Implementing Zoom Contact Center Interaction Logging with Detailed Call Detail Records (CDRs) Exported to Splunk for Advanced Analytics
This guide details the architectural implementation of a high-fidelity logging pipeline that extracts Call Detail Records (CDRs) and interaction data from Zoom Contact Center (ZCC) and ingests them into Splunk. The end result is a real-time analytics dashboard in Splunk providing granular visibility into interaction durations, agent performance, and customer journey mapping.
- Zoom Licensing: Zoom Contact Center (ZCC) license with the Advanced Analytics add-on.
- Permissions:
- Zoom Admin role with
Contact Centermanagement privileges. App Marketplacepermissions to create and manage Server-to-Server OAuth applications.
- OAuth Scopes:
contact_center:read:adminrecording:read:admin(if exporting recording metadata)report:read:admin
- Infrastructure:
- A Splunk instance with the HTTP Event Collector (HEC) enabled.
- A middleware layer (e.g., AWS Lambda, Azure Functions, or a dedicated Python service) to act as the polling engine and data transformer.
1. Designing the Data Extraction Strategy
Zoom Contact Center does not push CDRs via a real-time webhook for every single interaction event. Instead, the architecture must rely on a polling mechanism utilizing the Analytics API to retrieve conversation details. Because interaction data can be voluminous, you must implement an asynchronous job pattern to avoid API rate limiting and timeout failures.
To extract the detailed interaction logs, you must use the conversation details query endpoints. For small batches, a synchronous query is sufficient, but for enterprise-scale CDR exports to Splunk, the asynchronous job pattern is mandatory.
The Technical Flow:
- The middleware service authenticates via Server-to-Server OAuth.
- The service initiates a job via
POST /api/v2/analytics/conversations/details/jobs. - The service polls
GET /api/v2/analytics/conversations/details/jobs/{jobId}until the status isCOMPLETED. - The service fetches the resulting conversation records, transforms the JSON into a Splunk-compatible flattened format, and pushes it to the HEC.
The Trap: A common failure is attempting to use POST /api/v2/analytics/conversations/details/query for bulk daily exports. This endpoint is designed for targeted lookups. When used for bulk exports, it frequently returns a 429 Too Many Requests or a 504 Gateway Timeout because the server cannot aggregate thousands of conversation segments in a single synchronous request. Always use the /jobs endpoint for CDR pipelines.
2. Implementing the Asynchronous Extraction Pipeline
The middleware must be programmed to handle the lifecycle of an analytics job. Below is the production-ready logic for initiating and retrieving these records.
Step A: Initiate the Job
The request must specify the time interval. Ensure you use ISO 8601 format.
HTTP Method: POST
Endpoint: /api/v2/analytics/conversations/details/jobs
Request Body:
"interval": {
"startTime": "2023-10-27T00:00:00.000Z",
"endTime": "2023-10-27T23:59:59.999Z"
"order": "desc",
"pageSize": 100
Step B: Monitor Job Status
The middleware must implement a back-off timer (e.g., check every 30 seconds) to verify completion.
HTTP Method: GET
Endpoint: /api/v2/analytics/conversations/details/jobs/{jobId}
Step C: Data Transformation for Splunk
Zoom returns nested JSON arrays containing segments (e.g., IVR, Queue, Agent). Splunk performs best with flattened events. You must iterate through the conversations array and create a separate event for each segment while maintaining the conversationId as the primary key for correlation.
Example Transformation Logic:
- Original:
conversation -> segments -> [segment1, segment2] - Transformed:
- Event 1:
{ "convId": "123", "segmentType": "IVR", "duration": "15s", "timestamp": "..." } - Event 2:
{ "convId": "123", "segmentType": "Agent", "duration": "300s", "timestamp": "..." }
- Event 1:
3. Splunk Ingestion via HTTP Event Collector (HEC)
Once the data is flattened, it is pushed to Splunk using the HEC. This is superior to file-based uploads because it allows for real-time indexing and immediate alerting.
HTTP Method: POST
Endpoint: https://<splunk-hec-url>:8088/services/collector/event
Header: Authorization: Splunk <HEC_TOKEN>
Request Body:
"event": {
"interaction_id": "conv_98765",
"agent_id": "agent_4432",
"queue_name": "Sales_Tier1",
"wait_time": 45,
"handle_time": 320,
"disposition": "Resolved",
"customer_phone": "+15550102030"
"sourcetype": "zoom:contactcenter:cdr",
"index": "zoom_analytics"
The Trap: Failing to implement a “checkpoint” or “watermark” in your middleware. If the middleware crashes, it may lose track of where it stopped polling. You must store the endTime of the last successful export in a persistent database (like DynamoDB or Redis). Upon restart, the middleware reads this watermark and resumes from that exact millisecond to prevent data gaps or duplicate records in Splunk.
Edge Case 1: The “Ghost Call” (Missing Segments)
The Failure Condition: Splunk shows a conversation started but never ended, or segments are missing from the CDR.
The Root Cause: This occurs when the analytics job is triggered too close to the actual end of the call. There is a propagation delay between the telephony layer and the Analytics API.
The Solution: Implement a “Look-back Window.” Do not poll for data from the current hour. Instead, poll for data from $T-2$ hours ago. This ensures that all late-arriving segments have been indexed by the Zoom platform before the extraction job runs.
Edge Case 2: OAuth Token Expiration during Large Job Downloads
The Failure Condition: The middleware receives a 401 Unauthorized midway through processing a large job result set.
The Root Cause: The Server-to-Server OAuth token expired while the middleware was waiting for a long-running async job to complete or while iterating through multiple pages of results.
The Solution: Implement a wrapper function for all API calls that checks the token expiration timestamp. If the token expires in less than 60 seconds, trigger the refresh flow before executing the next GET request to /api/v2/analytics/conversations/details/jobs/{jobId}.
Edge Case 3: API Rate Limiting (429s)
The Failure Condition: The middleware is throttled by Zoom.
The Root Cause: Too many concurrent requests to the /jobs status endpoint.
The Solution: Implement Exponential Back-off. If a 429 is received, the middleware must read the Retry-After header and pause execution. Do not use a fixed timer; use a jittered exponential back-off to avoid “thundering herd” problems.
