULL
5 CaseID IRF_USER_DATA_GEN_1 CASE_ID CALL DEFAULT_CASE_ID 1 NULL
6 CustomerID IRF_USER_DATA_GEN_1 CUSTOMER_ID CALL DEFAULT_CUSTOMER_ID 1 NULL
7 ServiceObjective IRF_USER_DATA_GEN_1 SERVICE_OBJECTIVE CALL NULL 1 NULL
8 IPurpose IRF_USER_DATA_GEN_1 IPURPOSE IRF NULL 1 NULL
9 GSW_CALL_ATTEMPT_GUID IRF_USER_DATA_GEN_1 GSW_CALL_ATTEMPT_GUID CALL NULL 1 NULL
10 Revenue IRF_USER_DATA_GEN_1 REVENUE CALL NULL 1 NULL
11 Satisfaction IRF_USER_DATA_GEN_1 SATISFACTION CALL NULL 1 NULL
12 _CB_SERVICE_ID IRF_USER_DATA_GEN_1 SERVICE_ID CALL NULL 1 NULL
13 _CB_T_SERVICE_START IRF_USER_DATA_GEN_1 SERVICE_START_TS CALL NULL 1 NULL
14 Language USER_DATA_CUST_DIM_1 DIM_ATTRIBUTE_1 CALL none 1 NULL
15 CustomAttribute2 USER_DATA_CUST_DIM_1 DIM_ATTRIBUTE_2 CALL none 1 NULL
16 CustomAttribute3 USER_DATA_CUST_DIM_1 DIM_ATTRIBUTE_3 CALL none 1 NULL
17 CustomAttribute4 USER_DATA_CUST_DIM_1 DIM_ATTRIBUTE_4 CALL none 1 NULL
18 CustomAttribute5 USER_DATA_CUST_DIM_1 DIM_ATTRIBUTE_5 CALL none 1 NULL
19 CustomAttribute1 USER_DATA_CUST_DIM_2 DIM_ATTRIBUTE_1 CALL none 1 NULL
20 CustomAttribute2 USER_DATA_CUST_DIM_2 DIM_ATTRIBUTE_2 CALL none 1 NULL
21 CustomAttribute3 USER_DATA_CUST_DIM_2 DIM_ATTRIBUTE_3 CALL none 1 NULL
22 CustomAttribute4 USER_DATA_CUST_DIM_2 DIM_ATTRIBUTE_4 CALL none 1 NULL
23 CustomAttribute5 USER_DATA_CUST_DIM_2 DIM_ATTRIBUTE_5 CALL none 1 NULL
24 FirstName IRF_USER_DATA_CUST_1 CUSTOM_DATA_1 CALL NULL 1 NULL
25 LastName IRF_USER_DATA_CUST_1 CUSTOM_DATA_2 CALL NULL 1 NULL
26 CustomData3 IRF_USER_DATA_CUST_1 CUSTOM_DATA_3 CALL NULL 1 NULL
27 CustomData4 IRF_USER_DATA_CUST_1 CUSTOM_DATA_4 CALL NULL 1 NULL
28 CustomData5 IRF_USER_DATA_CUST_1 CUSTOM_DATA_5 CALL NULL 1 NULL
29 CustomData6 IRF_USER_DATA_CUST_1 CUSTOM_DATA_6 CALL NULL 1 NULL
30 CustomData7 IRF_USER_DATA_CUST_1 CUSTOM_DATA_7 CALL NULL 1 NULL
31 CustomData8 IRF_USER_DATA_CUST_1 CUSTOM_DATA_8 CALL NULL 1 NULL
32 CustomData9 IRF_USER_DATA_CUST_1 CUSTOM_DATA_9 CALL NULL 1 NULL
33 CustomData10 IRF_USER_DATA_CUST_1 CUSTOM_DATA_10 CALL NULL 1 NULL
34 CustomData11 IRF_USER_DATA_CUST_1 CUSTOM_DATA_11 CALL NULL 1 NULL
35 CustomData12 IRF_USER_DATA_CUST_1 CUSTOM_DATA_12 CALL NULL 1 NULL
36 CustomData13 IRF_USER_DATA_CUST_1 CUSTOM_DATA_13 CALL NULL 1 NULL
37 CustomData14 IRF_USER_DATA_CUST_1 CUSTOM_DATA_14 CALL NULL 1 NULL
38 CustomData15 IRF_USER_DATA_CUST_1 CUSTOM_DATA_15 CALL NULL 1 NULL
39 CustomData16 IRF_USER_DATA_CUST_1 CUSTOM_DATA_16 CALL NULL 1 NULL
It doesn’t seem to be nothing wrong with that configuration as well.
is there anything in the STG_DISCARDS table of your infomart?
Hi
Yes I have found discards in the CTL_TRANSFROM_DISCARDS table.
When checking logs I do not found exceptions but on the Gensys website there is a similar case. It seems when this discard appears there are some other tasks that gets cancelled. This might be the cause. I am going to fix the issue and let you know if the problem is resolved
Regards
Hi
Thank you for all the help. The problem is resolved.
I did see the discards but did not think they will be related to the issue. Seems they were
Here is a link to the two cases I found that resolved my problem
https://genesyspartner.force.com/customercare/pkb_Home?id=kA4U0000000XZwcKAG&l=en_US&fs=Search&pn=1
https://genesyspartner.force.com/customercare/pkb_Home?id=kA4U00000008ekNKAQ&l=en_US&fs=Search&pn=1
Regards
I have same problems and I could not find a way to solve this problem.The URL of last answer is broken.Is it possible to share solution.
Thanks.
https://genesyspartner.force.com/customercare/kA4U00000008ekNKAQ
https://genesyspartner.force.com/customercare/kA4U0000000XZwcKAG
Just search the KB IDs from the URLs into the new platform
