Index NICE Cognigy.AI LLM Gateway Token Usage via REST APIs with Python
This script indexes LLM gateway token consumption by submitting structured usage payloads to the Cognigy.AI metering engine. It uses the Cognigy.AI REST API v1 with Python and the requests library. The implementation covers atomic POST operations, quota validation, overage alerting, webhook synchronization, and audit logging.
- OAuth 2.0 Client Credentials grant with scopes
ai:token:read,metering:index:write,quota:manage,webhook:trigger - Cognigy.AI API v1.0 or later
- Python 3.9+
pip install requests pydantic python-dotenv
Cognigy.AI uses a standard OAuth 2.0 Client Credentials flow. The token endpoint issues short-lived access tokens that require caching and automatic refresh. The following code establishes a secure token manager with TTL tracking and 401 recovery.
import os
import requests
from typing import Optional
class CognigyAuthManager:
def __init__(self, client_id: str, client_secret: str, base_url: str):
self.client_id = client_id
self.token_url = f"{base_url}/api/v1/system/oauth/token"
self._expires_at: float = 0.0
def get_token(self) -> str:
if self._token and time.time() < self._expires_at - 30:
return self._token
payload = {
"client_id": self.client_id,
"scope": "ai:token:read metering:index:write quota:manage webhook:trigger"
headers = {"Content-Type": "application/json"}
response = requests.post(self.token_url, json=payload, headers=headers, timeout=10)
response.raise_for_status()
data = response.json()
self._token = data["access_token"]
self._expires_at = time.time() + data["expires_in"]
return self._token
OAuth scope requirement for this endpoint: system:oauth:manage (implicit in client credentials). The token manager caches the credential and refreshes automatically when the TTL approaches expiration.
Step 1: Construct Index Payload and Validate Against Metering Constraints
The metering engine rejects payloads that exceed billing cycle limits or violate model tier quotas. You must validate the index schema before submission. The payload requires a usageReference, quotaMatrix, and tallyDirective. Pydantic enforces structural compliance.
from pydantic import BaseModel, Field, field_validator
from datetime import datetime
from typing import Dict, List
class QuotaMatrix(BaseModel):
model_tier: str = Field(..., pattern="^(standard|premium|enterprise)$")
input_tokens: int = Field(..., ge=0)
output_tokens: int = Field(..., ge=0)
context_window_limit: int = Field(..., ge=1, le=128000)
class TallyDirective(BaseModel):
aggregation_type: str = Field(..., pattern="^(atomic|batch|streaming)$")
billing_cycle_id: str
max_cycle_limit: int = Field(..., ge=1)
overage_alert_enabled: bool = True
class IndexPayload(BaseModel):
usage_reference: str = Field(..., pattern="^[A-Z]{2}-[0-9]{4}-[A-Z0-9]{8}$")
timestamp: str = Field(default_factory=lambda: datetime.utcnow().isoformat() + "Z")
quota_matrix: QuotaMatrix
tally_directive: TallyDirective
rate_limit_compliance: bool = True
@field_validator("quota_matrix")
@classmethod
def validate_metering_constraints(cls, v: QuotaMatrix) -> QuotaMatrix:
if v.model_tier == "standard" and (v.input_tokens + v.output_tokens) > 50000:
raise ValueError("Standard tier exceeds per-request token cap of 50000")
if v.context_window_limit > 128000:
raise ValueError("Context window limit exceeds metering engine maximum")
return v
The schema validation prevents indexing failures caused by invalid tier assignments or context window violations. The usage_reference follows Cognigy.AI gateway routing conventions.
Step 2: Atomic POST Submission with Rate Limit Compliance
The metering engine processes index submissions atomically. You must handle HTTP 429 responses with exponential backoff and verify format compliance on the response payload. The following function executes the POST request with retry logic.
import json
import logging
from requests.adapters import HTTPAdapter
from urllib3.util.retry import Retry
logger = logging.getLogger("cognigy_indexer")
class CognigyMeteringClient:
def __init__(self, base_url: str, auth: CognigyAuthManager):
self.base_url = base_url
self.auth = auth
self.index_endpoint = f"{base_url}/api/v1/ai/token-usage/index"
self.session = requests.Session()
retry_strategy = Retry(
total=3,
backoff_factor=0.5,
status_forcelist=[429, 500, 502, 503, 504],
allowed_methods=["POST"]
adapter = HTTPAdapter(max_retries=retry_strategy)
self.session.mount("https://", adapter)
self.session.mount("http://", adapter)
def submit_index(self, payload: IndexPayload) -> dict:
token = self.auth.get_token()
headers = {
"X-Request-Id": f"idx-{payload.usage_reference}-{int(time.time())}"
request_body = payload.model_dump(mode="json")
logger.info("Submitting index payload: %s", json.dumps(request_body))
response = self.session.post(
self.index_endpoint,
json=request_body,
headers=headers,
timeout=15
self.auth._token = None
return self.submit_index(payload)
retry_after = int(response.headers.get("Retry-After", 2))
logger.warning("Rate limited. Retrying in %d seconds", retry_after)
time.sleep(retry_after)
return response.json()
OAuth scope requirement for this endpoint: metering:index:write. The retry strategy handles transient 429 and 5xx errors. The 401 handler forces token rotation. The X-Request-Id header enables traceability in Cognigy.AI gateway logs.
Step 3: Quota Validation Pipeline and Overage Alert Triggering
Before indexing, you must verify that the submission does not breach the billing cycle limit. The quota validation endpoint returns the current cycle consumption and remaining capacity. The indexer blocks submission when the limit is reached and triggers an overage alert.
class QuotaValidator:
self.auth = auth
self.quota_endpoint = f"{base_url}/api/v1/ai/quotas/validate"
def check_and_alert(self, payload: IndexPayload) -> bool:
headers = {
validation_request = {
"billing_cycle_id": payload.tally_directive.billing_cycle_id,
"model_tier": payload.quota_matrix.model_tier,
"projected_tokens": payload.quota_matrix.input_tokens + payload.quota_matrix.output_tokens
self.quota_endpoint,
json=validation_request,
headers=headers,
timeout=10
quota_status = response.json()
remaining = quota_status.get("remaining_cycle_tokens", 0)
projected = validation_request["projected_tokens"]
if projected > remaining:
logger.error("Budget overrun detected. Projected %d exceeds remaining %d", projected, remaining)
self._trigger_overage_alert(payload, remaining)
return False
return True
def _trigger_overage_alert(self, payload: IndexPayload, remaining: int) -> None:
alert_payload = {
"alert_type": "QUOTA_OVERAGE",
"usage_reference": payload.usage_reference,
"remaining_tokens": remaining,
"timestamp": datetime.utcnow().isoformat() + "Z"
webhook_url = os.getenv("COGNIGY_OVERAGE_WEBHOOK_URL")
if webhook_url:
requests.post(webhook_url, json=alert_payload, timeout=5)
logger.info("Overage alert dispatched to FinOps dashboard")
OAuth scope requirement for quota validation: quota:manage. The validator compares projected consumption against the metering engine’s remaining cycle allowance. When the limit is breached, the system blocks indexing and posts an alert to the configured webhook URL.
Step 4: Webhook Synchronization, Latency Tracking, and Audit Logging
Production indexers must synchronize with external FinOps dashboards, track submission latency, and maintain audit trails. The following class wraps the submission pipeline with telemetry and audit generation.
class QuotaIndexer:
self.client = CognigyMeteringClient(base_url, auth)
self.validator = QuotaValidator(base_url, auth)
self.success_count = 0
self.failure_count = 0
self.total_latency_ms = 0.0
self.audit_log: List[dict] = []
def index(self, payload: IndexPayload) -> dict:
if not self.validator.check_and_alert(payload):
self.failure_count += 1
raise RuntimeError("Indexing blocked due to quota validation failure")
result = self.client.submit_index(payload)
self.total_latency_ms += latency_ms
self.success_count += 1
audit_entry = {
"event": "INDEX_SUBMITTED",
"status": "SUCCESS",
"tokens_indexed": payload.quota_matrix.input_tokens + payload.quota_matrix.output_tokens,
"timestamp": datetime.utcnow().isoformat() + "Z",
"response_id": result.get("indexId", "unknown")
self.audit_log.append(audit_entry)
self._sync_finops_dashboard(audit_entry)
return result
def _sync_finops_dashboard(self, audit_entry: dict) -> None:
webhook_url = os.getenv("COGNIGY_FINOPS_WEBHOOK_URL")
if not webhook_url:
return
sync_payload = {
"source": "cognigy_ai_metering",
"type": "usage_index_sync",
"data": audit_entry
requests.post(webhook_url, json=sync_payload, timeout=5)
except requests.RequestException as e:
logger.warning("FinOps webhook sync failed: %s", e)
def get_metrics(self) -> dict:
success_rate = (self.success_count / total * 100) if total > 0 else 0.0
avg_latency = (self.total_latency_ms / self.success_count) if self.success_count > 0 else 0.0
"total_submissions": total,
"success_rate_percent": round(success_rate, 2),
"average_latency_ms": round(avg_latency, 2),
"audit_log_size": len(self.audit_log)
The QuotaIndexer class exposes a single index() method that handles validation, submission, latency measurement, success tracking, audit logging, and webhook synchronization. OAuth scope requirement for webhook triggers: webhook:trigger. The telemetry pipeline enables cost predictability and financial governance compliance.
The following script combines all components into a runnable module. Replace the environment variables with your Cognigy.AI tenant credentials.
import os
import logging
import requests
return self._token
payload = {
return self._token
@classmethod
return v
self.auth = auth
total=3,
backoff_factor=0.5,
headers = {
logger.info("Submitting index payload: %s", str(request_body))
json=request_body,
headers=headers,
timeout=15
self.auth = auth
headers = {
headers=headers,
timeout=10
return False
return True
alert_payload = {
if webhook_url:
class QuotaIndexer:
audit_entry = {
return result
if not webhook_url:
return
sync_payload = {
"data": audit_entry
BASE_URL = os.getenv("COGNIGY_BASE_URL", "https://api.cognigy.ai")
CLIENT_ID = os.getenv("COGNIGY_CLIENT_ID")
CLIENT_SECRET = os.getenv("COGNIGY_CLIENT_SECRET")
if not CLIENT_ID or not CLIENT_SECRET:
raise ValueError("COGNIGY_CLIENT_ID and COGNIGY_CLIENT_SECRET must be set")
auth = CognigyAuthManager(CLIENT_ID, CLIENT_SECRET, BASE_URL)
indexer = QuotaIndexer(BASE_URL, auth)
sample_payload = IndexPayload(
usage_reference="US-2024-AB12CD34",
quota_matrix=QuotaMatrix(
model_tier="premium",
input_tokens=1200,
output_tokens=3400,
context_window_limit=8192
tally_directive=TallyDirective(
aggregation_type="atomic",
billing_cycle_id="CYC-2024-Q4-001",
max_cycle_limit=500000,
overage_alert_enabled=True
result = indexer.index(sample_payload)
print("Index submission successful:", result)
print("Metrics:", indexer.get_metrics())
logger.error("Indexing pipeline failed: %s", e)
Error: HTTP 400 Bad Request
- Cause: The index payload violates metering engine constraints. Common triggers include invalid
model_tiervalues,context_window_limitexceeding 128000, or malformedusage_referencepatterns. - Fix: Verify the Pydantic validation output before submission. Ensure the
usage_referencematches the regex^[A-Z]{2}-[0-9]{4}-[A-Z0-9]{8}$. Adjustcontext_window_limitto stay within the 128000 maximum. - Code showing the fix: The
validate_metering_constraintsmethod inIndexPayloadcatches these violations and raises a descriptiveValueErrorbefore the HTTP call executes.
Error: HTTP 403 Forbidden
- Cause: The OAuth token lacks the required scopes for the targeted endpoint. The metering index endpoint requires
metering:index:write. The quota validation endpoint requiresquota:manage. - Fix: Update the
scopeparameter in the token request payload. Regenerate the token and retry the operation. - Code showing the fix: The
CognigyAuthManager.get_token()method requests the combined scope stringai:token:read metering:index:write quota:manage webhook:trigger. If your tenant restricts scope granularity, split the request into separate client credentials flows.
- Cause: The indexer exceeds the Cognigy.AI gateway rate limit. Token indexing endpoints typically enforce 50 requests per minute per tenant.
- Fix: The
CognigyMeteringClientapplies aRetrystrategy with exponential backoff. The code reads theRetry-Afterheader and sleeps accordingly. If the limit persists, reduce the batch frequency or implement a token bucket algorithm locally. - Code showing the fix: The
urllib3.util.retry.Retryconfiguration inCognigyMeteringClient.__init__handles automatic 429 recovery. The manual 429 block insubmit_indexprovides fallback handling when the adapter exhausts retries.
Error: HTTP 409 Conflict
- Cause: The billing cycle limit is exhausted. The
quotaMatrixprojection exceedsremaining_cycle_tokensreturned by the validation endpoint. - Fix: The
QuotaValidatorblocks submission and triggers an overage alert. Rotate thebilling_cycle_idto the next cycle or request a quota increase from your NICE CXone account manager. - Code showing the fix: The
check_and_alertmethod comparesprojected_tokensagainstremaining. Whenprojected > remaining, the method returnsFalseand dispatches the webhook alert.
