Implementing Token-Aware Context Window Truncation for Genesys Cloud Transcript Data Using a Python Sliding Window Algorithm
- This tutorial delivers a production-ready Python script that extracts conversation transcripts from Genesys Cloud, applies a token-aware sliding window algorithm to enforce strict LLM context limits, and outputs a properly formatted message array ready for API ingestion.
- This implementation uses the Genesys Cloud Interactions API (
/api/v2/interactions/conversations/details/query) and thetiktokenlibrary for precise token counting. - This tutorial covers Python 3.9+ with
requestsfor HTTP communication andtiktokenfor encoding management.
- OAuth 2.0 Client Credentials flow configured in Genesys Cloud Admin with the
interaction:readscope - Genesys Cloud API version v2
- Python 3.9 or higher
- External dependencies:
pip install requests tiktoken
Genesys Cloud uses OAuth 2.0 for API authentication. The following implementation caches the access token and automatically refreshes it when the expiry window approaches. The SDK handles this internally, but manual management provides explicit control over token lifecycle and retry boundaries.
import requests
from typing import Optional
class GenesysAuth:
def __init__(self, client_id: str, client_secret: str, org_id: str):
self.client_id = client_id
self.org_id = org_id
self.token_url = f"https://{org_id}.mygen.com/oauth/token"
self.token_expiry: float = 0
def get_token(self) -> str:
if self.access_token and time.time() < self.token_expiry - 300:
return self.access_token
payload = {
"client_id": self.client_id,
response = requests.post(self.token_url, data=payload)
response.raise_for_status()
data = response.json()
self.access_token = data["access_token"]
self.token_expiry = time.time() + data["expires_in"]
"Authorization": f"Bearer {self.get_token()}",
Step 1: Fetch Transcript Data with Pagination and Retry Logic
The Interactions API returns conversation details in paginated batches. You must handle nextPageUri for complete data retrieval and implement exponential backoff for HTTP 429 rate limit responses. The following function queries a specific conversation ID and aggregates all transcript turns.
import json
def fetch_conversation_transcript(
auth: GenesysAuth,
conversation_id: str,
max_pages: int = 50
) -> List[Dict[str, Any]]:
base_url = f"https://{auth.org_id}.mygen.com/api/v2/interactions/conversations/details/query"
all_turns = []
page = 1
while page <= max_pages:
query_payload = {
"query": f"conversationId:{conversation_id}",
"pageSize": 250
headers = auth.get_headers()
# Retry logic for 429 Too Many Requests
retries = 0
max_retries = 3
while retries < max_retries:
response = requests.post(base_url, headers=headers, json=query_payload)
retry_after = int(response.headers.get("Retry-After", 2 ** retries))
time.sleep(retry_after)
retries += 1
elif response.status_code == 401:
raise PermissionError("Invalid or expired OAuth token. Verify client credentials.")
elif response.status_code == 403:
raise PermissionError("Missing interaction:read scope. Update OAuth client permissions.")
else:
break
entities = data.get("entities", [])
for entity in entities:
transcript = entity.get("interactions", {}).get("transcript", [])
all_turns.extend(transcript)
if not data.get("nextPageUri"):
break
page += 1
return all_turns
Expected HTTP Request:
POST /api/v2/interactions/conversations/details/query HTTP/1.1
Host: your-org-id.mygen.com
Authorization: Bearer eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9...
"query": "conversationId:a1b2c3d4-e5f6-7890-abcd-ef1234567890",
"pageSize": 250
Expected HTTP Response:
"entities": [
"conversationId": "a1b2c3d4-e5f6-7890-abcd-ef1234567890",
"interactions": {
"transcript": [
"from": {
"participantId": "cust-98765",
"participantType": "customer"
"text": "My shipment is delayed. Can you check status?",
"timestamp": "2024-05-12T14:30:00.000Z"
"from": {
"participantId": "agent-11223",
"participantType": "agent"
"text": "I can look into that immediately. Please provide your tracking number.",
"timestamp": "2024-05-12T14:30:05.000Z"
"nextPageUri": null,
"pageSize": 250,
"page": 1,
"firstPageUri": "/api/v2/interactions/conversations/details/query?page=1",
"lastPageUri": "/api/v2/interactions/conversations/details/query?page=1"
Step 2: Flatten and Normalize Transcript Turns
Genesys Cloud returns transcript turns with nested participant objects. You must map these to a flat structure that separates role, content, and metadata. This normalization step prepares the data for deterministic token counting.
def normalize_turns(raw_turns: List[Dict[str, Any]]) -> List[Dict[str, Any]]:
normalized = []
for turn in raw_turns:
participant_type = turn.get("from", {}).get("participantType", "unknown")
role = "assistant" if participant_type == "agent" else "user"
normalized.append({
"role": role,
"content": turn.get("text", ""),
"timestamp": turn.get("timestamp", ""),
"participant_id": turn.get("from", {}).get("participantId", "")
return normalized
Step 3: Execute Token-Aware Sliding Window Truncation
Large transcripts frequently exceed LLM context windows (typically 4096 or 8192 tokens). A sliding window algorithm preserves the most recent conversational context while discarding older turns. The following implementation tracks token counts dynamically and shifts the window forward when the limit is breached.
import tiktoken
def apply_sliding_window(
turns: List[Dict[str, Any]],
max_tokens: int = 4096,
encoding_name: str = "cl100k_base"
if not turns:
return []
encoding = tiktoken.get_encoding(encoding_name)
window: List[Dict[str, Any]] = []
current_tokens = 0
for turn in turns:
# Calculate token cost for the turn content plus role metadata
content_tokens = len(encoding.encode(turn["content"]))
role_metadata = f"{turn['role']}: "
metadata_tokens = len(encoding.encode(role_metadata))
turn_total = content_tokens + metadata_tokens
# If adding this turn exceeds the limit, slide the window forward
if current_tokens + turn_total > max_tokens:
while current_tokens + turn_total > max_tokens and window:
removed = window.pop(0)
removed_metadata = f"{removed['role']}: "
current_tokens -= len(encoding.encode(removed["content"])) + len(encoding.encode(removed_metadata))
# Edge case: single turn exceeds max_tokens
if current_tokens + turn_total <= max_tokens:
window.append(turn)
current_tokens += turn_total
return window
Step 4: Format for LLM Ingestion
LLM providers expect a specific message array structure. The following function wraps the truncated window with a system prompt and validates the final token count against your target model limits.
import tiktoken
def format_for_llm(
window_turns: List[Dict[str, Any]],
system_prompt: str = "You are a helpful customer support assistant analyzing conversation history.",
) -> Dict[str, Any]:
messages = [
{"role": "system", "content": system_prompt}
total_tokens = len(encoding.encode(system_prompt))
for turn in window_turns:
messages.append({
"role": turn["role"],
"content": turn["content"]
total_tokens += len(encoding.encode(turn["content"])) + 2 # +2 for message structure overhead
"messages": messages,
"token_count": total_tokens
The following script combines all components into a single executable module. Replace the placeholder credentials with your Genesys Cloud service account values before execution.
import requests
import tiktoken
from typing import List, Dict, Any, Optional
class GenesysAuth:
payload = {
def fetch_conversation_transcript(auth: GenesysAuth, conversation_id: str, max_pages: int = 50) -> List[Dict[str, Any]]:
all_turns = []
page = 1
query_payload = {
"pageSize": 250
retries = 0
max_retries = 3
retries += 1
raise PermissionError("Invalid or expired OAuth token.")
raise PermissionError("Missing interaction:read scope.")
else:
break
for entity in data.get("entities", []):
break
page += 1
return all_turns
normalized = []
normalized.append({
"role": role,
return normalized
def apply_sliding_window(turns: List[Dict[str, Any]], max_tokens: int = 4096) -> List[Dict[str, Any]]:
if not turns:
return []
encoding = tiktoken.get_encoding("cl100k_base")
window = []
current_tokens = 0
for turn in turns:
metadata_tokens = len(encoding.encode(f"{turn['role']}: "))
current_tokens -= len(encoding.encode(removed["content"])) + len(encoding.encode(f"{removed['role']}: "))
window.append(turn)
return window
def format_for_llm(window_turns: List[Dict[str, Any]], system_prompt: str) -> Dict[str, Any]:
messages = [{"role": "system", "content": system_prompt}]
messages.append({"role": turn["role"], "content": turn["content"]})
return {"messages": messages, "token_count": total_tokens}
CLIENT_ID = "your_client_id"
CLIENT_SECRET = "your_client_secret"
ORG_ID = "your_org_id"
CONVERSATION_ID = "a1b2c3d4-e5f6-7890-abcd-ef1234567890"
MAX_CONTEXT_TOKENS = 4096
auth = GenesysAuth(CLIENT_ID, CLIENT_SECRET, ORG_ID)
raw_turns = fetch_conversation_transcript(auth, CONVERSATION_ID)
normalized = normalize_turns(raw_turns)
truncated_window = apply_sliding_window(normalized, MAX_CONTEXT_TOKENS)
llm_payload = format_for_llm(truncated_window, "Analyze customer sentiment and extract key issues.")
print(f"Original turns: {len(normalized)}")
print(f"Window turns: {len(truncated_window)}")
print(f"Final token count: {llm_payload['token_count']}")
print("LLM Payload ready for ingestion.")
Error: HTTP 401 Unauthorized
- What causes it: The OAuth token has expired, the client credentials are incorrect, or the token endpoint URL is malformed.
- How to fix it: Verify the
client_idandclient_secretmatch a configured service account in Genesys Admin. Ensure theorg_idexactly matches your Genesys Cloud environment identifier. The authentication class automatically refreshes tokens, but initial handshake failures require credential verification. - Code showing the fix: The
GenesysAuth.get_token()method raises a clearPermissionErroron 401 responses. Wrap API calls in a try-except block to catch and log credential failures before retrying.
Error: HTTP 403 Forbidden
- What causes it: The OAuth client lacks the required
interaction:readscope. - How to fix it: Navigate to Admin > Security > OAuth Clients. Select your service account and add
interaction:readto the granted scopes. Save the configuration and regenerate the client secret if the scope was added after initial creation. - Code showing the fix: The fetch function explicitly checks for 403 and raises a descriptive exception. Add scope validation logic at startup if you manage multiple API clients.
- What causes it: You have exceeded the Genesys Cloud API rate limits for your organization tier.
- How to fix it: Implement exponential backoff with jitter. The provided
fetch_conversation_transcriptfunction reads theRetry-Afterheader and sleeps accordingly. For high-throughput pipelines, distribute queries across multiple service accounts or implement a local queue with rate limiting. - Code showing the fix: The retry loop inside
fetch_conversation_transcripthandles 429 responses automatically. Increasemax_retriesto 5 for production environments with bursty traffic patterns.
Error: tiktoken Encoding Mismatch
- What causes it: Using
cl100k_basefor models that requirep50k_baseorr50k_base. - How to fix it: Match the encoding to your target LLM provider. OpenAI models (GPT-3.5, GPT-4) use
cl100k_base. Legacy models usep50k_base. Parameterize the encoding name inapply_sliding_windowandformat_for_llmto support multi-model deployments. - Code showing the fix: Pass
encoding_name="p50k_base"to both windowing and formatting functions when targeting older model versions.
