Implementing Silent Monitoring and Barge-In via API Commands
This guide details the programmatic implementation of silent monitoring and barge-in capabilities using the Genesys Cloud Interactions Telephony API. You will build a middleware service that initiates, tracks, and terminates supervisor monitoring sessions without relying on the native UI, enabling custom coaching workflows, third-party CRM integrations, or automated quality assurance pipelines. The end result is a state-managed REST client that handles async session confirmation, exclusive barge contention, and event-driven teardown.
  • Licensing Tier: Genesys Cloud CX 2 or higher for all supervisor accounts. CX 1 licenses do not include programmatic monitoring permissions and will return 403 Forbidden on monitor endpoints.
  • Granular Permissions: Telephony > Monitor > Edit, Interaction > Monitor > Edit, Interaction > Read.
  • OAuth Scopes: interaction:monitor (required for POST commands), interaction:view (required for GET state queries), telephony:monitor (legacy fallback, deprecated but still functional in v2).
  • External Dependencies: Active telephony interactions with valid interactionId, OAuth 2.0 client credentials flow configured for service accounts, middleware runtime capable of managing async state machines and handling X-RateLimit-Remaining headers.
1. Establishing the Silent Monitor Bridge
The foundation of programmatic monitoring is the initial bridge creation. Genesys Cloud decouples the request submission from the actual RTP stream negotiation to optimize media server load balancing across global regions. You must design your middleware to handle this asynchronous confirmation pattern.
Issue a POST request to the Interactions Telephony Monitor endpoint. The payload requires only the target interaction identifier and the initial action.
POST https://{{org}}.mygen.com/api/v2/interactions/telephony/monitor
Authorization: Bearer {{access_token}}
Accept: application/json
  "interactionId": "a1b2c3d4-e5f6-7890-abcd-ef1234567890",
  "action": "start"
The platform returns a 202 Accepted response containing a monitorSessionId. This identifier is your primary tracking key for all subsequent state transitions. You must store this value alongside the interactionId in your middleware state store.
The Trap: Assuming a 202 Accepted response guarantees an active audio bridge. It does not. It only confirms that the request was queued for media server allocation. If your middleware proceeds to log the session as active immediately, you will experience race conditions where barge or whisper commands are issued before the RTP stream is established, resulting in 409 Conflict errors or dropped media packets.
Architectural Reasoning: We treat the 202 as a pending state. Your middleware must poll GET /api/v2/interactions/{interactionId}/telephony/monitor or subscribe to the interaction.telephony.monitor WebSocket event to confirm status: "active". This pattern prevents command queuing failures during peak concurrency when media servers are throttling new stream allocations. We implement a retry loop with exponential backoff (base 500ms, max 3s) to handle transient media server handshake delays without blocking the supervisor UI.
2. Executing State Transitions and Barge-In
Once the silent bridge is confirmed active, supervisors require the ability to escalate to barge-in or whisper modes. Genesys maintains a single media leg for the supervisor throughout the session lifecycle. You do not create new sessions for barge; you mutate the existing session state.
Transition to barge by issuing a POST to the same endpoint with the barge action. Include the monitorSessionId to bind the command to the correct bridge.
  "monitorSessionId": "ms-98765432-1234-5678-9abc-def012345678",
  "action": "barge"
The platform returns 200 OK upon successful transition. The supervisor audio leg now routes bidirectionally to the customer. The agent continues to hear the customer, but cannot hear the supervisor unless whisper or full barge is explicitly configured in the routing policy.
The Trap: Treating barge as a session creation event. Developers frequently issue a second POST /api/v2/interactions/telephony/monitor with action: "start" when attempting barge, which creates a duplicate monitor leg. This triggers SIP re-INVITE storms, causes audio feedback loops, and exhausts media server port allocations. The platform will eventually terminate one of the bridges unpredictably, dropping the supervisor mid-call.
Architectural Reasoning: We enforce a strict state machine in the middleware: PENDING -> SILENT -> BARGE -> WHISPER -> TERMINATED. Transitions are idempotent operations against the monitorSessionId. We validate the current state via GET /api/v2/interactions/{id}/telephony/monitor before issuing mutations. This prevents invalid transitions (e.g., barge → start) and ensures the middleware UI reflects the exact platform state. We also cache the bargeStatus field to disable barge buttons in the frontend when the bridge is already active, reducing unnecessary API calls.
3. Managing Session Teardown and Event-Driven Cleanup
Monitoring sessions must terminate cleanly. Leaving orphaned monitor legs consumes media server resources and can cause unexpected billing events in some carrier configurations. You must implement both explicit teardown and passive cleanup.
Explicit termination uses the stop action:
  "action": "stop"
The Trap: Relying solely on explicit stop commands for cleanup. If the agent hangs up, transfers, or the interaction times out, Genesys automatically severs the monitor bridge. However, your middleware may still hold an open polling loop, WebSocket connection, or frontend session object. Without passive cleanup, your service accumulates memory leaks, stale OAuth token usage, and degraded UI responsiveness.
Architectural Reasoning: We implement a dual-teardown pattern. Explicit stop commands handle supervisor-initiated exits. Passive cleanup relies on the interaction.telephony.ended webhook or streaming event. When the platform emits an interaction termination event, the middleware matches the interactionId against active monitor sessions and forces a local state reset. We also implement a TTL (time-to-live) sweep job that queries GET /api/v2/interactions?status=ended every 60 seconds to purge any sessions missed by webhook delivery failures. This ensures zero orphaned state in the middleware regardless of platform-side termination triggers.
Edge Case 1: Asymmetric Media Routing in Multi-Region Deployments
The Failure Condition: Supervisor initiates silent monitor successfully, but experiences one-way audio, 200ms+ latency spikes, or complete media dropout during barge transitions.
The Root Cause: Genesys routes the agent-customer bridge through a primary media server based on trunk affinity and geographic routing. When the monitor API call is processed, the platform may allocate the supervisor stream to a secondary media server to balance load. If the two media servers are in different regions or connected via high-latency interconnects, the RTP packets experience asymmetric routing. The platform does not automatically bridge media between servers for monitor legs unless explicitly configured.
The Solution: Enforce media server affinity by specifying the mediaServerGroupId in the monitor payload. Query GET /api/v2/telephony/providers/media-server-groups to identify the group handling the primary interaction. Include it in the POST request:
  "action": "start",
  "mediaServerGroupId": "ms-group-us-east-1"
If affinity is not possible due to failover scenarios, implement a jitter buffer tuning strategy in your middleware. Adjust the playoutDelay and nackEnabled parameters in the WebRTC client configuration to compensate for cross-region latency. Monitor packetLoss and jitter metrics via the interaction.telephony.media-metrics endpoint to trigger automatic fallback to a lower-bitrate codec if degradation exceeds thresholds.
Edge Case 2: Exclusive Barge Leg Contention
The Failure Condition: Second supervisor attempts barge on an already monitored interaction. The API returns 409 Conflict, or the first supervisor experiences audio dropout when the second supervisor attempts barge.
The Root Cause: Genesys enforces a strict one-active-barge-leg policy per interaction. Multiple silent monitors are permitted, but barge and whisper modes share an exclusive media channel. When a second supervisor issues a barge command, the platform rejects it to prevent audio mixing conflicts and SIP loopback conditions. The 409 Conflict response includes a conflictingMonitorSessionId in the error body.
The Solution: Implement a contention queue in your middleware. Before issuing a barge command, query the current monitor state:
GET https://{{org}}.mygen.com/api/v2/interactions/{interactionId}/telephony/monitor
Parse the bargeStatus field. If it returns active, queue the request in a Redis-backed FIFO queue with a 30-second TTL. Notify the requesting supervisor of the contention state via WebSocket. When the primary supervisor issues a stop or transitions to silent, the middleware dequeues the next request and issues the barge command. This pattern eliminates 409 errors, provides deterministic UX feedback, and prevents race conditions during high-volume coaching sessions.
Edge Case 3: OAuth Token Expiration During Long-Running Sessions
The Failure Condition: Monitoring session remains active for 45+ minutes. Subsequent barge or stop commands return 401 Unauthorized despite valid middleware state.
The Root Cause: Genesys OAuth access tokens expire after 3600 seconds by default. Long-running coaching sessions frequently exceed this window. If your middleware caches the token at session initialization and does not implement rotation, all subsequent API calls fail.
The Solution: Implement a token refresh interceptor in your HTTP client. Store the expires_in value from the initial POST /api/v2/auth/token response. Trigger a refresh request 30 seconds before expiration:
POST https://{{org}}.mygen.com/api/v2/auth/token
grant_type=client_credentials&client_id={{client_id}}&client_secret={{client_secret}}
Replace the cached token atomically. Implement a retry queue for in-flight requests that fail with 401. This ensures uninterrupted session management regardless of session duration. Never store tokens in frontend contexts; rotate them exclusively in the middleware layer.
