Implementing Whisper Prompts and Forced Disposition Codes via Architect Scripts
Executive Summary & Architectural Context
The moment an agent answers a call is the highest-stress point in the interaction. Without context, the agent must spend the first 30 seconds asking redundant questions (“Who are you calling for today?”), which degrades the customer experience and increases Average Handle Time (AHT). Conversely, the moment a call ends is the most critical point for data integrity. If an agent is not forced to provide a disposition code, the downstream reporting becomes a “Black Box,” making it impossible to measure ROI or identify systemic issues.
A Principal Architect solves both ends of this interaction lifecycle using Whisper Prompts and Forced Dispositions. By leveraging Architect Scripts, we can inject real-time context into the agent’s ear before they speak (Whisper) and enforce a strict wrap-up workflow that ensures every call is categorized with 100% accuracy.
This masterclass details the engineering required to build a high-performance agent handoff and wrap-up engine in Genesys Cloud and NICE CXone.
Licensing & Permissions
  • Licensing Tier: Genesys Cloud CX 1, 2, or 3.
  • Granular Permissions:
    • Architect > Flow > Edit
    • Architect > Script > View, Edit, Publish
    • Conversation > Call > Edit (for disposition updates)
  • Dependencies: Agent Scripts must be associated with the ACD queues.
1. The Handoff: Architecting the Whisper Prompt
A “Whisper” is a brief audio snippet played only to the agent immediately after they click “Answer,” but before the customer is connected.
Step 1: Dynamic Whisper Logic
Do not use a static “Incoming call” whisper. A Principal Architect uses Contextual Whispers.
  • The Strategy: Based on the IVR path, set a variable Flow.WhisperPrompt.
  • Example: If the customer successfully verified their account in the IVR, the whisper should say: “Verified Customer: Acme Corp, Platinum Tier.”
Step 2: Implementation in Architect
  1. Use the Set Whisper Audio action block.
  2. The Expression:
    If(Flow.IsVerified, prompt.whisper_verified, prompt.whisper_unverified)
  3. Place this action immediately before the Transfer to ACD block.
[!IMPORTANT]
Architectural Reasoning: The “Whisper” is technically a media-tier function. It prevents the “Hello… hello?” gap often seen in legacy systems by ensuring the agent is fully briefed before the RTP (Real-Time Protocol) bridge is established between the agent and the caller.
2. The Wrap-Up: Enforcing Forced Disposition Codes
Reporting is only as good as the data entered by the agent. “Forced” dispositions ensure that an agent cannot move to the next call until they have categorized the current one.
Step 1: The Script-Level Enforcement
In the Genesys Cloud Script Designer:
  1. Create a Dropdown component containing your disposition categories (e.g., “Resolved,” “Escalated,” “Billing Inquiry”).
  2. Bind this dropdown to the Wrap-Up Code variable.
  3. The “Strict” Logic: Disable the “Complete Wrap-Up” button until the dropdown has a non-null value.
Step 2: Architect-Side Configuration
In the Queue Configuration, set the Wrap-Up mode to Mandatory.
  • The Trap: If you set a wrap-up timeout (e.g., 30 seconds) and the agent doesn’t choose a code, the system will often default to a generic “Timeout” code. A Principal Architect sets the timeout to Infinite for high-compliance queues, forcing a manual selection.
3. Advanced: Dynamic Disposition Filtering
If an agent is in a “Support” queue, they shouldn’t see “Sales” disposition codes.
Implementation Pattern:
  1. Store your disposition codes in an Architect Data Table mapped to QueueID.
  2. When the call lands on the agent’s desk, the Script performs a Data Action lookup: GetCodesForQueue(Task.QueueID).
  3. The Script’s dropdown is then filtered dynamically, showing only the 5 codes relevant to that specific department.
This reduces cognitive load for the agent and eliminates the “Fat Finger” error of choosing a code from the wrong department.
“The Trap”: The Double-Whisper Overlap
The Scenario: You have a “Queue Whisper” (set on the Queue object) and a “Flow Whisper” (set in the Architect flow).
The Catastrophe: The agent answers and hears two audio clips playing simultaneously or sequentially, creating a 5-second delay where the customer is sitting in silence. This “Whisper Bloat” is a major driver of customer abandonment in the first 10 seconds of a call.
The Principal Architect’s Solution: The “Whisper Priority” Rule
Always prioritize the Flow Whisper.
  1. Set the Queue-level whisper to a generic “Beep.”
  2. Use Architect to provide the Variable Data.
  3. If the data is missing, the agent at least gets the “Beep” notification that a call is connected.
Integration: AI-Suggested Dispositions
For ultra-high-volume centers, manual selection is still a bottleneck. A Principal Architect integrates Sentiment and Speech Analytics to suggest the code.
The AI Pipeline:
  1. Real-Time Transcription: Genesys Cloud Speech Analytics listens to the call.
  2. Topic Detection: The system detects keywords like “Refund,” “Cancellation,” or “Technical Error.”
  3. Script Suggestion: The Agent Script highlights the “Refund” disposition code in Green and displays a prompt: “Based on the conversation, this appears to be a Refund request. Confirm?”
  4. Validation: The agent simply clicks “Confirm,” reducing wrap-up time (ACW) from 15 seconds to 2 seconds.
Edge Case 1: Multi-Lingual Agents
The failure condition: A French-speaking agent answers a call from the English IVR and hears an English whisper.
The root cause: Whisper logic is often tied to the caller’s language, not the agent’s.
The solution: Use the User Language attribute of the agent who accepted the call. Use a Data Action to lookup the agent’s preferred language and play the whisper in their native tongue, ensuring they understand the context instantly.
Edge Case 2: The “Short Call” Bypass
The failure condition: A caller hangs up after 2 seconds (Wrong Number). The agent is still forced to choose a disposition code.
The root cause: Global enforcement doesn’t distinguish call duration.
The solution: In the Script, implement a Duration Check. If Conversation.Duration < 5 seconds, the Script automatically applies the “Short Call / Abandoned” code and completes the wrap-up without agent intervention.
Reporting & Performance Metrics
Whisper and Disposition architecture directly impacts Operation Efficiency.
Metrics to Monitor:
  • Initial AHT Segment: Has the “Discovery Phase” of the call decreased since implementing Whispers?
  • Disposition Accuracy: Audit the “Topic Detected” by AI vs. the “Code Selected” by the Agent.
  • ACW (After-Call Work) Trends: Is ACW increasing? This might indicate that your disposition dropdown has too many options (Cognitive Load).
Target ROI: You should expect a 10-15% reduction in total AHT through better agent preparation and a 99%+ reporting accuracy through forced wrap-up enforcement.
