Indexing Genesys Cloud Interaction Search Result Sets with Python SDK and Cursor Pagination
This tutorial builds a Python service that queries Genesys Cloud interactions, validates results against schema constraints, and streams them into an external Elasticsearch cluster. It uses the Genesys Cloud Python SDK for authentication and httpx for atomic POST operations with cursor-based pagination. The code handles Lucene query parsing, scroll window limits, batch processing, and audit logging.
  • OAuth client type: Confidential client registered in Genesys Cloud Admin
  • Required scopes: interaction:search:view, analytics:conversations:view
  • SDK version: genesyscloud>=2.0.0
  • Runtime: Python 3.9+
  • External dependencies: httpx>=0.24.0, pydantic>=2.0.0, python-dotenv>=1.0.0
Genesys Cloud uses OAuth 2.0 client credentials flow for server-to-server API access. The Python SDK handles token acquisition and automatic refresh. You must cache the token to avoid unnecessary network calls during batch indexing operations.
import os
from genesyscloud import PlatformClientV2
load_dotenv()
class GenesysAuthManager:
    def __init__(self, client_id: str, client_secret: str, base_url: str = "https://api.mypurecloud.com"):
        self.platform_client = PlatformClientV2(
            client_id=client_id,
            client_secret=client_secret,
            base_url=base_url
        self._token_cache = None
        self._cache_expiry = 0
        current_time = time.time()
        if self._token_cache and current_time < self._cache_expiry:
            return self._token_cache
        token_response = self.platform_client.auth.get_access_token()
        self._token_cache = token_response.access_token
        # Cache for 80% of the lifespan to trigger refresh before expiration
        self._cache_expiry = current_time + (token_response.expires_in * 0.8)
The PlatformClientV2 object initializes with your confidential credentials. The get_access_token() method returns a valid bearer token. The cache expiry logic prevents token expiration mid-request. You must pass this token in the Authorization header for all subsequent API calls.
Step 1: Query Construction and Lucene Syntax Validation
Genesys Cloud Interaction Search API accepts a JSON payload with a Lucene-style query filter. You must validate the query structure before submission to prevent 400 Bad Request responses. The validation pipeline checks for required clauses, valid field names, and proper date range syntax.
import re
from typing import Dict, Any
from pydantic import BaseModel, field_validator
class InteractionQuery(BaseModel):
    filter_clause: str
    value: str
    type: str = "clause"
    size: int = 100
    scroll_timeout: int = 300000  # Max allowed by Genesys is 300000 ms
    @field_validator("filter_clause")
    @classmethod
    def validate_lucene_syntax(cls, v: str) -> str:
        # Enforce standard Lucene field:value pattern
        if not re.match(r"^[a-zA-Z_][a-zA-Z0-9_]*\s*[:=]\s*.+$", v):
            raise ValueError("Invalid Lucene filter clause. Use format: field:value")
        return v
    @field_validator("scroll_timeout")
    @classmethod
    def validate_scroll_window(cls, v: int) -> int:
        if v > 300000:
            raise ValueError("Scroll timeout cannot exceed 300000 ms (5 minutes)")
        if v < 10000:
            raise ValueError("Scroll timeout must be at least 10000 ms")
        return v
    def to_genesis_payload(self) -> Dict[str, Any]:
            "query": {
                "filter": {
                    "clause": self.filter_clause,
                    "value": self.value,
                    "type": self.type
            "size": self.size,
            "scrollTimeout": self.scroll_timeout
The InteractionQuery model enforces Lucene syntax via regex validation. It caps the scroll window at 300000 milliseconds, which is the hard limit enforced by Genesys Cloud. Exceeding this limit causes the API to reject the request immediately. The to_genesis_payload() method formats the data exactly as the /api/v2/interactions/search/query endpoint expects.
Step 2: Cursor Pagination and Scroll Window Management
Genesys Cloud uses cursor-based pagination for interaction search. The initial query returns a scrollId. You must POST to /api/v2/interactions/search/scroll/{scrollId} to retrieve subsequent batches. The cursor expires if you do not fetch the next page within the scroll timeout window.
import httpx
import logging
from typing import List, Optional, Tuple
class InteractionPaginator:
    def __init__(self, base_url: str, token: str):
        self.base_url = base_url
        self.token = token
        self.headers = {
            "Accept": "application/json"
    async def execute_query(self, payload: Dict[str, Any]) -> Tuple[Optional[str], List[Dict]]:
        async with httpx.AsyncClient(timeout=30.0) as client:
            response = await client.post(
                f"{self.base_url}/api/v2/interactions/search/query",
                headers=self.headers,
                json=payload
            self._handle_http_error(response)
            data = response.json()
            scroll_id = data.get("scrollId")
            results = data.get("results", [])
            return scroll_id, results
    async def fetch_next_page(self, scroll_id: str) -> Tuple[Optional[str], List[Dict]]:
                f"{self.base_url}/api/v2/interactions/search/scroll/{scroll_id}",
                content=b""  # Empty body required for scroll continuation
            new_scroll_id = data.get("scrollId")
            return new_scroll_id, results
    def _handle_http_error(self, response: httpx.Response) -> None:
            raise httpx.HTTPStatusError("Rate limit exceeded. Implement exponential backoff.", request=response.request, response=response)
        elif response.status_code in (401, 403):
            raise httpx.HTTPStatusError("Authentication or authorization failed.", request=response.request, response=response)
        elif response.status_code >= 500:
            raise httpx.HTTPStatusError("Genesys Cloud server error.", request=response.request, response=response)
        elif response.status_code != 200:
            raise httpx.HTTPStatusError(f"Unexpected status {response.status_code}", request=response.request, response=response)
The InteractionPaginator class handles the initial query and subsequent scroll requests. The fetch_next_page() method sends a POST with an empty body to the scroll endpoint. This is a strict requirement of the Genesys API. The _handle_http_error() method explicitly checks for 429, 401, 403, and 5xx status codes. You must implement retry logic in the calling class to handle transient 429 responses.
Step 3: Index Payload Construction and Atomic POST Processing
You must transform raw Genesys results into a structured indexing payload. The payload contains a query reference, a result matrix, and an index directive. Atomic POST operations ensure data consistency when pushing to your external system.
from datetime import datetime
class IndexPayloadBuilder:
    def __init__(self, query_ref: str, directive: str = "upsert"):
        self.query_ref = query_ref
        self.directive = directive
    def build_payload(self, results: List[Dict[str, Any]]) -> Dict[str, Any]:
        validated_results = self._validate_and_transform(results)
            "queryReference": self.query_ref,
            "resultMatrix": validated_results,
            "indexDirective": self.directive,
            "generatedAt": datetime.utcnow().isoformat(),
            "recordCount": len(validated_results)
    def _validate_and_transform(self, results: List[Dict[str, Any]]) -> List[Dict[str, Any]]:
        validated = []
        for item in results:
            if not self._check_required_fields(item):
            if not self._verify_date_range(item):
            validated.append({
                "id": item.get("id"),
                "type": item.get("type"),
                "timestamp": item.get("timestamp"),
                "metrics": item.get("metrics", {}),
                "participants": item.get("participants", [])
        return validated
    def _check_required_fields(self, item: Dict[str, Any]) -> bool:
        required = {"id", "type", "timestamp"}
        return required.issubset(item.keys())
    def _verify_date_range(self, item: Dict[str, Any]) -> bool:
        ts = item.get("timestamp")
        if not ts:
            return False
            dt = datetime.fromisoformat(ts.replace("Z", "+00:00"))
            # Prevent indexing future events or events older than 5 years
            cutoff = datetime.utcnow()
            if dt > cutoff or dt < cutoff.replace(year=cutoff.year - 5):
                return False
            return True
        except ValueError:
            return False
The IndexPayloadBuilder class enforces schema validation before indexing. The _check_required_fields() method ensures every interaction has an identifier, type, and timestamp. The _verify_date_range() method rejects records with future timestamps or records older than five years. This prevents query timeouts during external cluster scaling. The build_payload() method returns a JSON-ready structure with a query reference, result matrix, and index directive.
Step 4: External Elasticsearch Sync and Webhook Triggering
You synchronize indexing events with an external Elasticsearch cluster by POSTing the constructed payload to a webhook endpoint. The webhook triggers automatic batch processing in your downstream system. You must verify the HTTP response format to confirm successful ingestion.
class ElasticsearchSync:
    def __init__(self, webhook_url: str, api_key: str):
        self.headers = {
            "Authorization": f"ApiKey {api_key}",
    async def push_batch(self, payload: Dict[str, Any]) -> Dict[str, Any]:
        async with httpx.AsyncClient(timeout=45.0) as client:
                self.webhook_url,
                json=payload
            if response.status_code == 200:
                return {"status": "success", "acknowledged": True}
            elif response.status_code == 429:
                raise httpx.HTTPStatusError("Elasticsearch rate limit exceeded.", request=response.request, response=response)
            else:
                raise httpx.HTTPStatusError(f"Webhook ingestion failed with {response.status_code}", request=response.request, response=response)
The ElasticsearchSync class handles the outbound POST to your external cluster. The push_batch() method expects a 200 OK response. If the external system returns a 429, the exception propagates to the main indexer for retry handling. You must configure your Elasticsearch webhook to accept the exact JSON structure produced by IndexPayloadBuilder. The indexDirective field tells the webhook whether to upsert, delete, or archive the batch.
Step 5: Latency Tracking, Audit Logging, and Index Validation Pipeline
You must track indexing latency and scroll success rates to monitor pipeline health. Audit logs provide search governance by recording every query execution, validation result, and sync outcome.
import json
class IndexingMetrics:
    def __init__(self):
        self.total_queries = 0
        self.total_records_indexed = 0
        self.scroll_successes = 0
        self.scroll_failures = 0
        self.latencies = []
        self.audit_log = []
    def record_query_start(self, query_ref: str):
        self.total_queries += 1
        self.audit_log.append({
            "event": "query_start",
            "queryRef": query_ref,
            "timestamp": datetime.utcnow().isoformat()
    def record_scroll_result(self, success: bool):
        if success:
            self.scroll_successes += 1
        else:
            self.scroll_failures += 1
    def record_batch_complete(self, record_count: int, latency_ms: float):
        self.total_records_indexed += record_count
        self.latencies.append(latency_ms)
            "event": "batch_complete",
            "records": record_count,
            "latencyMs": round(latency_ms, 2),
    def get_health_report(self) -> Dict[str, Any]:
        avg_latency = sum(self.latencies) / len(self.latencies) if self.latencies else 0
        success_rate = (self.scroll_successes / (self.scroll_successes + self.scroll_failures) * 100) if (self.scroll_successes + self.scroll_failures) > 0 else 100
            "totalQueries": self.total_queries,
            "totalRecordsIndexed": self.total_records_indexed,
            "scrollSuccessRate": round(success_rate, 2),
            "averageLatencyMs": round(avg_latency, 2)
The IndexingMetrics class maintains runtime state. The record_query_start() method logs the query reference. The record_scroll_result() method tracks pagination health. The record_batch_complete() method captures latency and record counts. The get_health_report() method calculates success rates and average latency. You must expose this data via a health endpoint or write it to a monitoring system.
The following script combines all components into a single GenesysInteractionIndexer class. It handles authentication, pagination, validation, external sync, and metrics. Replace the placeholder credentials and webhook URL before execution.
import asyncio
import logging
import os
import httpx
load_dotenv()
# Import classes defined in previous steps
# from auth import GenesysAuthManager
# from paginator import InteractionPaginator
# from builder import IndexPayloadBuilder
# from sync import ElasticsearchSync
# from metrics import IndexingMetrics
class GenesysInteractionIndexer:
    def __init__(self):
        self.auth = GenesysAuthManager(
            client_id=os.getenv("GENESYS_CLIENT_ID"),
            client_secret=os.getenv("GENESYS_CLIENT_SECRET")
        self.base_url = os.getenv("GENESYS_BASE_URL", "https://api.mypurecloud.com")
        self.metrics = IndexingMetrics()
        self.sync = ElasticsearchSync(
            webhook_url=os.getenv("ES_WEBHOOK_URL"),
            api_key=os.getenv("ES_API_KEY")
        self.max_retries = 3
        self.base_delay = 2.0
    async def run_indexing_pipeline(self, query: InteractionQuery) -> Dict[str, Any]:
        token = self.auth.get_access_token()
        paginator = InteractionPaginator(self.base_url, token)
        builder = IndexPayloadBuilder(query_ref=f"qry_{datetime.utcnow().timestamp()}")
        self.metrics.record_query_start(builder.query_ref)
        payload = query.to_genesis_payload()
        scroll_id, results = await paginator.execute_query(payload)
        if not results:
            return self.metrics.get_health_report()
        while results:
            batch_start = time.time()
            index_payload = builder.build_payload(results)
                await self._retry_with_backoff(self.sync.push_batch, index_payload)
                self.metrics.record_scroll_result(True)
                self.metrics.record_scroll_result(False)
                logging.error(f"Sync failed: {e}")
                break
            latency_ms = (time.time() - batch_start) * 1000
            self.metrics.record_batch_complete(index_payload["recordCount"], latency_ms)
            if not scroll_id:
                break
                scroll_id, results = await paginator.fetch_next_page(scroll_id)
            except httpx.HTTPStatusError:
                logging.error("Scroll pagination failed. Ending pipeline.")
                break
    async def _retry_with_backoff(self, func, *args, **kwargs):
        for attempt in range(self.max_retries):
                return await func(*args, **kwargs)
                if e.response.status_code != 429:
                    raise
                wait_time = self.base_delay * (2 ** attempt)
                logging.warning(f"Rate limited. Retrying in {wait_time}s...")
        raise Exception("Max retries exceeded for external sync")
    search_query = InteractionQuery(
        filter_clause="type",
        value="voice",
        size=100,
        scroll_timeout=300000
    indexer = GenesysInteractionIndexer()
    report = asyncio.run(indexer.run_indexing_pipeline(search_query))
    print(json.dumps(report, indent=2))
The GenesysInteractionIndexer class orchestrates the entire workflow. The run_indexing_pipeline() method initializes authentication, executes the initial query, and loops through cursor pages. The _retry_with_backoff() method handles 429 responses with exponential backoff. The script prints a health report containing total queries, indexed records, scroll success rate, and average latency.
  • Cause: Expired OAuth token, missing interaction:search:view scope, or incorrect client credentials.
  • Fix: Verify your Genesys Cloud OAuth client configuration. Ensure the confidential client has the required scopes assigned. Call auth.get_access_token() immediately before the first API request to guarantee a fresh token.
  • Code Fix: Replace cached token logic with a forced refresh if your application runs longer than the token lifespan.
  • Cause: Genesys Cloud enforces per-client rate limits on the Interaction Search API. Rapid scroll requests trigger throttling.
  • Fix: Implement exponential backoff. The _retry_with_backoff() method in the complete example handles this automatically. Do not parallelize scroll requests for a single query.
  • Code Fix: Increase base_delay in the retry logic if you process large datasets. Add a static delay between scroll fetches using asyncio.sleep(0.5).
Error: Scroll Timeout or Cursor Expired
  • Cause: The time between scroll requests exceeds the scrollTimeout value. Genesys Cloud invalidates the cursor to free server resources.
  • Fix: Reduce batch processing time or increase scroll_timeout up to the 300000 ms limit. Ensure external webhook calls do not block the pagination loop.
  • Code Fix: Offload Elasticsearch sync to an async task queue if webhook latency exceeds 2 seconds.
Error: Schema Validation Failure
  • Cause: Missing required fields (id, type, timestamp) or invalid date formats in the raw Genesys response.
  • Fix: The IndexPayloadBuilder filters out invalid records automatically. Check the audit log to identify which interactions failed validation. Adjust your Lucene query to exclude malformed interaction types.
  • Code Fix: Add explicit logging in _validate_and_transform() to record skipped record IDs for governance tracking.
