Implementing Zoom Contact Center Post-Call Surveys with Conditional Question Logic Based on Sentiment Analysis
This guide details the architectural implementation of a dynamic post-call survey system within Zoom Contact Center. You will build a workflow that analyzes the sentiment of an agent-customer interaction and triggers specific survey paths (e.g., a “Recovery Survey” for negative sentiment versus a “Promoter Survey” for positive sentiment) to optimize customer feedback loops.
- Licensing: Zoom Contact Center Professional or Enterprise tier.
- Permissions:
Contact Center Adminrole.Survey Adminpermissions for form creation.API Integrationpermissions for webhook and middleware configuration.
- External Dependencies:
- A middleware layer (e.g., AWS Lambda, Node.js, or Python) to process Zoom Webhooks and execute conditional logic.
- Access to the Zoom App Marketplace to create a Server-to-Server OAuth app.
- OAuth Scopes:
contact_center:read:admincontact_center:write:adminrecording:read:admin(required to access transcripts for sentiment analysis).
1. Designing the Sentiment-Aware Survey Matrix
Before configuring the platform, you must define the mapping between sentiment scores and survey IDs. Zoom surveys are static forms; therefore, “conditional logic” is achieved not by changing questions within a single form, but by routing the customer to different survey URLs based on the interaction outcome.
Architectural Reasoning:
We use a multi-survey approach rather than a single complex form because it allows for cleaner reporting. A “Negative Sentiment” survey should focus on root-cause analysis and friction points, while a “Positive Sentiment” survey should focus on Net Promoter Score (NPS) and testimonials. Mixing these in one form increases survey fatigue and drops completion rates.
The Trap:
The most common mistake is attempting to trigger the survey during the call. If you trigger the survey before the call disconnects, the sentiment analysis engine has not yet processed the full transcript. You must trigger the survey via a Post-Call Webhook to ensure the sentiment score is finalized.
2. Configuring the Sentiment Analysis Pipeline
Zoom Contact Center provides automated sentiment analysis via its AI capabilities. You must ensure that “Conversation Summary” and “Sentiment Analysis” are enabled in the Admin Portal.
Technical Workflow:
- Navigate to Contact Center Admin > Settings > AI & Analytics.
- Enable Sentiment Analysis for all queues involved in the pilot.
- Configure the Post-Call Webhook to listen for the
contact_center.interaction.completedevent.
Middleware Logic:
When the interaction completes, your middleware receives a payload containing the interaction_id. The middleware must then:
- Call the Zoom API to retrieve the interaction’s sentiment score (Positive, Neutral, or Negative).
- Evaluate the score against your matrix.
- Select the corresponding
survey_id.
3. Implementing the Conditional Trigger via API
Since Zoom does not natively “branch” surveys based on AI sentiment within the UI, you must use the API to send the survey invitation.
Execution Flow:
Once the middleware determines the sentiment is “Negative,” it triggers the survey invitation. While the provided restricted API set focuses on identity and quality evaluations, the actual survey delivery in Zoom is handled through the Survey Management API.
JSON Payload Example for Survey Dispatch:
(Note: This represents the logic your middleware sends to the Zoom Survey endpoint)
"interaction_id": "int_123456789",
"customer_phone": "+15550109999",
"survey_id": "survey_neg_001",
"delivery_method": "SMS",
"custom_fields": {
"sentiment_score": "Negative",
"interaction_type": "Voice"
The Trap:
Failure to implement a “Cooldown Period.” If a customer calls three times in one hour and has a negative experience each time, sending three negative surveys is perceived as harassment. Your middleware must check for the existence of a recent survey sent to that customer_phone within a 24-hour window before executing the POST request.
4. Closing the Loop with Quality Management
Once the customer completes the survey, the data must be linked back to the agent’s performance record. This is where the Quality Management (QM) integration occurs.
Integration Logic:
When a survey is submitted, your system should automatically create a “Quality Evaluation” flag if the sentiment was negative and the survey score was low. This ensures the supervisor is alerted immediately.
API Interaction for Evaluation Search:
To audit how many negative sentiment calls resulted in negative surveys, use the following endpoint to search for evaluations associated with those specific interactions:
HTTP Method: POST
Endpoint: /api/v2/quality/evaluations/search
Request Body:
"page": 1,
"pageSize": 50,
"sort": [
"field": "createdDate",
"direction": "DESC"
"filter": {
"interactionId": "int_123456789"
By linking the interaction_id from the sentiment analysis to the evaluation_id in the QM module, you create a “Golden Record.” You can now prove that a “Negative” AI sentiment score correlates with a low CSAT score, which validates your AI model’s accuracy.
Edge Case 1: The “Mixed Sentiment” Interaction
The Failure Condition: A call starts with high frustration (Negative) but ends with a successful resolution and a happy customer (Positive).
The Root Cause: Simple sentiment analysis often averages the score across the call or only looks at the final 30 seconds.
The Solution: Implement “Sentiment Trend” logic in your middleware. If the sentiment moves from Negative $\rightarrow$ Positive, trigger the “Positive” survey but include a specific question about the resolution process. If it remains Negative, trigger the “Recovery” survey.
Edge Case 2: Asynchronous Webhook Latency
The Failure Condition: The survey invitation arrives 10 minutes after the call ends, making the customer less likely to respond.
The Root Cause: High volume of interactions causing a bottleneck in the middleware processing queue.
The Solution: Implement a message queue (e.g., RabbitMQ or AWS SQS) between the Zoom Webhook and the sentiment processing logic. This ensures that the interaction.completed event is captured immediately and processed in a non-blocking fashion.
Edge Case 3: Opt-Out/TCPA Compliance
The Failure Condition: Sending an SMS survey to a customer who has opted out of marketing communications.
The Root Cause: The survey trigger logic does not check the customer’s communication preferences stored in the CRM.
The Solution: The middleware must perform a GET request to the CRM (e.g., Salesforce or Zendesk) to verify the SMS_Opt_In flag is True before calling the Zoom Survey API.
