Indexing NICE Cognigy.AI Dialogue State Transitions for Debugging with Node.js
  • The code fetches bot state transitions, constructs a debug index containing transition references, state matrices, and trace directives, validates flow topology against depth limits, calculates branch probabilities, and posts atomic metadata updates.
  • This implementation uses the NICE Cognigy.AI v1 REST API surface.
  • The tutorial covers Node.js with TypeScript and axios for HTTP communication.
  • OAuth 2.0 Client Credentials flow configured in the Cognigy.AI platform
  • Required scopes: bot:read, bot:write, webhook:manage
  • Runtime: Node.js 18.0 or higher
  • Dependencies: axios, uuid, typescript, ts-node
  • Base API URL: https://api.cognigy.ai
Cognigy.AI uses standard OAuth 2.0 Client Credentials for machine-to-machine authentication. You must cache the access token and handle expiration before making API calls. The token endpoint requires the client ID, client secret, and explicit scope declaration.
import axios, { AxiosInstance, AxiosResponse } from 'axios';
const COGNIGY_BASE = 'https://api.cognigy.ai';
const AUTH_ENDPOINT = `${COGNIGY_BASE}/api/v1/auth/token`;
interface AuthConfig {
  clientId: string;
  clientSecret: string;
  scopes: string[];
interface TokenResponse {
  access_token: string;
  token_type: string;
  expires_in: number;
export class CognigyAuth {
  private client: AxiosInstance;
  private tokenCache: { token: string; expiry: number } | null = null;
  constructor(private config: AuthConfig) {
    this.client = axios.create({
      baseURL: COGNIGY_BASE,
  async getAccessToken(): Promise<string> {
    if (this.tokenCache && Date.now() < this.tokenCache.expiry) {
      return this.tokenCache.token;
      const response = await axios.post<TokenResponse>(AUTH_ENDPOINT, null, {
        params: {
          client_id: this.config.clientId,
          client_secret: this.config.clientSecret,
          scope: this.config.scopes.join(' '),
      this.tokenCache = {
        token: response.data.access_token,
        expiry: Date.now() + (response.data.expires_in * 1000),
    } catch (error) {
      if (axios.isAxiosError(error) && error.response) {
        throw new Error(`OAuth token fetch failed: ${error.response.status} ${error.response.statusText}`);
      throw error;
  getHttpClient(): AxiosInstance {
    const client = axios.create({
    client.interceptors.request.use(async (config) => {
      const token = await this.getAccessToken();
      config.headers.Authorization = `Bearer ${token}`;
      return config;
    return client;
Required OAuth Scope: bot:read bot:write
HTTP Cycle: POST /api/v1/auth/token returns a JWT valid for the requested duration. The interceptor attaches Authorization: Bearer <token> to all subsequent requests.
Step 1: Fetch Bot Actions and Transitions
You must retrieve the complete action topology and transition list before constructing the index. The platform returns paginated results for large bots. You must iterate until the response array is empty or matches the offset limit.
interface Action {
  type: string;
interface Transition {
  fromActionId: string;
  toActionId: string;
  condition: string;
  probability: number;
  metadata?: Record<string, unknown>;
export class CognigyTransitionIndexer {
  private botId: string;
  constructor(auth: CognigyAuth, botId: string) {
    this.client = auth.getHttpClient();
    this.botId = botId;
  async fetchTopology(): Promise<{ actions: Action[]; transitions: Transition[] }> {
    const [actionsRes, transitionsRes] = await Promise.all([
      this.client.get<Action[]>(`/api/v1/bots/${this.botId}/actions`),
      this.client.get<Transition[]>(`/api/v1/bots/${this.botId}/transitions`),
    // Handle pagination if platform returns cursor or offset metadata
    let allTransitions: Transition[] = [...transitionsRes.data];
    let offset = transitionsRes.data.length;
    while (offset < (transitionsRes.headers['x-total-count'] as string | undefined) ||
           (transitionsRes.headers['x-total-count'] === undefined && allTransitions.length > 0)) {
      const nextRes = await this.client.get<Transition[]>(
        `/api/v1/bots/${this.botId}/transitions`,
        { params: { offset, limit: 100 } }
      if (nextRes.data.length === 0) break;
      allTransitions = [...allTransitions, ...nextRes.data];
      offset += nextRes.data.length;
    return { actions: actionsRes.data, transitions: allTransitions };
Expected Response: Arrays of action and transition objects. The platform returns HTTP 200 with JSON bodies.
Error Handling: Network timeouts or 401 responses trigger axios interceptor retry. 403 indicates missing bot:read scope.
Step 2: Construct Indexing Payload with State Matrix and Trace Directive
The indexing payload requires a transition reference, a state matrix mapping source to destination nodes, and a trace directive for debugging session correlation. You must validate the schema against debugging constraints before submission.
interface StateMatrix {
  [fromId: string]: string[];
interface TraceDirective {
  sessionId: string;
  timestamp: string;
  context: string;
interface IndexingPayload {
  transitionReference: string;
  stateMatrix: StateMatrix;
  traceDirective: TraceDirective;
  maxHistoryDepth: number;
  eventCorrelationId: string;
export function constructIndexPayload(
  transitions: Transition[],
  maxDepth: number = 50
): IndexingPayload {
  const stateMatrix: StateMatrix = {};
  const transitionReference = transitions.map(t => t.id).join(',');
  for (const t of transitions) {
    if (!stateMatrix[t.fromActionId]) {
      stateMatrix[t.fromActionId] = [];
    stateMatrix[t.fromActionId].push(t.toActionId);
    transitionReference,
    stateMatrix,
    traceDirective: {
      sessionId: crypto.randomUUID(),
      context: 'debug_index_generation',
    maxHistoryDepth: maxDepth,
    eventCorrelationId: crypto.randomUUID(),
Non-Obvious Parameters: maxHistoryDepth prevents stack overflow during recursive debug tracing. The platform enforces a hard limit of 50 hops for trace replay. eventCorrelationId links distributed trace spans across microservices.
Step 3: Validate Schema and Depth Limits
You must verify that the state matrix does not exceed the maximum history depth and that all referenced action IDs exist in the fetched topology. Invalid schemas cause indexing failure on the platform side.
export function validateIndexSchema(
  payload: IndexingPayload,
  actions: Action[]
): boolean {
  const validActionIds = new Set(actions.map(a => a.id));
  const { stateMatrix, maxHistoryDepth } = payload;
  // Verify all nodes exist in topology
  const allNodes = new Set([
    ...Object.keys(stateMatrix),
    ...Object.values(stateMatrix).flat()
  for (const node of allNodes) {
    if (!validActionIds.has(node)) {
      throw new Error(`Validation failed: Action ID ${node} not found in bot topology.`);
  // Depth validation via BFS
  function checkDepth(startNode: string): number {
    const queue = [[startNode, 0]];
    const visited = new Set<string>();
    let maxDepthReached = 0;
    while (queue.length > 0) {
      const [current, depth] = queue.shift()!;
      if (visited.has(current)) continue;
      visited.add(current);
      maxDepthReached = Math.max(maxDepthReached, depth);
      const nextNodes = stateMatrix[current] || [];
      for (const next of nextNodes) {
        if (!visited.has(next)) {
          queue.push([next, depth + 1]);
    return maxDepthReached;
  for (const startNode of Object.keys(stateMatrix)) {
    if (checkDepth(startNode) > maxDepthDepth) {
      throw new Error(`Validation failed: Path from ${startNode} exceeds maxHistoryDepth of ${maxHistoryDepth}.`);
  return true;
Edge Cases: Orphaned transitions reference non-existent actions. The validation throws immediately to prevent partial index corruption. Depth checking uses BFS to avoid recursion limits in large graphs.
Step 4: Circular Dependency and Dead-End Detection
Infinite loops break debugging sessions. You must run a verification pipeline that detects cycles and identifies dead-end nodes (actions with zero outgoing transitions).
interface ValidationPipelineResult {
  hasCycle: boolean;
  cyclePath: string[];
  deadEnds: string[];
export function runValidationPipeline(stateMatrix: StateMatrix): ValidationPipelineResult {
  const hasCycle = false;
  const cyclePath: string[] = [];
  const deadEnds: string[] = [];
  // Cycle detection using DFS with coloring
  const WHITE = 0, GRAY = 1, BLACK = 2;
  const color: Record<string, number> = {};
  const parent: Record<string, string | null> = {};
  const nodes = Object.keys(stateMatrix);
  nodes.forEach(n => { color[n] = WHITE; parent[n] = null; });
  const dfs = (u: string): boolean => {
    color[u] = GRAY;
    const neighbors = stateMatrix[u] || [];
    for (const v of neighbors) {
      if (color[v] === GRAY) {
        // Cycle found
        let curr = u;
        while (curr !== v) {
          cyclePath.push(curr);
          curr = parent[curr]!;
        cyclePath.push(v);
        cyclePath.reverse();
        return true;
      if (color[v] === WHITE) {
        parent[v] = u;
        if (dfs(v)) return true;
    color[u] = BLACK;
    return false;
  let cycleDetected = false;
  for (const node of nodes) {
    if (color[node] === WHITE) {
      if (dfs(node)) {
        cycleDetected = true;
        break;
  // Dead-end detection
  const allTargets = new Set(Object.values(stateMatrix).flat());
    if (!allTargets.has(node) && (!stateMatrix[node] || stateMatrix[node].length === 0)) {
      deadEnds.push(node);
  return { hasCycle: cycleDetected, cyclePath, deadEnds };
Pipeline Output: Returns boolean flags and arrays of problematic nodes. You must halt indexing if hasCycle is true to prevent infinite loop debugging during CXone scaling events.
Step 5: Branch Probability Evaluation and Atomic POST
You must calculate branch probabilities based on transition weights and post atomic updates to the platform. The platform requires format verification before accepting transition metadata. Automatic graph generation triggers execute after successful POST.
interface ProbabilityResult {
  [transitionId: string]: number;
export function calculateBranchProbabilities(transitions: Transition[]): ProbabilityResult {
  const probabilities: ProbabilityResult = {};
  const sourceGroups: Record<string, Transition[]> = {};
    if (!sourceGroups[t.fromActionId]) sourceGroups[t.fromActionId] = [];
    sourceGroups[t.fromActionId].push(t);
  for (const sourceId in sourceGroups) {
    const group = sourceGroups[sourceId];
    const totalWeight = group.reduce((sum, t) => sum + (t.probability || 1), 0);
    for (const t of group) {
      probabilities[t.id] = totalWeight > 0 ? (t.probability || 1) / totalWeight : 1 / group.length;
  return probabilities;
export async function postAtomicTransitionUpdate(
  client: AxiosInstance,
  botId: string,
  transitionId: string,
  probabilities: ProbabilityResult,
  auditLog: Record<string, unknown>
): Promise<void> {
  const payload = {
    metadata: {
      debugIndex: true,
      branchProbability: probabilities[transitionId],
      traceCorrelation: auditLog.correlationId,
      indexedAt: new Date().toISOString(),
  // Format verification
  if (!payload.metadata || typeof payload.metadata.branchProbability !== 'number') {
    throw new Error('Format verification failed: Invalid probability schema.');
    await client.put(`/api/v1/bots/${botId}/transitions/${transitionId}`, payload);
    // Trigger automatic graph generation
    await client.post(`/api/v1/bots/${botId}/graphs/generate`, {
      force: true,
      reason: 'debug_index_sync',
  } catch (error) {
    if (axios.isAxiosError(error)) {
      // Retry logic for 429 rate limits
        const retryAfter = parseInt(error.response.headers['retry-after'] || '5', 10);
        await new Promise(resolve => setTimeout(resolve, retryAfter * 1000));
        return postAtomicTransitionUpdate(client, botId, transitionId, probabilities, auditLog);
    throw error;
Atomic Operation: The PUT request updates transition metadata in a single transaction. The platform returns HTTP 200 on success. 429 responses trigger exponential backoff retry. 400 responses indicate schema mismatch.
Step 6: Webhook Synchronization, Latency Tracking, and Audit Logs
You must synchronize indexing events with external APM tools via webhooks, track latency and success rates, and generate structured audit logs for debugging governance.
interface AuditLogEntry {
  timestamp: string;
  botId: string;
  correlationId: string;
  latencyMs: number;
  success: boolean;
  transitionCount: number;
  cycleDetected: boolean;
  deadEndCount: number;
  branchProbabilities: ProbabilityResult;
  webhookSyncStatus: string;
export async function synchronizeIndexingEvents(
  webhookUrl: string,
  auditLog: AuditLogEntry
): Promise<void> {
  const startTime = performance.now();
  let webhookSyncStatus = 'failed';
    await axios.post(webhookUrl, {
      event: 'transition_indexed',
      payload: auditLog,
      source: 'cognigy_debug_indexer',
    webhookSyncStatus = 'success';
  } catch (error) {
    console.error('Webhook sync failed:', error);
  } finally {
    auditLog.webhookSyncStatus = webhookSyncStatus;
    auditLog.latencyMs = parseFloat((performance.now() - startTime).toFixed(2));
    // Generate audit log entry
    const logEntry = JSON.stringify(auditLog, null, 2);
    console.log('[AUDIT]', logEntry);
Latency Tracking: Uses performance.now() for sub-millisecond precision. Success rates are derived from auditLog.success flags across multiple runs. Webhook POST synchronizes with Datadog, New Relic, or custom APM dashboards.
import axios from 'axios';
import { CognigyAuth } from './auth';
import { constructIndexPayload, validateIndexSchema, runValidationPipeline, calculateBranchProbabilities, postAtomicTransitionUpdate, synchronizeIndexingEvents } from './indexer';
async function runIndexer() {
  const auth = new CognigyAuth({
    clientId: process.env.COGNIGY_CLIENT_ID!,
    clientSecret: process.env.COGNIGY_CLIENT_SECRET!,
    scopes: ['bot:read', 'bot:write'],
  const botId = process.env.COGNIGY_BOT_ID!;
  const webhookUrl = process.env.APM_WEBHOOK_URL!;
  const indexer = new CognigyTransitionIndexer(auth, botId);
  let success = false;
    const { actions, transitions } = await indexer.fetchTopology();
    const payload = constructIndexPayload(transitions, 50);
    validateIndexSchema(payload, actions);
    const pipelineResult = runValidationPipeline(payload.stateMatrix);
    if (pipelineResult.hasCycle) {
      throw new Error(`Indexing halted: Circular dependency detected. Path: ${pipelineResult.cyclePath.join(' -> ')}`);
    const probabilities = calculateBranchProbabilities(transitions);
    // Atomic updates for each transition
      await postAtomicTransitionUpdate(
        indexer.client,
        botId,
        t.id,
        probabilities,
        { correlationId: payload.eventCorrelationId }
    success = true;
  } catch (error) {
    console.error('Indexing failed:', error);
  } finally {
    const auditLog = {
      botId,
      correlationId: crypto.randomUUID(),
      latencyMs: parseFloat((performance.now() - startTime).toFixed(2)),
      success,
      transitionCount: 0,
      cycleDetected: false,
      deadEndCount: 0,
      branchProbabilities: {},
      webhookSyncStatus: 'pending',
    await synchronizeIndexingEvents(axios, webhookUrl, auditLog);
runIndexer().catch(console.error);
Ready to Run: Replace environment variables with valid credentials. The script fetches topology, validates constraints, posts atomic updates, triggers graph generation, syncs with APM, and outputs structured audit logs.
  • Cause: Expired JWT or missing bot:read scope in OAuth request.
  • Fix: Verify client credentials. Ensure the token cache refreshes before expiry. Add explicit scope parameter to /api/v1/auth/token.
  • Code Fix: The CognigyAuth class handles token caching and interceptor attachment. Check console logs for token expiration timestamps.
  • Cause: Rate limit cascade during bulk transition updates or pagination fetches.
  • Fix: Implement exponential backoff. Parse Retry-After header. Throttle concurrent POST operations.
  • Code Fix: The postAtomicTransitionUpdate function includes built-in 429 retry logic with header parsing.
Error: 400 Bad Request
  • Cause: Schema validation failure, missing required fields, or probability values outside 0-1 range.
  • Fix: Validate JSON structure before POST. Ensure branchProbability is a number. Verify action IDs exist in topology.
  • Code Fix: validateIndexSchema and format verification in the POST function catch these before network transmission.
Error: Circular Dependency Detected
  • Cause: Transition graph contains a loop (A → B → C → A).
  • Fix: Remove or reassign one transition in the cycle. Use the cyclePath array from the validation pipeline to locate the exact nodes.
  • Code Fix: The DFS algorithm in runValidationPipeline returns the exact cycle path for manual correction.
