Implementing Warm Standby IVR Systems with Automatic Activation on Primary Health Failure
Configure a warm standby IVR topology that automatically routes voice and digital traffic to a secondary Genesys Cloud CX instance when primary health checks fail. The end result is a fully automated failover architecture with sub-ten-second SIP trunk redirection, synchronized IVR state handling, and DNS-based digital channel failover.
- Licensing Tier: Genesys Cloud CX 3 or CX 4 for both primary and standby instances. WEM or Speech Analytics licenses are optional but must be provisioned on the standby instance if you plan to route post-failover interactions to those services.
- Granular Permissions:
Telephony > Trunk > EditTelephony > Routing > EditArchitect > Flow > EditAdministration > API > OAuth ClientAdministration > User > Edit(for service account provisioning)
- OAuth Scopes:
telephony:trunk:read,telephony:health:read,architect:flow:read,admin:api:read - External Dependencies:
- Enterprise SBCs (Cisco, Audiocodes, or Genesys CX Platform) with SIP failover routing capability
- DNS provider supporting active health checks and weighted routing (AWS Route 53, Cloudflare, or Azure DNS)
- External automation orchestrator (Terraform, Ansible, or custom Python/Node script) for API-driven failover execution
- Both instances must share identical DIDs, SIP trunk credentials, and Architect flow topology
1. Health Monitoring & Failover Trigger Architecture
A warm standby system requires deterministic health evaluation before traffic redirection. Genesys Cloud CX does not expose a single “instance down” boolean. You must construct a composite health score from telephony routing status, API latency, and media server availability.
Deploy a polling service that executes the following sequence every fifteen seconds:
- Query the Telephony Routing Health API
- Measure API endpoint latency against a baseline
- Validate SIP trunk registration status
- Evaluate composite score against a failure threshold
Production-Ready Health Check Payload
GET https://{primary-subdomain}.mypurecloud.com/api/v2/telephony/routes/health
Authorization: Bearer {access_token}
Accept: application/json
The response returns an array of routing health objects. You must parse the status and detailedStatus fields for your primary routing profile. A healthy system returns status: "healthy" with detailedStatus containing zero degraded components.
The Trap: Polling only the UI-facing routing health endpoint. The Telephony Routing Health API reflects configuration state, not media plane availability. When media servers experience packet loss or codec negotiation failures, the routing API often remains green while callers hear silence or one-way audio. You must supplement this with a synthetic SIP INVITE test against your primary SBC or a dedicated health-check DID that returns a specific SIP 200 OK with a custom P-Asserted-Identity header. Parse that header to confirm media path viability.
Architectural Reasoning: Composite health scoring prevents false-positive failovers during scheduled maintenance or transient carrier blips. By requiring three consecutive failed checks before triggering failover, you avoid flapping. The automation orchestrator receives the failure event and executes the DNS and SBC routing updates. You must design the orchestrator to be idempotent. Network partitions can cause duplicate trigger events.
2. SIP Trunk & Telephony Routing Configuration
Telephony failover requires coordinated changes across your SBC, Genesys Cloud CX trunk configuration, and DNS SRV records. The primary instance holds all active SIP trunk registrations. The standby instance maintains identical trunk definitions but remains in a passive state.
Configure your primary Genesys Cloud CX instance with the following trunk settings:
- SIP Trunk Name:
PROD-PRIMARY-TRUNK - Host: Primary SBC IP or FQDN
- Transport: TLS 1.3
- Failover Trunk:
PROD-STANDBY-TRUNK(configured on the same instance as a secondary leg) - Health Check Interval:
10seconds - Failover Threshold:
3consecutive failures
On the standby instance, mirror the trunk configuration exactly. The critical difference lies in the SBC routing policy. Your SBC must maintain two SIP profiles: one pointing to the primary Genesys Cloud CX SIP URI and one pointing to the standby. The SBC handles the actual INVITE redirection. Genesys Cloud CX trunk failover settings act as a secondary safety net.
SBC Routing Policy Configuration (Generic SIP Proxy Syntax)
SIP-Proxy-Profile PRIMARY-GENESYS
Destination-URI sip:primary-subdomain.mypurecloud.com:5061
Health-Check-Method OPTIONS
Health-Check-Interval 15
Failover-Profile STANDBY-GENESYS
SIP-Proxy-Profile STANDBY-GENESYS
Destination-URI sip:standby-subdomain.mypurecloud.com:5061
The Trap: Configuring Genesys Cloud CX trunk failover without SBC-level routing policies. Genesys Cloud CX evaluates trunk health based on SIP OPTIONS responses and registration keep-alives. If your carrier or SBC drops the connection during a failover event, the Genesys trunk health check will timeout, but the SBC will still forward INVITEs to the primary instance. This creates a split-brain routing scenario where half your traffic routes to the standby instance and half routes to a degraded primary instance. You must enforce a single source of truth for routing decisions. The SBC must own the primary routing decision. Genesys Cloud CX trunk settings serve only as a fallback when the SBC policy fails.
Architectural Reasoning: SBC-level failover provides sub-ten-second redirection because the SBC maintains persistent SIP dialogs and can immediately reroute new INVITEs without waiting for DNS TTL expiration or Genesys API polling cycles. You must configure your SBC to suppress re-INVITEs during failover transitions to prevent mid-call media renegotiation. Genesys Cloud CX handles mid-call failover gracefully only if the call leg remains established. Forcing a re-INVITE during a health failure tears down the media path and forces the caller back into the IVR menu, degrading the experience and increasing abandonment rates.
3. Architect Flow Design with Fallback Logic
Your IVR flow must detect failover context and adjust routing behavior accordingly. The primary flow handles standard business logic. The standby flow must preserve caller state, skip non-essential steps, and route directly to agent queues or message queues.
Create two versions of your main IVR flow:
MAIN-IVR-PROD(Primary)MAIN-IVR-STANDBY(Standby)
Both flows share identical variable definitions. The standby flow uses a conditional branch at the entry point to evaluate the failover_active system variable. You populate this variable via an API integration or SBC header injection.
Architect Flow Entry Logic
IF {system.failover_active} == "true" THEN
SET {routing_mode} = "standby"
SKIP steps: greetings, marketing, survey_opt_in
ROUTE to: {queue.high_priority}
ELSE
EXECUTE standard_business_logic
Configure your SBC to inject a custom SIP header during failover:
P-Genesys-Context: failover_active=true
Map this header to a flow variable using Genesys Cloud CX Architect’s SIP header mapping feature. Navigate to Administration > Telephony > Routing > SIP Header Mapping and create a mapping rule that extracts P-Genesys-Context and assigns it to {system.failover_active}.
The Trap: Using identical flow names across both instances without version control. When you deploy updates to the primary instance, you must replicate those updates to the standby instance before the next failover event. If the standby instance runs an outdated flow version, callers will encounter broken routing logic, missing integrations, or deprecated queue references during a failover. You must implement a deployment pipeline that treats the standby instance as a production environment. Use Genesys Cloud CX’s Flow Versioning API to export, validate, and import flow definitions synchronously.
Architectural Reasoning: Standby flows must be lean. Every additional API call, queue lookup, or integration step increases latency during a failover event. When the primary instance fails, your standby instance will experience a sudden traffic spike. Reducing flow complexity minimizes CPU utilization on the standby instance and prevents secondary failures. You must also configure queue failover routing. If your primary queues become unreachable, your standby flow must route to backup queues or message queues to preserve caller data. Cross-reference the Queue Failover and Message Routing guide for implementation details on queue synchronization.
4. DNS & Digital Channel Failover
Voice failover handles SIP traffic. Digital channels (Webchat, SMS, Email, WhatsApp) rely on DNS routing and WebSocket endpoints. You must configure your DNS provider to monitor the primary Genesys Cloud CX digital endpoints and automatically shift traffic to the standby instance.
Configure your DNS provider with the following record structure:
chat.primary-domain.com. 300 IN CNAME primary-subdomain.mypurecloud.com.
chat.primary-domain.com. 300 IN CNAME standby-subdomain.mypurecloud.com.
Set the primary record weight to 100 and the standby record weight to 0. Configure a health check against the primary WebSocket endpoint:
GET https://primary-subdomain.mypurecloud.com/api/v2/telephony/routes/health
Expected HTTP Status: 200
Expected Body Contains: "status": "healthy"
When the health check fails for three consecutive intervals, your DNS provider automatically shifts weight to the standby record. The TTL must be set to 30 seconds or lower to minimize propagation delay during failover.
The Trap: Configuring DNS failover without WebSocket session persistence. Digital channels maintain persistent WebSocket connections. When DNS shifts to the standby instance, existing WebSocket sessions will attempt to reconnect to the new endpoint. If your standby instance does not share the same session storage or message queue configuration, callers will lose their conversation history and be routed to a new agent. You must configure Genesys Cloud CX’s Message Queue to support cross-instance session recovery or implement a shared external session store (Redis or DynamoDB) that both instances can query.
Architectural Reasoning: DNS-based failover provides a standardized mechanism for digital channel redirection without requiring application-level routing changes. By keeping the TTL low, you accept slightly higher DNS query load during normal operations in exchange for faster failover recovery. You must coordinate DNS failover with your SBC failover to ensure consistent routing behavior across all channels. Inconsistent failover timing between voice and digital channels creates fragmented caller experiences where voice routes to standby but digital routes to primary, complicating agent context and CRM synchronization.
Edge Case 1: SIP Dialog State Loss During Failover
The Failure Condition: Callers hear a brief silence or are disconnected immediately after the SBC reroutes traffic to the standby instance. Agent consoles show “Call Ended” or “Transfer Failed”.
The Root Cause: The SBC tears down the existing SIP dialog during failover instead of establishing a new INVITE. Genesys Cloud CX does not support mid-call SIP dialog migration across instances. The standby instance receives an orphaned SDP negotiation or a malformed REFER request.
The Solution: Configure your SBC to suppress re-INVITEs and force new INVITEs during failover transitions. Implement a SIP 503 Service Unavailable response from the primary instance during the failover window to gracefully reject new calls while existing calls complete. Configure your Architect flow to handle SIP 503 responses by routing to a message queue or voicemail rather than dropping the call.
Edge Case 2: DNS Propagation Latency & Caller Experience
The Failure Condition: Digital channel users experience connection timeouts or “Server Unreachable” errors for 60 to 120 seconds after primary failure. Abandonment rates spike during the transition window.
The Root Cause: DNS TTL is set too high, or the DNS provider’s health check interval does not align with the actual failure detection time. Recursive resolvers cache the primary record and continue routing traffic to the failed instance until the cache expires.
The Solution: Reduce DNS TTL to 30 seconds during normal operations. Configure your DNS provider to use aggressive health check intervals (10 seconds) and implement DNS failover with immediate weight shift upon single failure detection. Deploy a client-side retry mechanism in your Webchat SDK that detects WebSocket disconnection and automatically attempts reconnection to the standby endpoint using a hardcoded fallback URI.
Edge Case 3: Variable Synchronization Across Instances
The Failure Condition: Callers reach the standby IVR but encounter errors when the flow attempts to query CRM data, check loyalty status, or retrieve previous interaction history. Flow execution halts with “Integration Timeout” or “Invalid Variable”.
The Root Cause: The standby instance does not share the same integration credentials, API endpoints, or variable definitions. Your deployment pipeline updated the primary instance but failed to replicate the changes to the standby instance. External integrations enforce IP allowlisting or instance-specific OAuth scopes.
The Solution: Implement a configuration-as-code pipeline that treats both instances as identical deployments. Use Terraform or Genesys Cloud CX’s Bulk API to synchronize flow variables, integration profiles, and queue configurations. Configure all external integrations to accept traffic from both primary and standby instance IPs. Use environment variables in your integration middleware to dynamically route requests based on the originating instance subdomain. Validate variable synchronization during routine failover drills by injecting test variables and verifying data retrieval on the standby instance.
