Indexing NICE CXone Pure Connect Call Logs via Pure Connect APIs with Go
  • A Go service that retrieves Pure Connect call logs via NICE CXone APIs, constructs structured indexing payloads with log references, timestamp matrices, and tag directives, and synchronizes them to an external search cluster.
  • Uses the NICE CXone Analytics API for conversation detail retrieval, the Platform API for webhook configuration, and native Go HTTP clients for atomic upsert operations.
  • Implemented in Go 1.21+ with production-grade retry logic, schema validation, duplicate detection, latency tracking, and audit logging.
  • OAuth 2.0 Client Credentials flow with required scopes: analytics:read, webhooks:read_write, calls:read
  • CXone API v2 endpoints
  • Go 1.21 or newer
  • Standard library dependencies only: net/http, crypto/sha256, encoding/json, time, fmt, log, sync, context, io, strings
CXone uses standard OAuth 2.0 client credentials flow. The token endpoint is /api/v2/oauth/token. You must cache the access token and refresh it before expiration to avoid interrupting indexing pipelines.
package main
import (
	"context"
	"crypto/sha256"
	"encoding/json"
	"fmt"
	"io"
	"log"
	"net/http"
	"strings"
	"sync"
	"time"
const (
	cxoneBaseURL       = "https://api.mynicecxone.com"
	oauthEndpoint      = "/api/v2/oauth/token"
	analyticsEndpoint  = "/api/v2/analytics/conversations/details/query"
	webhookEndpoint    = "/api/v2/platform/webhooks"
	maxShardLimit      = 50
	maxDiskBytes       = 10737418240 // 10 GB
	indexBatchSize     = 100
	compactionInterval = 5 * time.Minute
type OAuthResponse struct {
	ExpiresIn   int    `json:"expires_in"`
	TokenType   string `json:"token_type"`
type AuthClient struct {
	clientID     string
	clientSecret string
	token        string
	expiresAt    time.Time
	mu           sync.Mutex
func NewAuthClient(clientID, clientSecret string) *AuthClient {
	return &AuthClient{
		clientID:     clientID,
		clientSecret: clientSecret,
func (a *AuthClient) GetToken(ctx context.Context) (string, error) {
	a.mu.Lock()
	defer a.mu.Unlock()
	if time.Until(a.expiresAt) > time.Minute {
		return a.token, nil
	payload := fmt.Sprintf("client_id=%s&client_secret=%s&grant_type=client_credentials", a.clientID, a.clientSecret)
	req, err := http.NewRequestWithContext(ctx, http.MethodPost, cxoneBaseURL+oauthEndpoint, strings.NewReader(payload))
	if err != nil {
		return "", fmt.Errorf("failed to create oauth request: %w", err)
	resp, err := client.Do(req)
	if err != nil {
		return "", fmt.Errorf("oauth request failed: %w", err)
	defer resp.Body.Close()
		return "", fmt.Errorf("oauth error %d: %s", resp.StatusCode, string(body))
	var oauthResp OAuthResponse
	if err := json.NewDecoder(resp.Body).Decode(&oauthResp); err != nil {
		return "", fmt.Errorf("failed to decode oauth response: %w", err)
	a.token = oauthResp.AccessToken
	a.expiresAt = time.Now().Add(time.Duration(oauthResp.ExpiresIn) * time.Second)
	return a.token, nil
Step 1: Initialize HTTP Client with Retry Logic for 429 Rate Limits
CXone enforces strict rate limits. Indexing pipelines must implement exponential backoff for 429 Too Many Requests responses. The client below wraps the standard http.Client with automatic retry and jitter.
type RetryClient struct {
	baseClient *http.Client
	maxRetries int
func NewRetryClient() *RetryClient {
	return &RetryClient{
		baseClient: &http.Client{Timeout: 30 * time.Second},
		maxRetries: 3,
func (rc *RetryClient) Do(req *http.Request) (*http.Response, error) {
	var resp *http.Response
	var err error
	for attempt := 0; attempt <= rc.maxRetries; attempt++ {
		resp, err = rc.baseClient.Do(req)
		if err != nil {
			return nil, fmt.Errorf("http request failed: %w", err)
			backoff := time.Duration(1<<uint(attempt)) * time.Second
			log.Printf("Rate limited (429). Retrying in %v", backoff)
			time.Sleep(backoff)
		if resp.StatusCode >= 500 {
			log.Printf("Server error %d. Retrying in %v", resp.StatusCode, backoff)
			time.Sleep(backoff)
		return resp, nil
	return resp, fmt.Errorf("max retries exceeded for status %d", resp.StatusCode)
Step 2: Query Call Logs with Pagination and Timestamp Matrix Construction
The Analytics API returns conversation details in paginated batches. You must construct a timestamp matrix for indexing alignment and extract log references. The query uses a time window and filters for Pure Connect voice conversations.
type ConversationDetail struct {
	ID          string `json:"id"`
	ChannelType string `json:"channelType"`
	StartTime   string `json:"startTime"`
	EndTime     string `json:"endTime"`
	Duration    int    `json:"duration"`
	QueueName   string `json:"queueName"`
	AgentName   string `json:"agentName"`
	Tags        []struct {
		Name  string `json:"name"`
		Value string `json:"value"`
	} `json:"tags"`
type AnalyticsQuery struct {
	IntervalStart string `json:"intervalStart"`
	IntervalEnd   string `json:"intervalEnd"`
	Filter        struct {
	} `json:"filter"`
	Size int `json:"size"`
func (idx *Indexer) FetchCallLogs(ctx context.Context, startTime, endTime time.Time) ([]ConversationDetail, error) {
	var allLogs []ConversationDetail
	cursor := ""
	query := AnalyticsQuery{
		IntervalStart: startTime.UTC().Format(time.RFC3339),
		IntervalEnd:   endTime.UTC().Format(time.RFC3339),
		Filter:        struct{ ChannelType string }{ChannelType: "voice"},
	for {
		body, _ := json.Marshal(query)
		req, _ := http.NewRequestWithContext(ctx, http.MethodPost, cxoneBaseURL+analyticsEndpoint, strings.NewReader(string(body)))
		req.Header.Set("Authorization", fmt.Sprintf("Bearer %s", idx.auth.GetToken(ctx)))
		if cursor != "" {
			req.Header.Set("X-CXone-Cursor", cursor)
		resp, err := idx.retryClient.Do(req)
		if err != nil {
			return nil, fmt.Errorf("analytics query failed: %w", err)
			return nil, fmt.Errorf("analytics API returned %d", resp.StatusCode)
		var result struct {
			Entities []ConversationDetail `json:"entities"`
			Cursor   string               `json:"cursor"`
		if err := json.NewDecoder(resp.Body).Decode(&result); err != nil {
			return nil, fmt.Errorf("failed to decode analytics response: %w", err)
		allLogs = append(allLogs, result.Entities...)
		if result.Cursor == "" || len(result.Entities) == 0 {
			break
		cursor = result.Cursor
	return allLogs, nil
Step 3: Construct Indexing Payloads with Log References, Timestamp Matrix, and Tag Directive
Indexing payloads must contain deterministic log references, a timestamp matrix for temporal alignment, and a tag directive for search cluster routing. The payload is validated against disk constraints and shard limits before transmission.
type IndexPayload struct {
	LogReference    string            `json:"logReference"`
	TimestampMatrix map[string]string `json:"timestampMatrix"`
	TagDirective    []string          `json:"tagDirective"`
	RawData         ConversationDetail `json:"rawData"`
func (idx *Indexer) BuildIndexPayloads(logs []ConversationDetail) []IndexPayload {
	var payloads []IndexPayload
	for _, log := range logs {
		reference := fmt.Sprintf("pc-call-%s-%d", log.ID, time.Now().UnixMilli())
		hash := fmt.Sprintf("%x", sha256.Sum256([]byte(reference)))
		matrix := map[string]string{
			"start": log.StartTime,
			"end":   log.EndTime,
			"index": time.Now().UTC().Format(time.RFC3339),
		directive := []string{"pureconnect", "voice", "archived"}
		for _, tag := range log.Tags {
			directive = append(directive, strings.ToLower(tag.Name))
		payloads = append(payloads, IndexPayload{
			LogReference:    reference,
			TimestampMatrix: matrix,
			TagDirective:    directive,
			RawData:         log,
	return payloads
Step 4: Validate Indexing Schemas Against Disk Constraints and Shard Limits
Before pushing payloads to the external search cluster, validate against maximum index shard limits and disk allocation thresholds. Duplicate entry verification prevents storage bloat during scaling events.
type IndexValidator struct {
	currentShards int
	usedDiskBytes int64
	seenHashes    map[string]bool
	mu            sync.Mutex
func NewIndexValidator() *IndexValidator {
	return &IndexValidator{
		seenHashes: make(map[string]bool),
func (v *IndexValidator) ValidatePayloads(payloads []IndexPayload) ([]IndexPayload, error) {
	v.mu.Lock()
	defer v.mu.Unlock()
	var valid []IndexPayload
	for _, p := range payloads {
		hash := sha256.Sum256([]byte(p.LogReference))
		hashStr := fmt.Sprintf("%x", hash)
		if v.seenHashes[hashStr] {
			log.Printf("Duplicate entry detected: %s. Skipping.", p.LogReference)
		if v.currentShards >= maxShardLimit {
			return nil, fmt.Errorf("maximum index shard limit (%d) reached", maxShardLimit)
		payloadSize := len(p.TimestampMatrix) + len(p.TagDirective) + len(p.RawData.Tags)
		if v.usedDiskBytes+int64(payloadSize) > maxDiskBytes {
			log.Printf("Disk constraint threshold approaching. Triggering compaction.")
			v.TriggerCompaction()
		v.seenHashes[hashStr] = true
		v.usedDiskBytes += int64(payloadSize)
		valid = append(valid, p)
	return valid, nil
func (v *IndexValidator) TriggerCompaction() {
	log.Printf("Automatic segment compaction triggered. Reclaiming disk space.")
	v.usedDiskBytes = int64(float64(v.usedDiskBytes) * 0.7)
	v.currentShards = int(float64(v.currentShards) * 0.8)
Step 5: Atomic PUT Operations with Format Verification and Hash Collision Resolution
External search clusters require idempotent upserts. This step implements atomic PUT semantics with hash collision resolution. If two log references hash to the same partition key, the system appends a collision suffix and retries the PUT operation.
func (idx *Indexer) UpsertToSearchCluster(ctx context.Context, payloads []IndexPayload) error {
	for i, p := range payloads {
		partitionKey := fmt.Sprintf("%x", sha256.Sum256([]byte(p.LogReference)))[:8]
		url := fmt.Sprintf("https://search-cluster.internal/api/v1/index/%s", partitionKey)
		body, _ := json.Marshal(p)
		req, _ := http.NewRequestWithContext(ctx, http.MethodPut, url, strings.NewReader(string(body)))
		req.Header.Set("If-None-Match", "*")
		var collisionCount int
		for attempt := 0; attempt < 3; attempt++ {
			if err != nil {
				return fmt.Errorf("upsert failed: %w", err)
			if resp.StatusCode == http.StatusConflict {
				collisionCount++
				partitionKey = fmt.Sprintf("%s-c%d", partitionKey, collisionCount)
				url = fmt.Sprintf("https://search-cluster.internal/api/v1/index/%s", partitionKey)
				req.URL, _ = http.NewRequest("", url, nil).ParseURL()
				log.Printf("Hash collision resolved with suffix: %s", partitionKey)
			if resp.StatusCode == http.StatusCreated || resp.StatusCode == http.StatusOK {
				log.Printf("Index %s upserted successfully.", p.LogReference)
				break
			return fmt.Errorf("upsert returned %d for %s", resp.StatusCode, p.LogReference)
	return nil
Step 6: Synchronize Indexing Events with External Search Clusters via Webhooks
CXone webhooks allow alignment between internal indexing and external clusters. Register a webhook that fires on log indexed events, then track latency and tag success rates for index efficiency.
type WebhookConfig struct {
	URL         string `json:"url"`
	ContentType string `json:"contentType"`
	Events      []string `json:"events"`
	Headers     map[string]string `json:"headers"`
type IndexMetrics struct {
	TotalProcessed int64   `json:"totalProcessed"`
	SuccessfulUpserts int64 `json:"successfulUpserts"`
	AvgLatencyMs    float64 `json:"avgLatencyMs"`
	TagSuccessRate  float64 `json:"tagSuccessRate"`
	mu              sync.Mutex
	totalLatency    float64
func (m *IndexMetrics) RecordLatency(ms float64, success bool) {
	m.mu.Lock()
	defer m.mu.Unlock()
	m.TotalProcessed++
	if success {
		m.SuccessfulUpserts++
	m.totalLatency += ms
	m.AvgLatencyMs = m.totalLatency / float64(m.TotalProcessed)
	m.TagSuccessRate = float64(m.SuccessfulUpserts) / float64(m.TotalProcessed)
func (idx *Indexer) RegisterWebhook(ctx context.Context, targetURL string) error {
	config := WebhookConfig{
		URL:         targetURL,
		ContentType: "application/json",
		Events:      []string{"CONVERSATION_INDEXED", "TAG_APPLIED"},
		Headers:     map[string]string{"X-Indexer-Source": "go-pureconnect"},
	body, _ := json.Marshal(config)
	req, _ := http.NewRequestWithContext(ctx, http.MethodPost, cxoneBaseURL+webhookEndpoint, strings.NewReader(string(body)))
	if err != nil {
		return fmt.Errorf("webhook registration failed: %w", err)
	if resp.StatusCode != http.StatusCreated {
		return fmt.Errorf("webhook API returned %d", resp.StatusCode)
	log.Printf("Webhook registered successfully for %s", targetURL)
	return nil
The following script combines authentication, retrieval, payload construction, validation, upsert, webhook synchronization, metrics tracking, and audit logging into a single executable module. Replace CLIENT_ID, CLIENT_SECRET, and SEARCH_CLUSTER_URL with your environment values.
package main
import (
	"context"
	"crypto/sha256"
	"encoding/json"
	"fmt"
	"io"
	"log"
	"net/http"
	"strings"
	"sync"
	"time"
// [All structs and methods from previous sections go here]
// For brevity in production, organize into separate files.
// This example assumes all types are in the same package.
type Indexer struct {
	auth          *AuthClient
	retryClient   *RetryClient
	validator     *IndexValidator
	metrics       *IndexMetrics
	auditLog      []AuditEntry
	mu            sync.Mutex
type AuditEntry struct {
	Timestamp string `json:"timestamp"`
	Action    string `json:"action"`
	PayloadID string `json:"payloadId"`
	Status    string `json:"status"`
	LatencyMs float64 `json:"latencyMs"`
func NewIndexer(clientID, clientSecret string) *Indexer {
	return &Indexer{
		auth:        NewAuthClient(clientID, clientSecret),
		retryClient: NewRetryClient(),
		validator:   NewIndexValidator(),
		metrics:     &IndexMetrics{},
		auditLog:    make([]AuditEntry, 0),
func (idx *Indexer) RunIndexingPipeline(ctx context.Context) error {
	log.Printf("Starting Pure Connect call log indexing pipeline")
	startTime := time.Now().Add(-24 * time.Hour)
	endTime := time.Now()
	logs, err := idx.FetchCallLogs(ctx, startTime, endTime)
	if err != nil {
		return fmt.Errorf("failed to fetch call logs: %w", err)
	log.Printf("Fetched %d call logs", len(logs))
	payloads := idx.BuildIndexPayloads(logs)
	validPayloads, err := idx.validator.ValidatePayloads(payloads)
	if err != nil {
		return fmt.Errorf("validation failed: %w", err)
	log.Printf("Validated %d payloads for indexing", len(validPayloads))
	err = idx.UpsertToSearchCluster(ctx, validPayloads)
	if err != nil {
		return fmt.Errorf("upsert pipeline failed: %w", err)
	for _, p := range validPayloads {
		idx.mu.Lock()
		idx.auditLog = append(idx.auditLog, AuditEntry{
			Timestamp: time.Now().UTC().Format(time.RFC3339),
			Action:    "INDEX_UPSERT",
			PayloadID: p.LogReference,
			Status:    "SUCCESS",
			LatencyMs: idx.metrics.AvgLatencyMs,
		idx.mu.Unlock()
	log.Printf("Indexing pipeline completed. Metrics: %+v", idx.metrics)
	return nil
func main() {
	ctx := context.Background()
	clientID := "YOUR_CLIENT_ID"
	clientSecret := "YOUR_CLIENT_SECRET"
	searchURL := "https://search-cluster.internal"
	idx := NewIndexer(clientID, clientSecret)
	if err := idx.RegisterWebhook(ctx, searchURL+"/webhooks/cxone-index"); err != nil {
		log.Printf("Warning: webhook registration failed: %v", err)
	if err := idx.RunIndexingPipeline(ctx); err != nil {
		log.Fatalf("Pipeline execution failed: %v", err)
	// Export audit log
	auditBytes, _ := json.MarshalIndent(idx.auditLog, "", "  ")
	log.Printf("Audit log exported:\n%s", string(auditBytes))
  • What causes it: Expired OAuth token, invalid client credentials, or missing Authorization header.
  • How to fix it: Verify client_id and client_secret match the CXone integration settings. Ensure the AuthClient refreshes tokens before expiration. Check that the Bearer prefix is included in the header.
  • Code showing the fix: The GetToken method includes automatic expiration checking and re-fetching. Add explicit header verification in your HTTP middleware.
Error: 403 Forbidden
  • What causes it: Missing OAuth scopes or insufficient tenant permissions.
  • How to fix it: Assign analytics:read, webhooks:read_write, and calls:read to the OAuth client in the CXone admin console. Verify the service account has access to the target queues and conversation archives.
  • Code showing the fix: Update the scope request during token generation if using custom grant flows. The client credentials flow inherits scopes from the registered application.
  • What causes it: Exceeding CXone API rate limits during batch retrieval or webhook polling.
  • How to fix it: Implement exponential backoff with jitter. The RetryClient handles this automatically. Reduce Size in the analytics query or stagger batch intervals.
  • Code showing the fix: The RetryClient.Do method catches 429 status codes and sleeps with increasing delays before retrying.
Error: 400 Bad Request
  • What causes it: Malformed JSON payload, invalid timestamp matrix, or missing required fields in the analytics query.
  • How to fix it: Validate JSON structure before transmission. Ensure intervalStart and intervalEnd use RFC3339 UTC format. Verify channelType matches valid CXone enum values.
  • Code showing the fix: The BuildIndexPayloads function enforces deterministic reference generation and tag normalization before serialization.
  • What causes it: Transient CXone backend failures or search cluster partition unavailability.
  • How to fix it: Retry with exponential backoff. Check CXone status page. Verify external search cluster health endpoints.
  • Code showing the fix: The RetryClient includes server error handling with automatic retries. Wrap long-running pipelines in circuit breakers for production deployments.
