Implementing Voice Bot Barge-In Detection and Graceful Interruption Handling
This guide details the configuration of barge-in detection within Genesys Cloud CX Architect flows to enable customers to interrupt automated speech with natural language or DTMF inputs. The end result is a telephony interaction where the Text-to-Speech (TTS) engine halts immediately upon detecting user voice activity, and control transfers gracefully to the next logical branch without dropping the call session.
To implement this architecture, specific platform capabilities and permissions are required. The configuration relies on the Genesys Cloud CX telephony layer combined with the Architect flow engine.
  • Licensing Tier: You require a Genesys Cloud CX license that includes Voice Bot capabilities or advanced IVR routing features. Specifically, the interrupt_on_speech property is available on standard Speak actions in Architect flows for CCX 1 and higher, but advanced Voice Bot specific analytics may require the Voice Bot add-on license.
  • Permissions: The user configuring the flow must hold the following granular permissions within the Admin Console:
    • Architect > Flow > Edit
    • Telephony > Trunk > Read (To verify SIP headers if debugging)
    • Voice Bot > Settings > Edit (If utilizing Voice Bot specific endpoints)
  • OAuth Scopes: If you are programmatically updating flow definitions via the API to enforce this configuration across environments, the application must request the following scopes:
    • flow.readwrite
    • flow.action.readwrite
  • External Dependencies: The underlying TTS provider must support streaming interruption. Ensure your chosen language profile (e.g., US English) is configured for low-latency streaming rather than full-file buffering to reduce the perceived delay between user speech and system response.
1. Configuring Speak Action Sensitivity and Interrupt Flags
The foundational step involves modifying the Speak action within your Architect flow. This action controls how the system reads text to the caller and determines whether it should pause for incoming audio. By default, many flows are configured with interrupt detection disabled to prevent accidental triggers during network jitter or background noise.
To enable barge-in, you must access the specific properties of the Speak node in the Architect designer. Locate the Interrupt on Speech setting. When enabled, the system continuously monitors the media stream for energy levels that exceed a defined threshold while TTS is active.
You must also configure the VAD Threshold (Voice Activity Detection). This value determines how loud the user must be relative to background noise to register as an interrupt. In a call center environment with moderate ambient noise, a standard threshold is often set between -60dB and -50dB. However, in a high-fidelity headset environment, you can lower this sensitivity to detect softer speech patterns.
Configuration Parameters:
  • Interrupt On Speech: true
  • VAD Sensitivity: High (Lowest numeric threshold) or Medium for noisy environments.
  • Silence Duration: 1000ms (Time to wait after speech stops before proceeding).
The Trap: The most common misconfiguration involves setting the VAD sensitivity too high (low dB value) in a noisy environment. If you set the threshold to detect very faint sounds, background noise from office chatter, keyboard typing, or HVAC systems will trigger false interrupts. This causes the bot to stop speaking unpredictably, leading to customer confusion and increased Average Handle Time (AHT). Conversely, setting sensitivity too low (high dB value) in a quiet room makes the bot feel unresponsive, as the user must shout to interrupt it.
Architectural Reasoning: We use the built-in VAD threshold here rather than custom logic because the system-level detection operates at the media gateway level. This is faster than detecting speech via a subsequent NLU intent recognition step. By handling this at the TTS layer, we reduce latency. If you rely on an NLU node to detect the interruption, there is processing overhead that makes the user feel like they are speaking to a wall. The Speak action interrupt flag bypasses the pipeline and halts the audio stream directly at the media server.
2. Designing the Interrupt Branch Logic
Enabling the interrupt flag creates a potential flow divergence point. You must define what happens when the interrupt event fires. If you do not explicitly handle this state, the system may resume the original TTS prompt after the user finishes speaking, creating a jarring experience where the agent or bot repeats itself mid-sentence.
You need to create a specific Branch off the Speak action that captures the interruption event. In Genesys Cloud Architect, this is typically handled by the return value of the Speak node. When an interrupt occurs, the flow execution should not continue down the default path immediately. Instead, it should evaluate a variable indicating the source of the interruption.
You must configure the flow to check for the interrupt flag before proceeding to the next node. A standard pattern involves using a Set Variable action immediately following the Speak node to capture whether an interruption occurred. If the variable equals true, route the call to a specific queue or intent handler. If false, proceed with the original TTS completion logic.
Flow Logic Snippet (Pseudo-JSON Representation):
  "id": "interrupt_handler_node",
  "type": "branch",
  "conditions": [
      "variableName": "$interruptDetected",
      "operator": "equals",
      "value": true,
      "nextNode": "handle_interruption"
  "defaultNextNode": "continue_original_flow"
The Trap: A critical failure mode occurs when the flow does not capture the interrupt state and simply allows the TTS stream to finish naturally after the user speaks. If the user interrupts to say “I want to speak to an agent,” but the bot ignores the flag and finishes its script before checking for intent, the user must wait for the remainder of the prompt before their request is processed. This increases friction. The second major trap is failing to clear the previous TTS buffer. In some legacy configurations, the system buffers the rest of the audio file locally. Even if you stop the stream at the gateway, the buffered data may play out after a delay. You must ensure the TTS engine sends a cancellation signal to the media server immediately upon receiving the interrupt flag.
Architectural Reasoning: We design the branch logic to be stateless where possible but persistent regarding intent. The interrupt event is transient; it does not carry payload data itself other than the fact that speech occurred. Therefore, you must route the call to a new processing node (such as an NLU node or a Queue) immediately. Do not attempt to parse the speech content within the same Speak action context. The latency of the interrupt detection plus the routing logic requires a clean handoff to a new flow branch to ensure the system is listening for the user’s actual request, not just the noise that triggered the stop.
3. Managing TTS Buffering and Latency Compensation
The physical implementation of barge-in depends heavily on how the Text-to-Speech engine streams audio. If your TTS provider buffers a full sentence before starting playback, the system cannot react to user speech until that buffer is filled. This creates a “dead zone” at the beginning of every prompt where the user cannot interrupt the bot.
To support effective barge-in, you must configure your TTS integration for Streaming Mode. In Genesys Cloud CX, this is often the default for modern voice profiles, but legacy integrations may use file-based playback. When streaming, the system synthesizes audio in small chunks and sends them over SIP/RTP immediately. This allows the media gateway to pause transmission instantly upon detecting energy spikes from the user.
You must also account for Network Latency. The time it takes for a user to press a button or speak, for that signal to traverse the network to the cloud, be processed by the VAD engine, and return a stop command is measurable in milliseconds. If your flow logic adds significant processing time after the interrupt detection (such as complex data lookups before routing), the user may feel the interruption was ineffective because they still hear silence or delayed audio.
  • TTS Mode: Streaming (Avoid File Playback)
  • Buffer Size: 100ms - 200ms (Smaller buffers reduce latency but increase CPU load)
  • Timeout Settings: Ensure the flow timeout for the Speak action is set higher than the expected speech duration to prevent premature call termination during long interruptions.
The Trap: A frequent error is assuming that enabling barge-in removes all latency. If your TTS provider uses a non-streaming endpoint, no amount of Architect configuration will fix the delay. The system must receive the full audio file before it can send any data to the user. This makes real-time interruption impossible. Another trap is setting the Silence Duration too low after an interrupt. If you set this to 0ms and route immediately to a new prompt, the user may be cut off mid-sentence by the bot asking for clarification. You must allow time for the user to finish their thought before the system speaks again.
Architectural Reasoning: We prioritize streaming TTS because it decouples synthesis from transmission. This allows the media gateway to maintain a bidirectional state where it can listen while speaking (Half-Duplex optimization). The latency compensation logic is handled by the system’s internal jitter buffer, but you must configure your flow timeouts to accommodate this variance. If the user speaks for 10 seconds during an interruption, your flow timeout must be at least 15 seconds to prevent the system from terminating the call due to inactivity while the user is still processing their request.
Edge Case 1: High Background Noise Environment
The Failure Condition: In a busy retail floor or open office environment, the voice bot interrupts itself frequently during non-speech moments. The system stops speaking when it detects HVAC noise or keyboard clatter as “voice.”
The Root Cause: The VAD Threshold is set too sensitive for the specific acoustic environment. The signal-to-noise ratio (SNR) of the user’s voice is being confused with ambient energy levels.
The Solution: Adjust the vad_threshold in the Speak action configuration to a less sensitive level (e.g., from High to Medium). Additionally, enable Noise Suppression on the SIP trunk or endpoint if available. This filters out constant background frequencies, allowing the VAD engine to focus on the dynamic range of human speech.
Edge Case 2: Interrupt During TTS Transition
The Failure Condition: A user interrupts a prompt, but the system resumes the previous prompt after a 3-second delay. The user hears the end of the original message they tried to stop.
The Root Cause: The TTS engine is buffering the audio locally rather than streaming it in real-time chunks. When the interrupt signal arrives, the buffer has already been flushed or contains the remaining data that must be played out.
The Solution: Verify the TTS integration settings in the Architect flow configuration. Ensure Streaming Output is selected for all Speak actions. If using a custom API integration for TTS, ensure your API endpoint supports WebSocket streaming or chunked RTP transmission rather than returning a static MP3 file URL.
Edge Case 3: Call Termination During Interruption
The Failure Condition: When a user interrupts to request an agent, the system routes them to the queue, but the call drops immediately after the interrupt.
The Root Cause: The flow timeout logic conflicts with the routing action. The Speak action may have triggered a default timeout because the interruption was not captured by the branch logic in time.
The Solution: Ensure the Branch Node following the Speak action has no timeout configured, or set it to 0 (infinite) if the branching is purely based on the interrupt variable. Also, verify that the routing node does not have an implicit session termination trigger. The flow must explicitly route to a Queue or Transfer node without passing through a “End Call” node by default.
Edge Case 4: Late Barge-In Detection
The Failure Condition: Users report that they have to wait several seconds after starting to speak before the bot stops talking. This creates a disjointed conversation flow.
The Root Cause: The Silence Duration setting on the Speak action is too high. This forces the system to listen for a period of silence after detecting speech before it considers the interruption complete and proceeds.
The Solution: Reduce the Silence Duration parameter in the Speak action configuration from the default 1000ms to 200ms or 500ms. This reduces the time the system spends waiting for the user to stop speaking before taking action, making the interruption feel instantaneous.
