Implementing Video Session Quality Monitoring with Automated Degradation Alerting
This guide details the architectural pattern for collecting real-time WebRTC video quality metrics, evaluating them against degradation thresholds, and routing automated alerts to operational teams or external SIEM platforms. When complete, your environment will continuously monitor active video sessions, trigger architect flows or webhook payloads when MOS drops below 3.5 or packet loss exceeds 2 percent, and suppress alert storms through intelligent windowing logic.
  • Licensing: Genesys Cloud CX 3 base license with the Video add-on. Real-time analytics requires the CX 3 tier. The WEM add-on is optional but recommended for agent-side performance correlation.
  • Permissions: Telephony > WebRTC > Read, Analytics > Real Time > Read, Architect > Flows > Edit, Routing > Queues > Edit, Integration > Webhooks > Create, Administration > Service Accounts > Manage.
  • OAuth Scopes: analytics:read, realtime:read, architect:edit, integration:manage, webhooks:write.
  • External Dependencies: Reliable SMTP relay or webhook endpoint (ServiceNow, Datadog, Splunk), DNS resolution for external SIEM, TLS 1.2+ termination for outbound alerts, and a dedicated service account for programmatic polling.
1. Configuring Real-Time WebRTC Quality Metrics Collection
Genesys Cloud does not expose raw WebRTC getStats() reports directly to the management UI. The platform aggregates client-side reports into the Real-Time API stream under the webrtc namespace. You must subscribe to the /api/v2/analytics/events/realtime endpoint filtered by webrtc and webrtc-video event types. The platform samples metrics at 5-second intervals per active session, calculating Mean Opinion Score (MOS), jitter, round-trip time (RTT), and packet loss.
The collection configuration happens in the Architect environment under Triggers. Create a new trigger with the following configuration:
  • Trigger Type: Real-Time Event
  • Event Type: webrtc
  • Filter Expression: event.type == 'webrtc-video' && (event.metrics.mos < 3.5 || event.metrics.packetLossPercent > 2.0)
  • Sampling Rate: Default (5s)
You must enable Real-Time Data Collection in the Analytics settings. Navigate to Analytics > Real-Time > Settings and ensure webrtc is checked under Event Types. The platform caches these metrics in an in-memory time-series store before flushing to the historical analytics warehouse. This caching layer enables sub-second query response times for active sessions.
The Trap: Configuring the trigger without a session.id deduplication key causes duplicate alert routing. Genesys Cloud emits a new event every 5 seconds while the degradation persists. If you route each event directly to a notification queue, you will generate a continuous alert stream that floods your messaging endpoints and masks the actual incident window. Always append a Group By or Throttle block in Architect to aggregate events per session.id within a 60-second window.
Architectural Reasoning: We use the Real-Time API stream instead of polling the Historical Analytics endpoint because historical aggregation introduces a 15-to-30-minute delay. Video degradation requires sub-60-second detection to allow agent reconnection or network path failover. The 5-second sampling interval balances network overhead with detection granularity. Increasing the sampling rate to 1 second consumes 5x more API quota and degrades platform performance during peak concurrency. The real-time event stream also preserves client-side codec negotiation states, which historical aggregation drops after session completion.
2. Designing Architect Triggers for Degradation Thresholds
Threshold design requires distinguishing between transient network blips and sustained degradation. A single MOS dip to 3.4 caused by a cellular handoff does not warrant an alert. Sustained degradation below 3.2 for 30 seconds indicates a broken media path.
In Architect, build a flow that receives the trigger event. Use a Data block to extract the following fields from the event payload:
  "session.id": "{{event.session.id}}",
  "agent.id": "{{event.agent.id}}",
  "customer.endpoint.ip": "{{event.customer.endpoint.ip}}",
  "metrics.mos": "{{event.metrics.mos}}",
  "metrics.jitter.ms": "{{event.metrics.jitter.ms}}",
  "metrics.packetLossPercent": "{{event.metrics.packetLossPercent}}",
  "metrics.rtt.ms": "{{event.metrics.rtt.ms}}",
  "metrics.bitrate.kbps": "{{event.metrics.bitrate.kbps}}",
  "timestamp": "{{event.timestamp}}"
Insert a Wait block configured for 30 seconds. After the wait, use a Query block to fetch the latest metrics for the same session.id via the Real-Time API. Compare the current MOS against the initial trigger value. If the MOS has recovered above 3.5, terminate the flow. If it remains below 3.5, proceed to alert routing.
The Trap: Relying solely on MOS for threshold evaluation ignores codec negotiation failures. A session can report MOS 4.0 while running at 15 kbps due to an aggressive VBR codec fallback, resulting in severe visual artifacting that MOS does not capture. You must include a secondary check for metrics.bitrate.kbps < 500 alongside the MOS evaluation. Without this, your alerting system will miss low-bandwidth degradation that impacts customer comprehension.
Architectural Reasoning: The 30-second wait window implements a hysteresis buffer. Network paths naturally experience micro-bursts. By requiring sustained degradation before alerting, you reduce false positive rates by approximately 70 percent. The secondary API query inside the flow ensures you are acting on current state data, not stale trigger data. This pattern prevents alert routing based on metrics that have already self-corrected. We also correlate this flow with WEM supervisor dashboards, as detailed in the WEM Agent Performance Monitoring guide, to ensure video degradation aligns with agent wrap-up behavior and after-call work patterns.
3. Building the Alert Routing & Notification Flow
Once sustained degradation is confirmed, the flow must route the alert to the appropriate operational channel. The architecture supports three routing paths: internal queue assignment, external webhook delivery, and email/SMS escalation.
Create a Queue named Video Quality Alerts with the following configuration:
  • Skill: Video_Ops
  • Wrap-Up Time: 0 seconds
  • Max Hold Time: 300 seconds
  • Routing Strategy: Longest Available
In the Architect flow, add a Queue block targeting Video Quality Alerts. Map the session.id to the queue.id field for tracking. Attach the extracted metrics payload to the notes field using a JSON string format. This allows WEM supervisors to pull the alert into their dashboard and correlate it with agent screen recordings.
For external SIEM integration, add a Webhook block configured with:
  • URL: https://siem.yourdomain.com/api/v1/incidents/webrtc
  • Method: POST
  • Headers: Authorization: Bearer {{oauth.token}}, Content-Type: application/json
  • Body:
      "incident_type": "webrtc_degradation",
      "severity": "high",
      "session_id": "{{session.id}}",
      "agent_id": "{{agent.id}}",
      "metrics": {
        "mos": {{metrics.mos}},
        "jitter_ms": {{metrics.jitter.ms}},
        "packet_loss_percent": {{metrics.packetLossPercent}},
        "rtt_ms": {{metrics.rtt.ms}},
        "bitrate_kbps": {{metrics.bitrate.kbps}}
      "trigger_timestamp": "{{timestamp}}",
      "environment": "prod"
The Trap: Sending raw webhook payloads without idempotency keys causes duplicate incident creation in SIEM platforms. If the Architect flow retries the webhook due to a 503 response from your SIEM, the SIEM will create multiple tickets for the same degradation event. Always generate a deterministic incident_key using a hash of session.id and floor(timestamp / 300). Pass this key in the X-Idempotency-Key header. Your SIEM ingestion layer must be configured to deduplicate based on this key within a 5-minute window.
Architectural Reasoning: We route alerts to an internal queue first because it provides immediate visibility to on-call WEM supervisors without depending on external system availability. The webhook operates asynchronously. If the SIEM endpoint is unreachable, the queue path still captures the incident for manual review. This dual-path design ensures alert delivery even during partial infrastructure outages. The JSON payload structure follows OpenTelemetry semantic conventions, allowing direct ingestion into Datadog or Splunk without schema transformation. The queue assignment also enables SLA tracking for incident resolution, which integrates directly with your WFM scheduling and adherence reporting.
4. Exposing Metrics via REST API for External Monitoring
While Architect handles real-time alerting, external monitoring platforms require programmatic access to historical and real-time metrics for capacity planning and trend analysis. You must configure a dedicated service account with restricted OAuth scopes to pull metrics without exposing PII.
Create a Service Account with the following roles:
  • Analytics Administrator
  • Integration Administrator
  • Read Only User
Assign the OAuth scopes: analytics:read, realtime:read. Disable telephony:read and routing:read to enforce least privilege. The service account will authenticate using client credentials flow:
POST /oauth/token
grant_type=client_credentials&client_id={{CLIENT_ID}}&client_secret={{CLIENT_SECRET}}&scope=analytics:read+realtime:read
Use the Real-Time API to stream metrics:
GET /api/v2/analytics/events/realtime?eventTypes=webrtc,webrtc-video&filter=metrics.mos<3.5
Authorization: Bearer {{ACCESS_TOKEN}}
For historical trend analysis, query the Historical Analytics API with a 5-minute aggregation window:
POST /api/v2/analytics/query
  "eventTypes": ["webrtc-video"],
  "interval": "PT5M",
  "select": [
    "metrics.mos.avg",
    "metrics.packetLossPercent.avg",
    "metrics.jitter.ms.avg",
    "count"
  "group": ["metrics.mos.avg"],
  "where": "timestamp > now() - 24h"
The Trap: Polling the Historical Analytics API at 1-second intervals triggers rate limiting and quota exhaustion. Genesys Cloud enforces a 100 requests per minute limit per tenant for historical queries. Aggressive polling will return HTTP 429 responses and block legitimate analytics workloads. Implement exponential backoff starting at 5-second intervals, and cache results locally for 60 seconds before re-querying. Always use the interval parameter to aggregate data server-side instead of processing raw event streams in your application.
Architectural Reasoning: Server-side aggregation via the interval parameter reduces payload size by 90 percent compared to raw event retrieval. The platform computes averages and percentiles in the analytics warehouse, offloading CPU from your monitoring service. The client credentials flow ensures token rotation without interactive login dependencies. Restricting scopes prevents accidental exposure of call recordings or customer PII when the service account credentials are rotated or compromised. This pattern aligns with PCI-DSS and HIPAA data minimization requirements by ensuring monitoring services only receive metric telemetry, never session media or customer identifiers.
Edge Case 1: Metric Sampling Gaps During Network Handoffs
  • The Failure Condition: The alerting flow does not trigger despite agents reporting severe video freezing and pixelation. Real-time metrics show a gap in the webrtc-video event stream for 15 to 20 seconds.
  • The Root Cause: Mobile clients and Wi-Fi handoffs cause the WebRTC peer connection to enter a disconnected state. Genesys Cloud pauses metric emission during peer reconnection. The 5-second sampling window skips entirely, causing the trigger to miss the degradation window.
  • The Solution: Implement a heartbeat monitor alongside the quality trigger. Create a secondary Architect trigger that fires on webrtc event type with event.state == 'disconnected'. Route this to the same alert queue with a severity: warning flag. This captures the handoff event independently of quality metrics, ensuring you receive notification even when the sampling pipeline pauses. You can also configure the WebRTC client SDK to emit a custom network_change event that bridges the sampling gap.
Edge Case 2: Alert Storms from Transient Packet Bursts
  • The Failure Condition: The notification queue receives
