Implementing Robust Token Refresh Logic for Long-Running Genesys Cloud Batch Jobs
  • A production-grade Python script that handles OAuth token expiration automatically during long-running analytics data extraction.
  • This solution uses the Genesys Cloud REST API (/api/v2/oauth/token) and the requests library with a custom session wrapper.
  • The tutorial covers Python, demonstrating how to implement exponential backoff and automatic token renewal without third-party SDK overhead.
  • OAuth Client Type: Client Credentials Grant (Machine-to-Machine).
  • Required Scopes: analytics:conversation:detail:view (for the example query) and oauth:client (implicit in client credentials flow).
  • SDK/API Version: Genesys Cloud API v2.
  • Language/Runtime: Python 3.8+.
  • External Dependencies: requests (v2.28+). Install via pip install requests.
The core problem in batch processing is not obtaining the token, but managing its lifecycle. Genesys Cloud access tokens expire after a specific duration (typically 1 hour for Client Credentials). If your batch job processes data for longer than this duration, subsequent API calls will fail with 401 Unauthorized.
You must implement a wrapper that intercepts HTTP responses. If the status code is 401, the wrapper must:
  1. Re-authenticate using the Client Credentials grant.
  2. Store the new token.
  3. Retry the original request with the new token.
We will use the requests library’s Session object to maintain state and hooks for this logic.
Step 1: The OAuth Client Credentials Flow
First, we establish the baseline authentication mechanism. This is a standard POST request to the token endpoint.
import requests
from typing import Optional
class GenesysAuthManager:
    def __init__(self, client_id: str, client_secret: str, environment: str = "https://api.mypurecloud.com"):
        self.client_id = client_id
        self.environment = environment
        self.token_endpoint = f"{environment}/oauth/token"
        self.token_expiry_time: Optional[float] = None
    def get_token(self) -> str:
        Retrieves a new access token using Client Credentials Grant.
        Returns the access token string.
        payload = {
            "client_id": self.client_id,
        headers = {
        response = requests.post(self.token_endpoint, data=payload, headers=headers)
        # Handle authentication errors immediately
        if response.status_code != 200:
            raise Exception(f"Authentication failed with status {response.status_code}: {response.text}")
        token_data = response.json()
        self.access_token = token_data.get("access_token")
        # Genesys tokens typically return 'expires_in' as seconds from now.
        # We calculate the absolute Unix timestamp for expiration.
        expires_in = token_data.get("expires_in", 3600)
        self.token_expiry_time = time.time() + expires_in
        return self.access_token
    def is_token_expired(self) -> bool:
        Checks if the current token is expired or about to expire.
        We add a 60-second buffer to prevent race conditions near the exact expiry second.
        if not self.token_expiry_time:
            return True
        # Buffer of 60 seconds ensures we refresh before the server rejects the token.
        return time.time() >= (self.token_expiry_time - 60)
Step 2: Creating the Retry-Enabled Session
We cannot simply check is_token_expired() before every request because multiple threads or rapid sequential calls might race. The most robust pattern is to catch the 401 error and refresh on demand. This is known as “lazy refresh.”
We subclass requests.Session to inject this logic into the request method.
class GenesysSession(requests.Session):
    def __init__(self, auth_manager: GenesysAuthManager):
        super().__init__()
        self.auth_manager = auth_manager
        self.max_retries = 3
    def request(self, method, url, **kwargs):
        Overrides the base request method to handle token refresh on 401 errors.
        # Initial check: if we know the token is expired, refresh it preemptively.
        # This avoids a single unnecessary 401 error.
        if self.auth_manager.is_token_expired():
            self.auth_manager.get_token()
        # Set the Authorization header
        headers = kwargs.get("headers", {})
        headers["Authorization"] = f"Bearer {self.auth_manager.access_token}"
        headers["Content-Type"] = "application/json"
        kwargs["headers"] = headers
        # Attempt the request
        response = super().request(method, url, **kwargs)
        # If we get a 401, it means the token was invalid or expired despite our check.
        # This can happen if the server clock is slightly out of sync or if the token was revoked.
            if self.max_retries > 0:
                self.max_retries -= 1
                print(f"Token expired or invalid. Refreshing token (Retry {3 - self.max_retries}/3)...")
                # Force a new token
                new_token = self.auth_manager.get_token()
                # Update headers with new token
                kwargs["headers"]["Authorization"] = f"Bearer {new_token}"
                # Retry the request once
                # If the retry also fails with 401, raise an error
                    raise Exception("Failed to authenticate after token refresh. Check Client ID/Secret.")
        return response
Step 3: Executing a Long-Running Analytics Query
Now we apply this session to a real-world scenario: querying conversation details. This endpoint (/api/v2/analytics/conversations/details/query) often returns paginated results. A large dataset can easily take longer than 1 hour to process, triggering the token expiry.
The scope required is analytics:conversation:detail:view.
def fetch_conversation_details(session: GenesysSession, date_range: str) -> list:
    Fetches all conversation details for a given date range, handling pagination.
    endpoint = f"{session.auth_manager.environment}/api/v2/anversations/details/query"
    # Define the query body
    query_body = {
        "view": "conversationDetails",
        "dateRange": date_range,
        "size": 1000, # Max size per page
        "entityTypes": ["call", "chat"]
    all_conversations = []
    next_page_token = None
    page_count = 0
    while True:
        page_count += 1
        print(f"Fetching page {page_count}...")
        # Construct the request body
        body = query_body.copy()
        if next_page_token:
            body["nextPageToken"] = next_page_token
            # Use POST for analytics queries
            response = session.post(endpoint, json=body)
            response.raise_for_status() # Raises exception for 4xx/5xx errors
            # If the error is not handled by the session (e.g., 429, 500), re-raise
            raise e
        # Extract results
        entities = data.get("entities", [])
        all_conversations.extend(entities)
        # Check for pagination
        next_page_token = data.get("nextPageToken")
        if not next_page_token:
            print("No more pages. Extraction complete.")
            break
        # Simulate a slight delay to respect rate limits if processing massive batches
        # In production, implement proper rate limit handling based on 429 responses.
        time.sleep(0.1)
    return all_conversations
This script combines the authentication manager, the retry-enabled session, and the data extraction logic. It is designed to run as a standalone module.
import requests
import json
import sys
from typing import Optional, List, Dict, Any
# Configuration
CLIENT_ID = "YOUR_CLIENT_ID_HERE"
CLIENT_SECRET = "YOUR_CLIENT_SECRET_HERE"
ENVIRONMENT = "https://api.mypurecloud.com"
# ISO 8601 date range, e.g., last 24 hours
DATE_RANGE = "2023-10-01T00:00:00.000Z/2023-10-02T00:00:00.000Z"
# Authentication Manager
    def __init__(self, client_id: str, client_secret: str, environment: str):
        payload = {
            raise Exception(f"Auth failed: {response.status_code} - {response.text}")
            return True
        # Refresh if less than 60 seconds remain
# Retry-Enabled Session
        super().__init__()
        # Preemptive check
        # Handle 401 Unauthorized
                print(f"[WARN] Token invalid/expired. Refreshing... (Retries left: {self.max_retries})")
                kwargs["headers"]["Authorization"] = f"Bearer {self.auth_manager.access_token}"
                    raise Exception("Authentication failed after refresh. Credentials may be invalid.")
        return response
# Data Extraction Logic
def extract_conversations(session: GenesysSession, date_range: str) -> List[Dict[str, Any]]:
    endpoint = f"{session.auth_manager.environment}/api/v2/analytics/conversations/details/query"
    query_body = {
        "size": 1000,
        "entityTypes": ["call"]
    page_count = 0
    while True:
        page_count += 1
        print(f"Processing Page {page_count}")
        if next_page_token:
            print(f"HTTP Error on page {page_count}: {e}")
            raise e
        if not entities:
            print(f"Page {page_count} returned no entities. Stopping.")
            break
            print("Extraction complete.")
            break
        # Small delay to be polite to the API
        time.sleep(0.05)
# Main Execution
    if CLIENT_ID == "YOUR_CLIENT_ID_HERE":
        print("Error: Please configure CLIENT_ID and CLIENT_SECRET in the script.")
        sys.exit(1)
        # 1. Initialize Auth Manager
        auth_mgr = GenesysAuthManager(CLIENT_ID, CLIENT_SECRET, ENVIRONMENT)
        # 2. Initialize Session with Auth Manager
        session = GenesysSession(auth_mgr)
        # 3. Run Extraction
        # This loop may run for hours. The session handles token refresh automatically.
        conversations = extract_conversations(session, DATE_RANGE)
        # 4. Output Result
        print(f"Successfully extracted {len(conversations)} conversations.")
        # Optional: Save to JSON
        with open("conversations_output.json", "w") as f:
            json.dump(conversations, f, indent=2)
        print("Data saved to conversations_output.json")
        print(f"Fatal Error: {e}")
        sys.exit(1)
Error: 401 Unauthorized After Refresh
Cause: The client credentials are incorrect, or the OAuth client has been revoked in the Genesys Cloud Admin portal.
Fix: Verify the Client ID and Secret. Ensure the OAuth Client is active and has the necessary scopes.
Code Check: The GenesysAuthManager.get_token() method raises an exception if the initial token request fails. Ensure this exception is caught and logged.
Cause: The batch job is sending requests faster than the API allows. Genesys Cloud applies rate limiting per tenant and per endpoint.
Fix: Implement exponential backoff. While the GenesysSession handles 401, it does not handle 429. You should add a similar retry logic for 429 status codes.
Code Adjustment:
# Inside GenesysSession.request()
    retry_after = int(response.headers.get("Retry-After", 5))
    print(f"Rate limited. Waiting {retry_after} seconds...")
    time.sleep(retry_after)
    return self.request(method, url, **kwargs)
Error: Token Expires Mid-Response
Cause: The token expires while the server is still streaming a large response.
Fix: This is rare for standard REST APIs but possible with streaming endpoints. The requests library buffers the response. If the connection drops due to token expiry during read, you will get a ConnectionError. The best mitigation is to keep the is_token_expired() buffer generous (e.g., 60 seconds) and ensure the client credentials grant is used, as it allows you to refresh tokens without user interaction.
Error: Scope Not Granted
Cause: The OAuth client does not have the analytics:conversation:detail:view scope.
Fix: In Genesys Cloud Admin, navigate to Admin > Integrations > OAuth Clients, select your client, and add the required scope. Re-authenticate to get a new token with the updated scopes.
