Indexing Genesys Cloud Media Transcripts with Python SDK and Custom Payload Construction
  • A Python service that retrieves media transcripts via the Genesys Cloud Recordings API, constructs validated indexing payloads with segment matrices and map directives, and synchronizes them to an external search index with latency tracking and audit logging.
  • This tutorial uses the Genesys Cloud Python SDK (genesyscloud) and httpx for REST operations.
  • The implementation covers Python 3.10+ with production-ready error handling, schema validation, and retry logic.
  • OAuth client credentials (service account) with scopes: recording:view, transcript:view, search:query
  • Genesys Cloud Python SDK version 1.0.0 or higher
  • Python 3.10 runtime environment
  • External dependencies: genesyscloud, httpx, pydantic, python-dotenv, stemmer
  • Access to an external search index endpoint (Elasticsearch, OpenSearch, or custom REST indexer)
The Genesys Cloud Python SDK handles client credentials OAuth flows automatically. You must configure the client with your environment URL, client ID, and client secret. The SDK caches tokens and refreshes them transparently before expiration.
import os
from genesyscloud import PureCloudPlatformClientV2
load_dotenv()
def initialize_genesys_client() -> PureCloudPlatformClientV2:
    """Initialize the Genesys Cloud SDK client with OAuth client credentials."""
    client = PureCloudPlatformClientV2()
    client.set_environment_url(os.getenv("GENESYS_ENV_URL", "https://api.mypurecloud.com"))
    client.set_auth_mode("CLIENT_CREDENTIALS")
    client.set_auth_credentials(
        os.getenv("GENESYS_CLIENT_ID"),
        os.getenv("GENESYS_CLIENT_SECRET")
    return client
The SDK raises genesyscloud.rest.ApiException on authentication failures. You must catch HTTP 401 and 403 responses and verify scope assignments in the Genesys Cloud admin console under Security > OAuth > Clients.
Step 1: Fetch Transcript and Validate Media Constraints
You retrieve the transcript using the RecordingsApi. You must validate the media constraints before indexing. This includes verifying audio track synchronization, language code alignment, and maximum searchable field limits.
from genesyscloud.recordings_api import RecordingsApi
import logging
def fetch_and_validate_transcript(client: PureCloudPlatformClientV2, recording_id: str, transcript_id: str):
    """Fetch transcript and recording metadata. Validate language and track constraints."""
    recordings_api = RecordingsApi(client)
    # Fetch recording metadata
        recording_response = recordings_api.get_recording(recording_id)
    except ApiException as e:
        if e.status == 401:
            raise RuntimeError("OAuth token invalid. Check client credentials.")
        if e.status == 403:
            raise RuntimeError("Insufficient scopes. Ensure recording:view is assigned.")
        raise
    # Fetch transcript
        transcript_response = recordings_api.get_recording_transcript(transcript_id)
        if e.status == 429:
            logger.warning("Rate limited on transcript fetch. Implement backoff at caller level.")
            raise
        raise
    # Validate language code alignment
    audio_track = recording_response.media.track if recording_response.media else None
    transcript_language = transcript_response.language if transcript_response.language else "en-US"
    if audio_track and audio_track.language and audio_track.language != transcript_language:
        raise ValueError(
            f"Audio track language mismatch. Track: {audio_track.language}, Transcript: {transcript_language}"
    return recording_response, transcript_response
The GET /api/v2/recordings/{recordingId} endpoint returns media constraints including track duration and sample rate. The GET /api/v2/recordings/transcripts/{transcriptId} endpoint returns segment arrays. You must align segment timestamps with the audio track boundaries before indexing.
Step 2: Construct Indexing Payload with Segment Matrix and Map Directive
You build the indexing payload using a Pydantic model to enforce schema validation. The payload contains a segment matrix, timestamp boundaries, a map directive for field routing, and stemmed keywords. You enforce a maximum searchable field limit to prevent index fragmentation.
from pydantic import BaseModel, Field, validator
import stemmer
class TranscriptSegment(BaseModel):
    start_time: float
    end_time: float
    text: str
    stemmed_terms: List[str] = []
class IndexingPayload(BaseModel):
    transcript_id: str
    recording_id: str
    language: str
    segment_matrix: List[TranscriptSegment]
    map_directive: Dict[str, str]
    metadata: Dict[str, Any] = {}
    MAX_SEARCHABLE_FIELDS: int = 100
    @validator("segment_matrix")
    def align_timestamps_and_stem(cls, v: List[TranscriptSegment], values):
        stemmer_eng = stemmer.Stemmer("english")
        aligned_segments = []
        for seg in v:
            # Boundary alignment: clamp to 0 and track duration if provided
            seg.start_time = max(0.0, seg.start_time)
            seg.end_time = max(seg.start_time, seg.end_time)
            # Keyword stemming logic
            terms = seg.text.lower().split()
            stemmed = [stemmer_eng.stem(t) for t in terms if t.isalpha()]
            seg.stemmed_terms = list(set(stemmed))
            aligned_segments.append(seg)
        return aligned_segments
    @validator("map_directive")
    def enforce_field_limits(cls, v: Dict[str, str]):
        if len(v) > cls.MAX_SEARCHABLE_FIELDS:
            raise ValueError(
                f"Map directive exceeds maximum searchable field limit of {cls.MAX_SEARCHABLE_FIELDS}. "
                "Prune non-essential fields to prevent index fragmentation."
        return v
def build_indexing_payload(transcript_response, recording_response) -> IndexingPayload:
    """Construct validated indexing payload from Genesys Cloud responses."""
    segments = []
    for seg in transcript_response.segments:
        segments.append(TranscriptSegment(
            start_time=seg.start_time,
            end_time=seg.end_time,
            text=seg.text
    map_directive = {
        "transcript_id": "keyword",
        "recording_id": "keyword",
        "language": "keyword",
        "segment_matrix.text": "text",
        "segment_matrix.stemmed_terms": "text",
        "metadata.created_time": "date"
    payload = IndexingPayload(
        transcript_id=transcript_response.id,
        recording_id=transcript_response.recording_id,
        language=transcript_response.language,
        segment_matrix=segments,
        map_directive=map_directive,
        metadata={"created_time": transcript_response.created_time}
    return payload
The map_directive defines how the external search engine maps payload fields to index types. The align_timestamps_and_stem validator enforces boundary alignment and applies Porter stemming to reduce query cardinality. The enforce_field_limits validator prevents schema bloat that causes indexing failures during scaling events.
Step 3: Atomic PUT Operation with Retry Logic and Webhook Synchronization
You push the validated payload to the external search index using an atomic PUT operation. You implement exponential backoff for 429 responses, track latency and success rates, trigger automatic index rebuilds on failure, and synchronize via transcript indexed webhooks.
import httpx
import json
from typing import Optional
INDEX_URL = os.getenv("EXTERNAL_INDEX_URL", "https://search.internal/api/v1/index/transcripts")
WEBHOOK_URL = os.getenv("WEBHOOK_URL", "https://hooks.internal/transcript-indexed")
class IndexingTracker:
    def __init__(self):
        self.total_attempts = 0
        self.successful_puts = 0
        self.failed_puts = 0
        self.total_latency_ms = 0.0
tracker = IndexingTracker()
def atomic_put_index(payload: IndexingPayload, audit_log_path: str = "indexing_audit.jsonl"):
    """Push payload to external index with retry, latency tracking, and audit logging."""
    headers = {
        "Accept": "application/json"
    with httpx.Client(timeout=30.0) as client:
        retries = 0
        max_retries = 4
        base_delay = 2.0
        while retries < max_retries:
                response = client.put(
                    INDEX_URL,
                    headers=headers,
                    json=payload.dict(),
                    follow_redirects=True
                elapsed_ms = (time.perf_counter() - start_time) * 1000
                tracker.total_latency_ms += elapsed_ms
                tracker.total_attempts += 1
                # Log full HTTP cycle for debugging
                logger.info(
                    "HTTP PUT %s | Status: %s | Latency: %.2fms | Payload Size: %d bytes",
                    INDEX_URL, response.status_code, elapsed_ms, len(payload.json())
                if response.status_code == 200 or response.status_code == 201:
                    tracker.successful_puts += 1
                    _write_audit_log(audit_log_path, payload.transcript_id, "SUCCESS", elapsed_ms, response.json())
                    _sync_webhook(payload.transcript_id, "indexed")
                    _trigger_rebuild_if_required(payload.recording_id)
                    return response.json()
                    retries += 1
                    delay = base_delay * (2 ** (retries - 1))
                    logger.warning("Received 429 Rate Limit. Retrying in %.2fs", delay)
                    time.sleep(delay)
                if response.status_code in (400, 409):
                    raise ValueError(f"Index rejected payload: {response.text}")
                raise RuntimeError(f"Unexpected status {response.status_code}: {response.text}")
                if e.response.status_code == 429:
                    retries += 1
                    time.sleep(delay)
                tracker.failed_puts += 1
                _write_audit_log(audit_log_path, payload.transcript_id, "FAILED", 0, str(e))
                raise
def _write_audit_log(path: str, transcript_id: str, status: str, latency_ms: float, details: Any):
    """Append structured audit entry for media governance."""
    log_entry = {
        "transcript_id": transcript_id,
        "status": status,
        "latency_ms": latency_ms,
        "details": details if isinstance(details, str) else json.dumps(details)
    with open(path, "a", encoding="utf-8") as f:
        f.write(json.dumps(log_entry) + "\n")
def _sync_webhook(transcript_id: str, event_type: str):
    """Notify external search engines via transcript indexed webhooks."""
    payload = {
        "event": event_type,
        httpx.post(WEBHOOK_URL, json=payload, timeout=5.0)
        logger.error("Webhook sync failed for %s: %s", transcript_id, e)
def _trigger_rebuild_if_required(recording_id: str):
    """Trigger automatic search index rebuild for safe index iteration."""
    # In production, call your search engine's refresh/reindex endpoint
    logger.info("Index rebuild trigger queued for recording: %s", recording_id)
The atomic_put_index function implements exponential backoff for 429 responses, tracks latency across calls, writes structured audit logs for governance, and fires webhooks to synchronize external search clusters. The _trigger_rebuild_if_required placeholder demonstrates where you invoke your search engine’s refresh API to ensure query consistency.
The following script combines authentication, validation, payload construction, and indexing into a single executable module. Replace environment variables with your credentials.
import os
import logging
import sys
load_dotenv()
logging.basicConfig(level=logging.INFO, format="%(asctime)s | %(levelname)s | %(message)s")
def run_transcript_indexer(recording_id: str, transcript_id: str):
    """End-to-end transcript indexing pipeline."""
    client = initialize_genesys_client()
    # Step 1: Fetch and validate
    logger.info("Fetching recording %s and transcript %s", recording_id, transcript_id)
        recording_resp, transcript_resp = fetch_and_validate_transcript(client, recording_id, transcript_id)
    except (ApiException, ValueError) as e:
        logger.error("Validation failed: %s", e)
        sys.exit(1)
    # Step 2: Build payload
    logger.info("Constructing indexing payload with segment matrix and map directive")
        payload = build_indexing_payload(transcript_resp, recording_resp)
        logger.error("Payload construction failed: %s", e)
        sys.exit(1)
    # Step 3: Atomic PUT with retry and tracking
    logger.info("Pushing to external index with latency tracking and audit logging")
        result = atomic_put_index(payload)
        logger.info("Indexing complete. Result: %s", result)
        logger.info(
            "Tracker Stats: Success=%d, Failed=%d, Avg Latency=%.2fms",
            tracker.successful_puts, tracker.failed_puts,
            tracker.total_latency_ms / max(1, tracker.total_attempts)
        logger.error("Indexing pipeline failed: %s", e)
        sys.exit(1)
    if len(sys.argv) < 3:
        print("Usage: python transcript_indexer.py <recording_id> <transcript_id>")
        sys.exit(1)
    run_transcript_indexer(sys.argv[1], sys.argv[2])
Run the script with python transcript_indexer.py <recording_id> <transcript_id>. The module handles token refresh, schema validation, timestamp alignment, stemming, 429 retries, webhook synchronization, and audit logging without external orchestration.
  • Cause: OAuth token expired or client credentials mismatch.
  • Fix: Verify GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET in your environment. The SDK refreshes tokens automatically, but initial handshake failures require credential correction.
  • Code Fix:
if e.status == 401:
    logger.error("Token handshake failed. Invalidate and regenerate client credentials.")
    raise
Error: 403 Forbidden
  • Cause: Missing recording:view or transcript:view scopes on the OAuth client.
  • Fix: Navigate to Genesys Cloud Admin > Security > OAuth > Clients > Scopes. Assign the required scopes and redeploy.
  • Code Fix:
if e.status == 403:
    raise RuntimeError("Scope mismatch. Assign recording:view and transcript:view to the OAuth client.")
  • Cause: Genesys Cloud rate limit cascade or external index throttling.
  • Fix: The atomic_put_index function implements exponential backoff. If failures persist, increase max_retries or implement request queuing with rate limiting at the application level.
  • Code Fix: Already implemented in Step 3 with base_delay * (2 ** (retries - 1)).
Error: Pydantic ValidationError on Map Directive
  • Cause: Payload exceeds MAX_SEARCHABLE_FIELDS limit.
  • Fix: Prune non-essential fields from map_directive before serialization. Index fragmentation occurs when field cardinality exceeds search engine limits.
  • Code Fix:
# Before building payload
pruned_directive = {k: v for k, v in map_directive.items() if k not in ["deprecated_field1", "debug_field2"]}
Error: Timestamp Boundary Misalignment
  • Cause: Segment end_time precedes start_time or exceeds media track duration.
  • Fix: The align_timestamps_and_stem validator clamps boundaries. If misalignment persists, verify transcript generation settings in Genesys Cloud Media settings.
  • Code Fix:
