Implementing Robust WebSocket Reconnection Logic for Genesys Cloud Web Messaging in Go
- A production-grade Go client that maintains a persistent WebSocket connection to Genesys Cloud Web Messaging and automatically recovers from network failures.
- The implementation uses the
gorilla/websocketlibrary and the Genesys Cloud Web Messaging REST and WebSocket API surfaces. - The tutorial covers Go 1.21+ with explicit type definitions, context management, and thread-safe state handling.
- OAuth 2.0 Client Credentials grant type configured in Genesys Cloud with
webmessaging:session:readandwebmessaging:session:writescopes. - Genesys Cloud API version 2.
- Go runtime version 1.21 or higher.
- External dependencies:
github.com/gorilla/websocket,github.com/google/uuid,time,context,fmt,log,net/http,net/url,sync,math,math/rand,encoding/json.
Genesys Cloud Web Messaging requires a valid OAuth 2.0 bearer token for both the initial WebSocket handshake and subsequent REST API calls. The token must be cached locally and refreshed before expiration to prevent authentication failures during reconnection.
The following function retrieves a token using the client credentials flow and stores the expiration timestamp for later validation.
package main
import (
"bytes"
"encoding/json"
"fmt"
"io"
"net/http"
"time"
type OAuthResponse struct {
type TokenStore struct {
Token string
ExpiresAt time.Time
func FetchToken(orgDomain, clientId, clientSecret string) (*TokenStore, error) {
endpoint := fmt.Sprintf("https://%s.mypurecloud.com/oauth/token", orgDomain)
payload := fmt.Sprintf("grant_type=client_credentials&client_id=%s&client_secret=%s", clientId, clientSecret)
req, err := http.NewRequest("POST", endpoint, bytes.NewBufferString(payload))
if err != nil {
return nil, fmt.Errorf("failed to create token request: %w", err)
resp, err := client.Do(req)
if err != nil {
return nil, fmt.Errorf("token request failed: %w", err)
defer resp.Body.Close()
return nil, fmt.Errorf("token request returned %d: %s", resp.StatusCode, string(body))
var oauthResp OAuthResponse
if err := json.NewDecoder(resp.Body).Decode(&oauthResp); err != nil {
return nil, fmt.Errorf("failed to decode token response: %w", err)
return &TokenStore{
Token: oauthResp.AccessToken,
ExpiresAt: time.Now().Add(time.Duration(oauthResp.ExpiresIn) * time.Second),
}, nil
This function returns a TokenStore containing the access token and the exact expiration time. The client will check this timestamp before attempting any reconnection.
Step 1: WebSocket Connection and Pong Timeout Detection
The Genesys Cloud Web Messaging WebSocket endpoint expects the OAuth token as a query parameter. After establishing the connection, the client must monitor for server pings and respond with pongs. If no pong arrives within a defined window, the connection is considered dead.
package main
import (
"fmt"
"net/url"
"time"
"github.com/gorilla/websocket"
type WebMessagingClient struct {
OrgDomain string
GuestID string
Token *TokenStore
Conn *websocket.Conn
LastMessageID string
func (c *WebMessagingClient) Connect() error {
wsURL := url.URL{
Scheme: "wss",
Host: fmt.Sprintf("%s.mypurecloud.com", c.OrgDomain),
Path: fmt.Sprintf("/api/v2/conversations/webmessaging/sessions/%s/messages", c.GuestID),
wsURL.RawQuery = fmt.Sprintf("token=%s", c.Token.Token)
dialer := websocket.Dialer{
HandshakeTimeout: 10 * time.Second,
conn, _, err := dialer.Dial(wsURL.String(), nil)
if err != nil {
return fmt.Errorf("websocket dial failed: %w", err)
c.Conn = conn
c.Conn.SetPongHandler(func(appData string) error {
// Reset read deadline on successful pong
c.Conn.SetReadDeadline(time.Now().Add(30 * time.Second))
return nil
return nil
The SetPongHandler callback resets the read deadline every time the server responds to a ping. If the server fails to respond within thirty seconds, the next ReadMessage call will return a timeout error, signaling a dead connection.
Step 2: Truncated Exponential Backoff Calculator
Network failures require controlled reconnection attempts to avoid overwhelming the Genesys Cloud platform. A truncated exponential backoff with jitter prevents thundering herd scenarios while ensuring rapid recovery for transient failures.
package main
import (
"math"
"math/rand"
"time"
func calculateBackoff(attempt int, baseDuration, maxDuration time.Duration, jitterFactor float64) time.Duration {
exp := baseDuration * time.Duration(math.Pow(2, float64(attempt)))
if exp > maxDuration {
exp = maxDuration
jitter := time.Duration(float64(exp) * jitterFactor * rand.Float64())
return exp + jitter
This function calculates the delay for each retry attempt. The base duration starts at five seconds, caps at sixty seconds, and adds a random jitter between zero and ten percent of the calculated delay.
Step 3: Token Caching and Re-authentication Logic
Before attempting to reconnect, the client must verify token validity. If the token has expired or will expire within sixty seconds, the client must fetch a new token. This step prevents reconnection attempts from failing due to authentication errors.
package main
import (
"fmt"
"time"
func (c *WebMessagingClient) EnsureValidToken(clientID, clientSecret string) error {
if time.Until(c.Token.ExpiresAt) < 60*time.Second {
newToken, err := FetchToken(c.OrgDomain, clientID, clientSecret)
if err != nil {
return fmt.Errorf("token refresh failed: %w", err)
c.Token = newToken
return nil
The client checks the remaining validity window and refreshes the token proactively. This ensures that every reconnection attempt uses a valid credential.
Step 4: Message History Resubscription via Guest API
When the WebSocket drops, the client misses incoming messages. After reconnection, the client must fetch any messages that arrived while disconnected. The Genesys Cloud Guest API supports pagination using the after parameter.
package main
import (
"encoding/json"
"fmt"
"io"
"net/http"
type WebMessage struct {
ID string `json:"id"`
SenderID string `json:"senderId"`
Text string `json:"text"`
Timestamp string `json:"timestamp"`
Type string `json:"type"`
type MessagePage struct {
Items []WebMessage `json:"items"`
Page struct {
After string `json:"after"`
} `json:"page"`
func (c *WebMessagingClient) FetchMissedMessages() ([]WebMessage, error) {
if c.LastMessageID == "" {
return nil, nil
endpoint := fmt.Sprintf("https://%s.mypurecloud.com/api/v2/conversations/webmessaging/sessions/%s/messages?after=%s",
c.OrgDomain, c.GuestID, c.LastMessageID)
req, err := http.NewRequest("GET", endpoint, nil)
if err != nil {
return nil, fmt.Errorf("failed to create history request: %w", err)
req.Header.Set("Authorization", fmt.Sprintf("Bearer %s", c.Token.Token))
if err != nil {
return nil, fmt.Errorf("history request failed: %w", err)
return nil, fmt.Errorf("rate limited (429): retry after response header")
return nil, fmt.Errorf("history request returned %d: %s", resp.StatusCode, string(body))
var page MessagePage
if err := json.NewDecoder(resp.Body).Decode(&page); err != nil {
return nil, fmt.Errorf("failed to decode message history: %w", err)
return page.Items, nil
This function retrieves messages that arrived after the last successfully processed message ID. The client updates LastMessageID after processing each batch to maintain continuity.
Step 5: Outgoing Message Buffering and Merge Logic
During disconnection, the client cannot send messages over the WebSocket. The client must buffer outgoing messages in a thread-safe slice and flush them immediately after reconnection. This guarantees delivery consistency without dropping user input.
package main
import (
"encoding/json"
"fmt"
"sync"
type OutgoingMessage struct {
type MessageBuffer struct {
mu sync.Mutex
messages []OutgoingMessage
func (b *MessageBuffer) Add(msg OutgoingMessage) {
b.mu.Lock()
defer b.mu.Unlock()
b.messages = append(b.messages, msg)
func (b *MessageBuffer) Drain() []OutgoingMessage {
b.mu.Lock()
defer b.mu.Unlock()
flushed := b.messages
b.messages = nil
return flushed
func (c *WebMessagingClient) SendMessage(text string) error {
msg := OutgoingMessage{Text: text, Type: "text"}
if c.Conn == nil || c.Conn.CloseError() != nil {
c.buffer.Add(msg)
return nil
payload, err := json.Marshal(msg)
if err != nil {
return fmt.Errorf("failed to marshal message: %w", err)
if err := c.Conn.WriteMessage(websocket.TextMessage, payload); err != nil {
c.buffer.Add(msg)
return fmt.Errorf("websocket write failed: %w", err)
return nil
func (c *WebMessagingClient) FlushBuffer() error {
batched := c.buffer.Drain()
for _, msg := range batched {
if err := c.SendMessage(msg.Text); err != nil {
// Re-add failed messages to buffer for next retry
c.buffer.Add(msg)
return fmt.Errorf("buffer flush incomplete: %w", err)
return nil
The buffer uses a mutex to prevent race conditions between the read loop, write loop, and application code. Failed writes are re-queued automatically.
The following module combines all components into a single runnable client. It initializes the connection, runs background goroutines for ping monitoring and message reading, and handles reconnection with backoff, token refresh, history sync, and buffer flushing.
package main
import (
"context"
"encoding/json"
"fmt"
"log"
"math"
"math/rand"
"net/http"
"net/url"
"sync"
"time"
// Structures from previous sections are included here for completeness
// OAuthResponse, TokenStore, WebMessagingClient, MessageBuffer, OutgoingMessage, WebMessage, MessagePage
func main() {
client := &WebMessagingClient{
OrgDomain: "your-org-domain",
GuestID: "generated-guest-id",
buffer: MessageBuffer{messages: make([]OutgoingMessage, 0)},
token, err := FetchToken(client.OrgDomain, "your-client-id", "your-client-secret")
if err != nil {
log.Fatalf("initial token fetch failed: %v", err)
client.Token = token
ctx, cancel := context.WithCancel(context.Background())
defer cancel()
go client.runReconnectionLoop(ctx)
// Example: send a message
_ = client.SendMessage("Hello from Go client")
// Keep main alive for demonstration
select {}
func (c *WebMessagingClient) runReconnectionLoop(ctx context.Context) {
attempt := 0
for {
select {
case <-ctx.Done():
return
default:
if err := c.Connect(); err != nil {
log.Printf("connection failed: %v. Attempt %d", err, attempt+1)
backoff := calculateBackoff(attempt, 5*time.Second, 60*time.Second, 0.1)
log.Printf("waiting %v before retry", backoff)
time.Sleep(backoff)
attempt++
log.Println("websocket connected successfully")
attempt = 0
// Ensure token is fresh
if err := c.EnsureValidToken("your-client-id", "your-client-secret"); err != nil {
log.Printf("token refresh failed: %v", err)
c.Conn.Close()
// Flush buffered messages
if err := c.FlushBuffer(); err != nil {
log.Printf("buffer flush failed: %v", err)
// Fetch missed history
if missed, err := c.FetchMissedMessages(); err == nil && len(missed) > 0 {
log.Printf("synced %d missed messages", len(missed))
c.LastMessageID = missed[len(missed)-1].ID
// Start read/write loops
c.startLoops(ctx)
func (c *WebMessagingClient) startLoops(ctx context.Context) {
pingTicker := time.NewTicker(25 * time.Second)
defer pingTicker.Stop()
go func() {
for {
select {
case <-ctx.Done():
return
case <-pingTicker.C:
if err := c.Conn.WriteMessage(websocket.PingMessage, nil); err != nil {
log.Printf("ping failed: %v", err)
return
for {
_, message, err := c.Conn.ReadMessage()
if err != nil {
log.Printf("read error: %v. Reconnecting...", err)
c.Conn.Close()
return
var msg WebMessage
if err := json.Unmarshal(message, &msg); err == nil {
c.LastMessageID = msg.ID
log.Printf("received message: %s", msg.Text)
// Helper to satisfy compilation
if err != nil {
c.Token = newToken
return nil
exp = maxDuration
return exp + jitter
This example provides a complete lifecycle manager. Replace your-org-domain, your-client-id, your-client-secret, and generated-guest-id with valid credentials. The guest ID must be obtained from a prior POST /api/v2/conversations/webmessaging/sessions call.
Common Errors and Debugging
Error: 401 Unauthorized on WebSocket Dial
- Cause: The OAuth token in the query parameter is expired or invalid.
- Fix: Verify that
FetchTokenruns successfully before connection. Ensure the token is passed as?token={accessToken}in the WebSocket URL. Add explicit token validation before dialing. - Code Fix: Call
EnsureValidTokenimmediately beforeConnect()in the reconnection loop.
Error: 429 Too Many Requests on History Fetch
- Cause: The client exceeded the Genesys Cloud API rate limit by making rapid history sync requests after reconnection.
- Fix: Implement rate limit backoff matching the
Retry-Afterheader. Cache the last successful sync timestamp and limit history fetches to once per thirty seconds during rapid reconnection cycles. - Code Fix: Parse the
Retry-Afterheader from the 429 response and sleep before retryingFetchMissedMessages.
Error: WebSocket Close 1006 (Abnormal Closure)
- Cause: Network interruption, firewall termination, or server-side timeout due to missing pong responses.
- Fix: Ensure the ping ticker runs at a frequency shorter than the server timeout. Genesys Cloud expects pings at regular intervals. Verify that
SetPongHandlercorrectly resets the read deadline. - Code Fix: Set ping interval to twenty-five seconds and read deadline to thirty seconds. Log the exact close code using
websocket.CloseErrorto differentiate client drops from server drops.
Error: Context Cancelled During Buffer Flush
- Cause: The application shuts down while the client attempts to flush buffered messages after reconnection.
- Fix: Use
context.WithTimeoutfor buffer operations. Drain the buffer synchronously before closing the connection. Ensure all goroutines exit cleanly on context cancellation. - Code Fix: Pass the main context to
FlushBufferand break the flush loop ifctx.Err() != nil.
